Q5 folding mirrors jerky
Old 06-26-2019, 01:20 PM
snordin's Avatar
Default Q5 folding mirrors jerky
I have a 2015 Q5 and the mirrors fold in and out but not smoothly as they did from the factory. I've taken this to the dealer to fix but it reappears after a while (maybe due to being bumped in parking lots?). I'd love to fix this on my own without having to go to the dealer every time. Is there a way to fix this? Any advice would be appreciated!
Old 06-26-2019, 01:40 PM
DennisMitchell's Avatar
I have noticed this too on my 2014 Q5 with 70,000 miles. I think it is friction of the housings where they pivot and I am going to apply some spray lithium grease in that area. I will let you know how it works out.
Old 06-26-2019, 02:08 PM
snordin's Avatar
Thanks! Fingers crossed that it works!
Old 06-26-2019, 03:26 PM
I just finished lubricating the folding mirrors. The spray on white lithium grease worked well. They operate smoothly now.
With your folding mirrors in "Up" retracted position, notice the areas that are exposed that are covered when mirrors are in normal position.
Apply spray on white lithium grease to these areas. Look for surfaces both on the moving part of mirror as well as the mirror mount. Use your finger to rub the grease on areas the spray didn't cover.
Operate the mirrors for a few cycles. Then leave the mirrors in normal position. While in this position, remove excess grease with a rag. When you lock vehicle you will see some grease on the surfaces exposed. I am going to leave that there for now.
Old 06-26-2019, 03:45 PM
snordin's Avatar
I’ll give that a try. I’ll have to pick up some white lithium grease. Is that easy to come by?
Old 06-26-2019, 03:50 PM
Yes. Any auto department store (Walmart, maybe Target, or auto part store). Make sure you get a spray can with the red tube to let you spray tight areas.
I think the problem we are solving is grime from the winter roads that is embedded between the surfaces. I can see many grooves from grit on my housings.
Old 06-26-2019, 04:20 PM
snordin's Avatar
Thank you! I’ll let you know how I make out!
Old 06-27-2019, 01:44 AM
apoelistas's Avatar
Sounds it is worth a try.
If side mirrors get stuck is there a procedure after removing the mirrors??
Old 06-27-2019, 12:47 PM
greasykid's Avatar
Default White Lithium Spray
[QUOTE=snordin;25335302]I’ll give that a try. I’ll have to pick up some white lithium grease. Is that easy to come by?[/QUOTE WALMART
AzkMe
03-27-2004 06:55 AM
simply J
04-07-2002 11:22 PM
TZL
03-30-2002 05:46 PM
blinkingyellow
06-16-2001 12:24 AM
Mike
01-05-1999 08:47 PM
Quick Reply: Q5 folding mirrors jerky
