Groaning creaking Suspension
I have had this problem now for 2 years and its driving me insane
Car: audi A5 2011, 120K
Symptoms: Car makes a "croaking" /"groaning" noise when going over bumps at low speed, steering the car makes no different and it only happens when the car is in motion
I have had a shock absorber replaced and some cracked suspension brushes replaced too, still no luck
The problem started after i had my gear box casing replaced as this became rattly once, literally as soon as i drove out the garage it started from having this issue
Reading around here i have seen issues where things have been torqued too much , the garage cannot find the issue and to be honest isn't accepting much responsibility, had 3 garages look at it, as the problem is intermittent it makes the situation harder to show them
It happens particularity on a morning!
i am going to start trying to spray wd40 on different components in the suspension to see if this helps and to see what stops it, but the fact this happened after i had something done on my gearbox /gearbox casing might be a clue, can anyone maybe drive any clues to what they may of done that may of caused this?
i am at my wits end with it, its so noisy and embarrassing when im driving and have people in the car!
Anyone else have any suggestions
I am going to get anything you guys say changed! so if there are any other suggestion to what it is then let me know and i will get them replaced
im sick of the noise i will try anything
does the sway bar get touched when anything with the gear happens? if it does then this might be bang on the mark
As i said earlier it started the second they did something with my gearbox
I have put 250k miles on Audi’s and I get a similar noise every 30k miles or so. I am betting it’s the sway bars from what you have described.
Thanks kevin
I will just get new sway bar linkages and bushes fitted and try. It happens a lot when I reverse backwards down a hill and turn I have noticed. Probably putting most stress on the sway bars at that point. Il report back and get car booked in
Thanks for your replies
