- Cheap (but high quality) A4 parts - 1996 V6 quattro
- Intermittent alternator failure, need advice.
- Grease Fittings
- Tightening control arm bolts
- Just got car back from shop! Now does not run!!
- Pictures of my hatch (finally)
- How to get another 50k miles out of my A4 2.8Q 5 spd? (brief novel inside)
- Suitable substitute for sunroof grease: G 000 450 02???
- New AW STFA Avatar =)
- 2001.5 Avant 86k fair price? (Sorry guys!)
- Toluene anyone?
- CEL: 17544 - P1136......possible causes
- PURE Motorsport Website will be temporarily down later tonight.
- Car stalled the other day....
- coilover install Sunday... who wants to help? (socal)
- Part # Help and determine what year audi a4
- So I had this brilliant Idea . . . and Im pretty sure its not going to work.
- Winter tire time: I'm thinking about the new Blizzak REVO 1
- My buddy socal from audizine wanted me to ask this here
- Sport Springs
- repost for day crew....i need some help with these codes.....
- Poll: Piano Black trim. 1- Interested? 2- If a decent stockpile
- RS4 Tranny mounts . . . worth the trouble?
- cellphone BT: I am a technology idiot, so I need your help. Here's the situation, I hate my phone
- Need to go work on my tt .. hasn't worked since i got the car back.
- What % tint when you have w/ tan interior? Post your pics of tint w/ what color int. you have TIA
- i bought oil for my rear diff
- I dont usually post that much and I have never posted photos of my car so here it goes
- K04 PC16 GIAC > AWE Kit
- I'm in the market for a new a4.... anyone got one laying around ? Must be in Socal
- WEMMT: H20 going on this weekend... What are you going to do?
- Just put on a k04, its running lean
- REMINDER: upcoming Audi GTG @ The Stand in Encino -- TUE Sept 26th
- Ko4 problems...
- The mileage on this one seems too good to be true...
- Greddy Profec B installed
- X-Post to K03 turbo internal pics
- Power Steering Fluid
- how do i get my radio out on my 97 a4....it is a kenwood radio not factory.. i think the grounds fkd
- left upper control arms....i was told that they should allow some up and down motion when replacing
- Wheel help... I'm almost ready to pull the trigger and I'm favoring a certain wheel.
- hello audiworld
- It is 2:30 in the morning and I am just getting finished!!!! LONG!!
- what is overboost?
- my 2001 Audi A4 rpm problem
- Best/Cheapest place to get valve seals? for 4 valves....
- A/C not working - auxiliary fan failure
- ok i got some codes! work your magic aw!
- If I have OEM Xenon, will halogen ecodes work
- Dealership says that tensioner isn't making any noise.
- ***Hartford, CT area GTG - Wednesday, September 27th, Updated Info***
- xpost:: Anyone know German that can help with a website. Looking for a trailer hitch for a friend
- Help removing the dash!!! I searched and looked in the tech section already
- i think i should give up..
- what causes clunking in the steering column....is it the steering wheel bolt or something else
- after replacing my upper control arms and tie rod on the left side...cont to have clunk turnin wheel
- teaser... fixing a mistake
- The parts are starting to arrive!
- what is the torque specs for the bolts on the shock tower in the engine
- Lowering and alignment
- I think its time to replace the valve cover gasket
- Getting rid of Carbon Build Up...
- OMG!!!! I must have missed the New A4
- How much boost
- Super Control Arm Replacement
- What would be under the intake manifold thats leaking oil?
- 98 Audi A4 quattro question
- Replacing Left Upper Control Arm/Ball Joint
- Update: BG Engine Oil Flush
- Fair price for this car?
- Final Rims/Tires Question: 35mm offset
- update on the 18014 DTC (bad ABS controller)
- hah! new favorite vag-com block to log...is block 101.
- DO NOT ATTEMPT TO BUY WHEELS FROM THIS COMPANY...(rant)
- Let play Name That Wheel
- CAPS time spped question.
- Nice. VW dealer cut my new (EBay) key for free.
- Current status of new shoes..
- What are possible ways to get independent fogs on 1998.0 a4?
- For those that have replaced springs/shocks...did you also replace strut mounts?...
- Converting auto AWM crank to manual AWM crank
- It makes me sad that there is enough demand for this on B5's...
- Tires
- 1997 a4 1.8t 2wd oil recommendations
- part numbers please
- Quick question about CCT R&R...
- 98 A4 30V, oil recommendations?
- Should I grab one of my Blackstone Labs oil analysis kit so I can take a sample pre-treatmeant or
- BBK kit? Track your car? This mod would be good for joooo. AZ content linked...
- Bird poop causing dents, Part II
- 2000 A4 Window Regulator Replacement - Rivet Removal
- Has anyone changed their brake hardlines?
- anyone ever log their knock sensor during a wot run?
- Anyone have these a6 wheels on their car? could be slick.
- Are there any pics of A8 vs. stock front brakes, under the same wheels?
- GL5 or GL4 in front/center diff on a Tip?
- Oil residue in spark plug holes and a little on plugs.
- Blast From The Past... Thursday Van Nuys KK Meet!!
- Would the first gen Oettinger Front Lip Spoiler fit on a Rieger RS4 bumper?
- whoot.. got me a phat noise installed... nice music tim ;)
- Is there any full-proof way to tell if the air mass sensor is dieing? Surging throttle? Other ways?
- my 99 audi a4's auto check led screen seems to be messed up help!!!
- turbo on a 2.8 30v a4....is that possible
- please vote in the audiworld photo contest
- Picked up an interesting resource today in the mail. All in all okay, but not exactly what I was
- What to clean inner muffler tips with?
- Since there's been alot of talk about pcv valve systems lately ...
- Paging: TOPAss please delete your question post in the FAQ
- PCV valve.......what's going on?
- Any opinions on the Hella Optilux H7 bulbs as a foglight replacement?
- Where to buy inlet and outlet intercooler hoses.
- fixed boost issue... 2 of you were right..
- i guess the 2 RULES that are in the faq arent CLEAR ENOUGH or BIG ENOUGH for the noobs!!!!!!!!!!!!!
- i remember seeing someone on here posting about getting a precat 02 sensor for $78~
- time to go solve this dv issue and tt...
- Electrical problems SOLVED! It's the ignition switch. W00000000000000000T!!!eleventy!!!11!!juan!!!!
- Oh God... I think its very safe to say my car hates me
- Tiptronic question: Shifter is loose.......
- WTB: Fog Lights and Fog light grills OEM B5 A4
- Anyone know who makes these wheels? I'm in love...
- key for 1996 A4
- how to get more grunt from Remus
- has anyone done the keyless entry remote antenna relocate
- hey im new to this place
- rallyvermont has some pretty good photoshop skills, he's got the s4 guys all confused.
- So I took the car in to get a re-tune today.
- Advise on aging and now broken stock Exhaust
- Are thier any relays that run to fuses underneath the car that effect any of the following
- VAG Volunteer
- where is a good place to get coil packs for a AEB
- Alrighty... i'm going to appeal the decision on my car.(link to original thread inside)
- w00t! Going in for a BG engine oil flush tomorrow. ~$80 for the flush and new oil
- Summer may be ending, but the STaSIS 14.5" Brake Sale begins...
- any idea how to take off drivers side fingerplate and where to find a replacment cheap
- Acidrane, what did you do to get your electrical system back up and running?
- I didn't use my vag-com for awhile and just realized that it can read generic obd codes!
- just got raped by audi yesterday
- Tire update - Can get Nitto NT 555 - 235/40/18 $114 a tire - 50 miles on them
- Achtuning H2O specials going until Friday!
- Instrument Cluster problem
- About to pick up some Tires for the 18" S4 B6 wheels.. will 235 be to wide??
- Gapina is KILLING me! Repainted 18" RS4 reps on the car!
- looking for function of this part....and how it's secured [sorry no pic]
- etka part# requests
- Couple pics from the autoshop with Rob last night (ScratchRob)
- X-Post: Here is a place for cheap K03/K04's for those who like that kind of thing
- I seriously don't like the feel of large wheels, im thinking of staying stock.
- AWE Tuning at H2O International
- GT28 with unitronic and N-DBW, what did you guys set your boost to?
- new owner of a 1998 Audi A4 2.8l quattro
- Excessive vibration at idle.
- ETKA part number question (relay)
- Anyone ever get the wrong parts from ECS? Dosen't it suck?
- anyone seen the new RS4
- Symptoms of a bad O2 sensor?
- Where can I buy just the FABRIC for the headliner rather than the whole thing?
- #3 Ignition Coil Power Overlode? read more....
- My engine makes a GURGLING sound when..... help me :(
- Oil Leak... Ideas?
- Anybody have a black plastic shift trim for sale?
- Stolen from toy guy... this pic looks like a good parking aid for a tight garage.
- Hey Silverstar...
- After Iwasawsome's post ..Your worst customs experience
- Sport package wheel size
- someone stole all my fvcken trunk badges! where should i
- cheap good way to increase horsepower
- o2 sensor location
- GOT MY CAR BACK !! Not without any drama of course...
- ohhhhhhhhhh yaaaaaaaaaaaaahhhhhh
- mystery braded hose
- I finally got pics of the stance with the new springs and shocks...
- Compressing rear springs
- Just a teaser... I'll make a more detailed post this weekend :-)
- Clunking noise when turning
- great, i have the 18014 DTC...searching reveals....
- Anyone have any luck "bending" or molding cowl cover?
- Checking interest on a bentley manual group buy...
- Where can I get a B6 airbag?
- Took off my 18" wheels because I am selling them and put back my stock wheels. Now there is a slight
- Which clamp should I get? I am trying to replace my rusted milltek clamps without taking the whole
- ABS Brake Problem
- pics, my valve train at 70K miles and 93K miles
- Does anyone have a Boost Gauge mounted anywhere lower than the IC level on their car?
- I saw a B5 A4 1.8T Avant today and I SWEAR it was Sprint Blue...
- Shock and spring installation question...
- oil leak fixed!
- ET*A pimps: What is this part number?
- Need referral for Audi service in Denver
- $775 shipped for used 18" sportecs hit/skip ?
- anyone have a fender roller?
- Can we finalize the manual quattro differential and transmission fluids needs?
- If anyone is looking for a an A4 in excellent cond..
- Overpriced?
- MAF/K&N
- Bout to pull the head, just found a demolished L shape PCV hose from the block to the metal pcv line
- I'm confused here, why am I told by everyone the oem CA's are the best
- Cleaning the MAF on a 30v - do I need to replace the gasket if I remove it?
- Anyone Know a Part # for the rounder Coolant Temperature sensor??
- anyone got pics of a B5 A4 with ASA AR-1's ? I'm thinking about pulling the trigger on them sometime
- Rant/Disappointment: None of the white LED's are truly white...I have figured that out after
- Clear Lamin-X ... Hit/Skip?
- September exhaust sale @ Tantrumwerks (metallic cats now available)
- 3 heads are better than 1!
- Update on the fastest chipped B5 Ever...
- After i shut off the car today, there was a hissing sound....
- Post KO4 upgrade questions....
- Looking for a part number: air horn
- im getting a noise from the right rear side, only when i hit the gas..what would that be??
- Question ... for all those that have had past experiences ... w/ CA's
- Tired of cleaning my MAF. Would a new one go longer without cleaning?
- Anyone running OEM spring / Bilstein HD on an Avant 1.8T
- No reverse lights or cruise control..
- My 1996 A4 Quattro 2.8 is over heating. NEED HELP!!!!!!!
- Question regarding the load reduction relay, ignition switch, and the bad headlight switch issue.
- Might need new exhaust........what do you 2.8 30V drivers recommend?
- Please Help with firmware phatbox update
- what kind diff oil i have to use change diff fluid./..
- Now THIS is funny. (With audiworld content, too!)
- pics of our cars w/ 19's
- AWE K04 PC16 or ATP Mika GT2X ?
- alright yFF'S.. i'm off to seattle. few questions..
- audi wheel center cap decals
- Well, today was the first day my car has ever been through an automatic washer....
- Does anyone (Nate, perhaps?) have an ETKA view of the 30v throttle and intake manifold available?
- Someone sell me a 8D0 907 557 N, M, or P ECU there are none in the classifieds [EDIT]
- Kumho ECSTA MX Tires
- Way to go
- Car searching: 98-01 Avant 5spd.
- Going to try a Revo flash on my '01 A4 1.8t
- EFK and pulley deletion belt size (w/ under drive pulley)...
- Driver's side lock draining my battery?
- cylinders 1, 2, and 4 misfires
- i hope my car appriciates this...
- how often should i change tip tranny oil??
- EPL Tuning update: So far we're up to 311whp and 312wtq.
- Is this OBD-II phenomenon normal?
- just me or is purems site running like crap?
- 15" snow tires and all weather mats for sale in Classifieds
- Need to replace passenger side mirror
- Vag code 0011
- Help with Rieger Illuminated Knob
- EPC Light on after car has been warmed up - help please
- Has anyone done business with Champagne Motors in Denver
- Check out these dyno numbers from a 2.0T W/ Testpipe/exhaust & REVO
- need help my turbo will not give more boost than 0.3bar. The next day ....
- How long can you store brake fluid.
- What can i possibly do with this?
- CPO is up in 9k few questions...
- GOD FVcking Damn Sh@T ... taking off to seattle.. they aren't letting the car through
- REPOST
