View Full Version : A4 (B5 Platform) Discussion
- I found a Cracked Hose of some sort
- how wide can i go?
- expansion Valve on AC Line
- Rear Fog Light
- Lug bolt size request.
- Bulb Out warning light....
- missing rain channel?
- stereo replacement
- Speed Limiter........Myth?
- Oil cooler bad?
- audi a4 quattro turbo
- 1.8t can someone confirm their oil light for me?
- STEERING RACK
- coolant leak update i posted few weeks ago.. new problem???
- The Missing Magnet?
- Complete Gauge setup...
- Adding keylock switch to disable front passenger airbag ?
- 98 a4 2.8 ground clearence seems too high?
- radio swap..
- electrical issue!
- manual swap
- DIY for FWD TIP transmission fluid and filter change?
- Power Steering Leak
- Where can you use Seafoam in a AEB 1.8T engine? Fuel system? ...
- A very clean b5 at the dealership, advice needed.
- front differential cover has cracked...anyone have an extra for purchase
- looking for Hood Release Lever (Latch located on the underside of the hood )
- cam tensioner code 16396 over retarded?
- shift
- CEL came on with 12 codes need some help
- LWFW Questions
- Guys who have installed Foglights on their pre-99.5 B5's...
- '99 Avant Head Replacement (Adapter)
- ATQ/AHA swap
- Gearbox
- a4 wont start,electrical problem
- Cambelt change
- 98 2.8 5spd A4 oil leak help!!!
- Exhaust diameter: Sound difference
- temperature sensor locations? help
- Do I have to purge the AC to replace my heater core?
- Coilover Problem?! Help please..
- Question about rear bearing replacement and control arm bushings?
- Oil Smell Help
- Axle question
- Parasitic Draw - Fuse 14 Schematic
- instrument cluster problem
- problem with my newly bought Audi
- Name that Leak?
- Water delector screws
- '01 A4 1.8T - V belt and ribbed belt
- Dealer Says Heater Core is plugged, I'm not sure.
- how to change the fuel filter?
- expensive hose replacement! yikes!
- new icm...still get a misfire
- Intermittent Failing Heater Blower Motor
- AIT Rs4
- Center tail light removal in 1996 audi a4 B5 Sedan
- Eurosport Design?
- Will front seats from '01 fit in '97 A4??
- audi a4 1.8T stalling problem.
- New Shocks
- Audi a4 b5 1998 won't start
- engine suddenly stalled
- Instrument cluster lights won't turn off
- front dashboard vents with different temp.
- Audi Concert I wierd problem
- A/C Low service port location
- Search orange glare light
- does anyone have VAG-COM experience (help)
- center console help !!!!!
- Check engine light on..No Input to find out code.
- blower motor speed
- Help Chopper sound.
- A Few Issues
- APTuning Now a Dealer for Stern Mounts and Suspension Products!!!
- Help major coolant leak on 2.8v6
- Misfire: which cylinder is what?
- Sparks
- Porsche 964 Calipers
- Instrument Cluster - bulbs
- 1996 front speakers
- 1996 Climate Control problems
- 1996 2.8 auto: intake leak?
- 1996 seat issues - heated?
- thoughts???
- Remote Control Key - changing battery
- Center Engine Mount - Load bearing?
- Need help with getting an alignment for my car!
- How to Reset Radio Fade Control on '99
- Auto Check System not turning on and abs/brake light on
- Anyone in North Fulton or East Cobb with inner tie rod removal tool?
- Door speaker replacement
- How to remove CD Changer from the trunk?
- Airbag light. Code: 01025
- maintaining the audi A4
- water cooling problems ... 2000 1.8T automatic
- Help!! No start, daily driver!
- What's the widest tires you've ever put on your OEM rims?
- Suspension upgrade
- Engine swap
- What's this issue?
- looking for SIDE MIRRORS
- Replacing passenger side mirror? How difficult to do?
- chime after turning off car
- Video Help
- '96 vs '99 A4Q: spring and shock swap
- Huge Coolant Leak
- 200,000miles
- Just bought 1998 a4 2.8 overheating issue
- witch t-belt
- changing manual transaxle fluid need help
- ** OIL service light reset!?!? **
- Rear Brake problem..Caliper piston will not retract. WTF!
- Audi A4 ABS Pump upgrade to ABS/ EDL/ ASR
- Chasing a Gremlin.
- Vac line and check valve help.
- Wheel bearing removal and installation
- 2000 1.8T Manual
- Anyone need a 99.5 A4 1.8T in the Killington, VT area??
- 1999 Audi A4 Transmission
- Lurching in low gears?
- Had Enough With Audi....never buying one again!!!!
- Lifter stuck in the down position...need ideas
- Exhaust advice
- headlights switch
- Transmission interchangeability question
- parts store
- Audi A 4 Concert Rado code
- upholstery help for 98 Audi A4
- coolant leaking
- Need some help with these codes.
- secondary air flow system
- need rs4 front bumber and side body moldings
- Buying a rack a pinion online
- Right Rear Creaking/Squeaking Suspension After New Bearing Replaced?
- My situation!!!
- Can tranny problem be water pump related?
- RARE for sale in Colorado
- I need a B5 A4 front bumper skin...
- 1999 AUDI A4 V6 Quattro CRUISE CONTROL AND CD CHANGER ISSUES
- Vibration at 15-1600 rpm 98 2.8 30v?
- A4 problem driving me mad!!! please HELP!!!
- Bad clunk when off and on the gas
- Engine Problem I can not figure out Plz help
- 99 A4 2.8 Clutch Replacement Questions
- axles
- Total Brain fade...How to remove E-Brake Cover?
- GIAC chip 98 a4 2.8 30v effects
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- Suddenly no headlights, beams, wipers, signals or horn. Repl ign sw +lr rly: no good
- Changed front control arms
- sunroof water leak problem down B pillar. Please Help!
- Oil filter adapter gasket
- Slim Ballast HID Kit & Bulbs * Sale *
- Clockspring Repair?
- 2001 A4 thermostat location
- Stage 3+ B5...value estimates?
- fuel mpg
- Aiming headlights
- O2 Sensors Gone Bad and Fuel Economy
- Bleeding coolant system without bleeder screws
- Gas Mileage on your V6 A4?
- Weird Squeaking! WTF! DRIVING ME MAD!
- 01 A4 1.8T Quattro Manual won't start
- New Cooling System/Thermostat issues after TB Job
- Odd feature?...
- Another no start
- I am Considering a B5 Audi A4 1.8T to Modify?
- HELP! Cams jumped out of timing
- 1995 1.8 manuel instrument cluster issues
- Flex pipe or no flex pipe. That is the question
- WTB: b5 a4 1.8t MANUAL in almost any condition.
- Headlight
- Any way to get a new key cylinder for my driver door?
- Regal Brakes and Rotors
- cats and flex pipes a4 2.8 30v
- Need Advise on buying a second hand 2001 model (A4 2.8 vs. A6 2.7T)
- No Headlights - Replaced Ignition Switch, Load Reduction Relay & Headlight Switch
- timing belt cost?
- wont start need help...
- need a 1.8t
- Green Inline Check Valve Part# 078905291 - Is it defective???
- issue with speedo and mileage off clock?!
- DrivTech | VMR Wheels NEW YEARS SALE – V701, V708, V709, V710, V713, V718
- b5 a4 Wheel Question
- Timing belt tool
- Audi in the snow
- new on AW
- best way to take out o2s?
- Just got my car back from a friend, multiple problems
- looking for a multifunction/neutral safety switch 01V 919 821 D
- Error codes P1557 and P0411
- soft suspension feel??
- Turn signal relay DIY ?
- Battery died, Engine won't start
- Throttle Body Adaptation
- Exhaust woes
- Relay designations...which RELAYS does what?? Bently Manual gives no help!!!!
- Bentley wiring diagram - I don't get it.
- Quattro + Pennsylvania Snowstorm= AWESOME!!!!!!!!!!
- Seafoam
- "01 A4 Hid'Xenon upgrade
- vagcom help
- Heater Element
- Audi TSB's & Recalls (1990-2010)
- VIN WAUGB28D6XA064623 - is that you?
- 7" wheels
- Overheating Please help
- Rear Wheel bearing
- Audi meet this weekend in SC
- Cam caps reinstallation sequence
- New 2 Here! Need some advice please
- a4 avant 2.8 30 v exhaust flex pipe dimention
- Understanding differences between Audi A4 clusters and the compatibility issues
- oily crap leaking above rear diff mount help
- need help somone had this problem before
- E-Brake Adjust
- Fogs without Headlights
- New car: Need opinions
- PCV System/Crankcase Pressure
- Helix/Depo Headlight and VVME HID Installation DIY (tons of pics)
- Oil change
- Relaying the headlites & have questions...
- ATF Change On Audi A4, A6 and A8 (Auto Trans!) with photos!
- A4 ABS Controller/Pump Repair DIY (with pics!)
- A4 Rear Differential Oil Change DIY (with pics!)
- A4 Changing the Transmission Gear Oil (5Speed!) with pics
- A4 B5 Front brake (Pads & Rotors) Replacement DIY with Pics!
- o2 sensors
- Oil temp sensor location???
- Help - Need part # - Breather connector
- I swear I laughed so hard.. Info on E85
- PARTING OUT B5 A4 IN NEW YORK
- question about the starting the car
- Will 205/55-16 fit on these rims?
- what goes first "viscous fan pulley bracket" or "vibration dampener guard"
- Car won't start
- Driver's B-pillar rattle: cheap, quick fix
- Spent some quality time with the '98 Avant last weekend
- More mods suggestions?
- need vacuum lines 00 a4 v6
- New guy..quick clutch question
- B5 2.8 5-speed (DJP, DJR, DWM) into a B6 1.8T
- reset check engine light?
- Hood light dilemma...
- Parrot CK3000 Install on B5 A4 with Concert radio and BOSE completed...
- headlight wont work
- Need a casablanca white rear bumper, anyone have a lead?
