- To flush my automatic tranmission or not to flush... that is the question...
- Great, just saw a coolant leak in front of the car, right under the right side of the ....
- I think I have the record for longest turbo cool down period(turbo timer questions)
- Tensioner Question
- How much paint is required for a full respray?
- The Day of Reckoning is here!
- need help removing cat
- Pix of the car I wanted to bring to the show and shine in Chicago
- Feeler post... wifes tells me I should, ahhh, wellllllll....... sell my Avant and buy another maybe?
- How Many Pounds Of Boost Is Stock For A 98 1.8T
- Tensioner Inspection per Class Action Settlement
- Can someone help me ID an air conditioner problem, please?
- What does DTM mean?
- just got back from barcelona just thought id post my fav pics
- Would this work in US A4, it has a same part # but it looks funny
- stock exhaust & removed resonator
- Can hanging/sticking calipers drag-on and groan ....forever? Like a bad wheel bearing, but not.
- sonofa... control arms are squeaking REALLY loudly. is there any safety concern here?
- Throtte Body Bood Query
- I think Im gonna get this instead of a chip
- i dont think i am worthy to be at waterfest!
- I read that if I get sharp squeaks going over bumps it could be from the brakes.
- To sell or not to sell, any help greatly appreciated....
- want to add some more horsepower...
- Tranny noise above 3000 RPM
- recent repairs and still having problems
- what oil plug do i have. 98 1.8t the plug is an inch and a quarter diameter
- im getting excited. 24hours to go and ill be getting started on this project:
- Trying to remove front bumper - trouble
- the electrical gremlins have invaded my car...
- Leaking Wiper Fluid Tank, how to remove?
- so get a chip or exhaust first for my 01 1.8
- Selling my A4, anyone interested in buying my Panasonic Headunit?
- AWE Tuning A4 1.8T clutch kit stage 1 help? (misposted in b6, should be here)
- crazy squeaks!!
- Anti-Theft interior alarm on 98 A4???how do i make it stop?
- i might be able to get my hands on the a8 rotors and tt calipers pretty cheap now
- looking for 96 cd changer (part #4D0 035 111)
- It was a good few years, but the A4's gone......
- Timing Belt Help!! Answer needed ASAP
- How do you tell if your upper control arms are bad?
- where do i get the AW decals?... i want to get some before WF....thanx
- If 01's have 10-11 psi with a 1.8 and a wrx has a 2.0 with roughly 13 psi i beleive ...
- Ugh, Broken rear spring, just what I needed.
- I was reading up on auto rx, and after use i saw the ...
- Car won't start, engine turns but doesn't fire...ideas?
- Squeak squeak squeak - Suspension noise up front, but not when the car's been sitting....?
- You officially have a new member (though I'll need a different name and sig soon)...
- Anyone know if you can adjust the speedo for oversized tires?
- Help me audi experts
- G1 Supercharger installed :-D (BWW)
- odd noise from tiptronic trans while in reverse
- Need "used" ABS controller; where to get one?
- Novel turbo sound discovered
- how to check chip upgrade ?
- Tie Rod Ends, Wheel Bearing
- should i get a manual or auto a4?
- Had super fun tonight
- Picture of my new tint
- Where can I get Speaker and Blau Adapter for Pre amp ?
- What oils are you using and how often changing?...
- Start up Sort of odd...
- can someone link me or tell me how to add a ESP on/off switch to my A4 01
- Any way to tell by VIN if it's 99 vs. 99.5?
- APR snub mount notes and parts question
- radio schematic! please help
- the oil cooler is not my friend
- I want to do the DIY short shifter mod...
- re installing factory head unit
- theres a repair manual from a 96 on ebay
- Please help -- caliper piston problems
- Because I sucked so bad at this last time . . .
- uh oh i'm retarded...
- 8D0 907 557C ~ VS ~ 8D0 907 557 P
- OK, I have a MAJOR flame protective suit on and a big fire extinguisher in hand...long...
- Anyone Seafoam a 2.8 30v recently? results?
- FYI. Cross Brace Install....
- Help Needed for Speakers installation
- Euro-plate on...
- How loud should my engine be 'ticking' before I should get worried?
- Anyone own a HKS Type-0 Turbo Timer, i saw the new Type-1 but i don't need all those options ...
- Nology & Magnecor
- ECS floor mats...why fit 99.5+ only?
- the faq is getting close to 10k views! did you contribute to it yet?
- i want an old s6 now!
- Squeak noise in rear of car?
- Whats a good turbo timer for the price and where can i find it?
- I think it's time to upgrade to cpp adjustable control arms
- Looking for OEM Low Lip for A4, Anybody??
- out of the blue and into the black (or into the red, maybe)
- Subaru, Volvo, etc. AWD vs Quattro ... whats the big differences that makes quattro better ? ...
- Spark plugs..what kind, what gap....
- Vacuum leaks - Vacuum line diagram
- Would ECU 8D0 907 557 C fit instead my 8D0 907 557 P??? What is that letter NEwayz???
- wheres best place to buy these parts????
- CEL error P0411...anyone know of any fixes...searched and found lots of problems but not fixes
- Can a 5speed ECU work on the Tiptronic?
- Thanks for everything
- 17967 Throttle valve control part (j338) fault in basic settings
- DIY air box mod
- UrS6 wagon - 1, K04 A4 - 0
- I already STFA and I can't find the size of the studs on the turbo
- Are all 1.8 prone to sludge issue or certain manufactured years??
- lookie here!! ATP has finally released the prices for the GTRS kit!!
- Belly pan - where to buy one ?
- car alarm on 99 A4Q
- So I bottomed out today and now my car sounds funny (ticking and chugging)
- VVVVVV PWNT VVVVVV
- new pictures of my 2001.5 audi a4 1.8 turbo quattro
- valve covers and leaky cam seal replaced
- date and time
- Just bought 4 Canton speaker - Need help for installation
- Anyone going? AMS dyno day tomorrow 9am-5pm
- Prop shaft bolts
- Dumb question... best to install Neuspeed Rear Sway on Jackstands or on Ramps?
- I'm either an idiot, or a big idiot ... what's the diff. between a caliper and a carrier?
- haven't people gotten in trouble before for using BoosTed's pics
- BPV easy install?
- What do you guys budget annually for maintenance? "NORMAL" drivers as apposed to "RACING" drivers;)
- DAMN AUTO DIMMING MIRROR!
- Cant figure out how to get my friggin shift knob off
- Oh Noooooos! I can hear my TRE failing!
- I'm an idiot, posted this in the wrong forum. RE: Parts I'm selling. ;-)
- car-part.com is the bomb
- Anyone have 96-98 taillights around? The ones with the orange in them??
- Where to buy AEB motor/tranny?
- 130k miles ... what service should i have done. A4 2.8Q
- Poll: What's your average gas mileage for city (stop and go) driving? My last fillup was 20.4 MPG.
- PAGING Audimods, or if anyone who knows him.
- Happy Friday..... 900hp VW polo!!
- What should I be measuring on Vag to determine If I am running too rich? Also
- Cluster Display acting up
- Suspension is creaking while parked, time for new coilovers?
- Difference between 2001 A4 1.8t and 2001.5 A4 1.8t?
- Gonna buy it!
- Did B5's come with an option for Dolphin Gray Metallic? Also, differences between 1999.5 and 2000?
- Catalytic Converter Deteriorating - Options? Cost?
- Help! What engine do I have?
- When greasing sun roof, you clean the rails first then grease correct?
- Found a local parts supplier that can get motul rbf 600 for $12.50 a bottle
- Ok so i take the car to the dealer, says my clutch is slipping, wants $1500
- Whats everyone doing this weekend? Car modding/cleaning wise?
- Prop shaft questions/Paging Phil/Carson
- Drove a 2000 1.8tqm for the first time, some questions about how the clutch and turbo should feel...
- Will S4/B5 front upright bolt right into A4? TIA
- Remove T/B, 1996 2.8 30v
- I'm starting to wonder if it is time to sell....
- Anyone seen a stock 1.8 & 2.8 race? results??
- OT , VAG-COM ,can I use it to code 99 and 01 Jetta transponder keys?
- Is it worth it to get a Hyperboost valve?
- HELP!
- Who's got the best deal on stainless lines for stock front calipers right now?
- installed the injectors, adj fpr, gauge and program last night, super easy...
- Clutch?
- Why do my car drives like a boat?
- more alternator woes
- ABS module repair kits... they do exist.
- A4 2.8Q I bought...
- i got my car yesterday, i cant wait to start modding it. Are there any suggestions to get it in..
- ollonglans - A4 tdi --where can i get your headlights??
- Is the a FAQ section on here? (more inside...)
- How long do you think T/B replacement would take...
- Can I switch the MAF myself ?
- Suspension Squeak only after driving?
- Woot!, finally changed my window regulator....... long DIY writeup
- 100k miles and just changed tb/tensioner!!
- The Ultimate Rice Mod?
- Fack. I hit a piece of truck tire changing lanes on I95
- ECS Coilover kit
- Anyone ever use DTR Performance in Florence, KY or AutoMotion in Louisville?
- 2.8 Missfire - Lesson about spark plug torque (long but worth the read)
- Finally some pics of my car!
- ac on my 96 audi 2.8V6
- Can a ko3 turbo from a 2005 fit a 99?
- Boring track pics
- Anybody have an avant bicycle roof rack they want to sell? Any brand will do.
- Key Remote Question -- Searched, but can't fix it
- The worst thing to come home from work and see...
- Cleaning out the garage of old B5 parts.. check the AZ classifieds for stuff. Free stuff too (here)
- How many of you don't carry your spare tire to save weight etc.?
- Autosport Werks Installed my H&Rs today...
- uh oh.... factory cd changer harness
- Moving to HI - selling S4 (and TT) winter wheels/tires
- finally have a picture of my a4 worth posting
- xpost: can anybody answer this question, thanks!
- Console was pulled out of the car tonight
- 6 control arms down
- Where can i get these deep sockets?
- anyone replace a door latch mechanism?
- what is that sticker on the 2.8 engine cover?
- FS: OEM suspension B5 S4
- Blauparts.com - Control Arms
- so, how long will it take me to replace all control arms, tie rod ends, and sway bar links
- Time to tune or sell?
- Oil send and return lines for k04
- JE Recal and A/C compressor...
- Bad gas mileage question
- Going into limp mode. Think I need new N75 valve.
- what are cam tensioner gaskets and valve covers
- as i am checking with junkyards and stuff it seems that most places will sell the TT carriers only
- hahaha, my audi idol...
- installing the adj. fpr, injectors & program tonight a few questions about this...
- is there anyone else have any info on brake pads to post in the faq thats not listed?
- so since i got the turbo now... how hard is it to install?
- Oil is leaking
- Check out this moron.......it'll make you laugh though!
- is my new turbo busted????
- thanks to those that helped me out... wore out my phone
- New Ferrari off road SUV for less than 100k!
- Attn: Matt & other OEM freaks like me... AZ stereo install.
- Chip question..was told by PES that my 1.5 bar chip should only boost 20psi??
- brembo rotors on ebay
- Antenna amplifier tigger ?!?!?!?
- So my spare ECU is on the way to AWE...
- i ordered the turbonator and installed it...
- getting pissed, anyone know where i can get a pair of caliper carriers 8E0-615-425-A...
- where is the best place to get bosch 310cc injectors?
- Seriously, what is the point in switching out the chip?
- Gonna DIY replace my coolant resevoir Saturday morning. Anybody have any tips?
- which alternator?
- 775 whp EVO VIII.
- Anyone try the DIY alignment before
- any one have pics of AT Italia Riva 17x7.5 on a blue a4? but any color will do
- While flipping through the tech section to get some ideas for my next mod...
- This Sunday, 7/10, CT/NY Audi Group Meet & Meguiar's Detailing Clinic - E.Hartford, CT
- A couple quick questions for you guys...
- O2 sensor problem
- need socket for security lug bolt on wheel. Where to get ??
- Any suggestions on where to get a CF hood painted in SoCal?
- WTF? I call Midas for mount and balance of 2 tires (my own) and they say $40, then...
- Loss of low end torque in a '99 2.8........
- I'm just curious... how much HP do you guys have in your 2.8/1.8t
- You Guys see what happened in London! 40 dead more injured from terrorist Bombings...
- Anyone know the pin-outs for bench testing the wiper motor?
- silver A4 might be sold this weekend, leaves me needing to drive the crashed A4...
- Somewhat easier fog light mod for 99.5+
- Just curious....what would/will be your next ride?
- Kris, Phil . . . .
- TINTED!!!
- 2.8 quattro
- hids are in... (PICS)
- is it safe to drive on a blown turbo
- K04 J31 owners, chime in!!!
- GIAC OR APR?
- illinois audi help
- TB change and VAG-Com?
- traditional chip vs. giac flash loader. it cant be worth the cost?
- Does N-E-1 know where is ignition fuse or relay, or clutch safety relay my car wont start
- Torque specs on 1.8 and 2.8
