- Someone please buy my guage cluster! Lowered the reserve!
- are these any good?
- Anyone here ever use spider spikes?
- anyone know which fuse controls the secondary air inj pump (aka smog pump) on a MY2000?
- New turbo timer install...(bww)
- $141 for a battery....now i know audi is crazy....
- Fog light Question...Yes i STFA...
- Update on 1.8TQM clicking noise
- K04 & N75J...
- AIR BAG light!! what's this mean! What can I do to fix it?? anyone have anyidea???
- Final word in OEM Brake Replacement for Normal Performance Application
- Recaro Pole Position package deal!
- euro plate question
- ECU Question
- Oil for Q 1.8 2000 Avant
- Whats the optimal time to set the turbo timer to?
- Tail light problem
- MTM w/ AWE TIP CHIP?
- Engine performance upgrades
- 2.8 12V, custom turbo project
- Help installing boost gauge!! TIA
- x-post to my boost gauge install.
- Ok, Redline MT-90 or Redline MTL? Dunno which to get.
- Anybody want this? (wheel cap)
- I have seen the light!
- just makin sure, we don't have any kinda clutch dump valve or anything right?
- rear ender.... near total?
- Another battery question...I checked the Amperage and im showing just under 14 when driving~13.5 and
- FS: 17" ICW rims/wheels w/ Sumitomo HTR+ 225/45/zr17 tires
- ecode? I can just use my OEM bulbs in the non-xenon housing, correct?
- best swaybar setup for front-trak
- stage 1 chip
- Is there a way to change the 1.8T oil filter without a mess?
- When braking i hear the sounds of the ABS kicking in ...while not slipping or sliding..:(
- Has anyone else installed the OEM Antennae for the alarm?
- Thoughts on Extending warranties
- is $60 for a used window regulator a good deal?
- Oil in intake plumbing, why is that (1.8t)
- control arm kits on ebay
- Poll: Max boost you've seen on a chipped 1.8T (20psi / APR)
- Repost for the weekday crowd
- Timing Belt and Spark Plug question
- OT - San Diego Halloween Party!!!!
- best place to get a v+s ss
- Thank you to MikekiM@PureMS, RKA, et al.
- Will RS4 intake manifold fit?
- Anyone know where I can get a set of Swing wheel center caps?
- BG Products located in NY
- Need help with sideskirts please!! I just need some questions answered.
- Front grilles
- ebay switchblade key
- B6 production ends at 8e-5-400 000
- 280mm to A8
- Just got a stud conversion kit. I can't remeber who buy someone on here inspired me
- Does anyone have links to their cars online?
- At what rate do D2S bulbs deteriorate?
- Anyone have a stock N75 valve they want to sell?
- I remember reading that some of you stage 3 guys are running the greddy boost controllers. (more)
- Anyone know the part number for this hose?
- Depo lights
- Sportek?
- fvck! how long is fuel good for sitting in your tank?
- Update on clicking noises in 1.8TQM
- Woot :) it's my car
- where does zelenda ship from?
- Hit or skip
- got an encounter with a nissan 2002 maxima tonight
- Dubfrest Caravan?
- Car Alarm went out...
- where is vwparts.com new address?
- Stranded in NY...ignition amp or coilpack. Need advice!
- Do 30v v6 heads would direct fit on a 96 v6 block?
- Update: Suspension Install Saga
- grill /grille
- Heres a quick on for ya, ATP Dump tube Q (x-post/perf. forum)
- possible NE Fall cruise
- Weird tail lights....need help
- where would i start to research info about a single turbo on a 2.8 30v?
- Steering Wheel
- shipping car from NY to LA
- Quick ? about automatic locks........
- K04 Owners
- where is the best deal on 02 sensor or
- wood interior trim...
- Anyone use these gauges? Saw them last night and they the black w/ red looks pretty stock...
- This isn't mine i found it on ebay and it made me laugh so i thought i'd share
- Question for B5 1.8T guys with Neuspeed/Bilstein set up...
- Turbo Timer installed...what do you think...
- sun damaged brake master cylinder reservoir
- getting a pretty bad Squeek/Groan from the Rack...Anyone encounter this before?
- Installing a Symphony II radio/in-dash CD changer in a 2000 A4?
- Dealership gouged my steering wheel, what should I do?
- Is this a good deal for an ETKA?
- Value of 99.5 2.8QM when new body comes out (multipart question)
- Where do i buy vag com softwar and what else do i need to hook it up
- Anyone know of somewhere that I can find a good deal on a new stock turbo for a 97 A4 1.8tQ.?
- Check Engine Light (MIL) NEED HELP
- Repost: Fix your broken LCD
- Just got my V&S installed along with Front & Rear Neuspeed
- Anyone selling a V1?
- Neuspeed 19mm rear swaybar...
- Brake Bleeding Question
- pic request... 1.8t underside.... any nice pics of the car up on a lift would help
- Torsen troubles.... have now evolved into transmission troubles
- VAG tool isnt clearing fault code
- Turbo Timer Q
- Southbend Clutch at drag strip
- Trouble Starting. Im also having some trouble starting the car, seems like a weak battery or
- Windshield Washer. My windshield washers have stopped functioning. I dont think its leaking as i
- Heater is making a squeaking/chirping noise after it's warmed up. Heats and cools fine though.......
- How to bleed (drain) power steering ?
- Radio Removal gone bad
- Is there any major diff. b/w; HRE, Kinesis, Fikse and IForged wheels?
- Induktion Motorsports Dyno Day (BWW)
- GreenRookieNewbie Brake question...
- Floored 97 2.8 12v, got no response, what gives?
- about to purchase rs4 wheels but still looking for tires, any suggestion sizes and type?
- new brakes ... ...suggestions.
- does anyone make a bozer carbon hood for the b5?
- a little overheated????
- Confused on what e-codes to buy?
- x-post: anyone know where to get a coilpack on the weekend in the bay area?
- Can anyone help me with a new sig???
- ANY ONE KNOW WHAT OTHER CARS HAVE 5X112 BOLT PATTERN ?
- Pic request and WTB plea. 18" OZ chrono's on black A4 (profile shots)
- Paging:GldnRkt STG3...if you finish your project...can I stop by and take a peek?...
- "Bosa" control arms?
- Just saw an advertisement for a product called Audiclean
- +44 offset 18x8.5 ok? Lowered 2.1/1.7" Mercedes wheels
- how to seek vengeance?
- mandatory milestone post...
- Where's the best place to get gear oil? Will I have to order it?
- Need help with car!
- How long does it take for your car to warm up?
- Would $2500 be enough to hook up a 1998 1.8T?
- rear bearing - how chronic?
- New Toy in the garage...
- winter wheels with A8 brakes
- HID Question
- Timing Belt Install...
- 22 minutes and My stock rims are gonna sell for $150!!!
- Anyone added a clean looking install of XM?
- who is the person with black a4 that just put RS4 reps on.
- Test Drives : Subaru Legacy GT / STi - longish with cliffs
- Quiz with a prize. a stainless steel hood strut
- Some pics from the induktion dyno day.
- Secret of Speed - audi video, link to the big one?
- AutoX Pics
- what size rims
- Another 2.8 30v Timing belt&Waterpump conquered
- washed and waxed the a4... [pics]
- Odd clicking noises
- A4 1.8T exhaust poll
- Watch this clip
- 2000 A4 Double Din Radio Trim Suggestions????
- Suspension Update Question
- Debadging is teh suck!
- Well..just got my homebrew FMIC installed (finally)-->
- Apexi Turbo Timer
- What options do I have for balancing out the understeer?
- Timing Belt Question
- Just got back from a Rally-Cross at European Rally School...lots of fun
- this is the best lookin front end (grill area) of the new audi's imo....
- I love my sister's new ultrasport
- b6 1.8t transmission swap
- Suspension DIY Question
- Has anyone KO4ed their car after 80K miles? It's a 98 5 speed.
- thinking about getting a set of BBS CHs in 17x8.5 for the street
- bored...fall pics
- check out this vacum hose!
- White smoke on cold start up out exhaust that goes away but not completely when car gets warm?
- What should I look for when Looking at 98 1.8T?
- 10,000.
- wheel suggestions
- PAGING NOJOI
- End of my Town Fair Tire story....
- Front Rotor Removal
- sodium filled valves?
- so friend broke my ipod ice-link, can i order just the cradle?
- Anyone have this stereo head unit?
- NEED HELP!!! ECU won't recode for Auto????
- PureMotorsports Stage 1 Brake Kit is in!!!!!
- STAGGERED LOOK!
- Any ideas?
- Anyone been to Kuala Lumpur, Malaysia?
- Got my car back from installing the Meyle Control Arm & Heavy Duty Tie Rod End kit...
- offset for oz sl
- torn brake piston dust covers
- anybody have any other pics of this car?
- Just hit 1,000 miles on the new 2.0L engine and tranny is still in one piece.
- is $168 for a hid xenon buld from dealership reasonable or should i go elsewhere
- Someone was looking for Oz SL's in Anthracite - Here are Mine :-)
- LOL, so for a car rental next October in Europe, what should I get?
- driver's side, rear window doesnt work anymore =(
- some random shots from tonight
- Anyone have a passenger side front bose speaker for an 01?
- Anyone using PIAA's Super LED wedge bulb in their e-code corners?
- Body kit (reiger) on stock suspension . . .
- r we aloud to offer a4 parts for sale? like a craigs list type of an add?
- just got a new momo ebrake, anyone know how the original comes out?
- xm install i hate eveythign they have nothign clean or stock looking any sugestions?
- Some one's got too much time on their hands!
- Is there any reason you can think of.....
- Seen The new A6 today..I was like where did i see that
- Bike Rack on 98 A4
- Need help changing spark plugs on 98 A4Q2.8
- Where can i find an Audi Rob Knob II??
- CT area Audi mechanic?
- APR Snub Mount Question
- Anyone with 18"x8.5 rims with 225/40/18, please look...
- I am about to order a VAG-COM from Ross-Tech. I am going to get the one second from the left...
- Higher than normal revs at idle
- should i tap into the green nipple for a boost gauge?
- eurocode tuning just sent me an email....
- bosch 3 bar fpr, is it oem on mkiv golf/jetta AND beetle, or JUST beetle?...
- I just lost a race against a bone stock 1981 Audi 5000S Diesel
- Just pulled the trigger on this
- Those of you with a radar detector and tint
- decreasing understeer with c/o?
- Biggest Audi dealership in Europe opens up 45 minutes away. Yeehar
- I can't remove the projector out the headlight housing. I have 1-piece headlight.....
- Got the E-codes hooked up with the relay!
- Any idea what a front bumper would cost on 98 2.8 Q?
- can you clean service N75?
- Hey guys!!! I have an IDEA!!!!
- I have a prediciment for everyone to give opinions on, please help!!
- What blinker fluid gives me the most HP gain?
- Help with Turbo Surge Problem
- Question ... squealing noise
- New pics with new wheels on...
- RIMS and Tires?? Audi A4 and VW jetta or any other VW Will they fit either on Audi's?
- Do any of the national auto chains carry Pentosin coolant?
- X-Post from Midwest forum. How my APR exhaust got 0wn3d, and question...
- So.. Is the kid that just bought a '99 1.8TQ in CB white at palisades audi here?
- CD ERR-1
- OT, anyone ever use Auto-Rx engine treatment?
- Instructions on replacing engine temperature sensor on 2.8?
- Toluene question?
- New here
- Replica Sportec Wheels in stock and on sale....18 x 8.5 et38 5x112 only $XXX each - limited supply
- Aftermarket Radio Antenna Hook Up
- SYN oil. WHO's using what?? Mobil 1 vs ??
- thinking of replaceing my trans mounts at the next Kc tech session How difficult is it?
- hard to decide
- cigarette lighter question..
- REMINDER: Denver GTG Saturday Oct. 9th
- Florida Club Driving event at Gainesville Raceway...
- someone posted about their vibration issue recently, including fix...
- Anyone had experience with 235/40/18's with a bilstein/h&r combo?
- Last reminder: Kent Falls, CT bbq is tomorrow (10/9)
