- Price quote on headlight issue
- 200K - Service Checklist
- engine temperature issue
- No toggle to access driver display panel
- fuel rail
- no power windows no wipers no door locks
- Low to NO dust brake pads for your Audi?
- Front end vibration
- New Schwaben Fender Roller! *$59.95* with Free Shipping!
- Does your car stink? Time for a new cabin filter from MANN
- Found a pair of BIRA S1 A4 brackets
- A6heaterproblem
- heating motor rarely works
- Last Day to SAVE up to 50% on your favorite brands!
- have a 2008 Audi 2.0t Quattro need help to fix it plz
- engine change on audi a4 b6
- Previous owner switched ignition and door lock
- Fuel Line Leaking (Why?)
- what is the meaning of the color mark on a rear coil spring for Audi A4 B7?
- Drive shaft or transmission tail shaft noise
- 17544 HELP!
- Sources for quality rebuilt 3.0 engine?
- GOLD!!!!!!! Limited Edition Forge Diverter Valves | In Stock | Free Shipping
- Last day to save on over 25 of your favorite brands up to 30% off
- Spray from injector
- Power Steering Fluid/Oil
- Save 20% on Maxton Design Exterior Upgrades!
- 99 Audi A4 1.8t No turn signals or hazards.
- up to $50 off ECS Street Shield Skid Plates!
- $50 ECS Gift Card + Free Shipping on select South Bend Clutch Kits | Best Deal!!!!!!!
- LCD screen on the instrumental cluster not showing data
- SALE 35% off Micro Jump-Start Kit Schwaben | Dead Battery Salvation | Free Shipping
- Free Shipping and up to 15% off P3 Gauges!!!!
- no hose no water
- Replacing Expansion Tank
- Key Fob doesnt open the trunk
- 15% off Malone Tuning Engine Software Upgrades
- VAG-COM "no response from controller"
- Increased Idle Speed at Cold Start - 2001 1.8T AWM
- OBD linking error
- Advice on sale price for a "Classic" A4
- Please help, bogs out, not fuel, not ignition
- Windshield Wipers don't work properly!
- Coolant leak
- Clutch Master Cylinder
- Can't figure out vibration at idle drives me crazy!!!! Help
- timing belt
- A4 B5 2.4L service manual
- A4 B5 HVAC Question.
- Engine swap
- A4 1.8T vs 2.8 reliability
- up to 50% off your favorite brands Cyber Monday|Supersprint HRE 034 Milltek and More!
- MAG WHEEL PAINT COLOUR CODE
- Fob drains batteries fast! How to get print out to clean?
- A4 1995 2.6 v6
- over center spring
- Old lady backed into my car today
- Trunk bent, doesn’t complete the waterproof seal
- Problem with inside lamp
- $50 off your B5 A4 ECS Street Shield! One Day Sale!
- Anyone willing to help a fellow European guy with B5 2.8 V6 30v?
- Hazard lights blink, but seperate index just stays on.
- adding tripcomputer to avant a4 tdi b5
- torx size on timing belt tensioner??
- A4 2.8 small turbo project help!
- Rattling sound from underneath the car 1999 Audi A4Q 2.8l Manual
- Intake Manifold stuck closed
- Wiper control issues on 2016 A3 Komfort
- rear brakes locking up
- Boost readings, Lambda fault, high fuel consumption (Fault codes included)
- A/C compressor swap
- Bolt Broke on Caliber Bracket
- Wiring diagram for Audi A4 B5 1997 AFN
- poor aceleration
- Original Owner 133k 1.8T Burgundy Tip A4 Avant FS in Seattle
- Very Special Car
- Single key reprogramming
- Line under Intake Manifold
- Instrument cluster/gas guage backlight
- Link error scanner, 2000 Audi
- will a replica rim 19 x 8.5 with a 35 offset form a merc s550 2008 fit a 2013 a6 3.0
- Help with 2001 Power seat plugs!
- Help needed with diagnosing problem audio
- Deleting Codes to pass inspection?
- If you are having cold start issues
- 2001 Audi A4 Quattro 1.8t won't start after going through Car Wash
- brakes
- Audi2013 Q5
- NEW! SACHS Performance
- Temperature Sensor problems pt..2
- 99 A4: need help, wont start
- 1999 A4 B5 deck replacement
- Need arm rest lid for my b5 1.8t
- 99 audi a4 wont start
- armrest lid catch replacement
- 96 a4 12v
- A4 wont start codes 1426, 1338, 0102
- Audi AG B5 manual turbo 1.8L interchangeable motors?
- Ignition help
- Vacuum question
- Horn not working after ignition harness swap
- NEW! Schwaben Radiator Pressure Tester Kit
- A4 B5 Alternator replaced - worse than original?
- Seek button?
- Radio in SAFE mode
- Current 01 A4 B5 led cluster display fix?
- A4 3.0 Ltr TDI smell in cabin
- what size bolt is the front two axle bolts on the 1997 a4 2.8 quattro?
- 2001 Audi A4 B5 2.8 Quattro Misfire! Please Help!!
- up to 40% off MSRP on H&R Premium Suspension Components
- Help me fix my reverse lights.
- AUDI A6 2.7T 2003 O2 sensor
- Payout loan early
- Facelift Full DIS Cluster - CANBus problem
- A4 Quattro - 1999 with 25K miles?
- Audi A4 estate cannot get reverse or number one gears on the run I am able to get gea
- SALE APR Software 15% off | Ends October 31st 2017
- starting relay location 2000 A4 1.8 quattro
- Kerosene cleaning method for oil pick up problem?
- Flash Sale! Up to 15% off ECS B5 A4 Stainless Steel Brake Line | Ends Oct 7th, 2017
- 1999 A4 B5 Inconsistent Starts
- My 1.8T cabriolet won't start again after a longish run.
- CAR DOESNT HAVE POWER WHEN MOVING FORWARD BUT REVERSES PERFECTLY WELL....WHAT COULD B
- A4 B5 2.8 engine replacement
- winter tires or 2006 audi a3
- ECU
- My 2008 A4 just started leaking a little oil.
- Removing original brake lines tips? 98 A4Q2.8
- I have a new Audi TT and i am getting a lot of condensation on the windscreen.
- 99 A4 B5 2.8L 30V Stalls on start
- What year 1.8t awd engines are compatible on a 98??
- 2001 A4Q 2.8 mystery: random, roaming, intermittent misfire. Expert help requested!
- :: ECS Tuning :: SALE up to 25% off CTS Turbo Performance Products
- A4 V6 1999 AUDI HELP! wont run without foot on gas
- Audi 2009 A4 serpentine belt change
- Audi A4 evolution! B1 to B9 all models, video!
- B5 A4 V8 swap questions
- :: ECS Tuning :: SALE 20% OFF APR Software | B5 A4 1.8T
- What do I need to replace to get rid of the underboost problem?
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- :: ECS Tuning :: In Stock | 034Motorsport Performance Upgrades
- A4 B5 Quattro V6 30V Engine noise
- 4 speed auto
- :: ECS Tuning :: SALE 15% OFF | Cooling Refresh Kits! | Flash Sale
- How to test for a bad relay switch?
- Coolant tank empty, no leaks - air in system?
- boilling of a water resevour what would be the cause of that?
- Weird creaking and groaning coming from front suspension
- Oxygen (Lambda) sensor, which one to buy?
- My custom A4 (B5) video! What you think?
- camshaft seal get replaced with water pump?
- Overheating or bad fan?
- :: ECS Tuning :: Euro Blind-Spot Mirrors Audi B5 A4 / S4
- Water spill caused seat to surge forward and I can't get it to adjust back to normal
- 1998 A4 front-end squeak after full suspension overhaul
- Overheating Help!
- Remote Key/ Key Fob
- B5 A4 2.8Q stalls at idle and won't restart until cooled
- ABS / auto transmission related issues?
- Linkage?
- c5 trans multifunction switch replacement
- Timing Belt Change
- Oxygen Sensor Part no.
- Multiple misfires.
- Clicking when turning, but only when the clutch is out.
- Windows dont move up and down by key
- mileage display not showing
- replaced rear dif axle seals now car is slugish ganing speed
- 2001 Audi A4 Quattro K&N Cold Air Intake Question
- Help with this part name, pls
- boost cut or fuel cut
- Headlight Change
- Halo LED headlights
- Stage 2 Low power issue
- Gearbox problems
- 1999 b5 automatic change to manual
- Low oil level
- Transmission issue
- engine management light on after repair
- Cv axle connection
- Damp and wet puddle
- Facelifting doors.
- Repeated thumping while accelerating
- Back to work on the Quattro (Doesn't turn past a certain point)
- how to fix a secondary air injection systeme incorrect flow detected
- studder
- Strange scuffing noise from Driveshaft
- 2001 1.8T no heat
- Q7 2006 hvac-fan won'turn off
- :: ECS Tuning :: 10% off ECU Upgrades! | Ends August 13th, 2017
- What does this buttons mean ?
- :: ECS Tuning :: Turbo Upgrades | Frankenturbo F21 | Free Shiping
- Blower motor same for left hand drive as right hand drive?
- All toad push start doesn't work in hear
- 30 PSI with engine running on cyl #2
- 2001 2.8 engine swap.
- 2001 audi a4 1.8t quattro AWM engine DAJ DWR Transmission
- Back in the scene
- A4 b5 cluster connector
- 2.8 Quattro engine replacement/swap
- audi tt 2003 smogtest
- How to play music through bluetooth
- Help with 95 A4 key
- Alarm and locks going haywire.
- Audi TT stereo code
- 1997 audi a4 2.8 fwd
- Exhaust fitting
- 1.8t audi a4 b5 tensioner roller sticks out. why?
- 99 A4 - hard start after new fuel pump
- Oil disappearing, Brown coolant
- Cigarette lighter removal
- 1997 A4 Quatro - Parts for Sale
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Last but not least the Engine Wiring Harness. How to fix or prices for this repair?
- Wire damage for the fuel injectors.
- Frontal throttle angle sensor too low. Questions on how to fix it myself
- How to change out TCU/TCM or get it cheaper from other salesmen and get it fixed.
- weird acceleration issue
- :: ECS Tuning :: $50 off Street Shields | Ends: 07/26/2017
- Vacuum leak? in rear driver wheel well?
- timing belt
- Engine stops when clutch pedal is pressed
- B6 to B5 swap?
- s8 radto unluck
- 2007 Audi A4 Glove Door Lock Assy
- Vacuum diagram for 98 2.8L AHA?
- Compatible years for replacing the truck
- [URGENT] Should I trade
- audi a3 2009 1.9 tdi with climate control
- Towed Audi
- Oil sensor warning
- 2005 Audit TT Quatro A/C Blower Runs Then Quits Repeats
- No Air flow from Centre Vents on Audi A4-
- Hard time starting 2002 a4t
- 96 a4 2.8 engine shakes when accelerating
- Cylinder head torque settings and sequence
- Where doesn't this wire go?!?
- Odometer not working properly
- Oil pipe 078115701
- Aftermarket wheels diameter & width
- coolant bleeder valve
- Accelerator sesnitivity
- Cold Start Issue
- What clutch and fly wheel is in a 1996 2.6 V6 A4 please?
- Changed ecm, misfire, no cel
- burning coolant and engine temp light
- Conect older maf on a newer b5
