View Full Version : Q7 MK 1 Discussion
- ESC & TPMS error. Car will not go into gear?
- Leaking sunroof
- Swap of black gloss front grill pate holder with filler (4L0807287T94)
- Q7 Wrong rear lid current position after replacing J605 motor
- Anyone from the tri-state area (Ohio, Kentucky, Indiana) Shop Recommendations
- Rough shifting on 2018 Q7
- Navigation Feature Shuts Down
- Cool wiper feature
- AdBlue leak at wheel well
- 2018 Audi Q7 Rear exhaust leak.muffler shop not able to weld
- Fan timer switch install
- Recall on Recall? Q7 4L Fuel flange / Filter leak - Butyl Goo gone wild - 20W9 / 20BJ
- 2013 Q7 3L TDI Removal Procedure?
- Merry Christmas and a Happy New Year!
- 2013 TDI Cold issues
- has anyone reduced oil consumption with an engine flush?
- It's d@mn cold, and snowing here, time to test Quattro 🙃
- Can anyone help identify this engine leak? 3.0 TFSI
- Very rough running, no engine codes
- 2013 Q7 TDI - NOx Bank 1 Sensor 2 issue
- Does anyone know how to fix it?
- Adaptive Lighting - How can I tell if I have it?
- Battery recommended for diesel?
- 2013 power lift gate not opening fully
- diagram for brake booster lines
- Holiday lights at the race track freaked my car completely out!
- Headlight bulb replacement
- Audi Q7 Heating issue
- Q7 2014 sline plus Standard speaker upgrade.
- 2015 Q7 Steering intermittent failure!!
- CN: How to change the SMALL screen language?
- AU: oil leak 3.0 tdi 2011
- 4L MMI 3G+ (HN+) Nav maps update?
- Funny thing happened today at work.
- 2014 Q7 3.0 TDI no start
- New to me 13 Q7 S-Line Prestige - I gots questions
- 2014 Front Seat Harness.... Are your plugs female?
- Rear bumper lower tail light screw?
- 07 Q7 3.6 long crank only when sitting
- How to Remove 2007 Q7 Rear Trunk License Plate Light Lamp Pull Handle?
- DEF delete in GA
- Audi side assist: Sytem Fault Help Needed
- Check engine light on 07 Q7: Misfire all 6 cylinders? Need Help
- Mmi not working properly 2006 q7
- 2013 Q7 Exhaust Tip Rotated
- RAWTEK DPF/AdBlu/SCR DELETE INSTALL
- High pressure fuel pump
- Coolant temperature sensor
- 2010 Audi Q7 MMI not working
- Ad Blue warning - 1k miles left - what's my play?
- Malone Tune and gas mileage data
- After market subwoofer
- hvac left side vent motor positioner
- TDI Dieselgate Warranty: Audi Towing Reinstated for 3yrs
- 2012 3.0TSFI oil leak from head gasket
- Hatch not opening from interior
- Q7 misfire
- Weird driving….in my head?
- Curious what others with the 3.0t (gas) in cold climates are using for engine heaters
- TDI Alternator
- Parking view camera / front and back sensors
- Low Oil Alert 2021 Q7
- What is length of propshaft(7L8521102H)?
- Low Temperature Gauge & Engine light
- 2007 Audi Q7 3.6 prem broken headlight connector
- Great deal on H&R lowering springs
- 13 Q7 diesel - 507.00 Oil?
- 2015 Audi Q7 - P2006
- Audi Q7 front license plate bracket removal
- TDI and Cold Weather help
- Audi side assist system fault 07' Q7
- VCDS hangs up
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- Audi Q7 voltage vault
- AIR SUSPENSION: The Reality and Do's & Do Nots...A Learning Curve
- Weathertech Side Window Deflectors
- 2018 Q7 remote starter
- 2015 S-Line Q-7 Oil Separator
- 2014 q7 TDI P246F
- New to the euro world
- FYI TDI Guys: Malone TCU Tune Now Out
- Audi Q7 dashboard
- Map/Navigation updates 2015 Q7 TDI
- Convenience Lights Stay On
- Where is adblue cap
- Urgent Question: Overheating. 2015 TFSI.
- UK: 2007 Q7 Radio issue
- Will 2019 Q5 wheels fit 2022 Q7?
- My first Oil change on the 2013 Q7 TDI
- Q7 TDI fuel economy issues - VCDS root cause analysis...
- Q7 3.0 TFSI (Petrol) B8/8.5 2009~2011 Repair Manual
- 07 Q7 Start Issues
- 2011 TDI oil change interval
- Help with a part number
- 2022 Q7 Premium Plus interior lighting
- Audi Q7 2012 4L Air Suspension Pump Advice
- AU: HPFP CP4 leaking
- Default '15 Q7 Sline 3.0 Gas- hard start and transmission issue
- 2014 q7 anderson plug
- Audi Q7 2010 3.0 TDI 70k.75mph/hills temp gauge shoots up limp mode stop and ok
- Audi Stop-start system - incline start
- 2009 Q7
- Optimal RPM for 3.0TDI?
- Weird noise when reversing??
- Q7 S-Line - Replaced a 2014 engine with 2013.
- a/c discharge hose
- Tailgate only opens 12"
- 2010 Q7 3.0 TDI problem starting
- 07 4.2 Q7 won't start on the first attempt
- 2012 Q7 TDI Adblue codes - Failure
- 2015 Audi Q7 Windshield Wiper Assembly
- 2017 Audi Q7
- A/c fan dying, where to get a good replacement?
- 2012 Q7 TDI: Fuel economy before/after delete and towing
- Engine Mounts Replacement
- New here :) IS OIL CHANGE MANDATORY ONLY WITH AUDI DEALERSHIP?
- Cost of diesel fuel - it's not "supply & demand"....
- Downsizing from 21" Peelers - Looking for pics and possible trades
- Passenger Wiper Base Cap/Air Deflector
- 2010 q7 Tdi code p0016
- ZA: Run flat tyres on non-runflat wheels
- UK: Audi q7 front wipers?
- 2011 TDI oil drain washer?
- 2018 Q7 full spec for $47,500 - good deal?
- AU: Fuel Injectors readings
- 2010 Audi Q7 Tdi loses prime at fuel filter
- Q7 TDI 2015 170k miles, dead?
- Low Fuel Rail Pressure 102K mi
- 4.2 FSI cat/downpipe removal?!
- AU: Possibly High pressure fuel pump
- 2017 Q7 cruise control traffic jam assist not working
- Burning oil like crazy
- Front / Rear camera install question
- Serpentine belt jumped off the tensioner!
- 2012 Q7 TDI - DEF/SCR Control Module Location?
- Remote Start on a TDI
- 2015 Q7 150,000 Mile Report
- License plate lights not working
- Wheel comparison, anyone have photoshop?
- 2015 Q7 TDI heater core replacement or?
- ADVICE BEFORE FITTING NEW 3.0TDI TO Q7
- Left headlight "dipped"?
- Transmission problem
- Anyone here with the 3.0T running JHM downpipes / HFC?
- Blower fan intermittent issue fixed
- Rear Brake Rumble 2021 Q7
- Question for those who have changed their transmission oil
- MX: Door locks going crazy
- Parking Brake Release Cable Failure
- Brake fluid brand recommendations
- WTB. Rear hitch cover 2014 S Line
- Dead battery - won't charge
- Cracking sound from under the car during hard turning
- UK: Suspension issue
- Audi Q7 Trip computer issue
- 2007 "sound system"
- 2015 3.0T oil leak - valve cover gasket at 95K miles?
- MY07 Q7 4.2 FSI Tension Roller Failure
- AU: Q7 diesel just stopped
- Infamous water around console
- Repair advice for grille and bumper
- Burning oil smell
- 2014 Q7 TDI - rear noise
- Q7 brake issue in wet slushy cold conditions
- 4L Q7 RS Style Grille Install w/ Adaptive Cruise and Front Camera
- Q7 2016. Gear not shifting to Parking. Need urgent help
- High pressure sensor(G65) lower limit exceeded
- Water pump replaced with other coolant issues
- Help, can't figure out where this connector goes.
- 4.2 FSI oil consumption?
- Transmission recall
- AU: Cracking Amps-battery-long cranks in warm start
- Lamin-x headlight / taillight film
- Feedback Desired: Kansas Audi Dealers
- To TDI or not TDI?
- Door sag?
- TPMS monitoring on instrument cluster?
- Annoying Buzz/Rattle/Vibration noise on drivers side.
- Is there a trunk cover when 3rd row is in use
- "Auto Hold" vs engaging the parking brake every time
- 2012 Q7 Transmission Jumps Between Gears
- My Q7 trouble codes
- Front Wipers Motor issues
- Maintenance
- 2015 Audi Q7 Tdi P0C2E
- Replacement Rear View Mirror
- 07 q7 Electric towbar won't go back in.
- P100D 04109 error
- UK: Passenger side door foam mould issue
- 3.6L Exhaust Tips
- Air suspension - worth the wait?
- TDI Ext. Warranty expired - do I keep it?
- 07 Q7 Sirius Radio Greyed Out
- Can't open door from inside or outside.
- Switching to black from chrome.
- KKL VAG-COM for 409.1VCDS-Lite Issue
- 13 premium plus 3.0
- Q7 air suspension adaptation issues
- 21" Tire size?
- Injectors, Seals and Bolts
- Battery re-code clarification?
- Q7 Heatet Seats
- q7, random shut downs
- Flippin' MMI
- Air Suspension Compressor Temperature Range
- Q7 TDi Long crank and white smoke after being stationary overnight
- Control Arms
- Malone Tuning 07' 3.6L / Worth it?
- How reliable is the 2013 q7 premium?
- Look for a dpf
- Air suspension issues
- Invoice Review for TDI Warranty Coverage
- Lost satellite radio
- Every Error Message Known
- Air compressor
- Engine Replacement (2015 - Q7 )
- 2007 Q7 code PO336
- Factory air tank location
- O2 sensor q7 2007
- Side mirror light bulb replacement?
- Looking at a 2014 Q7 Prestige 3.0TFSI
- An Bluetooth experts?
- AUDI Q7 2019 3.0 vibration at 900 rpm
- How much to add factory hitch?
- Value of Q7 after rebuild
- Air suspension VCDS lowering ?
- Audi Q7 4L 12v Switched/Ignition options
- VW Indicator Fluid same as Audi?
- Starting problem
- Eventual replacement of 2011 S Line Q7 should I buy another MKI or upgrade to MKII?
- UK: Audi Q7 S-line 63 plate.
- Intake manifold leak on 2007 Q7 3.6L
- Halogen to bixenon
- Audi q7 2007 4.2tdi coolant leak
- 2013 q7 tdi engine coolant temp sensor 3 located ?
- Need help to replace AC line with many pinhole leaks
- Red Coolant light
- Winter wheels/tires question
- Looking for a Q7 TDI Diesel gas cap
- 2012 Q7 TDI Maintenance
- Rear rotor extra recessed bolt needed?
- 2013 Q7 S-line drone/
- Labels for Q7 HVAC measuring blocks
- 2015 Q7 reprogram spare key
- Getting ahead of the timing chain noise
- Q7 rear drive shaft removal
- Mobile app
- Front seat compatablility
- Wet floor mats
