- Audi A4 b8 goes random into limp mode
- BG: Audi A4 B8 Electronic issue
- 2013 A4 Avant 1.8 code P0011 and cruise control misbehaving
- Is this a camera?
- New here and wondering what I'm this picture is
- P2293 on 09 A4 avant
- Any of y'all happen to be Naptown Tuner?
- Radio Unit Replacement Help
- Voice Recognition Language Change - CD Needed?
- MY A4 is listed as Limted Edition, how can I determine how many wer made?
- Replace left rear bumper reflector 2015 Allroad?
- Emissions Update - 23z2
- Fuel Relay Location?
- Questions about the Audi 4 cyl.
- Need to Drain Fuel Tank
- A4 B8 washer pump unusual problem
- trunk/battery
- Weird noise from the third gear
- Beware who you deal with on repairs
- A4 B8 rear diffuser
- 2012 Audi A4 Quattro air intake leak
- AU: Buying a salvage car, key question
- Drive line/ Transmission- to change gear correctly
- ESP FAULT
- Amplifier does not have power
- 2009 Audi A4 A/C
- Cooling Fan wont not starting
- B8 B&O speakers upgrade?
- AE: Audi a4 2015 (Right Dipped Headlight/Main beam headlight)
- Help! Audi B8 won't start after engine scan
- 2012 A4 Avant Shakes, CEL+EPC, Misfires + Fuel Pressure Sensor Malfunction
- Code P0101
- Allroad timing chain stretch?
- battery tender?
- Rough idle and shake 2.0tfsi
- How to replace red dis to color dis?
- OB1 6 speed gearbox questions
- What to do with it after catastrophic engine fail?
- Green Menu help
- Controlling individual leds from the headlight
- Anybody know what this part is called?
- Gas smell near rear right tire. Very low fuel economy. No codes.
- Rear brakes heating up
- Where to get spare Key FOB
- Oil pan bolts
- Split coolant T-pipe
- Stiff Steering Low Speeds
- Belt or chain?
- 2013 Audi A4 Custom Tire Pressures
- Glove box handle broke. Looking for manual release
- Rear door won't open from outside
- 2012 A4 2.0 Radiator Fan Not turning on ?
- Engine cranks but won’t start. Need to press gas pedal to start
- antenna location
- Looking to Buy: 2012 A4 quattro Premium Plus
- 2014 B8 Projector Headlight question
- Audi A4 B8 headlamp
- Chain tensioner /bicycle sprocket noise question
- Wheels and Tires
- Low Pressure (in tank) fuel pump replacement
- AU: Audi A4 B8 Advant
- Correct parts order
- Wiring diagram for AUX
- 2015 A4 B8.5 Oil Seepage - Repair Estimate Advice
- IE: I am very confused about my Audi and lowering it.
- MMI3 works but no sound from speakers (Water Damage)
- When (yellow) oil light comes on?
- Turbo underboost code
- SE: Audi A4 lines through screen
- Looking for Shop Recommendation near New Haven, CT
- 034Motorsport Catch Can Breather Adapter for sale
- UK: CJCB EGR has died AGAIN.
- 2014 a4 b8 screen has vertical lines on it?
- NV: 2010 Audi A4 sline Quadro
- 2016 B8 A4 - Service Due!!
- 2016 B4 Keyfob PN/Freq?
- NZ: Audi a4 1.8T 2009 wagon jump start noob, lots of smoke
- Unable to pick up calls via Bluetooth button
- A4 B8.5 Radio issue
- Audi A6 2013 2.0t C7 with high oil consumption 115k miles
- PL: Squeaking coming from window [A4 B8 LIFT)
- UBDII reader for Aibag issue
- Rear parking module gone.
- UK: Weird Vibration in Idle - Recent Cambelt change
- LV: A4 Electric trunk button?
- 2011 a4 premium (halogen) headlight replacement
- UK: Bonnet Cable Disconnected
- UK: 2010 A4 B8 CVT juddering at 2200RPM
- A4 B8 "Switch off engine and check oil level" red warning
- A4 B8 oil leak and P2015 00 [175] error msg
- Resistance steering while driving
- 2014 A4 allroad - Oil Consumption Question
- 2014 Audi A4 – 30,000 miles - engine failure
- RO: Amplifier?
- Amplifier replacement
- Modules not communicating
- Evap canister replacement info for B8
- Crash sensor help!!
- B8 Allroad No Power 1 (Rear) Channel
- Is my 2016 B8.5 Totaled?
- BG: CD Defective - Audi A4 B8, 2.0TDI, 2008 year,. Audio symphony
- CV Axles: 2014 A4 2.0 Premium Plus
- A4 2.0 TDi Auto alternator issues maybe Fix
- ZA: 2013 Audi A4 1.8 tfsi B8 Engine Part Identification (Has photo)
- Shut car off, low oil pressure
- P2293 + P053F with very poor fuel economy
- Vacuum pump torque specs
- Downpipe on audi a4 b8 2.0 tdi
- PDC ESP Push Button change HELP
- Downpipe on 2.0 tdi b8 a4
- Very Poor Fuel Mileage ~ 11-13mpg
- 2012 A4 Intake leak/oil leak
- Audi A4 2012 cant turn on ignition
- Car seems to rev limit at 4,200 rpm?? Please help
- Audi Concert - AUX
- 2010 Audi a4 b8, cvt missing the second plug???
- 708-203 Thermostat doesn't fit? What's the deal?
- Changing battery serial by 1 digit for more charging?
- Weird engine sound
- A4 2.0 Tfsi Quattro 162 KW(220 HP) 2014 B8 GEARBOX 8HP55 fluid change
- Broken aluminium on suspension
- 2009 B8 2.0t Vacuum pump leaking massive oil.
- 2012 Black ed corroded ECU
- 2011 Audi A4 Excessive Engine Oil
- Change thermostat or CTS?
- Thermostat replacement possible without pulling water pump?
- UK: Adaptive Light Defective A4 - Headlights still moving
- Custom remote tune
- reset adaptions
- Awesome wireless dongle
- 2015 A4 Sensor Issues
- CEL with 7 fault codes
- B8 A4 CTS BOSS 600 INSTALL HELP
- MMI and other electrical issues
- Car over-revved without shift, now won't start.
- KR: TPMS integrated to the 3G MMI?
- Transmission help
- P2187 & P12A2 diagnosis codes appear
- Electrical issues
- Space saver spare wheel for my car
- UK: Puddle light recoding green hidden menu?
- UK: Puddle lights?
- Connector/plug in glove box?
- Crank tight in new to me block
- Question Weird noise from front passenger side
- Head/main/rod bolts dry or oiled?
- 2.0T Cylinder head cover sealant
- Replacing thermostat B8.5 CJCB
- Audi A4 B8 2008/2009 year
- Bluetooth Unit Adapter
- Grill emblem dimensions
- Engine misfire (A/C compressor)?
- UK: Audi A4 diesel 2012 - low MPG average 38mpg
- Anyone had issue with the ECS Tuning dipstick?
- Mystery leak
- Mystery leak
- TN: car moves forward when it is in neutral RPM becomes unstable
- New turbo
- A4 b8 2g mmi control unit
- UK: Symphony unit unresponsive
- Rough idle codes out the wazoo
- Super low mileage opportunity! Opinions needed!
- SE: Audi 2.0 tdi 2009 (caga 140hp) engine swap HELP
- DE: TFSI Oil Issue
- Webasto Panoramic Sunroof Lift & slide arm broken
- VCDS issues
- 2015 A4 allroad key fob battery is CR 2032
- 2012 A4: Car locked up or seized
- Convenience Key Not Working
- Parking Brake Malfunction "U140500"
- Right turn signal /brake light /rear light WARNING
- Mmi update
- LV: Tyre size?
- Got the car back, and...
- Sound system
- A4 B8 2008 parking brake 03288
- SK: battery yuasa
- 2013 A4 Quattro. Water pump
- Camshaft Pos Sensor, Misfires, Catalyst Below Threshold, EPC Light at Low Speed/RPM
- A4 B8.5 2013 facelift model advice
- Loud Clunk noise when letting go of gas in reverse
- UK: Help please. I keep buying the wrong part.
- Dynamic Steering system fault light after vehicle towed
- Sound system upgrade and radio unit upgrade help
- Check engine—error code p0300
- Power steering acting strangely
- Please help, multiple issues, not sure what’s causing?
- 2010 2.0T Quattro misfire
- UK: Rusty, possible damaged underbody?
- IE: Multiple electrical issues
- 2018 A4 rear seat armrest cup holder.
- How reliable is the Adblue technology?
- Oil consumption and the catalytic converter
- Hard start problems
- Hit a snag during a DIY timing chain job
- Replaced ignition switch and battery now nothing works
- 2011 A4 Parked and now dosen't crank.
- A4 2010 - Gear problems
- Question relating to the MMI software/tel button/bluetooth
- 3.0 TDI feels sluggish after remap?
- New Audi Owner
- Help with A4 B8 electric seat wiring
- Trailer Hitch wiring? Help a girl out!! :)
- Audi A4 TFSI P0172 System Too Rich
- RO: Audi A4 B8 diesel DPF frequent regens and problems
- Is my car possessed?
- Issues with starting my car on a cold start
- That "Rislone" thread...
- Avant PR Option Code Sticker Location
- Purchasing a 2013 A4 2.0, thoughts?
- 2009 A4 emergency brake issue please help!!!!!!
- Belt tensioner shifted 90 degrees
- Reverse camera fitment B8 2008
- Is this the idler pulley
- Idler pulley - help
- Brakes rubbing but only when hot
- Audi A4 2.0tdi CR heavy misfire/judder
- Audi A4 B8 ( 2010 ) 2.0 TFSI Radio error code - HELP
- Rack and pinion lines?
- Fitting RS4 (B7) wheels onto an Audi A4 (B8)
- UK: A4 b8 avant tailgate?
- Carplay Modification
- Rear brake piston popped out
- ESC Fault / TPMS / Check Engine light after installing interlock
- 2011 A4 EPS light
- A4 Rear Springs
- Jerky Car after ZF 8 ATF is changed
- AX: 2010 all road 2.0 tfsi s tronic oil change
- Revs drop when change from P to D
- UK: Audi vehicle data sticker
- Hard to shift when hot
- PSA: Check Those Manual Door Locks
- No heat
- 2011 Audi A4 quattro misfiring
- LV: 2.0 tdi warming up
- Light bulb
- Unusual noise from the roof and pillars
- Water Pump Extended Warranty
- audi a4 2012
- I have a transmission service question!!
- Brake caliper bracket bolt part numbers
- Bad mpg and slow acceleration? Please help!!!
- Fuel pressures, read with software?
- UK:A4 2.0 TFSI Poor MPG and Throttle Response
- DTE system to DIS system
- Silly, but fun
- 2009 A4 B8 Quattro P2293/P12A4
- A4 B8 TFSI won't crank
- UK: A4 B8 2.0 TDI cold start problem.
