View Full Version : Audi A3 / S3 / RS 3
- Audi Service Maintenance Plan
- A3 3.2 Quattro 8P1 Bearing Carrier
- Engine failure... 2017 S3 FL
- Looking at a 2008 A8. A few things
- Super Low miles a3 valuation
- Moon roof will not close, stuck in the up position
- RS3 Full Carbon Fiber Kit
- I am having an odd electrical issue
- getAudiparts.com | Genuine Audi Car Covers!
- EPC flashes, engine gurgles & car stutters at low speed - help!
- Key Fob light Flashing and not working
- Part hanging off my A3. What is it?
- Audi a3 1.8TQ: crankshaft fit question
- A3 oil Leak 2.0T
- Extended warranty - which dealer has best prices?
- Lane assist
- 2017 Audi A3 DLR Issue
- Not much going on here
- Leak, or just dirty evap line from AC?
- UK: Service schedule?
- 8V Audi A3 oem parts
- Gearbox
- 2015 a3 2.0 auto transmission codes
- AU: 2010 A3 1.4TFSI Stuck in gear
- Exhaust swap 2006 -> 2009
- 2017 AUDI A3 door lights and foldable mirrors
- UK: Changing alloy sizes
- UK: Coolant Problemm?
- Car tracking left, help
- Steering knock, help!
- Need Help! Should I install a Wheel Studs Conversion Kit on Audi S3 8P 2012?
- 2007 A3 8P Newbie Help
- 2017 Audi A3 EPC issue
- Flash back to stock so Audi can replace battery?
- New & improved Audi Phone Holder!
- A3 8P Wing mirror kicked off
- audi a3 s line faults vcds
- A3 used base roof rack
- Pulling to the right when the steering wheel is straight
- Knock control issues
- Air Bag Passenger Side
- Headlight control module
- AC compressor running ragged / noisy
- Basic Purchase Questions
- Extended Warranty for 2017 Audi A3?
- Will I keep the Bose System working after upgrading radio
- All warning lights on. Please help
- 2016 Audi A3 Quattro
- Audi A3 2007 1.6 Sportsback 52,000 Miles Torque Logs
- Black Media Screen
- 2016 Audi S3 Heated Seats stopped working after adding Dash Cam
- 2012 6-SPD FWD - PZEV/emissions control fail
- Replacing a dead MIB
- MX: [8P S3 2012] Metallic noise under the car at low speed
- 8V S3 2017 16k miles - s tronic Gearbox Blown!
- A3 steering wheel retrofit
- BUZZING NOISE IN ENGINE BAY
- 2015 A3 2.0tfsi - No Power and Long Cranks
- Need step directions to unlock Concert radio code
- fuel injector leak
- 2012 A3 TDI CV Axle Vibration
- Service in West Palm Beach Florida Area?
- A3 front left parking light is intermittent and low voltage
- 2015 Audi A3 b&o sound system sounds louder in one side
- Audi A3 ECU problems
- GR: ESP CRAZY ENGAGE AFTER TYRE CHANGES
- A3 8p engine code difference??
- 2013 A3 TFSI 1.8 Ignition Failure
- Opinions on buying s3 when lease is over.
- Replacing Halogen bulbs with LED bulbs in A3 headlight
- A3 new Cup Holder
- Exhaust enquiry
- Halogen headlight adjuster problem
- A3 without magnetic clutch
- Lower Oil Pan for my 06 A3 3.2
- Audi A3 Convertible DAB Aerial issues
- *Resolved* Audi A3 “Alternator not charging the battery” warning
- 2012 A3 Premium - add Android Auto/CarPlay
- Looking for front lip
- Turn signals doesn’t blink
- eVenturi
- Thinking to buy an Audi A3
- 2014 A3 s line
- A3 sportback flywheel part number, I am struggling.
- Possible to add Drive Select to 2015 A3?
- 2016 A3 Quattro P11AE P11B0 errors...
- EPC Light - Turbo or TPS?
- 2007 A3 steering wheel trim
- s3 calipers
- 2015 Audi A3 Backup Camera Not Working
- Retrofit audi a3
- UK: Audi A3 2006 semi automatic keeps going into limp mode
- Quad tip rear diffuser for 2020 Audi A3 Sedan FWD
- Audi A3 s tronic gearbox service 2012 8p
- Brown patch appearing on paintwork
- Back right Door not opening from inside or outside
- Can I swap these parts on a high pressure fuel pump? (picture)
- Audi A3 2004 changing valve stem oil seals help
- A3 8P1 1.9Tdi 2009 help needed please with the drivers door wiring diagram
- RO: Oil change?
- Audi A3 1997 1.8 - help in reading DTC codes from the hidden menu
- 2008 Audi A3 Sportback
- Crazy to go after a higher mileage S3??
- UK: 2006 Audi A3 8p 2.0tfsi S-line "SPECIAL"??
- NL: MMI updates?
- Downpipe install and CEL question
- Heater flap headache.
- 8P - Door size on 3-door vs 5-door?
- 2006 a3 oil blowing out around oil cap
- 2016 A3 PODS warranty recall reoccuring issue
- A3 bumper piece removed
- 2 Alternators, 3 Weeks
- Help needed please for the door actuator threaded rod measurement
- Website for parts?
- Audi S3 wobble issue
- S3 headlights on A3 S-Line 2017
- MMI /AMI
- Quad tip rear diffuser that will fit a 2020 A3 non s line?
- Which other models will 2010 A3 TDI wheels fit?
- EPC and/or Engine light random!
- Whirring/build up whining sound only in 1st gear?
- Fitting Q2 seats in a A3 sportback 2013
- Help needed please to sort my drivers door unlocking problem
- Suspension set up with wheels and offset
- 2008 A3 SLine mysterious battery drain issue...solved. Bluetooth
- 2008 a3 2.0tdi clicking sound coming from drivers side from wheel
- Sunroof issues on 2015 A3
- Caliper Lockup after major pothole
- PT: 2010 A3 1.4 Sport tire recommendations?
- OBDEleven long coding
- 2015 audi s3 2.0 tsfi fuel filter location
- AUDI A3 AIR VENTS
- GR: Hello all. A3?
- 2004 8P Audi A3 Quattro 3.2 wheel hopping
- Audi A3 Sportback 1.6 Sport Tip.6sp 2007 intermittent acceleration problem
- 2016 Audi A3 2.0L Turbo Muffler Delete
- servicing help
- Audi A3 Smaller Raditor Fan Won't Turn Off
- Braking Upgrades
- Problem with central locking system
- Audi paddles retrofit ( R8 into A3 )
- Audi S3 - 2017 model - auto folding mirrors?
- FAILED INSPECTION NJ?
- RS3 CEPA rebuild
- Halogen to led
- MMI ISSUES?
- A3 Tfsi problem?
- A3 3.2v6 fuel pump isseu
- UK: Bent wheel stud, can't remove lug nut
- Engine Swap or Scrap? 2010 Audi A3
- Best down pipe for stage 2
- Help needed please to set unlock / lock chirp sound
- Broken latch on front sunroof 2011 A3
- Convertible problems
- Need help!!
- Need New Tires, Any Recommendations?
- Front speaker volume low after new HU?
- Audi RS3 P049F Code
- 2011 Audi A3: S-tronic/Mechatronics issue?
- Antifreeze leaks only when driving.
- Ongoing P0455 (Evap Emissions Large Leak) Indication Issue
- Missing pipe
- help detecting possible air lea BGU engine
- OEM Audi Center Caps for MSW Type 48 Wheels
- Petition: 2021 Audi A3, S3 and RS3 Sportback for the USA!
- 09 A3 Rear Left Wheel Speed Sensor Fault
- Interesting Power Loss
- U-Haul trailer hitch for an Audi A3?
- 2009 A3 losing electronics in hot weather
- 2006 A3 2.0T
- Error Codes
- 2010 Audi A3 transmission questions
- Maintaining Audi A3
- When you purchase a tune what happens?
- What 2010 Audi A3 mods you can put on before apr stage 1 tune?hne
- Audi A3 2013 Sport back.
- Looking to purchase a 2015 A3 2.0T
- Audi A3 transmission problems, no reverse gear
- Video / DIY on RS3 DSG Fluid Change?
- Summer tires needed for S3
- Sensor error
- A3 EPC light always on, car starts and dies
- Audi s3 2018 Can i swap normal clocks to virtual without swapping dash bord tha ks
- Is my automatic 2008 A3 2.0T a DSG transmission?
- Audi s3 seat not moving after accident
- 2012 A3 TDI - Loud bang when engine was off
- 2015 Audi A3 tire question
- Drivers door unlocking problem help needed please
- Audi a3
- 2016 Audi A3 Battery
- UK: Air?
- UK: Part ID?
- SECOND GEAR ISSUE PLEASE HELP!
- Clearmounts DriveSafe 2020 - Custom Audi Phone Holder
- AE: What's the little light on the door mirror?
- Using RS3 parts in an A3
- Audi A3 8p 2010 stearing wheel
- Audi S3 8V 2017 Sportback
- 2012 Audi A3 TDI Instrument Cluster
- Small chip on window trim
- BOLO: Stolen Car
- 2015 A3 EPC - TURBO
- Best trailer hitch for 2006 Audi A3
- Center Dash Vents and Wipers
- Audi s3 8p performance issue
- S3 rear tail lights
- FAULT: 000665 - Boost Pressure Regulation
- Switch light audi a3
- Help audi a3 banquette
- A3 1.4 TFSI worth a Stage 1 ECU + TCU Tune?
- Total lockup back brake S3-07
- A3 Possessed by evil spirit !
- car wont start on first attempt when cold
- P0113
- A3 wiring does not match the schematic help needed please
- Audi A3 Sline 2014-2016
- Audi A3 Driver Door Electrical Fault
- 2007 A3 S-Line (couple things)
- AUTO Light Upgrade - A3 2.0 Quattro (2015)
- Audi A3 engine swap
- Brand New Spyder Projector Headlights Audi A3 06-08 for sale
- Under car rust: normal?
- O2 sensor code P0137
- Problem entering security code
- Gear knob change.
- A3 sportback
- Audi a3 changing airintake
- Changing Halogen for LED on my A3 1.9Tdi help needed please
- audi a3 windscreen wiper defective
- AC Issues
- 2006 A3 2.0T Multiple Problems
- 2015 Audi A3 2.0T Quattro
- 2009 A3 Intermittent Locking Failures
- A3 Sub Woofer Short Circuit
- 2006 A3 2.0 Mystery P0300 to P0304 codes
- 2006 A3, 2.0 Mystery codes, P0300 to P0305 codes... Random Multiple Misfire
- 8v RS3 5 cylinder in 8p?
- MMI how to connect iphone with lightning cable
- Replace Broken Armrest Hinges
- AUDI A3 - Replace Broken Armrest Hinges
- Oil changes on 2014 Audi A5
- 2009 Audi A3 2.0t Quattro - Mechatronic Unit Problems
- 2008 A3 2l TDI - oil pressure warning after oil change
- P0321 check engine light on a 07 a3 3.2L
- 2008 Audi A3 2.0 DSG : weird noise coming from engine bay
- A3 Cabriolet 2015 - Roof stopped working
- 마카오카지노조작("「EON77.COM」")마카오카지노서울
- 인터넷카지노조작("「EON77.COM」")인터넷카지노서울
- 라이브카지노조작("「EON77.COM」")라이브카지노서울
