View Full Version : Audi allroad
- Cold Start Problem/CEL Light on
- rear vibration
- Steering?
- More Suspension Questions
- Rear washer line leaking at rear headliner
- Back Seat Control Trim
- Differentials drained and refilled
- Overheating drivers seat
- New Years Eve purchase!
- suspension level warning ligh on constanly
- Blinking Level Button and Suspension Indicator
- Using Techron Concentrate fuel system cleaner?
- Insrument Cluster Replacement
- Happy New Year to all of my web friends of the 'road.. let us all hope for..
- Suspension height
- Coilpacks
- Rear washer
- Codes 17544 / 16555
- Replacement Antenna suggestions for '01?
- paging suspension guru's!
- Mystery suspension issue
- Windshield washer fluid leak coming in behind driver's seat - advice?
- Need warranty
- 4,2 into a 2.7?
- Fresh Oil Smell
- window visors for allroad
- Rebuild a 2-piston Lucas/Girling front caliper???
- 2001 AR APR ECU upgrade flashable?
- A good day and I hit 190K
- No reverse uphill
- need right side lower aluminum door moldings
- 6 leaking fuel injectors...??
- Face Plate for AR in Dash Cup holder
- Oil leak on drivers' side & oil in the bi-pipes leading to intercoolers
- MERRY CHRISTMAS!!!!
- Snowburm - 1; allroad - 0
- Continuing "Check engine" light, nick-knacks
- 01 AR....torq converter info needed
- help needed locating a electrical panel
- Dashboard Cupholder stays out....
- Sorry, but this is another name that problem.
- :: ECS Tuning :: Mud Guards - 92% OFF!!
- Good report Aarnott suspension compressor
- what rotors for 01
- wating for ar to fall apart
- Allroad suspension options
- Introduction, mysterious navi buttons problem...
- Source for TPMS Components
- Need 17" twin spoke rims 2001 black allroad
- NYC got around 12-14" of snow last night...
- ipod adapter
- Level Control System Sensor; Front Left (G78) - fault
- CV Boot Grease?
- 2.7 and down pipes
- Yakima Railgrab towers fit?
- Clutch and stuff...
- Default System problem while driving, lights galore in dash
- Brake Pads Worn & Voltmeter??
- MIL - 17585 - Bank2: O2 (Lambda) Correction Behind Catalyst
- When must the timing belt be changed? 70K, 100K?
- Replace or Repair?
- Rear wiper squirter not squirting
- Radio reset isn't working
- w/s washer fluid lamp
- Changing miles to km?
- Air Bag light and 65535 code
- "Twisted" Allroad Shifter Rod?
- Tires
- Best car - and Worst
- Cooling fan are always on
- Very Cold Weather and Compressor Issue
- 2003 Navi Disks
- TC, motor mount, or ????
- Looking for a nice AllRoad - no experience with AR's
- 2.7 engine ID code letters
- PVC or Turbo?
- No Heat!!! and it's Cold out side.
- Thinking of buying a high mileage Allroad, advice needed please!
- Adjustable coil overs from Arnott
- strange rattling rt. rear...
- APR
- chains on allroad
- real world answer: Quattro or X drive
- allroad transfer case leak
- Newbie who bought the worst AR on ebay
- XM Dock and play
- HELP!!! passenger VCG replacement problem
- Gas mileage way down after,,,,
- Anyone willing to look at a car in Ballston NY for me? It's a long shot, but I didn'
- new cat
- suspension indicator lights--HELP
- Question on brake pads...
- DetailersDomain's Holiday Special 15% off and Free Shipping over $75.
- :: ECS Tuning :: Holiday Giveaway 2009 - $8000 of Free Stuff!!!
- Saw a very sad allroad today.. Front end was practically scraping on the ground..
- Calling any Baltimore, Md. Area allroad owners..
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
- Transmission Parking Question
- check engine light blinks and goes out
- Winter Blades
- HP2 calipers
- Cute little Audi
- suspension problem/leak?
- AR buying recommendation?
- Anyone with a vag in downtown FTC area...
- Cv boot ripped...
- Siezed pinch bolt upper control arm
- Boost at WOT
- MAX requested boost?
- Will 10mm spacers work for 18x8 et35 rims & 245 tires
- 2001 Allroad EGT sensor
- More tire help
- MBBS In Ukraine
- need help with interior door cable
- arnott suspensions
- :: ECS Tuning :: Holiday Sale – Nearly Website Wide Savings - Up to 25% Off
- What does this mean and how to fix it
- CO allroader's, Euro Denver GTG - Sunday, December 27th, 2009: 12-27-2009
- Coils for dummies
- Auto 3-blink turn signal?
- Manual tranny oil rec?
- Removing bottom steering post cover
- Torque Converter
- allroad air suspension
- Front ashtray stuck open
- Suspension question
- Radiator fan cross reference?
- Weird Oil Pressure problem
- Q5 OFF-ROAD PIC'S
- Wiper blades
- Prepping the AR for 1st long trip?
- 17965 and malfunctioning diverter valve?
- Allroad Diagnostic OEM/Vacom tool
- allroad w/19" HyperBlack RS4 replica wheels - pix?
- Any experience with cooper tires?
- 3 Dunlop Winter Sport M3 (225/R17) Available - Cambridge, MA
- Yet another "considering allroad" thread
- Looking to buy allroad
- Just lost Level 4!
- :: ECS Tuning :: Symphony I and II radios on MAJOR sale
- Fender flare
- Three warning lights again
- Anyone in Santa Barbara or Lake Tahoe area w/ VAG-COM?
- All new owners....
- interesting noise pulling into my driveway tonight
- Ok, so I did something dumb
- 2002 All Road : No Owner's Manual - Help!! A Few Questions...
- misfire
- Mapped Cooling error/coolant temp sensor
- Valve Stems- non TPMS- read on
- Low speed "groan" and steering feels more vague
- 2002 Allroad ride height question
- DIY - Replacing a side view mirror / removing door panel
- how would 18" chrome rims look on an allroad
- ESP Problem - kicking in when it shouldn't
- Pics please of 402 mod with 17's
- 6 speed shifter slop ?
- Child Car Seat Tether installation?
- Coil packs...
- CO allroaders - Peak to Peak gtg/cruise; Nov 28
- NE1 install, upgrade to the B6 S4 345x30 setup...
- what is largest bbk that will fit under temp spare...
- Anyone done the Arnott rears themself?
- Denver group - 18" vs 19"?
- New Stern Transmission Mounts
- WIX filters
- Update on '05 6MT purchase
- Anyone here stopped on the side of the road around 3:15 on I-70 E in Denver (ish)
- Pinch bolt? Gen II Air bags
- Line-X or Rhino liner?
- Axles for Allroad
- Market for Allroads
- Advice on control arms for ar? Read on...
- Test drive - '05 MT6
- Available Ross-Tech VAG-COM in Boston
- Boston area timing belt DIY tools?
- Tiptronic help..... :(
- Found this on Craig's list in denver today, if anyone looking
- anyone running oem sat radio with blitzsafe???
- Anyone else get the letter about the upcoming...
- Adjusting the headlight
- Help! A6 Quattro outer tie rod replacement
- Help! I am scrambling! New left rear airspring and car is not working right
- brake pads
- New (to me) allroad video.
- Manuals; Paper vs electronic
- Replaced rear left airbag with Arnott, car still sinks. (see previous post)
- paging paulroad: doing rear airspring, trying to get top nut out but it just rotates
- Boost Problem - need help
- Strange warning gremlin
- Any gearheads or DIY's have a Bentley manual?
- projector fog lights...
- cleaning the rubber bumpers
- Anyone need Audi Allroad Trailer Hitch?
- Allroad Gauge Cluster White Backlighting Out
- R&I door trim?
- Bose sub
- 2004 allroad 2.7T 6-speed manual for sale
- Window regulator?
- nameplate help
- Interior Light help
- ExtremeContact vs. Tripletred in allroad?
- pagin 04 allroad or ne1 w/leaky rear washer hose...
- help after XMSat install in MY05...
- Euro Loveland GTG - Saturday, November 14th, 2009
- Strange Warning!
- Battery died. Need replacement. What AFTERMARKET battery are you guys using?
- Has anyone put Arnott Gen II bags on yet?
- Windsheild vs Bolt... Guess who won!
- rear suspension down and light on
- Mounting the Ski Box
- DIY oil change?
- Allroad key fob worth anything to anyone?
- OT:This is for a certain someone on this board who likes to drive sideways.
- '05 allroad 2.7t
- Help in Replacing Motor mounts
- Many lights on!!!
- fair selling price for my 01 AR?
- Turbo "sweating" . . . fix is?
- Which road for my Allroad
- When is the new AR coming to US?
- 2001 AR Alternator bad, best place for replacement?
- Results on "slime repir" for airsprings anyone?
- Did someone here want a replacement headliner for their AR?
- Valve cover replacement
- dumb question on headlight assembly A6 == Allroad?
- Fault 01772 Help!! Air Suspension Mystery
- convert cluster trip info to metric
- 05 allroad nav without screen + xm + ipod
- Shocks / Struts?
- TB
- Rear Diff problems..
- Suspension Q's
- Swaybars on tirerack and hotchkis
- PureMS has group buy for H-Sports
- looking to purchase
- Where Can I Get Mods For Audi Allroad 01
- 02 6-speed for sale
- oil leak at left turbo
- Help me choose which ones...
- Suspension lift front right is not working.
- Falken ZE 912 Buy 3 get 1 Free
- Selling "Olympic Edition" Allroad
- The "Shimmy" and Parts
- x-post: A/S Tire Poll
- Anyone near North Salem, NY?
- ar headlight restoration
- Cruise Control
- Leaky engine gaskets
