View Full Version : Audi allroad
- First Time Audi Owner - Variety of Issues
- My '02 Audi Allroad Growls and whines.
- Cooling Fan Advice
- Trunk/hatch-mounted bike rack suggestions? Saris?
- 2004 6MT - Death by Engine Fire
- Best setting to keep your Allroad parked
- facebook for audi fans
- 2005 4.2 front air leak?
- zf5hp24 transmission
- The case of the missing A4 Allroad.
- 2.7T Wizards needed. Odd ball problem...
- oil leak
- 2003 Allroad wiper relay/control module LOCATION
- Neuspeed Power Module
- 2003 Allroad Key Fob Remote issue
- rastreador - qual melhor?
- 2008 A6 Allroad suspension gave up
- chain driven 4.2 torque converter line up to fly wheel
- Kayak / canoe tie down for Allroad?
- allroad won't move???
- Question about headlights replacement sources
- Question for alroad TNXXXXXXXXXX
- Audi A4 Convertible & Trunk switches dont work
- Stealth Hitch for A4 allroad 2012-2015!!
- Where to Jack with Floor Jack
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- A6 C5 Allroad Alternator
- Air to spring
- Here is a video of Hoffman Estates Audi Dealer stealing from my Q
- Replace combi hose pinch clamp with worm gear clamp?
- Any changes 2014-2016?
- 2013 Allroad sportwagon and Iphone interface
- 2014 a6 allroad rear bumper trim
- AllRoad 6spd 2.8L swap. Any issues?
- 2015 all road mmi replacement
- ALLROAD 2.7T 2003 Cranks and starts runs briefly.
- Any1 is socal able to enable VIM for my 2014 allroad?
- Headlight Problem
- Allroad Window control problem - help needed
- Surprise! Another C5 Allroad air suspension question
- 2018 allroad, remove rear sunshade bar
- Current Tire Recommendations
- Floor Mats
- 2001 allroad ignition switch problems.
- Air suspension intermittent fault
- A/C Pressure/Temperature Sensor (G395)
- Allroad Passenger Side Xenon Headlight Flicker
- Quality C5 Allroad 6 speed shift knob replacement?
- Need knowledgeable Audi mechanic or shop in N Houston TX.
- 2005 Audi Allroad Noise
- 2004 Quattro AC Issues
- Allroad battery/alternator issues
- 3.5 mm Aux Cable entry in my 3GMMI Wiress ?
- CEL and Self-Leveling Suspension Lights on Simultaneously
- Look what’s in my transmission pan...
- Audi Electric mechanic in Los Angeles area?
- Coolant Leak backside of engine compartment... ???
- airmatic suspension level does not calibate after changing a new compresssor
- 2003 AllRoad Transmission Issue
- Allroad - Automatic Gearbox Issues
- 2013 Allroad Dashboard/Computer malfunction??
- Another Audi AR wheel. And Downpipe question..
- Non-fatal timing error?
- wheels A6 to Allroad
- 2004 Allroad automatic concerns
- Control arms
- Backup Camera
- Audi allroad running lights
- swap a 3.0 in a 2005 A4 for a 2005 3.2
- 2018 wheels +40 vs stock offset
- Newbie Intro and Center Support Bearing Q
- A6 C5 V8 Air suspsension (self levelling) removal questions
- Brighter D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs
- Water damaged from cloak drain during rain
- getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
- getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
- Allroad timing chain
- what is the average price to replace the timing cover of a 2010 vw passat 2.0t
- Q7 downsize to Allroad anyone?
- Help deciding
- 2010 A6 passenger door won't lock/unlock
- Hot Oil 2.7T
- Allroad window regulator differences
- 2013 Allroad Performance Upgrades
- Body kit
- Power plant failure
- Will these rims fit my '14 allroad?
- 2014 allroad, drl not staying on after turning off engine
- Audi Shop
- Rim offset
- getAudiparts.com | Give a little TLC: Genuine Audi Car Care Products!!!
- Car wont start
- Ur-allroad suspension, reprise
- passenger rear child lock
- 2017 Audi allroad hitch
- getAudiparts.com | Got Fluids? Shop Genuine Audi Fluids!!!
- Tires to fit
- Steering Wheel Issue - feeling stiffer
- Missing interior part
- aux fan
- Brembo 17z - spacing issue
- Thoughts on Conti ExtremeContact DWS 06?
- Weird '03 AR Tip Trans Issue
- Left side audio speakers are out
- Does the A6 and A6 allroad quattro have the same jack (lifter)?
- shock absorbers
- oil pump
- The ol' suspension locked/ESP out issue
- Running rich both banks
- SAI pump relay location - pictures?
- Audi Allroad on 22" experiment
- Crankshaft position sensor
- Troubleshooting my air suspension ...
- Brakes not releasing af
- Sudden front end colapse
- hub cap for 2004 allroad
- How km i have to do when i change transmission to see it works perfectly?
- cam phasing
- 05 Allroad smoke test
- best year for 4.2
- braking
- Changing transimission audi c6 allroad 3.0tdi
- 2004 allroad 122k miles $1,300, buy?
- Audi a6 3.0tdi quatro
- Fuel Pump Mystery...
- Arnott Gen I or II Air Springs? Arnott or OEM Shocks?
- Max. Treadwear & Circumference Differences Between Tires
- Control module fail
- 2003 Allroad TCU Part Number???
- 2004 Audi Allroad Quattro 4.2 quit running! Need help
- Code P0741?
- Audi immoboliser fault car would not unlock with blip.i used now car wont start
- Wood shifter knob for under $90?
- Blank cluster LCD, flashing interior light and CEL?
- no rear traction
- front bumper splitter color??
- Gearbox oil manual 2002 audi allroad 2.5tdi v6
- Reprogramming after transmission replacement?
- Allroad Won't Start-has fuel, spark and power??
- Starting Issue - Fuel system
- Newbie to Audi looking at ‘14 A4 allroad
- air suspension
- 2001 allroad front end will not raise
- Multiple Broken Clutch Fan Blades
- 01 Allroad 2.7t No boost
- Secondary Air Injector "Abort Result" -70% flow
- WTS : Becker Mexico 7948 Retro Active:2000 EURO
- Anyone selling downpipes and / or exhaust for 2005 Allroad 2.7T 6mt
- transmission problem
- Is Stage 2 GIAC software worth it?
- Did I just kill my valves?
- C6 diffuser/rear bumper
- Air suspension
- fuse blows
- Bicycle Rack Hitch for New Allroad
- Front suspension gone
- Quick Immobilizer Question
- 2005 Allroad Tiptronic ... 175,000 miles
- 2004 2.7 bi turbo oil leaking into exhaust
- Allroad alloys advice
- 2018 Q5 - Ticking / Clicking sound from behind the dash
- S5 rims
- Arnott
- Key fob won't lock or unlock drivers side door
- Beginning To Plot My Entrance to The Allroad World
- Amplifier / Alarm problems after water leaking
- Audi Allroad sunroof drain clogged
- For Sale: 2014 allroad Premium Plus
- navigation plus stuck on 'safe mode'
- Post-cat O2 sensor extenders??
- Am I making a good choice??
- 01 Allroad Rear Top Shock Bolt removal
- fan not working
- audi a7
- Audi Allroad 2004 Fuel Consumption
- Just finished rebulding a 2002 2,7t engine. Installed andnturn the key hear a knock
- Problem with heating
- worn out compressor, sensors, or leaking strut?
- Best Tires for Audi A6
- Replacing (upper) control arms / Air line disconnect
- Will a Q5 wheel with 235/65R17 tires fit my A4 4F
- Used 1 owner 2003 Allroad
- what is the problem in my suspension?
- Recommend WInter Tires for 2003 Allroad
- adaptive air suspension
- New allroad project!
- Auto mirror folding
- Replacing rear shock upper bushing in arnott spring
- steel rims
- Audi Q5 2014 tail gate will not go down or up with FOB-OR button on the tailgate.
- spare tire
- Audi allroad coiler replacement
- Water Vapor in Headlight
- Transmissioin fluid additive ZF5HP19
- Now Available Techtonics Tuning Downpipes and Exhaust
- High pitched whine or almost whistle like jet engine
- Towing with AR B8.5
- New to AR... Just bought AR B8.5 and need advice
- paging SCVINES - ECS jack pad adapters work?
- Car cover for allroad?
- 2002 allroad fuel filter bracket?
- 2003 Allroad 2.5TDI in low power mode--need some tips
- Water Woes
- 2002 Allroad AC in shutdown mode
- 2001 audi allroad with apb engine /MTM
- Allroad high temp problem
- allroad 4.2 ECU tune: JHM vs APR
- xenon help?!!
- More BOOST! Frankenturbo 2.7T F21 Turbo Upgrades
- Water dripping?
- How do you check Bar pressure in compressor and holding tank?
- Allroad suspension control level switch constantly clicks
- Flash Sale! Up to 15% off ECS allroad Stainless Steel Brake Line | Ends Oct 7th
- what is big square with small line beside it code ?
- HELP PLEASE - Remove e-brake cable from caliper?
- Secondary Air Pump Replacement
- Audi A6 not lifting up
- check oil light
- 2005 A6 mirrior caps
- Noise Allroad due to crossbars 2018/2017
- absand esp lights on
- Changing air suspension for cllasic one on Audi Allroad 2,7biturbo quatro 2003 Y.
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- Will 19" S4 wheels fit on B8 Allroad?
- new remanufactured ZF Tip has rough TC clutch disingagement at 23 mph.Is this normal
- Access to lower hose connection Part 13 on a 2002 Allroad
- Reversing, drive disengagement
- Leak in RL air spring
- 2001 allroad suspension issues
- Allroad 2001 suspension problems
- mmi control for adjustable suspension
- Can't figure out where coolant is coming from.
- 03 Allroad OBDeleven suspension mod
- audi allroad 2003 ailr suspensions
- Allroads vs A6
- audi allroad 2003 ailr leak
- ARNOTT Front Air Suspension Spring for 00-06 Audi Allroad
- tilt/ tele steering does not function
- Removing rear bumper and facia
- Hi, my allroad 2004.
- 2002 Sprint Blue "Olympic" allroad
- I need sheet metal
- Annoying noise NSR boot
- Egt boards
- 2017 A4 Allroad Two click noise from steering column
- Spare Tire Well Drain Plugs
- Suspension issue - only 1 corner though..
- Aux switch for off-road lights
- Plz help with my suspension problems
