- Hello my A6 family !!
- Vacuum Hose/Lines replacement - 2013 A6 2.0T
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- Muffler Rattling
- Passenger side wheel speed sensor pin outs
- New exhaust setup
- Help identifying part number
- Audi s5 sportback wing mirrors not folding in?
- Where does this cover go?
- UK: A6 C7 Avant rotors and pads?
- Packages and what is included?
- Dealer says my transmission is blown. Need some advice
- Seatback 2010 A6
- 2012 A6 3.0 Passenger Side Resonator Delete
- 2000 a6 quattro 4.2l tcm issue
- Problems with interior lights
- mmi brightness
- '13 A6 Quattro Prestige Oil leak and new antifreeze leak
- Non S-Line Pre-Facelift aftermarket parts?!
- Sudden significant increase in fuel consumption?
- 2013 A6 C7 Audi connect
- Moonroof not opening, but I hear servo motor
- Just bought an Audi a6 prestige 2012 NEED HELP
- Broken spring ?
- MMI navigation update (2015 EU maps)
- New A6 owner
- Noises underneath the backend of my A6
- Audi A6 C7 2012 A/C not heating properly
- 2018 vs 2019 A6 Prestige - Advice on the Better Deal?
- crank no start after repairing driver seat--help!
- Audi A6 Weird Misfire - Help!!
- ABS Module Change - Coding problem Question
- All Vents Blowing hot except drivers side
- UK: C7 a6 bi tdi running ruff
- Rear Armrest & Pass Through
- A6 s-line bumper
- UK: 2014 audi a6 s line estate?
- interior dome light?
- UK: Battery ignighter circuit - short to ground?
- Audi A6 C7 quad pipe diffuser?
- AL: Engine oil capcity I put more oil
- Wheel fitment?
- BE: Question about engine swap for 2017 2.0TDI A6 C7
- Liqi Moly Motor Oil Saver?
- A6 Prestige (Auto highbeam/Lowbeam) Did this car have this feature?
- Vibration at idle - A6 2013 2.0t
- 2012 A6 3.0 SC Exhaust manifold gasket replacement
- Australian A6 VIN Decode
- Driver side seat only one side of the seat moves forward backwards
- A6 c7.5 Fl folding mirrors query
- Adblue range 1000km after filling
- P0379 error, DIY to replace V50 electrical coolant circulation pump
- Seicane Headunit - RSNAV Alternative?
- Audi overstock parts site
- Backup Camera issues
- ACC and Audi Braking Guard unavailable - Door Switch Issue
- 2012 A6 3.0T engine droning noise
- Vibration inside car at 1100rpm
- A6 Allroad air suspension problem
- HUD - has bubbles in the cover film?
- If you knew then what you know now?
- Audi daytime light left side not working
- Inside a failed fuel filler actuator.
- How to replace front parking assist camera on 2016 A6 3T Quattro
- latest MMI and Navigation versions are? update?
- NO: Headlight condensation
- 2012 Exhaust manifold
- Parking Assist stopped working
- IE: A6 c7 se to s line bumper?
- EE: Audi A6 C7 3,0BiTDi pre-Dieselgate software help needed.
- A6 humming sound when coasting- Differential? Fluid change?
- Parking heater cabin fan speed
- Am I crazy?
- MMI screen won't fold down into dash after turning off car.
- SD Card not being read correctly for MP3 Music
- Bluetooth
- MMI and center console problem
- Climate control no display
- Engine sounds higher pitched
- Air Intake Temperature Sensor for 3.0 TDI BiTurbo 2016
- No AUX or AMI ports!! - how to add any?
- 2013 A6 2.0T weird misfire issue
- 2017 A6 Rear window spoiler / Visor
- New to the German world and in need of advice.
- Drive modes
- New PCV at 189K miles but still adding 1qt every 500miles
- Bluetooth problem
- 2012 A6 C7 Help Battery
- Intake Manifold running flaps
- Head light bulb question
- HK: Audi a6 c7 2011 coolant temperature always low
- IE: Driver side drl not working?
- NZ: 2012 AUDI S6 C7 SUNROOF STUCK OPEN PLEASE HELP!
- 2016 a6 electrical issue
- 2013 A6 2.0L questions
- HU: ACC and Audi Braking Guard not available
- Headlight cover
- Can Xenon Projector headlights be retrofitted for Directional Beam?
- MyAudi app.
- How to update my MMI
- A6 C7 suspension upgrades
- 2014 - A6 - Premium Plus - Upper Timing Cover
- 120mm BMW wheels on Audi?
- Oil leak after water pump replacement
- Electrical problem?
- Media USB problem
- AdBlue/DEF in A6 C7
- Indicators not working
- C7 Audi A6 3.0T Project: ECSTuning Bumper Spoiler & Grille Accents i
- C7 a6 screen not working
- ACC will not work over 30mph
- Engine mount job
- 2012 A6 prestigue - rear CV Shafts
- 2012 A6 prestigue - rear cv shafts
- parking sensor help
- Audi A6 C7 4G - sq5 engine swap
- Tuning for my 2017 A6 2.0T Quattro?
- Audi a6 c7 ambient lights
- Audi a6 c7 matrix light help
- Mmi firmware and maps uptade
- New Audi owner
- Audi A6 C7 - knock/clunk noise
- NZ: Gearbox Malfunction error P187B 00
- NO: Question about a tpms
- A6 power steering rack
- S Line Versus Sport? Is S line lower or stiffer?
- Class Action Lawsuit against Audi 2.0t TFSI Engine
- New Parking Sensor Issue?
- illuminated door sills
- 2016 Audi A6/A7 3.0 TFSI Path to Oil Separator
- New Audi Owner
- Diagnosing failed supercharged clutch help? P25E9
- 2015 3.0 TFSI rough idle
- AU: Service Interval 2012 A6
- Where do you buy your brakes/pads?
- ACC and road sign recognition conflict
- VIN Holder Part Number?
- MMI connection issue - Please help
- LED headlight wiring diagram
- What's wrong with my A6?
- Firmware Version not showing
- C7 A6 Stolen w/ No Key Fobs
- 2014 pre facelift RMC screen is driving me crazy!
- UK: A6 Avant 3.0 BiTDi.
- Audi leaking coolant and oil
- 2016 a6 tdi prestige s line
- Engine Overheating Warning
- 2016 a6 tdi prestige s line: min wheel diameter?
- 2021 A6 55TFSI
- I need to be able to control MMI programmatically. For example to send button command
- Front Bushing Audi A6 C7
- chip tuning?
- Radio add on mirror phone to unit
- A6 c7 3.0t crank sensor
- 2016 Audi A6 3.0T intake codes
- CH: What are these wheels called?
- ACC camera basic settings
- Where is AMI interface Port?
- Water on the carpet
- 2015 A6 BiTDi dash buttons dont illuminate
- RS6 2015+ rear diffusor to BiTDI s-line bumper
- Headlight Interior Switch
- Decided to sell my 2016 A6.
- HR: TPMS/ESC/EPB/AIR SUSPENSION LIGHTS
- IE: Thoughts on oil sump plug
- Stiff Suspension after encountering a rear light error
- PowerStop Brakes
- CarPlay retrofit options; anyone got any experience with these 5 options?
- Engine Swap Audi A6?
- Auto Dimming not working
- What is this wire for? Rear windscreen
- New ACC camera new problem, ACC and Audi Braking Guard unavailable
- IE: A6 avant rear ARB options
- Fuel sender unit?
- How to remove passenger/driver side footwell trims to pull the carpet?
- ACC and Audi braking guard: Unavailable
- S-Tronic problem. Gearbox overheating
- 2015 A6 2.0 TDI Avant Manual 6 speed - judder
- C7 Auto folding mirrors
- 2012 c7 oxygen sensor replacement help
- 2013 audi a6 3.0T Exhaust
- Sport mode automatically engages 2017 A6 2.0T Quattro
- IE: Audi A6 C7 Auto
- Cluster / HeadUp Display Speed limit
- Overheating, low colant level
- A/C blowing hot air
- Tires for year-round summer (So-Cal)
- TDI Fans – I got $76,098.73 for my 2015 A6 TDI with 146,179 miles
- 64 reg audi a6 2.0tdi 190bhp
- Mapping 4-zone A/C
- 2013 A6 C7 carbon clean?
- oil filter housing/while I'm there
- Lower the tachometer! can someone help me? Thank you! A6 c7 2017 s tronic quattro
- Headliner sagging
- 2013 audi a6 3.0T P0235
- Audi a6 3.0T 2013
- SK: Harsh downshift from 2-1, occasional 3-2 (OB5/DL501, S-tronic)
- ACC camera? Breaking guard unavailable
- Electronic Brake Malfunction
- Sunroof won't catch on track
- Auto Start Stop Scenario: Feature or Malfunction?
- 2000 audi a6 cannot get radio out or find code please help
- VagCom Work - Marietta,Dallas, Roswell, GA Area
- Bluetooth Module Location
- Message Greyed-out on MMI
- Small vibration in steering wheel
- Audio streaming 2012-2014 Ac7 A6
- UK: No A/C?
- 3.0t Supercharger removal— lower coolant in reservoir?
- DE: Help me chose
- LY: Gearbox overheating please adapt driving style
- Retrofit from Audi Sound System to Bose
- Parking system
- Where is the Airbag Modul ? C7 2014
- Ambient lighting
- Build quality
- 2012 A6 3.0T Prem+ exhaust?
- 20" stagger Quattro help. Wider up front?
- RS6 Grill installed
- ACC unavailable fault
- IE: 2016 Audi A6 S line 2.0 diesel
- 2016 A6 P0456
- Choosing a Replacement Battery (non-dealer)
- Audi A6 C7 MMI not responsive, stuck in initializing only
- Increasing Heather Steering Wheel Temp with OBDEleven
- 2014 A6 AC blows hot
- New Project Car Reveal + Upcoming TT vs G35 Race
- Changed spark plugs in Audi A6 2.0 2016 now car misfires when I accelerate
- Car dies after driving for a bit
- UK: Transmission Mount Insert
- UK: Glow Plug Circuit High Issue - Help!
- Headliner coming off from the rear
- How to fix the front door bose speaker in the bottom
- ACC, Braking Guard, Lane Assist: Unavailable! A6
- Head gasket water leak with only 60000km 2013 have to change Why?
- First post: Is it repairable? If so can I get an estimate please?
- BG: Boost pressure regulation, V6 diesel
- TDI MPG IDEAS? Aftermarket Tunes?
- No start - Starter stuck Fault
- 2017 A6 Oil? leak
- Rodents destroy TDI Adblue hose
- HELP engine start system Fault
- Squeky noise coming from front left side of the car
- 2013 2.0T w/ CVT Misfires and Poor Shifting (VCDS Codes Included)
- Repost in correct forum - Radio region JPN to EUR
- Headlight high beam does not work
- NZ: Fold in mirror does not fold out
- UK: A6 C7 Q 3.0 TDI no ignition
- A6 Avant 2.8fsi C7 - Grumbling sound/vibration
