- NZ: Fold in mirror does not fold out
- UK: A6 C7 Q 3.0 TDI no ignition
- A6 Avant 2.8fsi C7 - Grumbling sound/vibration
- ACC and Audi braking guard unavailable
- Rear Sway Bar For Sale?
- Need Help Getting Out of Limp Mode
- Bi-xenon Headlamp electrical connector
- Tired of the "delay and surge" from a stop. Any solution?
- Bad oil leak/spraying after an oil change
- OEM Dynamic Rear Turn Signal retrofit
- Help! A6 C7 headlamp Wiring data
- Bluetooth Problem
- RS6 Grill mod for an A6 diesel?
- Problem vcds coding… Im idiot… please help…
- Help! Extremely unusual P2181/P1889/P2099
- TR: Audi A6 2.0 TFSI Quatto Vibration Problem in D or R
- wheel/brake noise
- Audi A6 2.0T 2014 Timing Chain Query
- Locating a stolen vehicle?
- Nox Sensor and Quattro module
- Anyone running a radar?
- IE: Audi A6 2014 Quattro 3.0L - Software Updates
- different hp outputs
- Where to tap for aftermarket amplifier power?
- UK: A6 Allroad C7 272 PS TDi Aux Belt pulleys and Tensioner
- UK: steering noise issue 2.0 quattro
- Couple of error codes
- Can't fine the part number
- Stuck disc
- Audi A6 C7 2.0 TDI (140kw /190 ps) Gearbox issues
- 2014 Audi A6 Intermittent Hesitation
- SI: full led?
- keyless entry
- Engine Vibrate at Idle
- UK: Audi A6 2.0D quattro 2017
- DK: 2016 FL RVC retrofit?
- Misfire issue
- Ipod integration?
- 2017 A6 2.0T quattro rough 3 ->2 downshift in Efficiency Mode
- 2013 Audi A6 3.0T No A/C; Code for Humidity Sensor and Coolant Circulation Pump
- Brake Pad Warning Light!
- A6c7 air con issue
- Intake Camshaft
- 2014 A6 2.0 0-60 in 8 seconds?
- UK: Clanking/rattle sound when car is on slow speeds
- BG: C7 320 BiTDI + ZF8 jerky gearbox changes
- c7.5 A6 Turbocharger Speed Sensor Short To GND P2580
- UK: Service intervals
- Audi A6 Quattro 2.0 vibrations on idle and full lock
- Help with A6 C7 Error Code Diagnosis
- new wheels
- UK: All dash warning lights coming on
- Extended Service Contract saves the Day
- Strange noise
- Start-stop time out?
- Coolant Leak/Oil Separator
- Car shakes when standing and accelerating
- MMI firmware
- Parking assist now not working
- Accident Help Requested
- C7.5 Thermostat job regrets
- SI: Service intervals and replacements
- MMI screen in always open
- HU: Audi A6 C7 Side Assist Retrofit
- 2012 Audi A6 3.0 starting problem/Transmission malfunction
- AL: Where is located Headlight washer fuse (C7 Europian version)
- Windshield washer aiming
- SI: Req Dataset 4G8907468 0113
- Swapping Sports Suspension for 'Regular' suspension package
- Mojio 4G Upgrade
- Radio problem
- SI: Air suspension and headlight range control fault
- UK: A6 2013 - electrics going crazy- help please
- Lexxson CarPlay and Android Auto Wired/Wireless for 2012-2016 Via AV Input
- a6 c7 2.0 tdi cnha 2015 - starting problem
- Assistance Please! CEO Came On!
- AUDI S tronics jerks while in P
- 2018 A6 transmission issue. Need advice!
- Battery Life?
- Fog mode is active
- Camshaft sensor calibrate
- Audi side assist System failure and ACC and Audi braking guard unavailable
- Blackout plate behind grille logo?
- Rear view camera VCDS
- UK: Knocking noise from front
- Audi a6 c7 bixenon
- 2014 A6 3.0l PCV valve
- KR: Retrofit Standard seats to Comfort Premium seats (ventilated seats)
- Audi A6 allroad 3.0 tfsi 310 hp C7 4G - custom exhaust
- P179D00 Cooling oil valve Electrical error
- Audi A6 C7 2.0T 2013 115k miles burning oil?
- Alternator fault - battery not charging
- 13812 - Exhaust Gas Temperature Sensor 4 Bank 1
- Heating only on one side
- NO: Air suspension fault
- No A/C - G395 or Secondary Coolant Pump
- Radar detector placement
- Rear Main Seal @45k???
- Timing belt chirping sound
- S-Tronic clutch slip?
- SE: Audi A6 2.0 diesel 2016/2017: where can I find a sport exhaust?
- Help with Neutral Idle Control
- Driver Assist Package Lane Departure times out in 10-15 seconds. Changes?
- Just Bought Used A6 / Water Rushing Noise when AC is on?
- New wheels for A6 Allroad
- Is the rear view mirror trim replaceable?
- Does my 2016 A6 use 3G?
- UK: My car will not turn over unless it’s jump started.. and I have a new battery
- A6 C7 platform side assist fault
- Spark Plug Recommendations
- Great mpg
- WEIRD SOUND WHEN TURNING
- Motor mount nightmare
- 2012 A6 prestige misfiring on the drivers side
- Battery date help
- DIY 2.0L (easier than 3.0L) motor mount replacement, A6 C7
- 2017 A6 C7 3.0 mirrors won't fold in automatically
- Scary rattle noise
- Audi drive select modes
- 2018 A6 2.0 valve cover gasket
- Does this look like a leaking, cracked motor mount?
- Green menu a6 c7 adaptive air suspension
- SI: Quality of materials?
- Dashboard and MMI dead 2013 A6
- 2016 audi a6 C 7.5 3.0t quattro abs, tpms, parking, and headlight range control light
- Audi a6 '12 3.0 p0416
- 3G Shutdown...what will I loose?
- Sound system upgrade
- AU: Oil on spark plugs?
- rain sensor wiper
- Oil in one cylinder
- Audi A6 C7 2012 ACC camera problem
- Audi a6 2.0T or 3.0 supercharged?
- Rear light issue + few others
- Audi Connect/T-Mobile 3G Sunset Update
- TDI Settlement Update - Check Your Mail
- DE: oil and water temperature display in HUD?
- ACC and Audi braking guard: not available
- Diagnosing bad PCV valve, how much suction should there at the oil cap?
- P1893 - Signal Line For Gear Display On Selector Lever
- Adaptive Cruise Control not working in cold weather
- Dash cams
- Selling Advice?
- Bypassing the Engine Oil Cooler on an Audi A6 / C7 (2014)
- Weird rattle at low speed
- Coilovers without lowering?
- WPT tuning for the gen 3
- 2013 A6 Rear End Clunking
- turn signal wire
- Ticking sound?????
- Help with some aftermarket mods
- Audi a6 engine mount
- 2014 A6 Rear Climate Controls--mostly dead
- Prices?
- A6 won't start. Will OBDEleven find codes if not?
- UK: Looking for Help as a Noob Who is Looking to Buy a car
- A6 C7 ACC, lane assist and aux. heater problem
- Parcel Shelf Not Working?
- Audi replaced Water Pump, now says its a Head Gasket
- Mmi system upgrade
- Looking for dipstick!
- Backup Cameria
- Intermittent rear indicators
- 3.0TDI hissing under acceleration
- DE: Audi A6 allroad 3.0 tfsi 310 hp C7 4G - wheel fitting
- Need to get by disk and pad change. can anyone give me some input?
- Rotor Size?
- Massive Oil Leak
- Led Headlight r
- Stiff Suspension on stock C7? Looking for stock OEM replacement perhaps?
- Audi a6 navigation update
- Removing RMC Head Unit
- A6 Thermostat Replacement
- Dashboard light up like a Christmas tree after start
- navigation update
- Keyless Entry
- navigation system
- Car wont start and batter voltage at 10v
- A6 Allroad-Europe- Springs? Want to lift my C7 A6 sedan. Will that work?
- Maintenance Due
- 2015 A6 3.0T - MMI Not Displaying Text Message Option
- A6 2014 Navigation not installed?
- MMI Replacement and Trunk Latch Replacement
- Headlight
- 2015 A6 CarPlay/Backup Camera- Recommendation & Question
- How do I remove the DPF?
- Clutch Pedal Switch for Engine Start (F194) Fault
- AU: 3.0T fouling spark plug
- 2012 A6 shifter issues
- 2012 A6 disconnected hose?
- A6 2.0T Slow acceleration
- No heat or air coming out front center and rear vents
- S4 B8 Muffler on 14 A6 3.0 C7?
- Ignition switch relay stopped working
- SA: Audi A6 Overheat and Max Eng 950 RPM!
- c7.5 CarPlay update question
- 2017 Fuel Door Actuator Part
- A6 c7 no sound from the speakers
- A6 Allroad C7 Panoramic Sunroof Issue(s)
- A6 3T Stage 1 tune future reliability
- 2018 audi a6 2.0l exhaust
- Oil Filler cap leaking oil-possible
- Kind of regular clunking noise around 80km/h
- 2016 c7.5 A6 water leak
- Trouble Code P253900
- 2014 A6 - Steering Warning Light
- Headlight problem
- 2013 Audi A6 3.0T Rear Heated Seats Problem
- How do I remove the rear seat?
- Bluetooth looses connection
- Squeaking sound when stopped
- Disable AFS adaptive headlights on C7?
- Coolant Temperature Issue
- Quiet tapping/popping noise coming from front suspension or engine bay
- Front parking sensors stopped working all the sudden
- 21583- Loss of crankshaft synchronization
- A6 C7 2.0 TDI CNHA: High consumption on IDLE and bad smell
- Speed Limit display: outside operational area
- rattling/clicking noise when braking
- Screen/Radio shutting off and turning on
- Technical qs.... right side loom from A pillar
- DIY Engine Mount Job
- 360 video cameras inop .
- Hard blow from the exhaust (like a fan)
- Replace tensioner when doing alternator belt?
- Prelude to Transmission Issues
- FI: Installing a fixed battery charger (DEFA Multicharger)
- Glossy or matte roof racks
- Join us on telegram chat for c7/7.5 platform
- 2013 Audi A6 3.0TFSICoolant System: Fault Turn Off Engine"
- Protective Flaps/shields for Steering Rack tunnel
- 2016 s6 remote start
- MMI firmware upgrade?
- 3.0 TFSI CGXB vs CTUA Engine compatibility?
- ACC Not available Help
- AT:MMI Emergency Flash Utility
- EGR cooler replaced - coolant leaking and problems (A6 C7 2.0 TDI 190 hp)
- Problem a6 RMC
- A6 C7 pre-face lift to facelift
- 2014 Audi A6 C7 cluster stopped working?
- IE: Help… 2017 Audi A6 …
- 14 A6 TDI to a 16 TDI feels much stiffer? Any changes in spring ratios with 16?
- ES: FALLO GPS 0 SATELITES A VECES
- C6 or C7?
- Retrofit Apple CarPlay
- Main beam HELP!!!!
- LED light upgrade
- HVAC fresh air/recirculation air flap motor adaptation
- A6 2016 Electronics Keep cutting off mid-trip
- Mapping/GPS dropping favorite/home settings
