- Rear Passenger Seat Belt Buckle Rattle
- DE: A6 C7 2.0 tdi 190 hp, check engine light on
- Gauge Cluster lights
- Rotor Recommendations?
- audi a6 3.0t maybe leaking oil out of Exhaust
- what is this?
- A6 4G2 2.8 V6 204 BHP Clutch friction plates replacement
- Fuel fill-up keeps clicking off
- TCU for C7 A6 8-speed Tiptronic?
- Extended Warranty Question
- Is this diesel sound OK?
- Transmission Jerking
- 275/35/20 Tires Fit the A6?
- Rear Rotors Warped
- IE: Please Help A6
- A6 C7 Rear View Mirror Question
- Cup Holders (frivolous)
- 2012 A6 issues - P0691 MMI display..need advice
- C7 with APR Stage 1 and going to the dealership
- Crazy Question: Can an A6 be lifted slightly for better ground clearance?
- Key fob not working
- Installed my Thule Rack
- Need help fixing my sliding ashtray compartment lid
- Cold Air Intake for 3.0
- New to Me A6 3.0!!
- Engine Making a Ticking Noise: 3.0T
- Need Car Cover recommendations
- Central locking problem
- P0018 Code
- Engine Temp Climbing Toward Redline - Maybe thermostat?
- Hello everybody! motor mounts on A6 with 36k miles!?
- My New (to me) A6 Competition
- UK: Map Updates Edinburgh
- A6 C7 2.0t Timing chain or belt
- IE: Ad Blue Fault Alarm and Engine Check Light
- 2013 A6 C7 Allroad — CV Joint Replacement
- UK: 2016 A6 avant - fuse mistake
- UK: Engine tapping noise, diesel
- Right Adaptive Headlight/Main Beam Headlight Error
- All lights on the dash are coming up every morning
- Terrible recent Audi decisions (killing the supercharged v6 & releasing quattro ultra
- Trying To Soften & Raise a Sport Suspension With Tire Change
- Remote Key Not Working
- humming noise seemingly from rear, only heard while inside car
- Coolant Leak in footwell
- NO: Occasionally Distorted R Front speaker sound (a6-c7, non-BOSE)
- front brake chatter
- My Audi Mobile Access Problem
- MMI screen stuck
- UK: Updating MHi2 firmware
- almost bought a A6 2016 2.0, but
- IE: Sat Nav Audi A6
- UK: A6 engine seized(?)
- Audi A6 2015 MMI problem
- Audi A6 C7 arm rest cover replacement
- A6 C7 weird behavior
- 2018 A6 Quattro Sport Engine Air Filter
- A6 3.0 acceleration whine
- How to disable the auto up-down of the rear window shade?
- SI: Car does not start - signal problem?
- Heater Exchanger Options
- Thermostat / Crossover Pipe leak
- UK: Please help! P00af00, diesel
- S4 vs A6 vs S6
- Wheel hub threads damaged?
- Whine from Auto Gearbox
- Car does not start sometimes
- Battery died and key not turning
- Motor Mounts replacement A6 2012 3.0T
- Audu a6 c7 rear camera glitch
- Pine cone Stash In Engine Bay 2017 A6 3.0
- Leak from underside
- Replace Steering Wheel Logo
- Dashboard Air Vent
- AL: Is this exhaust noise normal when accelerating ( A6 C7 2.8 FSI )
- Parking sensors stopped working because of old battery?
- Dash and screen upgrades
- Clutch and flywheel replace
- BOSE 14 Speakers - where are they?
- Parking Brake Malfunction after rear pads replacement?
- Passenger Turn signal + brake light not working
- Potential new purchase
- Audi A6- Adblue cap stuck
- Glove Box Removal?
- Audi A6 C7 2.0 TDI Stronic knocking noise
- Headlight dead driver side
- Belt squeaking?
- Coolant pump B circuit open 261A00 confirmed A6 2014
- Runner flap stuck closed
- RMC -> MIB2 Climatronic panel & Turbo/supercharger
- Low Power on 3.0tfsi 2012
- Spare part code for lashing strap in the trunk?
- IE vs ECS Intake Help
- 2018 3.0T Tune?
- Need help ASAP??
- Max engine speed 4000 RPM
- MAP Sensor
- Body Shop recommendation Denver
- Trying to understand dynamic/comfort.
- A6 3.0 Intake Options?
- Steering wheel replace
- Break pad warning broken
- 2014 versus 16 wheels- 19 inch- Wheel Weight?
- A6 C7 Exhaust Recommendations
- Error during Clutch valve calibration 0B5
- Mechatronic won't come out, connector housing is stuck
- Sat Nav Issue
- RO: Basic Settings (VCDS) S-Tronic 0CK DL382 ???
- S-Tronic 0CK DL382 problems
- Replacing Front Upper Control Arms W/Out Removing Strut
- Looking to put RS6 back exhaust onto my 3.0 TDI
- PL: Decoding passanger occupancy sensor?
- Custom gear shift knob for my Audi A6 C7
- A6 C7 3.0 Supercharged supercharger difference
- Replacing 18" with 20" wheels....what can I expect?
- Audi A6 c7.5 Speedo.. Climate Controls & Steering Wheel Buttons DEAD!!
- EE: Audi a6 3.0 180kw
- A/C still doesn't work after replacing pressure sensor (G395)
- Post Diesel Fix 2016 versus 2014? Any difference in smoothness? Might go fr. 14 to 16
- Radiator Fans pulsing on and off and not keeping cool
- Stolen battery and cut wires. A6 premium Quattro 2.0T 2015
- Who puts 3 kids in the back seat of their C7?
- Front Suspension Rattle / Clunk - Brake Pads!
- Exhaust on A6
- A Warning to Golfers
- 2013 A6 Door Handle Sensor
- RO: A6 C7 3.0 diesel 272HP shaking at startup - need help
- New to Audi, help with purchase
- UK: A6 3.0TDI C7
- Rear View Mirror A6 Quattro 2013
- Front coil springs
- 2018 A6 3.0T Sport - Rotor Replacement Question
- Back in the A6 family - 2017 A6 3.0T
- 2017 A6 MMI Mib2? Updating maps?
- A little assistance please. (cooling issue)
- DK: multiple errors?
- AU: Anyone else had an electrical fire?
- 2017 A6, Extended Warranty Question
- Seating position
- Calculated Range in Miles based on Tank Level
- Space Saver Spare Tire Replacement
- UK: C7 Auto box issues
- Audi A6 TDI versus BMW 540D?
- Parking Aid Sensor
- Oil consumption on 3.0T?
- Drivers Side Motor Mount DIY
- A/C codes, can someone look and help?
- Audi A6 low speed grinding noise (front left wheel, no brakes applied)
- Battery replacement and code change
- Replacing battery and code change
- Oil Cooler Bolt Part Number.
- Features not working
- C7 inner tail light assy disassemble
- Electrical component not turning off
- Make lighter sockets work with igition off?
- 3G Sunset
- Noise when car starts for a second after oil change. HELP
- A6 Coolant Issues
- Spark Plugs
- A6 2017 Front Camera
- 2015 A6 3.0T Engine/Maintenance concerns?
- Engine EPC light
- SI: Audi A6 2017 wider wheels?
- Pet peeves on the C7.5
- CY: Nothing written on mmi display?
- Latest MMI?
- Does A6 C7 Avant tail lights fit sedan A6 C7?
- Finding a trunk spoiler
- Water Buildup in Drivers Side Footwell - front and back
- Adaptive Air Suspension Retrofit
- Tuning, Maintenance, Longevity & Reliability
- Audi TSB for False Coolant Pump Malfunction P1B1C00
- 1995 A6 2.0 SE All Four Windows Stopped Working
- Audi a6 c7 3.0 TDI 7g s tronic problems
- Andover, MA Cars Coffee Tomorrow
- Dashboard lights
- Voltage in back seat 12v outlets
- 2016 A6 C7 2.0 TDI 190 S-Tronic: P 2002 Help Needed
- Audi 3.0 TDI Quattro
- A6 maintenance and longevity?
- Squeaky shifter (manual) juddery 1st gear on pull away
- 2 inch trailer hitch receiver options
- Car doesn't know it's in Park
- HEADLIGHT SWITCH ELECTRICAL DIAGRAM COLOR CODE?
- Egr delete with only tune?
- Blow off, Diverter or Wastegate???
- You are a very unique group of Audi drivers
- Left mirror indicator barely/not working
- 2011 and engine swap
- Feeling uneasy about cost of repairs, should i fight or pay?
- Back to Audi but New to Leasing
- Two phones: First - Android Auto for maps and Spotify, SoBluetooth for calls
- Intercooler upgrade with dual pulleys and ecu tune?
- A6 TDI TPMS SENSOR
- Help with troubleshooting
- SE: So many trouble codes! Help!!
- Facelift models
- Need help identifying a sound
- Need Advice - Engine Required Additional Oil
- Tire recommendation?
- Fuse boxes
- Longevity of OE Battery?
- C7.5 2.0T Structure-borne Sound retrofit
- Rear Window Roller Blind Retrofit
- Is a 2018MY A6 in the US the C7?
- 2.0T Tiptronic shifts slow unless in Manual
- Performance Brakes for A6 ???
- Audi A6 c7 blank flip screen not working
- Headers on 3.0T
- Oil Change Schedule?
- TDI high mileage car?
- air suspension grayed out raise or lower function
- UK: Transmission circuit failure
- Coolant system Fault message
- 125,000 miles and going strong
- Alternator not charging A6 C7
- VW remote start retrofit
- Reading errors
- Direct speaker replacement for non bose
- Engine hesitation at around 1500 rpm
- Repair Shop/Mechanic in Bay Area Recommendation
- Audi A6 C7 2017 JackSet
- Audi A6 rear diffuser
- g37 throttle vs A6 3.0 throttle
- Audi A6 c7 lowering springs
- Say hello to the A6 e-tron Concept
- C7 Allroad does not raise suspension in allroad mode.
- A6 and Q7 floor mats - are they the same?
- Has anyone used Camber Bolts to adjust camber on an Audi A6 C7?
- US Looking for input RE: Dealer Warranty for pre owned 2016 A6 2.0T
- Diameter of anti roll sway bar 4G0411309E?
- Rear wheel bearing and hub
- Used A6 maintenance tips....
- Rough Idle just went over 100K is it motor mounts?
- 2013 Audi S6 Has been Down Since October 2020 Please Help
- How difficult is it to install a cold air intake into a C7 3.0T?
- Heater problems
- Vibration when braking but not brakes
- Repairs and Preventative Maintenance North of 70,000 Miles
- is it possible to switch off auto mirror fold ?
- Transmission Trouble
- MMI cable for old iPod 3rd Gen Firewire
- Sell Your Gas Powered Audi Now
- C7 avant air compressor and relay
- 2017 Audi Connect features questions and issues
- Headlight Washer Cover
- AC Behavior
- diagnosing error code on 2014 A6 im looking to purchase
- Key fobs resync after car battery failure
