- Rear brake job
- Help! Advice/info on converting 2.3NG to EFI???
- About to buy a 96 cabriolet
- e brake conversion
- Engine block coolant drain plug
- central locking system
- newbie got ?'s about quattro rear wheel bearings
- insturment cluster lights
- Alarm-related Electrical Problems
- Sport button
- DIY information
- finally took some pics to share
- I am looking for timing belt tool kit
- Trans fluid question
- Your iMPG ?
- looking at a '91 Coupe in need of a tranny. been out of the game for a while...
- Audi part # question
- Water temp gauge not working
- 96 Cabriolet compatable AFC engines
- 1995 90 QS Rear Tie Rod
- Anyone have an extra door lock / latch
- cs quattro mods
- 90 20v charcoal canister
- '91 CQ Door Panel - Space around door handle frame when vinyl is removed
- Clutch Pedal Adjustment?
- Parts shopping for 95 Cabriolet
- New 1995 Cabriolet
- WTB: Trailer hitch to fit 1993 Audi 90 Quattro (B4)
- FS: 94 v6 12v cs Q with k&W coilovers cheap
- power steering fluid leaking through cap
- my new nightmare
- Convertible Top Stopped Working
- Problems with no answers in site
- selling my 90 cs Q
- radiator help
- timing belt question
- water pump and timing belt replacement help
- Hello All
- 1988 80 Quattro misfire/stuttering when accelerating
- My new audi 90
- was it someone here who hooked my up with LEDs for my temp gauge?
- parting out a 93 90.. please leave requests for parts...
- Roof wont come down
- Cabbie owners: Discovered water in front passenger footwell after heavy rain on Sat.
- was adjusting fuel/air mixture and got this code
- 90K maintenance costs?
- Winshield Washer Tank Access
- Window Regulator Replacement
- '98 cabriolet joins the family!
- Transmission seal leaking on drivers side
- i tested my o2 sensor and got this.....
- 1994 Audi Cabriolet 12v 2.8L oil cooler?
- Headliner Replacement - DIY or not?
- Fuel Guage not working.. speedo almost.
- Front drivers side axle seal leaking
- FOG LIGHT MOD
- idling high Audi 80 1996
- how do i make just the fog lights turn on?
- Rear alignment adjustment
- Which engine is the fastest??
- 1989 90 Quattro Tension Idler Problem.
- 1989 CQ 90 FOR SALE
- Sell the car w/ a busted heater core or repair before selling?
- Here are my emissions test FAIL results!!! Your advice needed...
- Parting out 1990 CQ black/black
- To find the impossible part...
- Opinions on Bentley manuals?
- i got stuck!
- Replacement exhaust for B4 90
- 1995 90 with 190K shuts down
- Will this ever stop? Or shoot me now...
- picture friday or my bumper is here :-D
- Hot spark plugs,,,,need part number......
- Fuel Line leak!
- audi 80 bumper
- 1988 80 Q - What Kind of Coolant? Do I Need to Flush It?
- B5 A4 Sport Wheel Swap Questions
- Audi 90 Speedometer issue
- Need Help, my 1995 Audi 90 AC compressor is acting up
- :: ECS Tuning :: Audi 90 Brake Rotors $19.95!!!!
- Looking at a 90 QC, have a few questions.
- Vandalism. Anyone have a spare tail light?
- Clock not working
- Replacing timing belt - can't get the power steering pulley off for the life of me.
- Fun with the odometer
- loud grinding noise in gearbox and also no lights, indiactors etc
- Please Help! I need to locate the relay for the window and sunroof.
- Air bag light on for 2 minutes on 1995 90
- is my ISV dead????
- Selling 1988 Audi 80 (not Quatro)
- Driveing with rear differential locked
- Timing mark, where is it ??? Please Help!!!
- Selling my springs
- (Possible) Product Review: Volo VP12 Performance "ECU Soft-Flash" Chip
- Pictures of your Quattro in action
- B4 transmission / clutch DIY
- Windows, sunroof stopped working
- Transmission Removal
- To good to be true?
- Gear select display
- Calling Audi World members need some advise
- Question about front suspension interchangeability
- kau 3 speed trans
- Key Battery type/size 1994 90Q CS
- Aftermarket steeringwheel w/o airbag
- strange noise and alternator question
- Where does this wiring harness plugs in to?
- Self inflicted mystery...
- How to remove clip that holds
- 20v Throttle issues
- new rear wheel bearings causing problem?
- New front rotors vibrate when stopping as well as car shifts LEFT when they are wet!
- anyone got a Carfax subscription right now? Run a VIN for me please ?
- 1993 80 Vacuum leak under dash
- Where to buy an Auxiliary Fan Resistor Pack?
- I Really Need Help! New 80 quattro Cranks but Will Not Start!
- Need Help Bad!!!
- cabby on ebay in the northeast
- Cabbie Transmission shifting early, near-stalls, etc.
- I miss my Coupe
- smell coolant when flooring it, heat works fine
- '91 CQ Valve Cover Gasket Leak
- If it's really cold out, does the AC stay off?
- 1988 80 quattro Won't Start
- 95 audi 90 quattro tranny problem
- 1995 90 heater core or hose leak?
- Fuel problem - Going crazy!
- Need wood trim for '95 Audi 90
- Where is fuse S74 (circuit control box)
- Where can i get koni's??
- BUMPER NEEDED
- accident
- 1995 Audi 90 Sport Ecm/ecu Help
- Fog light switch
- Headlight
- about to try DIY alighnment
- Front of Engine Oil Leak after Timing Belt Change
- Fitting woodgrain/carbon trim to standard door cards
- 93 90 climate control swap
- Goodbye Soft top
- 80 cabrio roof latch probs....
- Car turning over, but won't start
- radiator fan running constantly in cold weather..!
- Fender flares.
- Bowden Cable Source
- my latest purchase/headache
- Cleaned my injectors
- a question of value?
- 93 Audi 90 wont start??
- Anybody want to sell "The Audi Quattro Book by Dave Pollard"????
- SoCal Pick and Pull Yards with Audis?
- 1996 Cabriolet
- new door mouldings for Audi 80
- New 1990 CQ owner!
- driver window regulator
- 034 transmission mounts came in
- Oh happy day, fixed exhaust = return of the torque!
- FS: 1994 90cs quattro sport + parts
- HELP PLEASE.!!!
- I'm Obsessed!
- Car shut off mid drive
- Need Help: Low Fuel Pump Voltage???
- parting out: '93 90 fwd auto
- Car Was idling with old fuel filter
- keys
- 92 80 quattro fuel filter
- First drive, problems, questions , impressions
- Abs sensors
- Fuel Filter
- Been a long time
- Bentley Manual
- Help What Did She Do???
- fuel level sender repair
- 1995 90 wont idle first couple mintues
- Remote Start CQ20V 1990
- Thermostat troubles - with a twist!
- audi 90 idle issue.
- Fix Cabbie or just sell as is?
- 01E 6sp in a B4 qustions?
- Wiring Diagram - Anyone have one to share?
- 95 audi 90qs - No start
- Was 80q barely runs. Now weird results from FI computer output tests
- Center Brake Light On and Parts Cars Available
- 1995, 90 quattro
- finally! steering wheel install...
- Oil Filter, which?
- Valve tip height?
- Compression Tester
- 88 80q 2.3 i5 NG barely runs. Help!?
- Hey socalclimber
- Audi 90 V6 heater blower motor not working
- DIY - replacing B4 clutch master cylinder
- Selling my 95 90q + 94 90 parts car. $1250. Timing Belt broken
- Bored and need ideas!
- 1990-91 Audi Coupe Quattro
- Transmission not going in to gear?
- Tranny removal procedure?
- Gunk in the breather hose
- HELP!!!
- Digital HVAC controls on '91 CQ?
- Gamma volume problems...
- Replacing Rear Window?
- MAF sensor differences - '93 vs '95?
- FYI: Gamma radio code for your Audi for free...
- clutch problems x-post
- 1990 - Audi 90 Instrument Cluster
- Need parts for '88 80 Quattro
- B5 to B4 column switches adaptation questions
- Thermostat question
- Happy Holidays guys!
- Replacing rear calipers. Bleeding ?
- Message to socalclimber
- stick is moving
- Heat/cooling issue 90CQ
- Can a stock alternator handle 4 driving lights?
- cleaned my intake/gas consumption experiment
- Fuel distributor issues, such fun
- ITS FINALY SNOWING!!!
- audi newbie
- fuel distributor question
- fuel distributor '90 80 series
- 90 CQ rear tailight wiring assembly needed?
- cold start issue- 1990 80 series 2.0
- Wipe it off...
- seats
- coolant/water ratio
- please help with lock cylinder
- Driver Door wont close
- 93 90 Quattro - 4 to 5 lug conversion?
- WTB: 1993 Audi 90 Quattro AAH V6 parts
- Busted gray connector hanging on driver's side
- Good vacuum line diagram or where to find in Bentley DVD?
- Quieting manual gearbox whine...
- solenoid change-over valve clicking
- 91 CQ antenna
- Picture Friday: Looking at weight distribution....
- cabby for sale in northeast
- Audi Quattro Concept is Amazing! Light Weight High Performance...
- help for Audi 80 fan
- Is there anybody out there...?
- Euro headlights
- 97 Cabriolet Climate Control Head
- Timing belt, thermostat and waterpump replacement - does anyone have the tools?
- who needs a truck when you have an audi 90?
- Which spark plugs for my AAH?
- climate control problem, no heat
- '95 90 Quattro - Wiring connector colors - HELP
- '89 90 quattro warning light/symbol?
- MAF sensor cleaning
- Wanted to post one more time before I send her to the scrap yard
