PDA
View Full Version : Audi 90 / 80 / Coupe quattro / Cabriolet
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258
  1. Catalytic Converter!
  2. Noise from Trans - Concern?
  3. new guy
  4. Euro healights wanted for standard 90 CQ (Not S2 as in last post)
  5. FS: Set of Borbet Type B w/ Falken FK451s
  6. vacume problem!
  7. Vag-Com issues
  8. '93 90q. How Can I Lift It?
  9. Tips for buying a 1988 90 quattro...
  10. Book Ordered!
  11. Fuel Injector Cleaner
  12. Where to find Audi 90 q 20v Fuel Injectors
  13. 10V Timing marks!
  14. Interior fan quit on my CQ
  15. How difficult is it to replace clutch slave cylinder on B3?
  16. Very specific symptoms - smoking and clunking
  17. Help! 90 Coupe not starting when warm, only cranks but no start
  18. Anybody know where to get a 1995 audi 90 intake kit for the 2.8 v6?
  19. found great price on brakes!!!
  20. Cab tie rod replacement
  21. Ignition switch or starter?
  22. No Clutch Pedal, master or slave??
  23. USELESS!!!
  24. Questions regarding EURO parts on NA cars??
  25. Gentleman, need the location of the check valve on a 1988 B3 please!
  26. What're the thoughts on ceramic brake pads for our cars?
  27. Interior Trim - NEED help!
  28. Fuel Pressure/ Starting issue
  29. Where is the water temp sensor (not switch) located on a 1988 B3?
  30. Who has euro bumpers they want to sell me?
  31. 95 Audi Cabriolet - want to change the rear window
  32. oil leak
  33. Clutch Replace Coupe Quattro Upper Trans Bolts
  34. Trying to find a passenger side tail light, having no luck
  35. Newbie Audi 80 2.6 cold start problem
  36. Audi 90 melting bulbs?
  37. Seriously considering "lowering" my Audi. What all is involved?
  38. Heater issue, maybe a short?
  39. "ABS OFF" lights up and headlights dim
  40. Cabrio Radio Removal
  41. Tie Rod Bushings
  42. "Anti-Lock Off" Stalled my car's engine!!!
  43. Can't shift out of park when engine is on
  44. Clutch pedal sticking down
  45. Need ETKA diagram identifying location of turn signal/emergency flasher on B3. PLEASE
  46. Help me identify a part
  47. Another instrument cluster/ bulb question. Still no lights!
  48. Well guys, fog lights are back only if I remove 2 different fusues???
  49. Instrument Cluster for B3:How many bulbs do I need (total) and what color?
  50. common A/C leaks?
  51. 95 Audi Cabriolet - cruise control not working
  52. fog lights trade from B3 to B4???
  53. Audi Coupe Quattro Rear Damage
  54. Fog lights fuse keeps blowing on my B3!!!
  55. audi 80 coupe help please :)
  56. What is code 2142?
  57. Mystery "connector" leaking lots of engine oil????
  58. 95 Audi Cabriolet - Seems slow
  59. another ow crap... fender liners
  60. 80 quattro autocross setup
  61. Audi 80 4cyl distributor?
  62. New Audi owner
  63. More juice out of my coupe
  64. Audi 90 vs Audi Cab
  65. Where is the turn signal flasher and the Hazard lights flasher located on a B3?
  66. fuel pump
  67. Turn Signal Flasher on B3?
  68. shifting problems
  69. 90q Airbag light on
  70. A/C RECHARGE HELP...
  71. 95 audi cabriolet shift selector lights not lit
  72. 95 audi Cabriolet sometime stalls when idling
  73. Itermittent Power windows... help needed,
  74. B3 Torque Setting for Knock Sensor???
  75. Newbie saying hello with a fault
  76. Bogging 90 Coupe
  77. Knock Sensors for B3 1988
  78. anyone got a set of S2 or RS2 headlights they would like to get rid of?
  79. who had the audi 90 fender on their cabrio?
  80. Hardtop for my cabrio. HELP NEEDED
  81. Cooling Fan Relay on B3
  82. Bad Valve Stem Symptoms?
  83. Last weekend's meet
  84. Radiator support
  85. who was installing an RS2 replica front bumper from ABS plastic?
  86. Which Coolant pressure tester for my 1988 B3???
  87. 95 quattro-a few questions
  88. Car nearly stalling after startup
  89. Just bought my first B4!
  90. How do I test my 1988 B3 for codes?
  91. 4.2l in a cabriolet.
  92. 1994 Cabriolet Idle Speed?
  93. 2.8 overheat!
  94. brand new front bearings
  95. Car in dire need of engine upgrade
  96. S2 bumper on cabriolet question?
  97. Update to "Poor Man's B4 Rear Upper A-arm Inner Poly Bushings..."
  98. Hubs for audi cabrio
  99. Does the B3 sunroof tilt up?
  100. well... $HIT... just got in to an accident...
  101. How do I remove the metal stud on our white plastic clips from door moldings?
  102. need someone to buy suspension for me
  103. Anyone have an S2 bumper they want to get rid of??
  104. Tips on replacing temp sensor on 90 coupe quattro
  105. Diluted (50/50) or full strength antifreeze???
  106. [BRAKE] Light comes on in CQ
  107. what an experience tonight..read on
  108. Crazy Idea
  109. Removal of outer cv joint (nut style)
  110. 1994 audi 80 coupe alarm
  111. My 2.8
  112. my 1990 cq troubles me!!!
  113. Will a b3 lower dash cover (cubby) fit a b4?
  114. Where the FUHHH
  115. leaking fuel lines?
  116. climate control & intrument cluster back lighting
  117. 1994 audi 80 coupe
  118. tranny fluid change??
  119. gauge cluster malfunctioning
  120. 89 audi 90 quattro
  121. 89 audi 90 quattro
  122. What diameter sizes do I need to replace vacuum hoses in my 1988 90 quattro?
  123. Thermostat/rad replacement
  124. audi 80 warning signs meaning
  125. 12v for 10v engine swap?
  126. Where is my knock sensor?
  127. HELP!!! Low beams don't work but high beams are fine
  128. tach wiring????
  129. audi coupe problems?
  130. '95 12v octane
  131. 4 wire to 3 wire MAF swap voltage question
  132. Need a CBR tranny, or what else can bolt in?
  133. need suspension big time help!!!
  134. Cabriolet Rear Window Replacement (for posterity)
  135. hi here
  136. Tie rod or sway bar problem
  137. P/N's for 1990 CQ controll arm bushings???
  138. 2 control unit relays?
  139. NO A/C!
  140. lost spark!
  141. seatbelt
  142. Cluster, nozzles, antenna needed - 98 Cabriolet
  143. New (to me) coupe... now what?
  144. Coolant guage lines??
  145. Ronal 7x15 with 45 offset on a CQ?
  146. Car Photography
  147. 20v runs like poop... help!!!!
  148. will a 1.8t bolt to the 20v and 12v trans?
  149. Anybody have a parts car? I need a driver's door latch.
  150. Car Wont Start! Need Help
  151. wood trim/repair?
  152. still newbe
  153. HELP with 034 A-arm bushings....
  154. radiator fan
  155. FS: 1988 90 Quattro Southern California
  156. What are the "telephone cord mod" and the "egr mod?"
  157. Engine coolant temperature sensor
  158. New look
  159. cover that conceals the rag top
  160. couple quick questions
  161. Will the B4 bumper fit on the CQ....
  162. Cold Natured
  163. 90 90 20v has big problems HELP PLEASE!!
  164. Just got a 90 90 20V - pics inside
  165. 1993 90S Radiator/Blinker/Wiper Fuse keeps blowing
  166. Having some problems with my 96 Cabriolet
  167. Seafoam or decarbon technique from my own experence
  168. City Mileage vs. Highway Mileage
  169. Anyone bought the clear B4 turn sigs off Ebay?
  170. air mass meter
  171. RWD instead of AWD?
  172. Changing power steering fluid. How to drain?
  173. alternato replacement does not require removal of bumper!!!
  174. Looking for a wiring diagram for a 1990 CQ
  175. RS80 still alive!
  176. Audi 90 rear upper control arm bushings replaceable?
  177. Engine hydrolocking after fuel dist. rebuild
  178. I found a AUX GUAGE set at the local yard today.
  179. Listed my Cabriolet for sale but can't edit details?
  180. AC didn't start up on first hot day this year.
  181. turn signal issues in a B4 90
  182. springs for my cabriolet??
  183. Mystery check engine light on 90q
  184. s2 sedans
  185. FREE 12V V6
  186. Two questions regarding...
  187. expansion tank sensor disconnect???
  188. Backlight on switches (defroster, heated seat, ABS off) Is it repairable?
  189. Where can I find steering wheel like that? (pic inside)
  190. MC-1 80q Tech help needed!!!!!!!!!
  191. steering wheel upgrade 90q for 01's4
  192. Euro plate portion (rear) wanted
  193. 928 Porsche rear calipers???
  194. Body kits???
  195. audi 90
  196. OK... One last job (I hope)... before summer
  197. Part numper please? [black leather shift boot]
  198. Shifter Slop
  199. Looking for some euro lights
  200. Cabriolet shimering upon acceleration....
  201. Wheel Bearings
  202. Passenger side visor removal [How on earth..?]
  203. Fluid reservoir for '97 cabby convertible motor
  204. I need the panel behind the passenger headlight ....
  205. An Interesting Cabriolet Transmission Issue (that actually might not be...)
  206. Anyone got a used Fuel Distributor for sale?
  207. 1995 90 Quattro Subframe compatability
  208. For the High Flow Airbox mod....
  209. Reasonable setup?
  210. Spark Plugs
  211. oil drip fixed
  212. 90 CQ speedline wheels question.
  213. Right turns, "Card in the Spokes" noise...
  214. 1997 Cabriolet front bearings
  215. 1990 coupe window relay (Driver's side)
  216. Propshaft U-joint
  217. Need a pic of relay 1993 Audi 90
  218. Huge Coolant Leak! (B4 90 quattro)
  219. Audi 90 gas tank vs audi cabriolet???
  220. few thingsd on my 90q v6
  221. New to the AudiWorld forum - '98 Cabriolet
  222. Need OEM black floor mats for a '98 Cabriolet
  223. Need Right Outer Tail Light for a '98 Cabriolet
  224. Headrest Compatability
  225. Who has replaced their fuel lines under the car?
  226. Beachin' B4
  227. '98 Cabriolet Power Antenna mast replacement
  228. Anyone with a pass. side Hella fog 4 sale?
  229. I need new door glass ...
  230. Cel light/front windshield or windscreen whichever ya preffer call it
  231. Turn Signals Stopped Working
  232. Quirky Problem
  233. 1994 quattro rear struts
  234. Current source for all metal radiator?
  235. Do B3 rear lights fit B4 ???
  236. 1998 Cabriolet Remote Issues
  237. The 90q hits Florida...
  238. cq spring rates
  239. Rieger RS2 Bumper on B4 Audi 90
  240. cabriolet bumper 1998-2000 fog lights
  241. Does anyone in Ontario have a set of rims for sale? (B4 quattro)
  242. Hub Conversion Opinions
  243. Dang it !! I snapped a bolt...
  244. Need some help! Engine shut down ...
  245. oem brake kit front and rear
  246. 4x4.25" Wheels on a CQ
  247. 1994 90cs not starting [one clarification]
  248. "OK" screen on cluster
  249. Intro - Test Driving America in a 90q
  250. selling oem brake kit
