- If not a bad fuel pump, then what?
- To paint or not to paint the cabriolet wheels? (Follow link for pics)
- DOHT!! Over-throw spring
- Need Help...Removing rear lower control arms...
- Ok guys, 1 more question, re: air filters
- Procedure to dump DTC's?
- Since the ATS Comp. Lite rims are being held in customs.....
- 91 CQ outer CV boots are cracked open/ any simple fix labor wise?
- (Flame suit on) What kinda things would I need to be on the look out for w/ a small shot nitrous kit
- Seat belt question.....
- dashboard lighting
- need to find inside door latch cable
- When ur O2 sensor is going or gone...
- coolant
- I'm trying to clear out the AC drain tube, how should I do it? I tried using a hangar...
- Nate/ Azeem: (regarding VAG OBD1- OBD2 tool)
- Someone with a AUDI Model 90 4cy HELP O2 Wiring??????
- Front bumper removal procedure on B4
- '93 90_Can The Lower Control Arm Bushings Be Replaced?
- New member of my family.
- interior stuff
- wow.....major audi surgery.....long day.....hope to have AC soon...
- anyone parting out a coupe
- 88 90Q will a 87 4KQ RR strut interchange?
- my audi hates me :(
- 2.7Turbo: I noticed you painted your lower front bumper to match body,
- (Brake line question) The small rubber hose that is near the front springs...
- Moldings removed and more.... Over 20 pics.
- A/C - how much does it cost to add refrigerant?
- How much do you think I can get for my 1990 80 AT 2.0 Sedan?
- would it look good to paint all of the lower black trim around?
- MIKTIP: what do you call the wrench to the left on your pic?
- a/c problems
- It's acceptable to buy a universal o2 sensor from local auto parts store, right?
- A/C vents
- Creature comforts? ;O)
- Hey Guys!
- Fuel Gauge or Fuel Tank?
- did a simple mod today
- Audi 80, 1989, 4Cyl, FWD - cleaning ISV
- Your guys' opinion/price quotes...
- antilock off?
- Burlington VT area...
- Replacing control A-Arm bushings
- Lookin at '91 80
- Miktip, washer sensor question.
- Help selling my car - particularly CA
- freinds car broke, need help to diagnose........
- Engine Temperature
- MikTip...Wood Dash trim.
- Did anyone see the last GT race
- The cloth is falling off my sunroof. How do i tuck it back in and get it to stay?
- New Engine "heat" smell
- anyone know where these go?
- Need a clear picture(diacram) with arrows pointing to the parts for 1990 80 2.0 AT pretty please.
- 91 AUDI COUPE QUATTRO FOR SALE
- Need advice on a good but not too costly do it yourself cat-back kit.
- Check this out! ;O)
- installing new cd player
- Got Wood??
- red 90q+pearl 90q racing silver A4 on NJ turnpike today...
- Anyone ever use Royal Purple synthetic?
- how should i connect these wires?
- is this the right stuff for the manual tranny gear?
- No more Audi but I'm still in the family...
- Hey MikTip how hard was it to make that custom Intake housing of yours?
- Anybody heard of a 1986 S4 with a V6...haha
- Audi Ryder.............
- Any way to mod an intake so it doesnt make so much noise?
- 98 A4 sport wheel on a 95 90cs?
- 20v Cam Re-grinding
- 1994 90s
- what's the oil capacity for manual tranny? (B4)
- Is overheating while sitting still a common problem?
- Picture of OEM LED in-dash cluster...
- AC Noise
- O2 sensor question
- Dumping DTC Codes?
- S4 Bi Turbo or S6 implant into a 95 90cs? Am I Crazy?
- How much do the Milli Migila F20 Rims way in a size 7x 17, does anyone know
- Battery question
- need engine...help with decision on purchasing '95 audi 90
- I know I should just junk the car instead of replace this but...
- What are the reasons for steering wheel to vibrate?
- New junkyard stuff
- About tinting Taillights? Is is possible to get them done @ a place which does windows?
- uhhhh guys, when i step on my brakes, the rad fan turns on.......
- Front end field day.
- i had a little disagreement with some guys in the 5kt forum...in reply I said to them this...
- HELP!! Front end part id for newbie??
- Anyone know anything about pace setter exhausts??
- Is there any way to tell if a 1990 Audi 90 Quattro has Hitachi injectors without poppong the hood?
- Assuming he's right abtou the MAF, I have one spare !!!
- What next?
- Got my Control Arm bushings today - PAP Parts big thumbs up.
- Crappy pic... But you get the idea... Hella kill switch..
- YIKES! I got my 93 90s today and...
- Sunroof switch disassembly
- Aftermarket Fogs? ;O)
- '95 90 - Airbag light stays on for two minutes after every start... WTF?
- Trunk isn't locking centrally - What's this about a pump and vacuum lines?
- First comes red, the next will be a few things yellow and a few things blue ;o)
- Has anyone tried those "High Mileage Oil" ?
- Well, she's goin' in next week...
- Lite is blinking on my AC Control Head on my 20V. What does it mean?
- Miktip...
- 26,0000 mi on a 1990 Coupe!
- Understanding EKTA
- seems like my coolant lines may be slightly clogged
- oxs sensor, which wire is the signal ?
- It seems that my car is much faster when i'm mad.. :8(
- I lock the doors centrally from my driver's door, and the trunk doesn't lock...?????????????????????
- The trunk light never shuts off, even when the trunk is shut and the doors are locked... ???????????
- Dome lights don't come on when I open my driver's door, but it chimes when the door opens. . . ?????
- im gettin sick of this...
- if i get these....will i go fast??
- Can someone confirm wether or not..
- What to do with this Cruuz control switch...
- ticking/knocking coming from hydraulic pump
- Audi 80, Rear window, side mirrors defogger not working
- door latch question..
- new toy today!!!
- I am abandoning my project car=-(
- well couper got a engine transplant!!!
- fan switch pregunta
- for those with the short shifter - anybody figure out a way to make it less "notchy"?
- any good aftermarket cabrio websites?
- Replace air filter on Audi 80 1989, 4cyl, 1984CC
- Odometer stopped working! - 1988 90Q -
- Idler pulley diagram
- Anybody else receiving e-mail viruses from Motodyne?
- Aaaagh!
- anyone have a pic of a bearing seperator and a decent bearing press for..
- Alarm Help
- There needs to be a sticky thread at the top of this forum that says...
- Something is wrong with this forum...
- O2 Sensor wiring 1988 90
- Can't Seem to Remove Fog Light...Please Help
- Power Boost Valves
- Audi 80 Question
- more questions....i kno i kno
- Is it me or is MikTip getting younger? I like his Audi 90 and his hip new lingo.
- is this tail acceptable?
- Serpentine belt snapped
- the do it yourself short shifter instructions suck
- oops..pressed enter...
- Rs2 mirror install on a B4 sedan
- German translation please? see inside
- Exhaust sound clips on my site now....
- 600 rpm idle
- $175 for new Eibach springs a good deal? Any other comparable brands worth looking at?
- 93 90- Shock recommendations - Koni adjustables or Bilstein Sports?
- 1993 90cs interior door handle cable
- Anybody have a laser red driver's side door handle?
- rebuild kit for steering rack?
- Help! Convertable top won't open
- Audi cab antenna motor needed!!!
- Rad Temp question
- Does anybody know if a 911 motor will bolt up to an Audi Tranny/
- Good price! ;P
- Anyone ever deal w these guys?
- I wonder....
- MikTip, I think you should have an Audi BBQ at your house and show us all your cool stuff.
- Anyone Interested???
- HP Air Filters? More silly newbie questions.... ;0)
- Suspension Tips for Newbie?
- replacing the rad.
- Unichip ECUupgrade for the B4
- Anyone here?
- Miktip, I think I noticed in one of your suspension pics that you had an additional bump-stop...
- Source for a clutch kit in canada, i remember reading before that somebody could get them through...
- Blaufergnugen
- A/C on,,,,,,,,,Get water on feet!
- You believe people put these on their Audi's? :O/
- Look closely
- TabulaRasa - Magnecors
- Lowering springs...
- Found the perfect Van for El skolnick! ;O)
- Anyone want a Haynes Workshop Manual??
- FYI the part number for 4cyl and 5cyl front ball joints is the same
- Can someone confirm? Cuatrokoop?
- MikTip... just saw your post on the 4000 forum. Tire size is 205/55/16 on the car and...
- one more thing
- few ideas for my darling audi.
- Please,help newbee locate starter!
- Junkyard treasures
- uh-oh, the miss is back...
- Someone here say your coolant tank was leaking the other day???
- Did it happen to anyone?
- Audi_80 do you have a pic of the side of your red 20vQ...
- Do you guys have these relays?
- Has anyone rebuilt an alternator?
- How to Check DTC codes??? (12v.org is down)
- anybody want an engine?
- Wheels for Topless
- Any difference between a the gauge cluster of a B3 & that of a B4?
- where can you get shift patterns, also old knobs.....
- 1990 CQ stebro exhaust question
- Changing the thermostat on a '93 90 S
- New Muffler...What Should I buy?
- Painting rotor caps?
- Instructions for novice needed-A/C Recharge '93 90 S
- 90 S-Clunk noise when releasing brake?
- Who here has worked on the memory module for their seats(20V)?
- Proper paint for my ride.
- best wax to use.....
- Does anyone know where I can get a good paint job in the Bay Area?
- possibly selling my car.....need advice
- alex...
- if I think I have a head gasket leak, why isn't it puffing white smoke consistently?
- headlights, dome light...and...well...all lights on the car flicker.....why??
- Just a quick qeustion....1.8T related....
- Anyone have a picture of the O2 mount in the downpipe?
- Lets hear some roof rack oppinions....
- Car cranks, but won't fire (NOT fuel pump or pump relay)
- Changing the fuel filter on my 90 coupe
- Gawd Damn Plastic screws...also my bad too...kinda long....
- Multiplication, this time the picture version...
- s2 bumper needed
- Anyone have one of these?
- Will someone sell me......
- 2.8 Badge on my trunk ... follow link for pics
- HELP, car wont start but has power, when i clutch start it, wont shut off!
- Don't buy the Taiwanese B4 hoods.
- Questions on installing my basslink? What gauge wires do I need to use for power, etc.?
- Bay Area Paint Job
- Caliper piston boot
- Installing my basslink, where can i run a power wire through the firewall?
- Looking for Crank case vent tube.
- Looking for brake hose
- knock sensor location on 4cyl 80?
- Bidding Farewell...
- Curiosity is killing this cat....
- eS2 conversion update...
- Front right door panel on a 1993 90S...
- Bike rack time!
- BAD IDLE HELP
- 1988 Audi 90 4cyl Down Pipe
- Can the V6 be driven w/out a Serp. Belt...
- Best place online to buy parts for Audis? ( I guess this is a poll )
- Would these Fit on a 90 CQ??
- OMG My father just gave me his credit card to buy parts!!!!!!!!
- This is my favorite shot of my car ever! Thanks so much BakerCoupe for all your hospitality! U rule
- Any write-ups for replacing head gasket/s?
- ok, how to tell if MAX throttle switch is bad?
- Who's is this?
- X-Post from PacNw forum. Mt. Baker Cruise..
- A few parts left-over from recent mods! ;O)
