- front brake discs choices
- urethane bushing..
- keyless entry
- 20VT into a 1993 90?
- 20V NON TURBO Engine Modifications??? What are your thoughts???
- a_90. You in Chicago?
- Do you have to drain the oil when replacing oil pressure sender? this might be too obvious but
- clutch
- cruise control
- A/C question..funny noise.
- Interesting Argument - Engine Gurus
- Seriously Considering Purchase of a 90q for turbo conversion
- Redoing exhuast soon... catalytic converter question
- Help, I need part ### for an 80/90 Coupe quattro
- K&N Panel Filter vs. K&N Cone Filter
- does the slave cylinder for the audi 4000 1984-87 fit on the 88 audi 90
- is it ok to use castrol on my 88 audi 90
- relay question
- alloys
- Any way to check rear diff fluid level?
- Is a red wire with yellow stripe a power wire, Audio stuff
- Anyone wants to buy a short shift lever?
- Anybody has an extra flush mount adapter for Infinity kappa tweeters or can I use any adapters?
- Help: Bilstein Sport part numbers for 1990 90 20v quattro?? (my car)
- VT audi owners...
- Rear brake question (not about the special tool!)
- What are these? (repost)
- Any Jersey 90 Meetings?
- any instructions on how codes worked. I have no idea whatsoever.
- MI and IN people
- Where did the tread go for the ETKA? Any got the link?
- Spark plug poll...What are you using and on what car....
- Strange problem: Ignition Switch?
- What's it gonna take??
- T-BELT
- After almost all day in the driveway, I am finally done....
- The "Ping"
- it might be stupid q but can you put 20vt in a fwd car? i would think no???
- rear speakers
- SlowPearl...
- Bosch B3 H4's, real cheap
- Any of you have blaupunkt CD player...how you like 'em???
- Heya, BigMouse here, still around. Am now in Portland, Oregon...
- tornado fuel saver
- looking for 88 audi 90 fenders any ideas where to look?
- ok, so i lubed up the window regulator centre track with some lithium grease, anyway, there's still
- Brake pad poll
- MikTip - APR Snub Mount ?
- 20V Headers going cheap! ;O)
- Door Locks
- looking for lube results
- changing the front and rear diff
- removing the rear door speakers
- I NEED A/C HELP!!!
- custom turbo job
- HELP!! 93 Audi 90 Wiring Diagram
- Some new pictures of the car
- Where can I get these so called "$0.20" dash bulbs?
- Comparing A4 to 90
- Trying to fix my loose window regulator --
- clutch master or slave cylinder? help!!!!
- Who of you out there run scorpion exhausts?
- Do I need to drain the oil to remove the power steering pump?
- Looking for zipout window for Cabriolet
- Can anyone help me out?
- S2 engine in Passat?
- Electric Windows and sunroof, Fuse???
- Just bought a 90 coupe. The trip computer has no life. Is it dead? a fuse? maybe turned off?
- Tim Sager
- oil dipstick filler tube Audi 80 1990 model
- FYI- MHW's website.
- ECU or Fuel Distributor - need opinions from the experts !
- Ahh great now a wheel bearing, where to obtain one?
- Clutch Install (please help)
- laser/jammer
- question....
- FYI, there is a guy on the 100 forum selling a Hex-Com and TB tools
- Paging Oliver Sprenger you out there?????
- What hareness is the speedometer sensor wiring on in a v6?????
- Getting through firewall
- Reccomend a good Audi repair shop in Massachusets
- Bentley Cd
- Attn: Audidriver9
- Brake Calipers
- Shameless Plug
- slighty tranny problem (maybe)
- anyone headed to the LRP driving school on wednesday?
- For 50 euros?? I'll buy it now fly there and drive it home!
- Dyno day with Coupesta and Stage III jetta (follow the link fo pics)
- Can I make a CQ ehaust system work on my 91 90 20v quattro?
- Need a photochop favor....
- Exhaust leak
- OEM radio problem
- New Exhaust Pics
- I know I've posted this before, but can anyone tell me...
- Question for "93 Ed" about your R38's (or anyone who knows)
- any idea why my abs kicks in so gosh darn early?
- stereo wiring
- Now it won't start! Here is a mystery for you. . .(semi long)
- The good old beaten oil filter topic.
- pics...(BWW)
- Badges and screensavers?..fasheezie
- Is it ok to downshift the 20V (engine braking) to 4,000 Rpm instead of using brakes?
- Nice Package.
- New member intro...(long w/?'s)
- Reminder: NorCal Audi Club Marin drive June 21, 2003, 10AM
- 80Q v6 Saloon Cyl Head removal
- 1993 Audi 90 Odometer
- AUTOPORNO: moldings, mods....and hot-hot-pics ;)
- any additive recommendations
- new to audi, wheel help needed
- Show me your clean 90!
- 93-95 speaker placement
- 3rd Annual Audi Owners Gathering!
- Before & After - the Audi 90 with .. 370K+ miles
- stereo
- 269mm rear rotors? i think i can do it :)
- XPost from 4k/CGT forum....F1 track drive
- Are STI plug wires any good?
- Missing something near throttle?
- Help - exhaust leak in "donut"
- 18" Racing Hart C2's going on soon!!
- rear caliper rebuild? where to buy kit?
- Car pulls to right
- Newb needs explanation
- hmmm..the exchange rate is 1.18 EURO to the USD, so....
- Someone should really grab this up!
- Any thoughts on the exhaust system offered by TDL???......
- where is everyone going to be at waterfest?? i dont live too far from there so ill be around
- BakerCoupe go online or I'll kick ur arse!
- HELP !! Car wont start - need your advice
- Fiber Glass RS2 Bumper
- Whats the difference in these engines...
- Carbon Fibre Hood
- With all this talk of 20v headers . . .
- Hydraulic pump ?'s (Rebuild vs. replace)
- Jim Bush, did you install that hood yet???
- spark plug wires...
- bilstein strut caps needed!
- best auction EVAR
- Treser smoked tails...
- Some repair work, kinda long and a few pics watch bandwidth
- the group buy
- I have a chance to get a set of used Porsche big reds.
- Weird electrical problem.......
- Could the problem be the alternater?????!!! help please
- Waterfest!!!!!!!
- Since I am in the selling mood: FS regrind 20v Naturally aspirated cams...
- Can anyone post the Part number for the Factory 90 Quattro spoilers, both types if possible? Thanks
- TDL Racing
- Attn Northern Indiana / SW Mich people!
- wheelzzzzz
- Hey Livi, any luck getting the headers pulled out yet?
- Audi Car Club Canada Chapter Fun Rally
- Shift Linkage UPDATE
- Thinking about buying a 90 Sport - wise decision?
- Long Term, extermeley annoying, problem fixed!! (High RPM Power Loss)
- Could the oil pressure sender/sensor cause leaks when it goes bad?
- anybody fabricate a rear strut tower brace for their B4?
- Car audio teaser pics
- G60 brakes questions
- anybody ever tried to paint (black) the contrived looking wood trim in a b4?
- tranny help needed!
- How much should an air idle valve cost? And breather hose?
- A couple of questions for anyone:
- Exhaust time! help me :)
- Hokie_90 -- thanks for the info re: cabin air filter mod....i disappeared for a few days, just got
- Paging: Aaron[MA] you out there???????????????
- 1991 audi 80
- Performance Parts
- Catalytic Converter Problems
- cracked exuast manifold
- Check out my 95 90Q
- stereo....?
- afc vs aah
- Intrax Springs 93-95 audi 90 2wd
- Need a favor from a Canadian-
- CapitalAudi: Next Drive is Saturday, June 21st in Northern Virginia...
- Where can I get OEM looking REAR RS2 bumper?
- Paging Steve Balgach - and something to the moderator
- Anyone have decent pics of the v6 front crossmember???
- buying questions
- Dont be fooled by "smaller" spoilers, this is the one you want!!!
- '95 90 Quattro - AFC or AAH?
- Exhaust Question... Please help.
- C2RLSPoRT5 are you there? Just heard your selling your ride....why?
- oh Schweet!!!!!
- Some dirty pics from the weekend... (Not WW)
- Scooter in RS2 Audi Blue
- What light is this person referring to, how much and is it worth it?
- What's needed to get this to work with my B4:
- Two quick questions...
- Need Part number or price tag for plastic or wood trim for aux guages
- Here is my 90.
- need help on a decision
- quattro defined
- East of Cleveland OH Mechanic?
- Ultrasonic cleaning of 6 injectors for $35 w/shipping
- Anyone selling Spring + Shock pakage for 1988 Audi 90 Quattro?? Please email me..
- My 1988 90 Quattro with 16" O.Z. Supertourismo Corsa wheels
- ATTN: V-A-G-Nuß
- Brandon Hall is putting out feelers for selling his Es2 Coupe
- Got the short shifter installed...
- What do ya'll think about RS4 bumpers? Anyone have one on their ride...pics?
- Anyone converted the AC system on a 90-91 coupe to the new refrigerant?
- Resist the urge...
- Looking for white face guages....who knows where??
- speedometer sensor
- For all the local Vancouver folks, A-Scott has a 1988 90 in quite nice shape
- Is anybody here running a K/N cone filter, and if so do you find it loud...
- I want this interior... Did i mention i want this interior???
- How do you post mutiple pictures on one post>
- Intrax Springs for sale 93-95 audi 90
- Anybody have some parts numbers for universal O2s? The Bosch 13913 is not available in my area.
- noob pics :p
- Power steering and brakes gone....
- It's alive
- you asked for it, now you have it! Revamped pics of RS2 bumper w/ blackout grills & ellipsoids
- cooling fan problems
- How to replace Fuel Pressure Reg. on 12v V6?
- Help with PS pump removal on B4 V6
- cabrio questions....
- Is there a way to adjust the length of the hood pins? Mine needs to be a little bit longer.
- Blasphemy!!!
- Finally fixed my knock sensor problem....
- Transmission mounts, help
- Where's the knock sensor on a '91 CQ?
- my car bas been acting up.....
- help mee!
- Pics. of me and my car at Loudin, NH getting my COM racing licence:)
- Could someone shop these on my 90, there a few pics in my poster... TIA
- can any one tell me where the speedometer sensor is or if i have a cable
- spee-o-meter
- speedometer
- drum role please......my attempt at Photoshopping a RS2 bumper to my car. Enjoy! =)
- what are all the factors dealing with a vac. leak?
- of broken backlights and other matters
- how do magnaflow cats sound?
- What is the black stuff blowing out the vents since they replaced the evaporator and condensor?
- Some 6 months ago a got into a "fender/frame bender.....i have one pic.....
- Is this the part I need to get all the blower speeds working again???
- Anyone see this???
- $700CDN -Magnaflow VS $1500CDN Brullen Exhaust!
- Jim Bush: Are you getting my e-mails?
- Lifters are installed ...
- lskolnick i have a question for you
- 90Q ram air pipe???
- p-chop please
- How do you guys like this??? not bad
- 12v repaires
