- hey lskolnick, how much does a full throttle switch and oil pressure sensor cost in CAD $??approx
- quattro fun at the 'ring
- F__ING PASSENGER SIDE MOTOR MOUNT!!!!! The nuts are off from .....
- Another hard to find problem
- Easter Bunny visited :)
- Bizarre problem!? 90 10v 1988
- Looked at a 1990 Coupe for sale /owner says "New Engine" in past year and not original 20Valve NON T
- supsension options
- My cruise control works great, for about 10 to 15 miles, then abruptly lets go...
- Another spoiler on ebay... Grab it before it goes!!!
- Help needed: do your window switches glow slightly when.....
- Boom...
- Rear bumper upgrade and sideskirts question
- Dumb question - how do you check the power steering fluid level - 88 90Q
- 20V's: How many miles are you getting per full tank? Quattro or non?
- Bigmouse intercooler, and turbo question
- Anyone know where I could find a replacement rocker panel?
- tail lights and alignments
- Any one know what's the resistance in the temp sensor
- 1988 80 FWD Supsension install
- Any of you guys with universal cats.....
- to top it off, third cylinder vavles just went by by.. toasted.. spark plug all fudged up
- V6s: How many miles are you getting per full tank? Quattro or non?
- Help diagnosing front end squeak
- Idle Stabilizer Valve
- 1990 90, barely used, accelerates so slow that an accent would smoke me. Whats the problem?
- Help Needed!! Lifters -> Tightening procedure details inside!
- Anyone have a Koni Sport or stock rear quattro shock lying around? TYP89
- Audi 90. Eveyone says no auto tranny fits. What about this then?
- So the pearl antipathy here, stems from quantity or...
- What does it mean when................
- Getting closer to figuring out the problem: getting 2232 air mass sensor, voltage too high...
- Panzerwagen, we got a bone to pick
- Radiator fans always on when ignition is on...
- Brain Teaser question of the day (Like the ones on "Car Talk" only different)
- S2 front bumper parts
- Power Steering rack R&R .....
- RE-POST/ AC leak under the battery? Is it a hose? Any cheap Hose solutions?
- RACK AND PINION ANDPOWER STEERING PUMP
- COULD I SWAP AUDI 80 DOOR FOR AUDI 100 DOOR
- Just replaced steering rack and pump yet steering wheel still shakes
- possible to advance the timing a few deg to get a few more ponies outta the bottom end?
- My car-related b-day presents...
- Cheap spolilers...
- Well...after changing my O2's i got 380 mi from a tank....
- Changed tires... now grinding noise...HELP!!!
- to those that have leather seats
- what tool am i supposed to use for removing the struts and shocks
- Allrightly next question.... Getting a psssssssssssssss... sound...
- can some one verify this pics is right: cam timing....
- location of ISV in an '88 Audi 90 FWD (2.0)! Picture would be great!
- 1.8t engine into a 1993 Audi 90 s
- did any ever heard of rebuild rear differential and $$$ ???
- engine sluggish good/bad days....
- Cruise Control Question
- Hey everyone.... significant power increase.... for FREE!
- Why does my 90 feel like its shaking/vibrating
- Best way to pop balljoints & remove right engine mount...
- The (heater/ac) blower is not spinning...!
- Cleaned my ISC/ICV last night. No more odd idling. Thanks for your help everyone.
- Fool!
- A/C hissing leaking under the batery? AC hoses? $$ where to buy
- My car is killing my budget!!!!!! Sry little long!
- the car is tellin me i got low oil pressure
- TYC Clear Corners! (Sorry no pics for now)
- I think this will be my last question on my brakes- this is on the rears...
- what are typical reasons for overheating? (other than low coolant)
- When backfires attack...
- My car looks pretty
- 2 Questions about CQ
- An end to the confusion, Finally, at least I think........
- can any one give me a diagram of how a bumber conections
- i was going 100 on the high way and found that my brakes suck whats the best thing to do?
- update on ricer instrument guages
- contol arm bushings '93 90s
- Trying to decide wether to have my moulding painted...
- Can anyone explain the function/theory behind the valves in the top of the intake on a V6.....
- Blacked out RS lights?
- 20V Turbo Cabriolet!
- Coupe flyer! ;O)
- Anyone ever had a crushed rocker panel replaced?
- Just prepped my car for Auto-X on Sunday...
- cuatrokoop (or anyone else): What are the compression readings I should get for a '90 Coupe Q?
- Anywhere online to rent those Timing Belt Tools for a 12v???
- When my car was bought brand new, it had almost 3k on it.
- Well I just figured out the problem, but I don't understand the answer.. Timing related
- PLEASE....Let me pay $10 more for yours than the dealers...
- Time for an Oil change...what brand do you guys suggest? I used Valvoline last time...seemed good
- InfernoCL, how did you get your Kappas to sit so low in the dash?
- yay i got the ricer guage faces installed
- U think this person will get what they are asking?
- SUMwut of a squeeking sound coming from under the hood
- Normal temp range?
- weird sound near rear diferential
- Hey Yesterday my clear corners arrived!!! Took exactly 9 days for shipment! had no time to pick up..
- Anyone have closeup pics of Hella B4 clear corners?
- Yet another brake question on the E-Brake this time
- Another brake bleeding question...
- question on removing drivers side head
- Anyone have an explanation for why the front battery hold down hole is smaller than the rear one ?
- X-post... semi off topic, but on topic because it relates to my broken car.
- SOMEONE TALK ME OUT OF BUYING THIS 90 20Vq...
- First time brake bleeder.
- I also have a check engine light question......
- Check Engine Light Question...
- well... I REALLY SCREWED UP!!!
- FIA World Rally on Speed @ 9pm Eastern!
- Some good news and some bad...
- 90 quattro
- stereo help
- 3 Vents on the center console
- ABOUT lowering springs
- Where is the temp sensor on a 80 ABK 2.0E 93
- well, I have to admit sjm is a very nice site......
- What are these? (1 cut wire, 1 sensor?)
- Anyone have the specs for a 1995 90 audio system??
- Get yer S2 right here.....;-()
- MikTip...where did you get that spray for your taillights again?
- Hm....recalled tranny?
- Warranty on items from a Woldrpac online source...
- Re: rear deck spoiler #8A0-071-640
- Cat size???
- '88 80 Service Training Manual
- Door lock problem on '88 80
- DC/MD/VA: Capital Audi River Road Drive this Saturday and other upcoming Audi Events.
- What is the auto tranny code on '88 Audi 90 4cyl?
- is it harmful to run the A/C compressor if the refrigerant is low or empty?
- x-post: seeking lightweight rims - 17x7, 4x108, 40mm offset (+/- 5mm)
- steel wheel source?
- For those of you who have replaced rear pads...(almost long)
- Wheel Question ("Hubcentric Ring")
- I think I'll have to go change my grundies now-
- SUM leak...
- Got my engine to run today, and then all of a sudden it completely dies, and there is no spark...
- Did this car come to Ontario / Canada
- MFI (check engine) question
- 20V code pulling & the engine check light.
- APR doesn't know their Snub Mount will work for us.
- Update, coolant Q's
- Whats up with 2.7turbo selling his Cabriolets for parts? ;O)
- IF anyone has a pic of where the coolant temp sensor is, could they please post it, if possible..
- Anybody have european headlight 4 prong connector?
- hatch removal?
- About checking the codes...AGAIN sry...
- any one know if the low shut off when the highs are put on ...on a rs2 headlights?
- Possible to interchange the AFC and AHH V6's with each other???
- anyone have the Part number for RS2 lights handy??
- INTAKE
- Any body heard of Vogtland Springs?
- Spy shots of MikTip's latest conversion project
- Would you guys say the FWD is way faster or just a bit faster than QUATTRO in acceleration?
- QCRAZY, are the instructions for reading code on 12v.org the the same as to read them on a 88 90 Q?
- Real nice 90 on Ebay if anyone is looking.....
- 88 80 Sway bar??
- I just don't think I can handle another quattro..
- Wheel Gaposis
- '88 Audi 80 auto. Tranny is going...what to do?
- Wondering what your interior would look like after a nuclear meltdown?
- No floor heat...
- Stock CD changers - 93-95 and 93-98 Audi cabriolets-
- Where to get
- Help with O2 sensor i THINK.......
- Has anyone else tried replacing their OEM fog light with a Hella? It doesn't fit through the hole!
- Caliper rebuild P/N confusion
- Using rims for 4 x 4.25 bolt pattern (mustang)???
- Rockford Fosgates Rear Speaker Install...HELLLPPPP!!!!
- Part needed! help me out please!
- A/C refrigerante of 93 Audi 90
- 20V Turbo Engine
- I'm curious to the way my 89 20vq shifts...
- More pictures, anyone whos worked a lot on electrical please help
- Das coupe had a birthday.
- Natwhite (or anyone else)...
- Alright I gave up !!!
- Hi guys First time posting, got some questions on my POS(long)
- lskolnick loves these! ;O)
- should there be a gasket there???
- Anyone tell me how to removemy Climate Control Panel? I was trying to pick at the sides of it...
- put on my Bilstein/Eibach Pro-kit...
- Who here has a 7A engine (2wd) with the cast manifold and O2 sensor in the cat???
- Auto tranny in 88 Audi 90...does anything else fit?
- hmmmm..
- Miktip? Does the Bentley guid show this?
- Mmm, I think I need to re-torque my head bolts...
- Will 100 91-94 European H4 Headlights fit my 90 90?
- Borbet Wheels. GOING... GOING...
- Still trying to track down this EGR issue.
- Anyone interested in the OEM 10 spokes (see pic) ... let me know..
- Save $$$$ for a 20v turbo engine for my coupe or buy this????
- Rear lock button lube question
- Looking for a used car in Canada
- Throttle valve switch help!!!!
- Can anyone tell me how to, step by step, remove the Coupe door handle & lock?
- Tensioner
- cluster light problem
- This car is killing me!!!!!!!!!!!!!!!!!!!!!!!!!................
- My caliper had a baby...
- anybody has springs for sale?
- Where does this wire go?
- axle/cv joint job is gotta be the most disgusting
- oxygen sensor question
- who makes some kind of sport springs for a 95 90q
- Not what I expected....
- '88 80 4C for parts/project
- Who's got the best price on a set of RS2 head lights? ;O)
- Electrical Problems
- For anyone here who has changed...
- Who said the I5 was a slow motor? ;O)
- Am I a fool if I sell my old CQ Speedlines for less than $150?
- Was there ever BOSE system for 90's?
- '88 90 Q drive shaft questions
- CQ suspension install
- '88 90Q Exhaust dia. between cat and resonator... 2" or 2 1/4"? (ID right?)
- help a brotha out, i do i disconnect the
- ISV...
- What's a good price for a set of used cabby wheels in good condition?
- revised: will dealers still honor these recalls?
- Revised adhesive question
- Speakers for '88 80?
- Best source for small parts for '88 80?
- the bentley CD doesn't give the whole story...
- another vibration dampner question
- Question about Coupe outside door handle.
- Rims For Sale
- Urgent: Anyone know the # to Audi of America.
- Rear brake caliper rebuild question
- To 2.7 turbo and cuattrokoop: RE: Bumper flex epoxy....
- What is the best way to heat...
- New Car
- Where can I get the PUR adhesive mentioned in the Bentley?
- Coupe on Ebay...
- Urgent: Has anyone lost all keys for there Audi before?
- What is the best stuff to use to clean the inside of the intake?.....
- Another hot cab
- Interesting -
- Physically longer cone...helpful or just a waste of money?
- MikTip, Where is the transmission drain plug and fill plug? Thanks
- Outside temp backlight bulb?....
- To all please accept my apologies for the postings to Audi21.
- Glad I asked you guys before I spent $170 on a new EGR valve......
- coupe thermostat -- PITA!
- Might be a silly question, but anyway.....
- Please direct me to
- Did the '98 cabriolets have the 30V 2.8? ... or did they still have the 12V?
- tires
- brake bomb
- Aux radiator removal/elimination question!!!
- Help: Electrical question, need help diagnosting shorted fuse
- lowering kit
- Door moulding adhesive question
