- Any pics of Pearl Audis w/ Dark Window Tint?
- where can I get the pump for the thing that washes the headlights
- 20v distributer gear
- Brake question... HELP!
- Low RPM Hesitation
- OK its been a while and u all a probably want another Vancity Audi Club video, HERE IT IS
- Slow acceleration...
- this is super rare
- where can i get the rings for the inside of a motegi rim
- Panzerwagen- you da man
- Help...how to replace heater/AC blower
- Weard thing!!
- vibration dampner bolts
- Good deal on a Timing Belt Kit...
- I think I should get an award for the fastest oil consumption
- Door trim removal for speaker wire
- "Bless thine Audi" says St. Francis....
- audi2l I would challenge you to battle of wits but you appear to be defenseless. lol
- how to: proper removal of dashboard?
- coupe quattro strut mounts
- One more question on the front brakes... and I promise I won't ask any more on the fronts!
- Miktip...PayPal???
- torque settings for k24 turbo??
- whats that line everyone says about a great deal????.........
- Burlington, VT area.....where to buy rims/tires??
- fixing rust spots
- What do I do with the senor wire on my new pads? there's no place to plug it in. Cut it?
- Brake install on 93 90S
- Brake question re: anti-rattle clips (Anyone with Pagid experience please!)
- rear deck spoiler #8A0-071-640
- someone asked about Intrax springs a while back...
- Trying to hammer the CV joint on...
- problems... problems.....
- a/c service valve-low side 1993 90s?
- Steering wheel not self-centering
- Replaced noisy tensioner pulley today...
- 91 CQ replaced Front shocks with Boge T-Gas, NOT rear, car is still very leany on corners.
- What is the trick to get the ball joint out of the hub...
- Rebuild underway...
- Help plz.....fuse keeps blowing out....
- Extra battery hold-down for auto-x ?
- Where are the best raising/support points? 93 90S
- "Interesting" special "tool" in trunk!
- When bad news equals possible good news. getting low compression, and high oil pressure...
- 97 Cab Power top confusion
- Anyone got any ideas how to loosen this bolt?
- (e) Anyone have a pic of the front corner removal?
- Wiring for diff switch in center console?
- Plug torque? Plug gap? '97 Cab 12v
- Hey Mik... how would I go about removing my front side fenders?......(more)...
- which tire size for my B3 90 20V?
- Audi Racing S2....
- One of the cleanest turbo engines I've ever seen...
- Part # 056 115 561G (Mann oil filter), usable on 1988 90Q? Thanks!
- My power seats won't work all of a sudden...
- Is this worth it???
- how many horsepower does this add?
- aftermarket speedlines...
- New summer shoes just arrived....215/50 , 16, 712s......
- Caliper rebuild kit question...
- engine problems with no codes in CQ
- '98 Cabriolet
- Good post about HID kits with stock headlights vs. projector headlights..
- Brake "paste" question
- Best way to raise my car?
- 97 Cabriolet Convertible Top
- EGR system questions??
- MikTip, buy your youth back.
- Power antenna failure
- ok you ricers
- My heat will not come out of the floor...
- Alright I'm back...non-Audi related, but I still want your opinions guys...thanks!
- boreing cylindrs in 80 Quattro
- Speakers in Audi Coupe Quattro
- Car Show at Virginia Tech this weekend...with "mobile dyno"
- Cabriolets
- Anyone interested in any gtg's in central jersey??
- Where i can get a pollen filter?
- subwoofer thoughts for 20v
- what's your say on these folks?
- 9490s01913... question about your ImportVision DEPO H4s...
- Stereo Replacement: 90q20v
- H&R springs 1995 90 Quattro part numbers??????
- sebring
- Whine at 3500 + RPM
- Dashboard light blew. HELP!
- when replacing rear shocks on quattros, do you have to remove the springs as well?
- Any chance some Cab. floormats would fit in my CQ? Fronts more important than rear...
- What size (ID) hose will fit on my bleeder screws..
- Brake tool question
- Can anyone post an 89 90q vacuum diagram?
- Blue smoke
- my bumber is falling on my 95 90
- what up grade first?
- Is B 000 100 the same as...
- Am I going to need to resurface my new brake pads?
- Transmisson/Axles...??
- 10vt turbo conversion shopping list:
- AC core leak
- Not that i can afford it now, but what do ya think.......
- Oh, the temptation........
- CQ control arm bushings stupid question..........
- Any one with a green quattro?
- Will Lisle tool 28600 work on my 93 90S brakes?
- How Are the real Glass Lights compare to Stock lights?
- Can anybody help with an advice?
- New wheels
- Just looking for some opinions
- Problems arise
- need an exhaust, floormats
- Mik, what is considered a "newer" A4/A6 Throttle Body?
- MikTip... Whad' that new cone do for your MPG's???
- 7A, 20v swap vs. 10v turbo swap in a Coupe quattro.
- ok would it matter if the oil pressure switches were put in backwards or upside down.... more inside
- where/how to get Euro bumpers and how much?
- Smoked Clear Corners and Tail lights!!!!!
- Seat heater relay??? WHERE???
- "Tricked Out" hahaha Red Audi Coupe....
- Prepping for Auto-X
- the question of the day.... How do you attach the fuel pressure regular when the new metal crank...
- coupe weight
- when did coupes have carbon drive shaft
- ATTN : MIKTIP.. whats difference in dealing with airfilter you put on
- Washer resevoirs
- Xel .. you went to Germany too?
- Pic from my German vacation. My parents have a V8q over there. :)
- Recommendations on car cover and where to buy ?
- front bumper
- Tach, speedo, gas, and temp guages dead!
- what a pain!!
- Brake question from former Nkugs9390, decided it was time for a name change...
- Figure this one out...
- Att miktip
- Idle problem
- HEAD GASKET HELP?
- yumyjagermiester: did you get your ronal R38's yet?
- repeat: DOES ANYBODY HAVE A B4 FRONT LICENSE PLATE HOLDER??
- Why are my new rotors sticky?
- can somebody post a pic of where the lines go into the the bottom of the gas tank in the trunk...
- Where's the place in CO that rebuilds the bombs?
- ATTN: mroberts. Did you receive "the package" yet? Pix?
- Free CQ stock exhaust with cat and driveshaft....
- CQ power steering rack preload adjustment
- New Motor Mounts?
- Anyone selling a 95 front bumper and valance?
- Anyone know how to remove the stock Gamma radio and have a wiring diagram?
- Exhaust manifold question take 2...
- Installed new HU, now I can't select Defrost ???
- 94' 90 dead battery problem
- Running power wire for subs
- The "Ultimate Cone Setup!" ;O)
- This one's for you Iskolnick, build the sedan version...
- Strange blue light??........
- rear differential seal dimention?
- To those who replied to my brake question, I say thankyou.....
- For those who wondered what my car lokes like!!!!! (Looked like )
- a different kind of grill...
- Head light wahers
- Paper? ;O)
- More FYI! ;O)
- FYI ;O)
- Anyone have a 1990 CQ parts car ? I be needin something.
- where is the transmission mulitfunction switch???
- what is the rarest option the 90 ever had...ie leather, winter package, color, material etc...
- I have posted this question befor so please....
- Help!!!!
- May Issue of European Car Magazine (sorry typo before)- write up on "only" CQ V8 conversion.
- HALP! Exhaust tip question for my non-quattro.
- Someone here with Yellow 90 with MB motoring wheels..post your pic again pls..
- Disconnected both oil pressure switches...
- to everyone with 20vQ Audi's (without turbo)
- Help needed from all w/ aftermarket head units
- so, what the deal with this site and the spyware it keep putting on my computer? anyone know?
- Cheap lights follow up...Have Pics...
- Finally, a pic of the coilover kit, I'll have closeups later
- Caliper rebuild kit...
- to do that throttle body mod, do i need to take out the throttle body? and where do i put the bolts?
- Am I missing something???? Trying to bleed the brake system.
- If I was to put valve cover breathers on my V6...
- Fuba Antenna Question...
- The family transportation, aawwww
- If you had a choice between a '96 A4 and a '95 90...which would you want?
- where can i get a kamei grill for a 95 90q
- Was there such thing as Audi A80c ?
- Are Zimmerman rotors good??? They are german?
- 20V Turbo, been done.......20V G-60, hmmm??????
- From where is that front bumper
- On Olivers RS80's...did he just have the bottoms painted, or are those some type of sideskirts?
- 12V chip?
- Does the 1990 coupe Weisbaden have a security code ?
- dead instrument cluster
- Short Shifter
- Update on the brake caliper...
- will 5x112 S2 front hubs fit a 4kq?
- e//S2 conversion update...
- Audio upgrade question?
- My rally spec URquttro, Euro 90, and original URq...
- Anyone put a roll bar in a Cab, 80, 90 or CQ?
- I need a new starter. Need advise (more inside)
- Is the direct fit cat for 91 90 20V fits the 91 Cq 20V?
- ATTN: Slab....
- 95 90 Brake Light
- Will a 20vt intake manifold bolt right on to a NA 20v head?
- catalyic converters
- Cheap Aftermarket Lights...If anyone is interested...
- exhaust manifold help....
- Is there a lowering limit at Audi Coupe Quattro `92 2,8V6
- 3A engine price question
- Just got my control arm bushings...it just occured to me that the...
- Question about Worldpac part N1042-36933 (Caliper pin boot kit)
- Does anybody have a B3 picture with the middle door trim removed?....
- Anyone have a plastic Timing Belt cover they can sell me?
- If one was to remove their side moldings and get their body repainted......
- Need springs?
- A LOT of german sites...sorry but couldn't link them so i copied!
- How 'bout this 80???
- Now this is real 2HP gain...guaranteed!!
- How rare are cloth sport seats for B4?
- RS Bumper Mods...FINALLY....take a look
- Rear break caliber piston...
- MasterB. Aluminum skidplate for Coupe, maybe sedan?
- Auto Transmission
- When the igniton is at the second position what lights...
- Who sells a good carbon fiber tap to cover the interor wood?
- times
- horsepower
- What happened to the 'Radiator Fan Wiring' thread from last night?
- breather tube part #11 on etka has a little mesh filter in it, this stock??????
- New wheels and wheel stud upgrade for my Coupe.
- Ever wonder how one changes turbo's on a 2000 S4? ;O)
- Them Honda guys......
- Spring Auto Trans change?
- Priorities! ;O)
- S4 Cabriolet
- European B4(?) Racer
- Rough idea for 20v turbo conversion price
- MikTip, can you e-mail me
- oil temp
- Does anyone think the M3 lip spoiler that the A4/S4 guys use would fit a B4 90?
- Vid from car show including me driving the new S4 Avant...
- Any way to fix an odometer, or find a new replacement ?
- Who watched the F1 this morning ?
- Where to get cluster lights, other than dealer ?
- oil pressure sender question...
- Another shot - 17" with 215 45 17 Falkens :o)
- Woo Hoo! Got my new wheels at last...
- The CQ finally needs a new clutch, any segestions?
- temp guages
- More Fun Pictures
- If anyone wants some parts from Cials, car, not the ones for why i bought it, .......
