- 1993 Audi 80 V6 Avant - Any known weak-points?
- went drag racing tonight...at LACR
- Hey, Miketip...your email is not working....
- HAs anybody replaced the rear diff bushing at the rear of the diff....
- OT: Just a good laugh at the ricers!
- are there and good wheels for....
- Making a 90 autocross-able..
- WOW!!!
- Audi_80 or MikTip! My 200 doesn't seem to have any compression!
- Where would you get.............
- Is the dash lighting switched on by a relay when the lights are on?
- Just so the jerk doesn't get an ego boost,
- Location Check: Where are you guys from?
- Doors Automatically locking after Car in Drive
- exhaust leak!
- senna4life, you out there?
- Change water pump with timing belt?
- replacing front brakes
- Driver SIde Front Wheel
- v8 bi? turbo in 90? pic inside.
- Good to know!
- Part diagram needed....
- Cat options
- Heater core leaked!!!! What do I use to get coolant off carpet?
- To GreenDoh about your RS bumper
- am I missing anything
- 200-300 dollars to spend...bone stock '93 90 CS....
- How are the 1988 90 quattro's?
- any b4 audiers wanna hit me up on AIM? sn on sig
- Has anybody put 6 1/2" speakers in the front of their 90 ?
- Someone said a few days ago they got their clear corners from nopi
- Mike i havent recieved my email from you on my Sig.
- I get about 18 MPG with the A/C on. Is this normal? Seems pretty bad, my last car got 28.
- Where would I go to fix this?
- Another interesting find!
- Ported and polished heads
- Interesting find!
- new signature
- RS2 headlights with turn indicators
- For all the 'Non-believers'! :o)
- Hi, Mike..can you make me a kool Sig w/Audi's and a sexy women in it???
- radar detector
- What do you guys think of this heat shield?
- alternator
- In need of some parts.... Anyone have this stuff laying around?
- What is the scoop on this RS2 bumper... anyone have details???
- Hey Miktip!
- Just got the quote for the RS bumper install/painting..
- custom exaust questions
- Freon recharge
- MikTip Help - Cams?
- ABT 10v Camshafts
- Throttle Body
- BTDT- What does it stand for?
- anyone ever seen a 16V 6A
- Special tools required for suspension r&r?
- very, ah, strange audio set-up
- Gear oil replacement ?
- Hey Catamount90.. have you seen?
- tough decisions
- For anyone in the midwest, specifically chicagoland
- Attn: Livi
- ground control coils---fit my coupe?
- FS: Climate Control Unit...
- What Are Some Cheap or Free Mods I Can Do
- A4 3 spoke wheel
- PIAA, or other brand, Fog Lights --> Who's got what? 93-95
- Any pics of a RS2 bumber installed?
- I feel terrible driving my car.
- Damn people!!!!
- Pics of 35% Llumar
- Lock not sliding down easily, clicking????
- WANTED: Gamma radio
- What coupe came with the NG code engine?
- Name change...
- Should Window be up or down when removing door pannel?
- Yikes! These things are never simple
- rs2 bumper on a B3
- Strut mount
- Help- Rpms come down slow when I shift.
- O2 sensor wrench/socket???
- Good info and pict on shifter R&R could also help DIY Short Shifter
- anyone selling lowering springs?
- Engine ticking latest update
- A/C Compressor and Clutch
- 2 things of interest........
- OWDLVR -- What were the results of your Vibrant Performance muffler challenge?
- Gold Quattro
- for any one with an 90 & earlier 90 in So. Cal. nice car in Pick-ur-own-Parts in Wilmington
- can someone link me to a site that has rear mufflers for our cars?
- bentley
- Starlight whines sometimes when I start up from a stoplight........
- doing brake job, what else?
- Aftermarket Keyless Entry System
- Who's still planning on going to WaterFest?
- NEED gas pedal for 88 90Q...please help!
- tiptronics
- V6 Van!
- 90(B4) Blackened Tails by MHW
- Every part for every car you ever wanted to know about! ;o)
- Stebro Exhaust / Short Shifter Install ! ! !
- removing the starter....HELP!
- etka 5.6 etka 5.6
- Nut size and other screwed up questions...
- How do I remove the door panel?
- Hey Guys
- quick question
- Look what I got to drive today!
- Anybody ever heard of timing the spark from the spark plugs?
- The Audi Gods really must hate me! I'm goin' atheist!!!
- Caused a short to earth in my electrical system . . .
- Anybody up for a 1.8t engine swap! This came up a while back!
- I need a new air filter....
- Bumper
- Would these go into my 1993 90cs?
- cooling system sensors
- looking for info on 90-91 Coupe quattro...
- Speedline center cap...know where I can get one?
- Starter motor not working...
- knock sensors.....
- Overheating
- Anybody know why........?
- What do you think of these...
- The Ultimate Home Depot Mod!!!!!
- Hey Audios 68+1 when are you going home?
- whats a typical price for a leak down test on the 20V?
- Do i need i new alternator?
- Help with Starting Problem (Vacuum?)
- Good Info! :o)
- front radiator on 88 80 quattro
- RS2 Headlamp Wiring
- Headlamp Globes,which are the best ?
- Just finished painting my calipers...
- The perfect Cone setup??
- Shocks... Need advice!
- My car broke down....need some help PLEASE! (long)
- Ok guys! I'm through! I'm selling my car and getting this hunk of metal! It should do for now!
- MikTip: Where did you get those clear corners?...
- O2 Sensor Question...
- Can someone tell me what size my axle bolt is? Also...
- hey scott email me again concerning the Audi hood you bought from me
- Wondering what your car will look like with exhaust and wing? Look here!
- tachometer
- My new exhaust
- RS4 bumper kit on my Audi!
- Does anyone know if it is worth it to put......
- Hood repainting
- Ok My car is starting to freak me out!
- Squeeling noise when braking
- Audi80.com no longer in English? Why not?
- PES Supercharger for a 2.8 V6 12V...
- Front End Noise?
- Aux Gauge wiring?
- MikTip re: oil pressure (pressure limiting valve)
- Is there any negative side to fender rolling to accommodate a few extra mm of wheel/tire?
- Ok guys...what do you think about porting TB and intake manifold on V6?
- Traction PLUS
- Replacing of AC compressor,receiver/dryer etc. on 90 CSQ
- Anyone looking to buy CQ?
- are there any mods for a....
- waterwagens - August 4th, 2002 - registration is now open (Audi and VW show)
- Someone stole my front license plate!
- Pics of the new bumper....I finally got around to uploading them
- hypothetical question
- Anyone got manual pics for removing clutch master cylinder? Or dig. pics?
- ATTN: Audi_80
- Must sell 16" wineglass whls&tires...Came off 2002 A6 with 1200mi on em....anyone...anyone!
- Someone stupid guy in a truck hit me!!!:(
- Another ques... somebody is selling their H&R spings for a 2001 S4, will these fit a 93 90s?
- Help with wheel and tire set up (long)
- are the turn signals off an 88 90 the same as the ones off a 93+ 90?
- To service or not to service auto trans
- Anyone want to sell me the 3 center console gauges with their housing?
- Recalls!
- Engine ticking saga -- diagnosis back to oil pressure...
- subs in/ check light taken care of
- poor acceleration
- Dealership says that for my VIN # there is no recall on injectors. I guess this is legit, agreed ?
- Can somebody please give me DETAILED instructions on how to...
- anyone got a good condition 90Q 5cly radiator to sell?
- Wide Rims
- Here's a challenge for you - fuel / computer / idle problem
- Chain reinforced exhaust hangers
- 90 CQ acceleration /pedal sticky after long reving down
- Can fuel injectors cause the kind of ticking/clacking that could be confused with hydraulic lifter
- Engine hesitates
- Hey Miktip...
- Anyone here seen audios69 recently?
- About to order the white gauges from MHW - are these the ones i want?
- Has anyone been told by the dealer that their car has not been recalled?
- Should this look like this? (K & N users)
- Just bought a 88 90 Quattro 5 speed.....have some questions, can anyone help?
- Recall on injectors for our cars? Anybody else familiar with this?
- torque specs on the o2 sensors?
- Latest update to engine ticking saga....
- hey Audiboy_17 did u recieve your lights yet???
- ok where does this plug fo???
- Anyone have stock sport springs for sale?
- hmm....
- New koni's installed...first impressions
- Hey tipton
- so, finally a little [very little] headway...
- Anyone know a good place to get Bilsteins? H&Rs? 88 90Q
- Problems bleeding clutch...read that I need a pressure bleeder, that true?
- radiator leak
- Self AC charging
- A/C question
- Audi 1990 Coupe Quattro
- 80 quattro speakers...tell me what you think
- Need help - ISV signal lost with A/C on
- Mabe skid plate possiable solution: just cut a hole out
- Rubber Audi Sport Floor mats...
- Where is the ISV? (I have pics)
- car doesn't start
- Is 5mm differing offset from stock a lot?
- did anyone notice...
- Miktip where are you getting your wheel bearing?
- Bad News
- YEA!! Congratulations Audi 1-2-3 at LeMans!!!
- I'm having problems with my 93 90S, Please help..... (long)
- Rear Dif service?
- Who still uses their skid plate?
- Festivities!
- pics/help
- Vibration Confusion
- A gutless plug...
- Sound of your 12V V6...
- 1995 90 quattro 2.8 oil question
- 93 Audi 90CS
- 2.0w bulb is too much, is 1.1w enough?
- New transmission on my car, I am worried something might be wrong.
- I saw a B4 80 Avant today on the highway...
- hey Audiboy_17 your lights are back on the way...(Wrong address first time) about Audi lights
- What size is the stock exaust pipe? 2 1/4"?
- The ticking engine saga rages on....
- 18" Superleggeras....what are the chances they will rub ??
- Tomorrows Festivities! :o)
- All I can say about Starlight's new suspension job is WOW! I can recommend this S. Fla. shop....
- Changing instrument cluster, How many bulbs?
- Need help accessing odometer inside instrument cluster - miktip i think you know how to do this
- Taking off Horn Pad on 89' 90
- Random Stalling
- Question for anyone that knows anything about the 1995 90Q V6
- Who likes my new cold air intake?
- Idle problem...
- a few progress pics of my 94
- Another Rice Coupe arrgghhh.......
- Car hard to get in reverse 5 speed 89 90Q
- Just got my coupe back from the painters........
- what should i use to lube my sunroof tracks???
