- Throttle body part 2
- poll, keep the 5 star Q rims on the new 90Q or put the 10 spoke FWD rims on it..
- Re: Off Topic Posts and the 80/90/Cab/CQ forum
- need paint code for black audi b4 :) thank u!
- Could someone remind me please?
- Gomera Pearl Effect for all you haters...
- Searched... found, but still confused. Control arm removal, offset wrenches didn't go in far enough.
- BTW....spotted a cab in the movie "Rumor Has It"
- This is how my CQ started its life with me...
- How long have you owned your car?
- rear speaker help..I know it's been done.
- how to replace the CPS
- Help body kit wanted
- random CEL at highway cruising
- ICM??
- which is better, VAP strut adaptor with UrS/UrQ Bilsteins or KW coils?
- Thanks for the wonderful welcome back BakerCoupe. . .
- why look for a 3B when you are going to upgrade anyway on a 7A?
- Looking to replace front bushings.....and seeking more hp.
- driveshaft center bearing replacement issue
- As of 2:35pm there's 422 Big-Bore threaded strut tube extensions ready to go!!
- need help with a electrical problem with fuse number 14 (B4)
- Let me share a story about my black CQ....
- Stuck diff lock.. Any ideas?
- Passenger power seat just stopped working (1990 CQ), is there a fuse?
- Engine is out and stripped of all brackets and parts, head is off....
- Damn...just saw 1Pissed90's car again this weekend...that car is sweet.
- I heard something in my right side inside axle flange of the front axle shaft
- New struts, ball joints, and tie rod ends installed this weekend.
- Remember Carlisle is this weekend!
- Could one shot catalytic converter decrease performance significantly?
- car doesn't want to accelerate..
- Dealer vs. Blau....
- does a B4 manual tranny have a Wire or hydraulic clutch?
- Clutch question
- 1995 90 quattro idle issue (stalling)
- Finally starting working on my summer projects today...
- Tire Suggestions
- Replaced starter, engine now overheating
- Just a couple o' Coupes.
- Do 96 - 98 Cabs have the B4 dash or B5 A4 dash?
- Just my Audi cabriolet
- how labor intensive is swapping a ps pump?
- Any interest in buying Motorsport coilover strut assemblies outright w/exchange program?
- Some have a bentley procedure for the R&R of tie-rod assemblies in a B4 90Q ?
- Do our cars have clutch master cylinder's so that the fluid can be chaged?
- I love free fixes that eliminate little things that nag you on your car!
- RallyX by air
- RallyX picture
- 20v engine won't rev down
- Turbo and diesel Audi - FTW!
- I'd like to be the first to welcome germanmissle back to the fold... Wrx's are crap, CQ's are
- cabbie
- Heheh, I "think" 800# front coilover springs with 1,100# rears "might" be a little overkill...
- First time I see this.. blue 90 fs in my area
- umm, my 95 has a gray wire in pin #8, where do I move it, was it #1 or #9?
- Throttle body dismantling
- So why does it seem like only Canada got those nice black auxillary's/ashtrays?
- Buzz kill: Lots of noise comming from a torn cv boot...
- Start gone bad XXX
- opinions on A/C problem
- E-Code headlight adjuster motor wiring (would be same for RS2 lights, or any euro lights w/ motors)
- Fuel Pumps
- Picture Friday - My two beautiful coupes
- Is it still picture post day?
- euro rear bumper help please. i finally got my euro bumper fixed and repainted to match and ready to
- DON'T PUMP GAS MAY 15th!!!!!!!!
- My most redundant/repeated email of the past 2 weeks by far!!
- I bought this long ago and never got around to installing it (Mance Velocity Stack)...
- Online EKTA?
- One of the Worst mistake ever!
- serious distorting/popping with new HU ..help!
- What's the stock exhaust diameter size for b4 90's??
- Great day machining today! Sometimes ya just get lucky and everything ya do works...
- anyone have a link to the site that lists the Audi recalls for the B4 90's?
- Quick wax job on the Coupe after work today. Looked so nice that I had to shoot a pic.
- does QCRAZY still hang out here, or anyone know how to contact him/her?
- Euro (hella) H4 headlight adjuster motors/harness FTW...
- My Coupe Won't Stay in Gear. . .WTF?
- Aftermarket catalytic converters? I've got a bad driver side one. What are my options?
- I'm in ur hoodz jacking ur audis
- Pic 1; Today's projects, by the numbers...
- Coupe Quattro wide fenders
- Get ready to drool a little...
- Odd radiator fan problems...
- Watch Audi TV
- Vogtland spring question - bottom 3 coils compressed?
- Can someone explain why torque on a bolt will be so many foot pounds PLUS a fraction of a turn?
- who here has done a 20vt swap into a 10v 80?
- Coilover Update; Design updates and weight savings
- Does anyone have a diagram of how the CQ climate control / cruise control vacuum works?
- Windshield....
- OEM Springs
- Servo Dust Boot
- Crankcase breather hose gunk!!
- are the wires to the airbag light in a B4 back/blue stripe & white/yellow stripe?
- Thanks to everyone for all there help yesterday, fixed 2 problems and have 1 more question..
- I have been driving my CQ for 10k now. One failure in that time which did not leave me stranded.
- is this a repost? pretty funny.
- Front strut question.
- Today I'm making tool steel kiss-cut dies for cutting urethane coilover spring insulators...
- rear brake problem: squeal when pulling away from dead stop
- 14v bulbs for the switches?
- Ignition switch?
- good thing this wasnt an 80/90...
- AAN experts...
- 2 more 1995 90Q questions
- skolnick, is it you that has the light up red shift nob? if so where did ya get it?
- yo tecknoquatt, reference this link..what size and length gear wrench should i get for the...
- turn key to lock in door (B4) doors lock but no "beep" form factory alarm horn?? what gives?
- when I set my interior lights to "on with door open" the light comes on with the doors closed..
- Update: First coilover manufacturing-related delivery shows up...
- Weirdest compliment or comment youve gotten on your car!?
- Regenmeister i see the plates on your vehicle read illinois
- just bought these wheels yesterday
- Audi Wont move
- Illustrated 12V Timing Belt / WP / Crank Seal / Cam Seal / Expansion Tank job. No 56k.
- Big Brake Upgrade
- can I bypass the alarm, but keep power locks?
- Scargo, where did you get this shift nob?
- When ignition is on, '91 CQ blower does not turn off and is always on High
- Anybody else in Winnipeg with an 80/90 Quattro?
- Anyone from Canada?
- brought the new girl home this weekend...
- Please excuse me, but I must vent a little. (maybe a little long)
- Suspension help.
- Problems with clutch pedal 1991 Audi 80
- Can spring in front suspension be upside down?
- This one's just for Mance...;-)
- Re-torqued my Blisteins today...
- M.Wetzel's Racing Products LLC delivers awesome products
- newbie just saying hello
- Hottest Audi in America? --->
- hot hot
- anybody have a source for Audi cufflinks?
- 95 90q. Passenger seat slides back and forth on rails, but only locks on furthest back
- audi 90 cs ?
- got oil pan what do i use for gasketing? liquid gasket? any type?
- Way off topic, but LET'S GO DE LA HOYA! You da man!
- How to install cam seal on the 12V?
- For those using GC coilovers currently or in the past, how many have ever had need...
- Threw 2 codes last night: 1111 (control unit) and 2142 (red knock sensor)... damn....
- I apologize for the noob questions=>
- Just removed my crank bolt - it was only hand tight! Sketchy!
- ABS Trouble???
- Look what I found in Bend, OR......................
- What is the torque spec for the Bilstein top threaded cap?
- Question about steps for removing the 12V crank bolt...
- Cheap struts?
- I found a 36" tube of "CP" Titanium in 2.375" OD x 1.813" ID w/.281" wall...
- Picture Friday...
- Picture Friday
- The 4kQ front strut daimeter vs UrQ, B3, B4, CQ et al...
- Hey Mance (VAP).. quick question for ya bud..
- Car turns over, no dash lights and won't start
- Family portrait
- Tool 3242
- good idea or stupid idea?
- Do the dash and the center console from a CQ swap with one from a 80/90??
- Timing belt / Crank holding tool not threading in 100%
- Early pear paint sourcing
- Mance? technical opinion on power steering cooler?
- 80/90 Coupe Cab national meetup?
- Need specs on those 2 bolts/nut (size and lenght) that hold the inner tie-rod to the rack
- Coolant Temp light blinks 99% of time (but intermittent) temp. gauge and H2O level ok... Any ideas??
- Windows/Sunroof Intermittent... Ignition Switch or some Relay? Help please.
- Question Nononsense: Where have you find the piece circled in yellow...
- 80/90 quattro 5spd
- You guys have any idea???
- What should i be paying in labor?
- Ya'll should post up your favorite 4x108 wheels ;-) I'm trying to get some ideas, since my...
- If you can't fit the turbo in it, cut up the car
- Just to whet the collective whistles 'round here...
- Compatability ???
- Stereo Help
- So, I'm gonna kick it old school on the Coupe. I'm getting a Hella driving light grille kit.
- Weeee! I'm excited. I've finally got all of my parts together for my suspension revamp...
- Adding Depo H4 lights...wiring upgrade necessary?
- the weirdest thing happened, my rear view mirror...
- Europrice Leftovers Sale, it's on the shelf, it's dusty, it's priced to go...
- Looking to throw some (more) $$$ at my CQ to get more hp...
- looking for pictures of green B4's
- Next phase of coilover kit production; Urethane noise-cancelling spring insulators...
- so i had posted up a couple weeks ago, friend wrecked his 90-
- whoa.. someone finally came up with a diff taillight.
- And what color would we like our coilover kits hard-anodized?
- camshaft position sensor 1995 90
- i searched but didnt see an exact answer. bumper fitment
- What is the going rate for a 1990 (early build) CQ's motor and trans?
- ok update pn my allroad tranny mount reasearch for a B4Q..
- 10th time is a charm!!
- Last reamaining strut tube OD question regarding 4k Audi...
- Pulled over yesterday...
- grrr... someone hit my rear bumper and left a nice mark... obviously dragged on it...
- Some video of the Coupe at the Redline Time Attack this weekend.
- Another new Coupe owner here!
- ok reference my earlier post about tranny mounts...Do I want the All road tranny mounts?
- Well, I have everything to start my next project... I will need some help..
- some rollin shots... add your cars rollin shot to this thread
- hiw hard it it to swap tranny mounts in a B490Q..IIRC it is a easy job, no?
- Strut tester for coilover strut/spring rating is on the way...
- Just going through my bentley....
- poll, do I swap my B3 aux gauges/WFG into my B4 and have mismatching..
- '95 90 quattro stalls at idle when hot...?
- As of 10:30 am Mountain Time I'm in the Vintage Audi coilover business...
- a_CQ. Heat shield?
- Brdman*, what exactly is the prob with WFG in the B4 aux gauges.
- anyone got a pic of B4 90Q rims (5 spoke) with polished lip? or polished lip and painted black??
- I need strut outside diameters for EVERY small-chassied Audi front/rear...
- ignition coil problems
- A little FYI for folks in the NYC area....
- Day 2: Started the heater core job, what a PITA...
- New coupe owner (almost)...looking forward to learning and contributing when I can.
- stopped by to snap a few pics of the new 90Q
- Starter Help
- UrS front strut adaptation, B4 rear coilover conversion and 7075 tubular rear tie rods...
- Clear corners are on.
- so I put a deposit down on a 95 90Q yesterday, pick it up net Fri or Sat....
- 1991 Cabrio, roof lid will not open
- So what is this special tool needed to replace struts?
- Anyone know why the coolant reservoir swells? Swiftaudi I see you had this problem.
- Installed some Pro-mounts on the 90Q yesterday....
- Wheel width
- Cool shot...
- Can you use a regular 3-arm 4" gear puller for the cam pulleys?
- i'm searching for ...
- 1995 90qs Auto Climate Control
- Ummm Houston... we have UrS Bilstein Sport Front Strut to Pro-Mount/SSM integration...
- Front corner bulb...
- wheel help
- Good news: Strut tube extender tubing is ordered. Bad news: Wont be here til a week...
- One touch up for windows and sunroof control Q's
- Wings....
- Sexy !!
- MTM S1 :)
- The designer should be shot :)
- A for effort, F for follow through :)
- I don't even know what to call this ?
- New Audi CQ owner
- Pic Friday....interesting look
- Looking for that B&W timing belt sheet that MikTip used to post on a regular basis
- Sunroof doesn't close
- Slightly off topic, but I bought a new car...
- Whats a good asking price for coupe doors/fenders?
- How do I tell if the half shaft that I have is a right or a left CQ Front??
- The Catch-22's of strut conversions...
- Were there incremental design changes made too window switches between sedans & CQ's?
- Love it...
- anybody has ever heard of that kind of car ?!?
- X Post- Look what crawled out of a snow bank. The summer car.
