- big problems here after 3" intake/XTB install
- Anatomy of an OEM strut mount, Part 1
- speed meter sensor
- Has anyone mounted a turbo in a b4 2.7L engine?
- Cooling System revisited
- what do you guys use to affix badges and such??
- All you Cq owners with upgraded brakes: did you upgrade the master cylinder as well?
- 96 Cabrio soft top won't come up
- lights, windows, tranmission all malfunctioning on my Audi 90
- Pics with new rims, and fixed pass side coupe
- Picture Friday
- Does the B4 linkage look like this?
- would a bad wheel bearing cause clicking/clunking noise when in reverse?
- Rear fog wont turn off.
- and some more pics of mounts.
- Friday pics, and vids! Laguna Seca with the 90/80 and Coupe
- 6 month Pro-MOunt trial is over
- pics form last nights suspension work...
- Friday rant
- Is there a Porsche website equivalent to AudiWorld ?
- Bling bling
- convince a b5 a4-er to get a 90q
- WOA. Lil tweaks but results
- Dammit!!!! My ladies 93 90 CS is going to frell me up again!!!! Subframe problem!!
- Gotta ask...what makes this an S-Line?
- Idle speed control valve.
- Beautiful S6 on craigslist...
- does anybody have an install guide for a rs2 look bumper?
- Some updates and the new addition to my Audi family :)
- help
- engine shaking
- engine
- Suspension compatibility...
- electric windows
- What should I do with these e-code headlamp lenses?
- B3 vogtland springs - Just called Vogtland...(WTF?)
- Rear licence plate surround on a cabby...
- AW New England GTG on the 18th
- Stupid question, but I just need to make sure... (Vogtland springs)
- Friday-for-me post: B4 sighting (mww) & CQ update.
- Who can count?
- the only b4 i saw in tahoe last week
- I miss my car...
- Can the shift boot be removed without pulling off the whole center console?
- Metal showing on the inside of the back tires...
- what prices have you come across to painting rear bumper?
- FS: Red 1994 Audi 90CS Quattro Manual
- Disgusting S8 spotted while out walking...
- Easily the most bad-ass B3 Coupe I have ever seen...
- oxeygen sensor #2
- Valve cover gaskets
- White CQ or white 90Q 20v around Ball State/Muncie, IN?
- Bleeding Cooling System
- wow didnt know stebro charged so much for their 20v SS exhausts
- Alloy wheel hub caps... picture
- Local Audi....LOL!!
- BRAKES!
- My sister just emailed this to me, someone was apparently upset
- You guys gotta get a load of this Audi80 on Autotrader right now
- 90 CQ 20V drivability problem..
- Skolnick, I STFA'd about your budget 5 lug swap on your Cq and could not find a list of parts.
- Search...
- Key not turning in ignition
- i did the red led cluster bulb swap.
- My baby just keeps getting better all the time
- story time.
- Pulled the trigger
- So, the Stebro sounds pretty funny on my Coupe.
- Exterior temperature display
- do I have enough room on that side? nice parking job
- European Wreckers
- why do we have 4x108 bolt pattern? its so damn effin hard to find rims! why couldnt we get
- who posted a pic of the back side of the instrument cluster? i need to know
- Did heater core and washer reservoir R&R this weekend on a 95 cabby- that was teh suck
- Best place for cheap floor mats for b4 90q?
- Which fuel filter?
- CHIP - How do I go about re-chiping the old b3 cis systems? the ke - jetronic system
- Pearl white '91 coupe in a salvage yard in Maryland
- 3rd gear grind
- Hub upgrade... I want to do the hub conversion, whats the best way?
- power steering fluid..
- Who had that spare driver's side B3 headlight?
- This would make a great dedicated VAG-COM laptop
- Interesting tid bit i forgot to share with you all from my recent TB/WP replacement...
- Is there a write-up for the door-lock fix?
- If these were made of Chrome-moly with the correct balljoints, do you think ...
- Guys with CQ's. Whats 's your procedure for moving off from a dead stop such as stop sign etc.?
- Black quattro script interior
- Fuel Gauge...
- does ATF burn up?
- interesting info on tools...
- pics of tank idk about ...haha
- Front parking lights and hazards not working?
- I need some help to understand what happened........
- What is the going price for a complete 7A package?
- I'm have a hard time determining what to do with the new CQ
- Quick Q: What type/size socket do the 7A head bolts take?
- the aluminum jack I got from harbor freight is broken, it can't hold the weight
- brown connectors
- Where can i get control arm bushings for a B4Q... mine are 99.9% shot and there are none on ebay....
- car is back finally
- My completed lago blue 20vt coupe quattro....
- what is..
- hydraulic repair kit for top motor availability?
- poor coupe! why would someone do this!?
- A/C works but air is not coming out of vents
- 1991 80q - Fuel Tank?
- my new garage for pic friday
- anyone located in or near green bay wisconsin
- Spotted a B3 90 here in town
- replaced struts inserts on Audi 90, but don't know if I did it right.
- FRIDYA@!! Quiz! Name these AW'ers...
- Could use some help diagnosing a problem with a CQ window...
- Friday Pics
- Rollin' deep
- Is there any trick for resetting the Airbag light without a Vagcom/Aftermarket scanner
- Friday Pic of Today's Mod...
- Inside Track Motorsport Magazine... page 65... thats me!! Winter Rallycross.
- Someday...
- "Body"
- What should be my next car...
- Pic day
- Friday picture!
- What are the similarities between 4kq's and early 80 quattros?
- ETKA help please.
- seen this R8 hillclimb?
- After that CQ comparo I have a question
- An interesting place to put a 12 valve engine.
- cq help
- Does the 95 90 power antenna have an amp?
- car running good but throwin code..
- Busted!
- The stock exhaust is rotted on my Coupe is rotted, so I got a used Stebro from a buddy.
- Idleing
- Early 1990 Coupe vs. Late 1990 Coupe; A Photo Comparison (really pic intensive, over 40 of them)
- VTAnnon please email me!
- What do CQ Yakima racks with the bike rail and the ski/board attachments sell for??
- 1994 90S, 12V; A/C Compressor not kickin in,
- Haha, another deletion? This forum has more drama than a Jerry Spring show.
- Don't wanna jinx it, but I might have found an NA 20v for my coupe.
- the 90 left me stuck tonight..... long
- how to remove the center vents on my b3 90q
- I like
- ballar
- 88 90 4 cylinder not starting :o(
- Just heard that Audi has ONE last 20V B3 engine (tall block) they are trying to sell.
- No spark at the coil and no Check engin light
- Thinking about custom fabing a B5 A4 bumper to my B3 90Q
- Copper or aluminum crush rings? I've always had/bought/used copper on all of my Audis...
- Help me diagnose this thunk?
- Ooops...
- VT guys - anybody got a lead on a B4 hood...
- Help with cruise control, and a few other problems
- Rooftop Antenna...
- Looking to buy a '95 90 model...
- Well, finally got the new turbo/injectors and other stuff installed
- anyone know how or where I can blue tint side mirrors?
- Poor Pasta Rocket
- Has anybody ever NOT crashed an Enzo?
- Which one of you guys posted here about mounting your S2 rear bumper &....
- Does anyone here use Radar Detectors and laser jammers?
- Looking for a good source for Euro 20v rotors 893 615 301
- opinion on 1991 Quattro coupe
- Are these the allroad trans mounts?
- Some could get a deal
- 93 Audi 90 cs -fuel gauge and temp guage sensors
- Wish me luck...Update 1 (long)
- Hey guys... looking for a reason to post here.
- guys with RS4 rep's, just looking for take
- Whoo! finished another carbon fiber project on the 90
- RS6 headache? Yesterday at PepBoys watching owner and PepBoy salesguy trying to change...
- AUDI 80 electrics
- Any positives to adding an afterrun fan on a B4?
- Lol, if you've been wanting a CQ but weren't sure if you're ready. Start off w/ a training 1
- my ultimate dream bumper..
- B3 Hood???
- Radiator Fan update
- whats the difference between..
- nac, but looking for horizontal bar lock for door.
- Where can I get my bomb recharged?
- any other ideas on how to remove the cam sprocket??.....
- Cabrio Top Motor and Issues
- Wish me luck........
- Here's your chance to own an '84 coupe for the price of a Sport Quattro...
- Rear spoiler
- Ha! Look what this moron did...
- Why is VOLVO advertising on Audiworld? Stupid Google ad service.
- dash lights will not turn on!
- Turn your 90 into the RS4 look ?
- Can anyone translate this...
- Audi 90 Quattro transformation
- What lights will fit in the S2 bumper?
- let me see if i got this correct
- Whos got high mileage on their 12v 2.8 V6? ('92-95) Robust as the 5cyl? Should be interesting poll..
- Audi 89 Cabriolet manual book
- Good independent Audi specialists in the Berkshire area (UK)?
- Audi 89 Cabriolet (1993 model) roof won't operate
- Audi 89 Cabriolet rear screen replacement (1993 model)
- Moving the shifter position
- I need a quick ETKA lookup........S2 hub bearing
- special deliver form gremany!
- Got updated front Vogtland springs. One of the easiest things I've ever done...
- i just found out my oil pan has a crack!!!
- speedmeter
- No more crush washers for me
- Anyone end up getting PEX ball joints
- Break time. I'm out.
- S2s-R-Us, pick a car, pick a turbo
- I thought it was Friday?
- B4 Hood and Headlight Gap
- I haven't check the bentley yet, but regarding center vents..
- (Lowering) Shocks, Springs, & Drop Height - Recomedations :)
- OIL PAN CHANGE?
- CQ window regulator stuck down, in Seattle...
- HELP! windows+sunroof do not work correctly.
- CQ Coolant/Oil Temp sensor warm up issue
- I know its not firday yet, but i gave the coupe a bath today so....
- Some oil found on my spark plugs- bad rubber gasket the culprit?
- Has anyone put a VW antenna on the back of their roof?
- sway bar links
- Part number for coupe window regulator mounts?
- 91 CQ Instrument Cluster
- For those who believe in Santa Claus (or that Meyle parts are made in Germany)...
- haha, had a great electrical day with my car last night
- What online retailer sells OEM (non Meyle) coolant tank reservoirs?
- holy F#$%$# nice 90 saloon
- central locking system ftw
- Well, the Coupe is running like a top now...
- custom fabbed exhaust $?
- I cannot use the air compressor anymore due to house wiring, would electric impact
- 1.5W instrument cluster bulbs.
- For those that have replaced bad clocksprings on the older style ('94 and earlier) airbag...
- Dependability
- it's funny, someone calls themselves an "actor" they always have to include "songwriter, bartender
- Can somebody tell me if the REAR "A" arms on a CQ are the same arms on the front of a '86 4000 CSQ?
- How do I remove the front strut assembly?
- Just some weight differences info: Euro Cabbie bumper is much lighter than S2 one. Also...
- Where do I get these lights?
- OEM temp. range that the radiator fan switch kicks on? 75°C
- What to do with a broken CQ
- Now for something completely unexpected.....widebody kit for CQ?
- Ways to clean up a 12v engine bay. Just lookin' for an idea thread.
- Will the 160 mph speedo from the B4 fit my 20v? *cough* SCarGo
- Pricing of a 90Q
- Ok, so what REALLY needs to be replaced when upgrading to new struts and springs?
- IS the euro cabrio rear bumper the same as the S2/CQ?
- Just a few 7A vs AAN comparisons
- just got an rs2 b4 bumper for my 90 any suggestions on mounting?
- 1994 Audi 80 2.6E part number question
- spaghetti for lunch :P
