- Started engine removal today
- Wow! I just wanted to make sure everyone has read the R8 article on the main page
- [TUE Oct 17] This is it L.A., last GTG @ The Stand for this year... don't miss it!!!
- My stock CQ clutch will no longer hold the power
- A good Audi guy has to give up his dream and sell off his parts.....
- It's out! The end of an era! If you need any B3q parts, now's the time...
- 2114 Code Hall sensor sporatic...FIXED...
- Megasquirt, here I come!
- Just replaced the VSS, but still no speedo reading...
- how much is this in us currency
- Audi 80 body panels
- What is stock idle on the cq?
- car keeps failing smog at idle
- I'm close to pulling the trigger on some new front seats, but wanna make sure I'm not...
- need help modifying my light wireing harness
- just got ripped by my FLAPS
- good thing i passed on this. interior isnt that nice
- Puzzles about timing
- what I picked up on Sunday
- Battery drain on fuse 19 for locking system and door lock heaters.
- I cannot find the 80/90 FAQ.
- 1990 '90 3spd Auto tranny problems
- Bought another CQ tonight, pearl white on grey. #230 100% bone stock
- Underside pictures of your custom exhaust, sound files if poss., and description of the setup used
- Is $3000 a lot to pay for the 20VT engine swap??
- Oh great....wonderful end to today....
- what's involved in putting in an Air Fuel Ratio meter ? ......thanks
- So I finally fixed this squeak in the back of my CQ.......thought to share......
- Bentley pimps... need help w/ temp sensor tests
- climate control unit
- So who needs parts from my 90? I have a billion of them lying around and my dad is on my case...
- If you had the choice.....
- How would a CQ run if the throttle position sensor is not hooked up and shouldn't that trip the chec
- Next problem....rear sway bar
- diagnostic ports??
- PIN OUT for a b3/b4 cluster?
- Is there a coolant temp sensor on the 20v sedan?
- Anybody got an extra one of these? 20V intake boot.
- 2Bennett Stebro exhaust. Anyone have any experiences with this?
- Looking for a good/cheap tie rod puller. How's this one from sears??
- just got the coupe back from the shop...
- New development?
- diagnosis q: blower motor or stuck flap? read on ...
- Trip computer install into B4 cluster. Can't find the write-up in the Search.
- Anyone ever swap from manually controlled climate control unit to digital climate control unit?
- whats the deal with the two different blower motor resistors?
- Anybody have the pigtail for the throttle position sensor for a CQ? It's a white 4-pin female.
- Hahaha... broke the gas pedal off tonight.... rally car is finally back on the road!
- WTB: Front subframe for a B4 quattro...NEEDS to be mint....ASAP
- DS spline ends cut ready for next step............
- Serpentine belt update for a 93 90cs...
- What is normal fuel pressure for the CQ?
- Need new CQ antenna - Fuba Beta-Flex D- CDN supplier
- Trunk lock part needed........who's got a parts car?
- Which spec 034 injectors does my 20v need?
- Braking issues?
- Ok....new cap and rotor....no change to the no-start.....
- I think im missing something...
- Just got a 4000q front swaybar for my 90q rear. Need some end-link suggestions
- looking for the torque setting on driveshafts for B4's
- 88 90 2.3 5 cyl 10v performance
- Anyone have a diagram for a B4 90 Quattro to show where knock sensor is?
- Just drove my Coupe for the first time in ~2 years.
- Booyah!!
- Any write-up's on putting a 2.8L 30 valve V6 from a B5 Audi A4 in a '95 90 Quattro?
- got a free audi coupe quattro (my second) ... tornado red
- Motul tranny gear oil
- Enjoy some autocross video:
- 90qcwhite
- Just drove the Coupe after a week away from it.
- HOLY Zebrano!
- woah, haven't been around in a while... where's a good place to get B3/B4 performance parts
- help!!! 10v problems
- 88 80Q parts and tire questions
- Someone has to want these...
- Parts?
- Is gauge cluster brightness potentiometer a dealer part?
- Strut bezel installation procedure. Step 1;...
- mc2 swap wiring questions
- Probably a repost, not mine not associated...
- shocks and struts
- Hi guys and gals, particularly those in Utah... I'm usually in the 5k/200/V8 forum but....
- hmmm. hit/skip?
- Clean & tight engine
- shipping wheels over the border
- Xpost: Winter cometh
- Cabrio back to life
- Sacrificial Drive Shaft arrived this week...........
- got this in the mail today..
- 1995 Audi 90 quattro air conditioner leaking
- Need new Right side marker (clear) or Source for one
- 10,000th Post. Does this mean I win life?
- Anybody out there with a B4 90 parts car, I need a few things.
- Any RS2's for sale?
- Ok...now i think its fuel related....
- the coupe drained my brand new battery in 48hrs.
- Where does the sunroof drain to? 1988 80Q
- Picture Friday Mania!!!!
- On the lookout for a second set of wheels, any ad sightings?
- What looks odd on this car?....
- suspension question for ya
- Friday
- Coolant Temperature Switch location?
- Renault wins Japan F1
- restoring Zebrano
- Anyone have a used stock 90q20v or CQ flywheel lying around?
- Remove door window/mirror switches etc...
- Anyone here near Portland, Maine?
- 3.0L V6 block in a B4 90: is there engine mount issues?
- Joe (NoNonsense) Are those 5x130 wheels on the B4 90 in your sig? Thx.
- Steering noise....
- Trans questions.
- 94 90s
- pix friday! yay 1st one!!!!!!
- what wheels are these?
- 1988 90Q 10v - water pump difference?
- ok, i need some input on deciding on a new car...
- I'm thinking about buying a '94 cabrio. Mistake? I'm a total DIY...
- What is normal oil pressure (bar) when crusing at 60, and at idle, '95 90q 2.8 V6-warm engine Thanks
- can anybody confirm these part numbers for bilstein sport shocks for a '94 90 quattro ?
- Cheep 91 20vq...
- Just curious....Guys with 93-95 sedans, your driver's headrest....
- Anyone have this problem?
- How do you remove the clutch master cylinder on a B4?
- Time for rear calipers to be replaced. Where's the best place to look?
- part number question
- Another gauge illumination problem thread. glove box light works OK...
- Access to the CL pump
- Advice needed on Audi Coupe
- heater blower motor fan yada yada questions...
- Brake hard line question
- can this riddle be solved, what can cause transmission or rear engine rattle sound and idle jumping
- stupid seals should be shot
- differential pressure regulator question
- Ok so i think i figured out the pattern to the No Start issue....
- rasphy (sp?) exhaust note
- Bentley Manuals
- Hey Skoolie...
- How can i tell if i have an early or late CQ?
- The exceedingly shy & rare double-strutted yellow-breasted Quattro Warbler...
- Awesome video for all of you IMSA and early DTM fans...
- This enough offset to get into the subframe to do the control arm nuts? Or should I go higher?
- (Hub question) Does anybody know . . . . . .
- Do these wheels remind anybody about anything?
- in a perfect world...
- Is my 90Q capable of majorly breaking down after this?
- PSA: jpcady is the man
- a_CQ I sent you an email....
- Timing belt job....
- Will pay for Hella Right side marker (Clear)
- Part 4 of my on-going problem with the propshaft center bearing squealing....
- Option code look-up help...
- Some vanity plate options....State of IL got back to me with pissing news...
- '95 90q Sport - Should I get Bilsteins or BOGE, and who has the best price? And some cars for sale!
- Does a 20V have a Steel RF shield on the distributor?
- it's official... the rally car hates me.... 2312 temp sensor ghost.
- I need a new Hella Right side marker Clear need a source
- My CQ has no muffler... just straight pipe from the resonator
- Last chance offer on RS4 wheels 17x7.5 et35
- WTB: 14" (yes 14") wheels for my 86 5K -- 4 x 108
- Just looked at the R8 pics. love it but the silver intake covers remind me of Mercedes
- I've got that sinking feeling! Clutch pedal low?
- Hmmm....how do i bring a thread back to the top, so it doesnt get lost in the mix.....
- replaced ignition switch and have some problems
- LOL...this is hilarious! Audi commercial...
- Cliffs notes on replacing front subframe bushings on a CQ. Anyone?
- I WANT COILOVERS!
- Coupe window regulator rebuild
- Pro-Mount Review #1
- Can the cluster bulbs be bad even though the filament appears intact?
- CQ hatch leaks, anybody else? Comments please...
- Cheapest source for 7A flywheel?
- Heater core housing not moving
- Just for a little advice...
- Removing Throttle Body
- NEW PARTS!!! 4 weeks later!
- Ordering a new trans, 1995 90 q 5 speed. Where is the code on the unit?
- Took a LOT of math but I've finally done it!! I've nailed an equi-distant strut washer gap...
- This is a public apology to Tim & his outfit FAP99....
- Comparisons between stock 5cyl and stock 2.8 6cyl.
- Nate!!!!! Why you selling you 90?
- Can anyone confirm that a dead temp sender on a 1990 CQ will show nothing?
- Having a heack of a time finding coolant hose # 855 819 375 F... any ideas?
- Having a very hard time getting power steering pump model
- Allroad mounts on B3 (coupe-q) rear differential
- Anyone know of an good NJ shops?
- 01108 - Power Window Closing Relay (J292)
- Man I need to clean my car again...
- LAST CALL: ACNA 2-day track event @ Willow Springs (Oct 9-10)
- Are there any folks here that live in/near/around Boise? I'll be out there from this Thursday...
- Auto trans lighting BT....The bulb is ok on the auto trans shifter but ....
- Happy Birthday Jacky
- Whats the correct procedure for 1994 90S Ignition switch replacement? Seen different proced's
- 2 part question...
- AANarchy
- Does the timing belt get louder as it gets near its life's end?
- These will make someone very happy...
- 20v with no balls, bad knock sensor?
- 90 q c
- B4 Clutch problem... what do you guy thing ?
- Is rear window from B3 swappable with B4?
- Timing belt off without mark! What should I do?
- 2006 Central PA SCCA Driver's Challenge - Very faint Audi content
- Hello...
- Is there any reason why I can't have different springs on the front vs. rear of my vehicle?
- fair price to sell 1990 coupe quattro 90k miles?
- Did clutch. Hard shifting bleed already
- More alloy washer blueprinting
- measurement/clearance and strut travel issues you can expect with alloy washers...
- anyone got a working ISV that they want to part with?? ....
- Schumi WINS!!!!!!! In CHINA
- a couple of questions
- hey! anyone need any remotes?
- ECU Pinout/Bentley request.... B3 90q... Need to know pins for knock sensor
- Hey all, back from Greece and brought some pics for all (long)
- head gaskets
- How to hold cam pulley while removing the center polt?
- If anyone needs B3 or B4 parts let me know.
- springs / shocks for my 90Q -- looking for sources
- 91 CQ Power Seats
- yo CV did you send that CD to my adress in Ontario or New Brunswick???
- Radio question....
- Oh, did I mention they true up and polish out VERY nicely?
- got my srutmounts replaced about a year, 10 k (km) a go and they seem loose again ?
- do these parts have the right specs for the 3 to 4 wire maf swap??
- my car is bleeding black goop
- tbelt (what else do i need?)
- picture friday
- Ok so why thf don't my gauge lights work? cut out the trunk wires already.....
- How to pull codes on a 95 90s
- some might be interested (not my ebay auction)
- alloy cupped washers with strut bezels installed in car...
- whould this work on the cq
- Ok here's Ryan's discovery and with some other things it'll work as well as if I...
- Speedo quit on me today....
- Mance, did anyone ever guess correctly what "Side B" of the Pro-Mount tool was?
- anyone ever install rear euro lights?
- Pic Day
- What options are there for raising the suspension on B3 90 Quattro?
- Friday is picture day?
- I set off the alarm on my CQ. Woo, it works.
- How do you bypass immobliser
- dad got me an awesome birthday present =)
- Might be time to **gasp** sell the CQ... (kinda long)
- Heheheh, I just had a lil stoplight-to-stoplight dalliance with a V8 S4...
- What are the 2 little plastic tube pieces that come with a head set
- o2 sensor replacement update...
- Buying 97 Cabrio Any advice?
- Is there a procedure for breaking in new brake pads and rotors?
- Anyone have a spare pearl under headlight trim for the driver side? Never lost one before....
