- buying rebuilt axles for my 88 90q, even tho there is a vin split and I should get the correct one
- Re-post picture friday...........
- I replaced some bulbs on my CQ last night. Now all the dash switches light up.
- It's time. I need a 93-95 90 fwd 5 speed
- AC power drain
- 200 shift knob on a CQ?
- Audi 90 non-quattro
- Anybody know where I can find the rubber piece that fits between a B4 hood and the grill
- Suggestions for a broken speedo/odometer
- All of you RS2 front bumper owners please share the secret!
- still lookin' good...
- i just recieved a new front wheel bearing from autohaus, the 2 inner sleeves are different
- CV joints to suit a '94 Quattro?
- Odd request... Anyone have any pics of side-impacts on a 90q? Specifically, interior shots...
- Still trying to figure out a starting\running problem
- Test drove a few Audi's today!
- Vermont People: European Cure/Metric Machines
- how many of you have replaced your fuel injectors and found a noticeable difference..
- DIY Switchblade Key
- What are the symptoms of a failing heater core?
- Lookeeee what I did
- Anyone know if any Audi currently comes with 3" exhaust?
- catalytic convertor heat shield
- Timing belt broke while I was driving Fri night.....
- Do I have to remove the CIS on my 90 to get to the air filter?
- Best place for a new or reman rear caliper for an '88 90? Shokan?
- Can't let a beautiful car go to waste.
- Trifecta I guess....where do you guys get subframe bushings for CQ???
- Another question....got my new Clutch master and slave cylinder today...both are FTE brand and made
- Rear diff mount question....I took my old one off, ripped the rubber bushing out and....
- Looking for 112 x 5 adapt
- Anyone have a spare front fog light switch and/or B3 fogs?
- Recent Work?
- parting out both of my 20v, if anybody wants anything.
- If he sells this for the asking price or near, I have a plan...
- Need CV Joints for 93 audi 90 fwd manual
- I guess I'll ask again... see if you guys can help - cooling problems
- wheres the best place to find cheap struts?
- Which year A4 can I transfer wiper arms from to my 90?
- any CQs, 80s, 90s, Cabs going to the Motorstadt show??
- I have eliminated the vacuum connection between my intake manifold and carbon cansiter
- V8 running
- blower housing bushings...how to remove?
- re: My "Another one bites the dust" thread
- I hate Regenmeister
- looking for air intake parts - '88, 90 quattro 5 cyl
- Miktip, what's this?
- Has anyone ever used AcCel yellow Spark plug wires ?
- 12v guys, waterpump question...
- H&R springs and Koni shocks are on, I've been driving too much to take pictures.
- So is the dealer really my only resource for a
- Wheel spacers for CQ... Any links? Thanks..
- for those interested.. I just found a really neat resource-table for FUEL INJECTORS. check it out
- Theres a '92 80 tdi in LA
- Troubleshooting my cooling system... need help!
- is there something cooler then water?
- is this even a bit accurate?
- is it true
- starting problem.
- Bleeding the brakes?
- Question about sunroof repair and cruise control?
- Gas milesge.....Best speeds to save?
- Cabriolet top latch questions
- Gunked up fuel distributor? Or wet ECU?
- Looking for an arm rest with mounting bracket
- dose B&G springs make a model for quattro i can only find ones for Fwd
- Any other sensors to change out while intake manifold out?
- 80 got a new CD player today...
- Came back from the dealership with bad news =(
- feeler, possible FS 93 S4 parts car....
- CQ: What kind and size of speakers have you replaced the OEMs with?
- is there info in the tech section on the A4 wiper upgrade? i couldnt find it
- Looking to replace tranny mounts...
- New [old] O-Z wheels installed
- Magnaflow Cats
- I caved..
- how do you pull codes on an '88 model 90 ? Do I need the "2x2" Vag-com adapter ?
- can i get some feedback
- Finally rolling again...some pics of the progress
- Audi 90 parts car!
- Mount-Savers just blew past 3.5 million miles on over 2,200 pair on over...
- 1993 Audi 90s PARTS CAR
- New ClearCorners,fogs and headlights
- CEL, '88 model 90
- Another one bite's the dust
- Fluctuating Engine RPM (kicking)
- If anyone is looking for a coupe, seems like a steal
- 17.2 @ 83mph.....is that about normal or is my car really slow??
- 1995 Audi 90 - Knock Sensor location?
- Is there any market for a fiberglass or carbon fiber B3 hood?
- For those of you have have BTDT 'realigning ABS Speed Sensors'
- I powder coated my wheels...
- ALMS Mid-Ohio photos and video. Hope you've got a high-speed connection
- I'm in a jam and this might not be cool to ask,but is there anyone in Seattle with a car trailer...
- Old battery box removed
- From one 12v to another.....(Bandwidth warning)
- CQ and 90 update. Wow. It feels like so long since I have posted anything new here.
- Part number?
- error codes 00514 and 00516, now what?
- She's gone
- Anyone in or near AZ? There is a MC1 and 5Speed posted for free on
- anyone in the Se. PA area that has worked with Megasqirt EMS ?
- Need to share my frustration.....
- Saw some VERY nice Audi's in Ohio a week or two ago...
- Space....
- Which way are the fans supposed to blow?
- 1995 90 S Quattro For Sale -- STILL FOR SALE - REDUCED!!!!
- Who's had experience with Luminics Bulb?
- Anyone run H&R's on a cabrio?
- ok here are the available toys .. i need to do something about this :)
- Help... my '93 CQ is blowing fuse after fuse
- H&R springs on the coupe, Binding?
- Hurray, my rear caliper isn't crap...
- I'm usually better at this, but....
- PNW... Need a front bump stop/dust boot and RF tie rod end for the coupe... anyone?
- Right Rear Caliper Rebuild kit?
- *spotted* Black CQ with S badge & PCA sticker, anybody here? OK, my server is working this time
- borbets getting hard to come by
- friday pix day..... "Wheres Audi"
- My first Friday pic....
- Floor mats!!!
- Antenna Question
- When I get back from Burien, its time to rip the CQ apart
- does the thermal switch (fan control) in the rad need a o-ring ?
- My coolant idiot light is possessed!
- Hard brake pedal = bad bomb????
- Need an oring size for a 2.8 12v
- today on the way back from work ...
- New to Forum, new Coupe
- Picture day...
- June 2nd and my school has a 2 hour delay?....
- PSA: FAP99 a real good and cheap source for OE parts...
- headlight,corners and fogs...replacement...anything I should look out for...
- Chickaan Stripping Two... tribute banner for the second dissection =)
- Chickaan Stripping One... my tribute banner (yea, it took a while in making/finishing it)
- Odd question - does the area under the belly pan have positive air pressure?
- Go wide!
- Welp. q.P. is back in action
- Can rear wheel alignment affect the steering wheel center?
- So I've done a little work lately, nothing special
- Audi 80 Starting Problems Please help!
- give me some reasons why my front alignment would get thrown off when hitting hard bumps going fast
- Is $330 for an aftermarket B4 hood 'shipped' too much??
- Anybody ever heard of this stuff?
- What do you call the tube on the 7A going from the intake manifold to the ISV? (I need to order one)
- any BTDT on rehanging B3 doors? I'd like my car to have that 'shooomp' sound when I close the doors
- Former 80 Owner here
- Man here it is Summer & I haven't seen a posting about converting AC...
- Will a front ABS sensor work in the back? ...(90 CQ)
- Its back!
- Zoom!
- 20v Exhaust Cam Swap questions...
- Its Friday!
- Anyone know where I can source out a B3 80 fwd auto 3 spd tranny?
- Any pics of Titanium grey anyone?
- Screw it, I will be a pw today
- SOS pad back in. Hope I never have to replace that again.
- Miktip re: brake lines
- I need a belly pan for my '93 90s oil changer didn't put it on correctly
- Looking at Magnaflow cat, center and rear muffler for my 3" exhaust system...
- Impressive....
- Speedometer difference...?
- where can i get eibach or H&R springs from?
- Unplugged ISV, car ran smoother, idled BETTER.
- 94 90 having trouble cranking...
- hey SoCal, check out upcoming JUNE Events - Pine Mtn Drive/Winefest & Streets of Willow track
- HELP! Anyone driving from Phoenix to the Seattle area?
- Update on crankcase breather hose
- Replacing the Diff Mount on my CQ but have 2 ?'s...
- seems like bad things come in bunches...
- Is this anybody here? Black Audi CQ with //S badge & PCA sticker
- The first thing I'm gonna get when I go to Poland =)
- CQ electrical gremlins...
- Do any of you have the Widebody CQ?
- Gonna do a whole new stand-alone inductive pick-up mount for the 60-2 degree wheel...
- Some pics of yesterday's montreal Audi meet
- Goin to my dealership tommorow =)
- Pimp my 80?
- Do B4 2 piece brake lines work on a CQ (that also needs 2 piece lines)?
- Any BTDT w/ replacing the oil pressure sensors in a 7A?
- Brought my CQ home last night, got it running today in under an hour...
- Who has bought a CQ within the last 5 months? Put up your hand.
- what is the differences between these two O2 sensors??
- Last new 5x112 17x8.5x35ET SSR wheel in the US and check out the inner boxes...
- My CQ is half black.
- I WANT TO DRIVE MY COUPE!!!!!!!
- For those of you that have sold OE 14" B3 mesh wheels, how much did you ask/get for them?
- Don't mean to be a pw, but has anyone wet sanded their car?
- What are the affects of a collapsed crankcase breather hose?
- Any one have a central locking pump for a CQ
- Best place to get inner & outer brake lines for a '90 CQ?
- Paging Gogu YGM :)
- Cabrio Hard Top.....
- AUDIMAN3 (Mike's) CQ...
- wrong forum... but this can't be real....
- The heat shields on Audis are amazingly expensive and just as flimsy! LOL!....
- magnaflow high flow cats
- Is there a way I can change the email listed under my account #, without changing my user handle??!
- End of and era for MasterB - 90q20v officially for sale
- Could Someone please help me with some info on Radiator Flush on a 93 Audi 90Csq
- someone needs to place a bid
- ultranator almost completely crapped out, battery light comes on during heavy usage
- No auto check and no spark! Please help
- Poor radio reception
- So, with the temps nearing 100 degrees today, I'm becoming motivated to diagnose......
- this was ****ty.....99 passat
- Steering in a '90 - 80
- Factory parts
- awesome experience over the weekend
- Thanks to help from KoupeKrazy then engine came out of my 90 last night.
- how much did you pay for an AC service (change gas /recharge system)
- anyone want a factory repair manual for Audi 80s,90s, and coupes.
- Does anybody know if Billzcat1 is still selling SS brake lines?
- Farewell to my beloved 1988 80tq, today, I kill you. (need parts?)
- What kind of fuel mileage are you guys getting on a non-quat auto 1.8 '88 sedan?
- Catalytic Convertor - 1993 90s Manual
- ok seriously I think I am just tired, but where are the screws holding the ignition switch in?
- Looking for another Audi.....classis
- So... I'm gonna flush my own coolant...
- Some cool, free music available on Audi's website. Bit "lounge-y" but nice for long drives
- Soon to be morphed into the cabrio
- B3 90q - Need T8 connector at fuse box......
- What are the odds of this happening? New driveshaft bearing...
- will my 1989 90 seats swap into a 1995 90??
- I am lowering the Cabrio 20mm. (Eibach). Do I need to install also sport shocks?
- "When you STFA, heed advice in advance, and STILL F*&#^ up".....
- What is stored where?
- Gas guage quirkiness...
- Is it possible to remove the intake manifold without removing the throttle body on a 7a engine.?
- why did my moonroof decide not to close today?...
- New ride for the summer.....*ducks and runs away*...
- Anyone?
- Anyone have a pic of..
- pics
- Nkugs90 I got the tail light, thanks!
- When car starts it jumps to 3000rpm and stays
- This is very cool
- to whomever worked on my car previously... antiseize does not equal loctite!
- mobil 1
- SKY INT air intake........anybody ever used this intake? 93 90CS quattro
- Is there any reason why a 10V would rev fine while in gear, but rev irregularly while in neutral?
- New member introduction
- Anybody have a Bently they want to let go (CQ)
- 95 Audi Fog lights?
- learning "curve"....93 90CS Quattro
- got out for the weekend yet again...did some work on tha 90
- Audi Expo 2006 - Come be a part of history again!
- 3rd Annual Old School quattro gathering in Cumberland, MD starts July 28 - click to sign up now!!
- Finally got my checks in...
- Flikering CEL at 5500 RPM 7A 90/90
