- Differences with 80 and coupe
- fuel injector R&R....
- Is there any where to get the hoses under the manifold?
- ignition timing for '88 4cyl 90
- Location of OBDII plug?
- OK.. How do I remove fuel pump without the damn special wrench?
- Winter beater in parts...
- Silverstars or High Wattage
- Wheels, horn button for an aftermarket steering wheel
- DIY for Torsen diffs
- Any CQ's out there with 17" BBS RX's?
- S2 bumper on my B3, sorry kids no BBS RX's though
- just when I get rid of the 90, the A4 starts coming apart...
- Ive looked all over. Where to get lowering springs for my 93 90 cs Quattro?
- Update...
- And another one...
- Anyone in CT have a fuel pump wrench (3307) I can borrow for a few hours?
- How worn is this clutch on a scale of 1-10? also some swap pix
- odd problem, running out of ideas..
- Locking dif?
- anyone know the way the mount is suposed to be facing...
- whose got a pic of that S2 sedan driving on a street with treesthe leaves are kicking up behind
- pix friday and what i did yesterday...
- The father of "quattro".
- 4th (unused) pin on B4 headlight connector?
- Cab fans.
- Poor RS2.
- RS2 in winter mode.
- Friday....hot car sans the overhang...
- Friday
- More photoshop fun... ;o) [edit2]
- Anyone parting a B4 out there?
- Thoughts on the 20v "bag-o-snakes" tubular header...
- The MikTip cello
- Just fixed my comp and lost everything, Bentley and ETeeKA are in boxes somewhere for move.....
- Friday is picture day...
- Picture Friday's pic of the year....
- Headlight relays
- which way is top on Vogtland?
- Photoshop is funnnnnnn...
- Mance I got a couple brake part pics for ya :)
- 1994 90q beater. Fix it or flip it?
- Oooh, I found a '96 Cabrio in the junkyard today!
- Need cam gear timing pulley!
- OK!! Got the right manual and making headway. Bad STARTER for now
- Removing lower door molding?
- Whats the link to the B4 carbon hoods??
- Does anyone have a scorpion exhaust theyd sell
- what's the correct bolt size to mount my new rear license place to my CQ?
- My friend just sent me these pcitures. A $16,000 Ginster Yellow Euro Cabriolet in the US.
- pretty cool...kinda OT
- OK I'm leaving the office and one of you is in charge
- Brdman, do you still have your site? Can not find link in your sig?
- from our new FAQ
- Pageing 96 cab...did you evar get answer on...
- 12v.org is back!!!!!!!!
- who here lives in the PHX area?
- The work-in-progress 80/90/CQ/Cab forum FAQ...
- Speaking of coupes, I want one, lika dis, in disa nice setting...
- 18" on Coupe Quattro...anyone got pics?
- IS there a relays dedicated to the windows and sunroof?
- wow! Subframe finally came out at 3:30AM CST
- Heater core on 1993 90S
- SCarGo, you've seen this...your neck of the woods
- TC in a 4cyl B3...I will do this, I will...
- Clutch Issue - Continued...
- defrost
- real quick... front blinker bulb on b4 90 is?
- CANAAD!
- so I go thru hell and high water and the front subframe
- Temp gauge issue... Thermostat??
- CV Joint Quest
- Anybody interested.....
- You can't fix it. Last posting. I promise.
- Colorado rules!
- The bew ignition switch is in. No dice. LOOK inside tell me whaat you think
- OK i have a 93 90 cs quattro. I need the relay locations. I have no manuals owners or repair.
- I thought you guys might enjoy a story about how skolnick owned himself.
- Few probs with my '94 A80 Sport SE
- 95naudi90 (or anyone else) still looking for a working autocheck/trip comp? [edit]
- Fuel rail leak...
- Just to confirm a auto trans ?
- I got the weirdest bagel combo this AM
- Here's what I got at the junkyard last night for you guys
- Aftermath of wreck pic's
- Quick help. No time to search. Regarding Issue I have posted previously
- S4 oil cooler upgrade question 1PO'd90. Is this plastic part...
- those pesky M8 triple square CV bolts can kiss my ass goodbye
- Would this sport steering wheel be a direct fit for my '95 90Q?
- ATTN: Calgary Audi 90 owners....(long)
- Anyone, if I drop the subframe on a B4 AT FWD do I need to supprt the motor?
- ok, what do you think is the most recognizable Audi to date?
- Flywheel bolt size? on V6 or a link on how to access russian web based ETKA?
- dealer only part?!?!?! come on now>!
- look at this crazy cab
- Saw some cool seats on a cabby this weekend
- I think my wheels have something against me.
- Alright Rob (qpilot) how long until you fit these bad boys?
- Stumbled across a green B3 with a green leather interior...
- I'm heading to the junkyard tonite, let me know if you need any small parts
- ETKA/part number help, Ryan....I'm basically talking to you
- What happened to 12v.org?
- I'm pretty sure I have a leaky headgasket..
- How to properly take advantage of quattro
- Coupe Battery specs?
- what ever happen to this site?
- Alright, this will need the help of the whole forum, but I want to make an FAQ - hosted on my site..
- anyone ever mess with this?
- Eurotuner, October issue, page 52 - anyone notice anything?
- Found a new Ronal R-38 pic....
- EGR system..>?
- Occasional CEL solved
- A4/S4/RS4 rear final drive
- Need some side shots of Coupes with Turbo Twists...
- Need repair manual pronto. Would like a book but will take CD if i can get NOW!!
- Cat Back Exhaust suggestions....
- Need a pair of known good knock sensors for 20v
- Looking into a 90Q.
- Engine Fire Pics
- bah! after the 5hr drive yesterday I've decided to replace my rear
- Quiiiick My car broke down I need help and info!!!
- The Quattro Experience
- How do you spell stupid?
- Did you guys know Princess Diana owned a B4?
- first-time Audi owner, question about VIN
- Yeah, so I pretty much got run off the road tonite
- lets try this again......
- Anyone have a spare B4 radiator laying around?
- why are these so bloody expensive
- 7A injector saga...
- EKTA pimps... need the PN for water temp sender
- Unknown part picture>
- blue smoke coming from under hood this morning. Checked the plug connectors and #5 has oil on it
- 7a hoses and vaccum lines?
- brooklyn, ny to killington, vt = 3:15 + 1 dead bird.
- anyone know the size of the plastic fuel line from tank to filter?
- I think I'm my own worst enemy. You can't fix it?
- Need some help with replacing the front control arm bushings..
- I've got the DFPR blues...
- 20v help, all hatachi, power cuts WOT 4000+rpm intermittently
- are the 90Q brake pads the same as the fwd 90 ones?
- I got a major problem so it seems with 94' 90 Q
- 89 Coupe Quattro Help
- Looks like KoupeKrazy has been doin' some work...
- Question to those with 996 calipers & RS2 carriers: Anyone fit 16" steelies over them?
- just realized my car is 18 years old.... hahahaha this car is old
- hahaha wow
- Engine Fire - help....
- need recommendation on 2.5" inlet/outlet muffler, anything quiet
- Xel likes to party part II
- 5hr drive from MN to Milwaukee, 350 miles 30mpg, 1/4 tank left
- header for a 1990 coupe quattro
- Post-rally..... well that just sucks.... write-off!
- new pads/rotors/cv booots/strut mounts/good coat of wax/lighter in the pocket and ready for winter..
- sub frame and trans mount questions
- Question on 12v MAF swap into 20v
- NAC, but has to be one of the coolest commercials I've ever seen...
- 90 CQ cutting out when going around corners...fuel pump issue?
- Well, she's officially out of my hands...
- SCarGo02.....Found a VERY useful piece of info on your site....
- anyone here have an auf tranny laying around......
- 93-95 Heated seat question
- Well I lost out
- I'm beginning to think about selling the car again.....
- Ok, passenger-side cat is definitely going bad....and suggestions?
- Need black fron bumper and A complete sunroof setupfor a 93 90 cs Quattro
- Is the 7A (03/1989) mounts the same as the 7A (04/1990)?
- How much can I sell a 20V sedan (B3) spoiler for?
- Front suspension & brakes on-car w/wheels mounted pics...
- Lights... decisions... decisions...
- 12V MAF swap on 7A engine. Any updates? koupekrazy? audicq? nothing?
- When replacing the coulmn stalks (lights, hazards, blinkers, etc.), how do you secure them back?
- how hot does the EGR valve get?
- Interesting center piece for US/Can CQs with tinted tails...
- Looking for a B4 90q to replace my 90S...
- Hub swap on my 93 90cs Quattro What are my options for lug patterns?
- Anyone have the outside lower door mouldings for a B3?...
- Zzak, or somebody with 7A experience, some advice please!
- OEM/Plastic sideskirts.
- Intermittant Vibration in propeller shaft
- Off to Vegas...
- anyone want anything from this car before I scrap it....
- Not bad for a 10 valve ;)
- The mother of all suspension/steering mods is 3/4 done....
- Milestone....
- Just had Vibrant 1134 muffler installed, thanks OWDLVR
- B3 team door handle lock problem
- Does the 20v I5 have a 2 piece or one piece rear main oil seal...
- Woohooo, started snowing today in Mass.
- Try to sell my 89 200, and this is what this guy that wants to
- Anyone know the part number for aux gauge bulbs off the top of their head?
- Diesel Engine Conversion
- for those of you who have swapped a turbo motor into an NA car
- Hey all, I bit the bullet on a Turbo today
- Just picked up another Audi member to use until my other project is finished... 1990 CQ with 123k.
- What size is wheel hub bolt to do cv boot repalcement?? 23mm is too small!! So is 25mmm and 26mm!
- got snub mount problems any sugestions?
- I took your advice Mance.....
- Fitted new coolant tank BUT still got a problem!!!
- Hello... first post... need parts
- WOOHOO! Killington is opening this weekend!
- new to audi
- 1pissedoff90, you having email trouble lately
- Does anyone know how I can achieve this? Tecknoquatt please chime in.
- Need some help...
- Roughness
- Question to anyone with an RS2 intercooler...
- Weird fuel delivery/fuel pump issue....
- need parts off a fwd 80 1990??
- Lets make a Friday Thread of Blinging engine shots, Doesn't have to be 20v But I'll start it out!
- need a part # lookup
- Just dumped a can of this in a full tank of 91..
- Are the tow rings that came with trunk tool kit in our cars worth a damn?
- Wouldn't have been nice if Audi had sold the 90 setup like this for the US market?
- Friday is picture day, right?
- Cold start valve
- Drive Shaft
- AWOT X-Post, Could use your guy's help...
- Stock B3 - RS2 lights not "lining up" ?
- What's my paint code??
- Photoshop alternative
- Anyone in MD/VA/DC? Looking to do weekend fun runs with other Audis
- New to the Audi scene.. Good sites for performance parts
- Finding 4x108 wheels is a Pain in the Arse.. Help!!! Anyone have any they wanna sell?
- car is losing power and I think it's 1 of the cats......
- 11 year-old stock mounts are completely worn...
- Parts for Sale, anyone interested?
- simple exhaust question....
- Picked up another 90q on tuesday
- Headlight Change question...
- anyone want any gear from the Rally de Catalunya?
- I need the correct type of spark plugs and gap..
- So it starts tonight, all new suspension and MANY other pieces
- Can somebody verify this? HID's in standard E-code headlites?
- New to Audi
- I'm in serious trouble, need help fast....
- Does anyone have the block --> oil cooler --> radiator (top) hose for a 4-cyl 80?
- Any way of finding correct paint code for my B3
- I sang "We are the Champions" like 100 times last night
- B3 stock bumper cover mounting brackets...
- Control arm replacements
- Audi 80 2.0 E Reverse lights
- Has anyone swapped an A4 5 speed FWD into a 90?
- I'm gonna show her my "OH' face. You know, ....
- The mother of all steering, brakes and suspension conversion is slated for the weekend...
- Is the SD engine interference or non-interference?
- info on Audi 2.0 E 16v engine
- I can finally say "the lump is out"!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 93-95 Audi B4 Limo Taillights (E-Spec) Help!
- anyone know if the engine from a 90 12vqm could mount to the transmission of a 86 4k qm?
