- Is there any parts list for a 92 audi 80 cab online?
- 1995 Cabriolet Top Woes
- Steering wheel change
- Audi CQ Electrical issue after sitting outside or driving through water.
- 1998 audi cabriolet
- 1986 Audi 80 B2 1.8 Coolant temperature sensor
- Can someone check link?
- 91 CQ front brake caliper options
- 1997 audi cabrilet (typ8g7)
- Audi Speedline Wheel
- 80 Quattro dash lights not working after installing a new license plate light
- 1991 coupe quattro rally spec suspension
- SVB's 1990 Audi Coupe Quattro
- Ecu part numbers and alternatives
- Fuel pressure check valve
- 97 cabriolet manual swap ECU reprogram
- DK: No rear speaker wire at Headunit - 1997 Cabrio
- What gearboxes fit to 10V 2.3E NG?
- Is anyone selling 7A engine injector adapters?
- 12V Coolant Temp Behaviour
- Needed: new blue headliner for 97 Audi cab
- '91 CQ Ignition Coil
- What voltage should hall effect sensor be
- Audi 80 instrument cluster problem
- Audi 80 2.0l ACE 16V oil pressure light on dash constantly
- Looking For (WTB / WTT) A decent B4 90 V6 quattro NorthEast US
- How to remove clutch slave cylinder - '84 4000 S Quattro
- Clutch pedal on floor
- Looking to talk to M.C. Cuccio
- Fuel Sender / Gauge Question...
- Cabrio taillights
- 1993 Audi 90 cs 2.8 12v issues
- New V-belt for my Audi 80
- Backfire when starting 2.6 v6- collapsed airbox!
- 1990 Audi Coupe Quattro - Black
- Stalling, rough idling Audi 80
- 97 CABRIO 1.8L trans swap cv axels
- Audi 80, B4, 2.0E 1994 No start after headgasket
- vacuum hose
- ABS sensors Audi 80 b3 1.9e 83kw
- 1992 Audi 80 Central Locking Pump doesnt unlock
- Absence of central locking
- (help) Car died now wont start. Fuel pressure going into rail but not returning.
- 93 CS Quattro Brake Master Cylinder
- 1997 Audi Cabriolet Convertible top light.
- 91 Audi Coupe 7A Manual Transmission and Rear Axle Oil
- Audi 80 Cabrio 1.8t engine conversion
- SE: Audi 80 cab 2.3NG with engine problems
- Central locking
- AFC engine Service Manual pdf
- 97 Cabriolet strange intermittent when starting hot
- 1996 Audi Cabrio - No Crank
- Looking for parts
- 96 Audi Cabrio stuck in park
- coupe b3 doesn't start when warm
- Pipes on 1990 Quattro coupe I have no idea what they do
- Lead for what ??
- Audi Cabriolet subframe
- 2.6L V6 (ABC) will not start - no codes...
- 1997 Audi cabriolet stopped running.
- WTB : Rear "20V" logo from B3 90 or Coupe
- Windscreen washer bottle
- 1995 90 second radiator fan speed doesnt work
- Why is this metal pipe clogged and what does it do on my Audi coupe
- New Owner, Got some questions.
- ISO Audi Coupe Quattro!
- hot air from vents even on LO
- AUDI 80 CABRIOLET CLUTCH PROBLEMS
- Cold heater
- Instrument cluster swap(Audi 80)
- Audi 90 b3 1988 rear brake disc replacement
- Instrument cluster replacement
- 93 CABRIOLET ROOF PROBLEM
- 1998 Cabriolet FS
- Will Cabrio manual front seats fit a '91 CQ?
- Audi 80 b3 problem with accelerator
- If I do not drive for 3 days oil pressure indicator
- Audi gamma cc upgrade audio system.
- Gearbox swap 80 b2
- Need help with choosing a new car player for Audi 80 1992
- Help... Failed Smog (High Hydrocarbons at Idle)
- 5cyl stroking, same as 4cyl?
- 1995 Audi 90 codes - How do I use VAG-COM?
- Audi 80 2.0E Engine issues
- Cabriolet transmission types 01N 097 CFS ???
- 1994 Audi Cabriolet Convertible Top Not Working
- Anyone have right inner Cabrio taillight?
- 2023 Spring Yard Sale; 1986 Coupe GT, 1993 90quattro and Interior Sets
- Help Identifying Brake master/hydro booster and some Q's
- AU: 80 auto klonk
- 10 spoke 15 Audi OEM wheels
- Challenging Oil Pump gasket replacement
- SE: Erratic idle when hot (2.3 NG KE III)
- Rear Struts for '91 CQ are NLA
- Help with rebuilding window regulators w/kit??
- Cabriolet overheating help
- Newer cylinder head on an 1986 EA827 block?
- Do rear shocks from a B4 fit a B3 coupe quattro?
- Suche original Radio für Audi 80 1996.
- ABS problems on 1990 coupe quattro 2.3
- 1999 AUDI CAB
- SE: Audi 80 B4 digital climate control retrofit?
- Audi 2.6 high hc readings in exhaust gases
- 80 Cabrio and Nardi Wheel
- BG: Audi Cabrio Floor Mats?
- 1996 Cabrio Question
- Audi 80 fuel problem
- brake tail lights problems on a 1999 audi cab
- 1999 AUDIO CABRIOLET ;BOOT WILL NOT OPEN
- Alternative to 91 coupe 7A 20v 2 channel power steering pump
- Does anybody have a schematic of this eletronic climate Control for a Audi 80 B4?
- '95 90 Coolant Hoses
- 96 Audi Cabrio hardtop number
- B3 idle goes to zero instantly
- Nardi 3-spoke wheel on '92 B4
- Audi Coupe GT fuel pump location and power issues
- ES: Audi 80 2.3 (NG) idle and ignition problems
- '95 90 Oil Light and Three Beeps
- Parts
- NO: Oil pressure?
- Is it the ignition Coil ?
- 91 80 quattro Fuel leak inside airbox
- PLEEEEASE HELP ME!! Heater Lambda.
- Audi 80 b4 2.0E → 4.2 V8
- Timing belt, service position?
- 1995 Audi 90 vs 1996 Cabrio
- Sport steering wheel for Audi 80 B4
- Valve stem seal help needed
- Strange warning lamp meaning on Audi 90 -88
- MY1993 90 CS quattro marked value?
- UK: Handbrake light re roof opening?
- Alternator belt breaking Audi 90 quattro
- No lowbeams (well, kind of but only with fog relay unplugged))
- Audi 80 b4 avant new member and question
- Big brake and 5 lug conversion questions
- Audi 90 wheel 10 Spoke for spare
- Need Mechanic near San Diego or Los Angeles
- Brake pressure regulator options?
- In need of a 1988 audi 90 fuel system.
- UK: ROOF?
- Power steering leak
- Power output stage
- Cabriolet Suspension choices
- UK: desperate roof problems
- Recharging A/C on 1997 Cabriolet
- adding freon but ...
- Ignition control unit
- DK: Audi 80 Engine shut off
- I am happy to anounce I have bought my first 1994 Audi Cabrio.
- Banjo bolt thread size
- veh speed sensor, '96 Cabrio, automatic
- B3 B4 Sunvisor Rebuild
- Audi 80 B1 Strut mounts
- Front Wheel Speed Sensor Options?
- front seats
- front seats
- temp gauge
- Maf sensor 4 pin Audi 90Q 7A
- '91 7A Radiator Fan 40A Relay Housing Around Pin 87A Melts
- Hydraulic Lifters for Audi 90
- Audi 90 B3 Injector hoses
- Audi Cabrio Belt Tensioner
- AC help, what should I try next
- Are B3 front axles interchangeable?
- Transmission rebuild kits?
- UK: strut?
- A/C blower, brakes
- roof problems
- LV: Audi 80 B4 automatic gearbox replacement?
- Help - Oil Cooler Gasket Blow Out
- UK: cab roof opens?
- Front Bumper Wrap '95 90 Quattro
- 1990 20v Coupe Quattro Stock Springs colors
- 1988 Audi 90, 2.0 another..fuel delivery thread
- UK: 2.8 manual Cabriolet.1998- Rear Spring info plz.
- New 1997 Cabriolet 2.8 12v Owner (questions)
- Audi 80 B4 indicator fitment
- DK: Best oil for 1992 2,3e?
- Central locking issues
- B3/B4 90 parts compatibility
- Audi 80 Exhaust Manifold
- Seriously Service Manuals
- Polybush set for Audi coupe B3
- Audi 80 center caps
- Immobilizer issues
- 1991 Coupe Quattro rear strut mounts?
- UK: MAF .. where is it please on a 1995 v6 cab?
- Steeringwheel Audi 100 1994 (s6) to an Cabriolet 1994
- HU: Audi 80 (B3) automatic transmission swap
- Audi B3 climate controle schematics wanted.
- 80 quattro crankcase vent breather
- NO: What type of connector is this?
- Water leak into the trunk
- ABK intake manifold bolt sizes
- Audi 80 2.3 - Fuel feed unit and pump
- what part is this?
- Audi 80 2.0E 1994 Automatic gearbox swap, valve body control question.
- BG: Audi 80 1.8s b3 - K-Jettronic replacement
- UK: Will any brand regulator fit a bosch alternator
- Wheel offset?
- UK: What size bolts attach my alternator regulator
- can any one help, engine problem
- Connecting up a 6 CD changer to original loom on the Trunk/boot
- UK: Will upgraded dash bulbs work
- b3 80 1.8t swap?
- UK: Slight miss on tick over on 2.6 v6
- Seat belt torque specs, 97 cab
- Trunk/boot gasket options for 1991 Audi 90q 20v?
- Procedure for no CEL/MIL light
- 2.0T swap into 1988 90 Quattro
- 1995 Audi Quattro (90) - Code 2113 Camshaft sensor
- 93 90 2.8l CS Quattro acceleration problem
- LED bulbs and jacking points for 98 cabriolet?
- I'll be undertaking the removal of a windshield from a Coupe.
- Cold start problem on my Audi 80 B3
- UK: ABS sensor cable clip? -B4 Cabrio -Picture
- ABS sensor cable clip? -B4 Cabrio
- FI: Audi 80, long crank when warm and fuel smell
- Any leads on a clean, noncabrio 12V?
- I need an Auto trans for my 1990 90S PNW
- Coolant seeping @ reservoir, how to burp system?
- How do I get a PDF of the Bentley for the Cabrio?
- Audi Quattro and Kaipola
- 95 90Q Sedan: Floor mounts for installing Recaro Speed V's
- 2.3 Ng timing
- 2.3 Ng starting issue
- Engine indentification
- Changing a windscreen washer pump
- UK: What Headlight bulbs would be recommended for winter night driving?
- 98 Cabrio windows not moving
- UK: What does each bulb in my instrument cluster light up
- 1995 Cabrio Roof Hydraulic Pipes
- '1991 Coupe Windshield Replacement and Removal
- EE: Audi 80 B4 1992 2.3E Warm Engine Problems
- Weak auto transmission in B4 cars in 1996?
- Rear calipers
- NZ: Air Intake Temp Sensor ABC 2.6e
- E10 petrol .. is it acceptable
- Can i get to my heater box without removing the dash
- '96 Cabrio conversion to manual transmission
- Audi Cabrio buying advice/problem areas?
- steering wheel question
- Weird interior lighting issue
- Does anybody know which AC pressure switch is which? Audi 90CS
- '97 Audi Cabrio engine is overheating
- Is this sound bad alternator bearings?
- Are the Audi 90 V8 quattro engines (3.6L) sought after?
- Help with vacuum hose routing
- crankshaft position sensor and thermostat replacement
