- RS: A5 B9 2017 2.0TFSI 190hp S-Tronic - drone sound while cruising
- Right Mirror Disassembly Instructions
- Reviving an old topic - Top camera view while parking
- Audi A5 2011
- Rear Climate Controls Not Working?
- New Winter Setup
- How do you store summer tires?
- Magma Red Seat Covers
- Monitoring Fluid Intake...it's damn good...
- 19 S5 APR and questions
- Carbon Imports spoiler defect..??
- Speakers covered under warranty?
- Wind Deflector extension tips
- Great Review on the RS5
- Does it worth US$288 with wireless CarPlay added?
- Warranty about to end - anything to check?
- High performance vs Grant Touring All Season Tires?
- Adaptive headlights to finally become legal in the US
- Ocean Vessel 467
- Hot Date w/Bambi Last Night!
- Didn't know the S5 could make this much power!
- Wet install MacBook Skins same as PPF
- 2019 A5 Sportback newbie question: larger wheels?
- Tubi Style Exhaust?
- S5 launch control with/out jb4
- Fault Codes, Fault Codes
- Bluetooth Grayed out/WiFi Not Working
- Are you using after market winter wheels?
- Question regarding stock tires
- New issue: Lurch when turning into a driveway when coasting
- No more free map updates?
- 2022 Audi. A5 prestige real world fuel economy? Mostly city?
- Q: A5 prestige 2021 vs 2022 and question on puddle lights
- Positive report from my first 6 months with S5
- Winter Wheels 22 S5 Sportback?
- Audi Splash Shields
- Performance or Aesthetics?
- 2021 S5 B9.5 Oil Change?
- Question on Brake Fluid Change
- Finally received my AAWireless
- ITM - Ontario Canada?
- New user/New Car - couple of questions
- 2021 flat bottom wheel
- (?) for those that use Spotify and Apple Music?
- performance tuner for b9.5 2022 S5?
- Oil temps in cold weather and FMIC
- Struggles with the grille rings
- Cars Are Going Electric. What Happens to the Used Batteries?
- AWE Switch Path Tips
- RS5 grill install in NYC
- ? for RS5 Racechip users
- OEM License plate bracket
- What ski box do you guys use?
- Apple has a fix for the emergency call feature that Audi will cancel
- Warranty related?
- Launch control looks like fun...LOL
- Strange sounds after locking car
- Carbon Fiber Side Skirts on B9.5 Installation
- Discount from MSRP in current market conditions?
- Brake Fluid Tester (for water)
- Does the car 'record' the time when the alarm goes off?
- Great 9/11 Article In Q4 2021 Quattro About Former Member
- Child Lock Mechanism?
- RS5 B9 ticking sound after 30 seconds
- Hit and Run! RS5 Going back to the body shop!
- Found my old key
- is this the end? switch off engine and check oil level
- Just Ordered my S5 SB Prestige.
- Door Issues
- Fuel Consumption - Short-term memory (2018 S5 SB)
- Fault codes .... HELP
- 2018 S5 SB - Engine oil alert - What oil can I use to top off?
- Green, Yellow, & Red Tachometer?
- Audicare, service intervals and low mileage
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- Subtle S5/RS5 spoiler
- Black S-Line Fender/Door Emblems Different By Model Year?
- Front lip out of socket. Help!
- Gas tank drain hole S5 b9?
- Diamond Stitching Seat Cleaner
- RS5 B9 transmission fault. Limp home mode
- M3 vs RS5 vs C63Amg
- B9 / B9.5 Tuning Experiences with EPL? Others? (Good, Bad, or In-between)
- Window Trim (Paint vs. Wrap)
- C pillar and rear seat
- UK: Pics...Just back from paint correction and ceramic coating....
- …60k and 70k service package
- Looking at 2021 A5 premium plus
- Front Lips/Splitters for B9.5?
- I bought something silly, now how do I install it?
- Sensors issue 2018 A5 sportback
- Delivery date thread
- ET25 or ET38?
- Corporate Fleet Vehicle?
- Will Audi follow Infiniti and do this for its customers?
- Lower Center Grille Replacement A5 S-Line
- New Car, New Member
- All Season Tires on Black Optics Wheels
- Help for an idiot with key locked in trunk?
- Another generation of ICE coming in the 2023 A4
- New (?) MMI icon
- How do you keep your Lunar Silver interior looking clean?
- Should I get an RS5 ?
- 2021 RS5 Sportback….633 miles…. And I dinged it. Suggestions.
- 2018 A5 sportback Owners Manual
- How much did you pay for your ATF change?
- Audi A5 Low oil pressure at idle/shaking
- Lane Keep assist permanently on
- RS5 Pulling to Right with change of One Front Tire
- Window button behavior not correct
- How to remove front door woofer speaker grille B&O?
- Missing traction control option in RS2 mode
- Blacked out window trim on S5
- 2021 A5 MMI not showing RDS
- Post-Facelift Hands on Detection Flat-Bottom Steering Wheel Packages...
- Insulation & Reliability of the S5 Cabriolet in Canadian winters?
- Going autocross, how to prepare?
- Tires for Drivers
- Coolant fan difficulty of movement anyone seen this?
- Delete old destinations in Navi - how?
- Proper style wheel bolts?
- The Europrice S5 Sportback Project v3.0 is For Sale...
- UK: Steering vibration?
- Some dealers are sneaking this in, worse than garbage!
- so what's going on with my 2022 orders?
- good bye, C43. hello, RS 5
- Ambient lighting for center console trim?
- Really Limited Car Inventory
- 2022 S5 on-sale date?
- S5 BRAKES!
- Wheel spacers in the UK for B9?
- S5 cabrio , diffuser B9 fits B9.5 ?
- Grinding/Vibrating noise at full lock at parking lot speeds
- 2021 S5 Cab Black Optics
- Water in side skirt
- OK to delay maintenance due to covid?
- 2018 A5 - AC NOT blowing cold
- UK: Ceramic Brake pad movement - clicking?
- Moose Test: A5 vs M4, C63s, A3, Alpha
- 2022 RS5 pricing expectations?
- Can I get some recommended places to buy the honeycomb grille?
- S mode 8th gear
- Is there a ‘better’ front strut brace?
- B9 RS5 grill install in Atlanta
- KR: Are my dampers leaking?
- 5F software update
- Hotspot options
- BlackVue Users
- VPS Resonator Delete finally installed!
- AGM Battery Life Questions
- B&O Sound System in 2021 A5s / S5 Sportbacks -- Better or Same Problems?
- Carbon Fiber Package
- Given up on Wireless CarPlay
- Loose wire?
- Best winter tire/wheel size for 2021 S5?
- Traffic Light Info in Sugar Land TX
- Got a "Coupe" light up your "Boot?"
- Tips on getting the best price on an Audi Extended Warranty?
- UK: RS5 B9 inlet pipes
- New S5 owner (with pics!)
- RS5 Rear Shudders When Turning Ignition Off
- Covered Under Warranty?
- Top only downpipe install... Am I crazy?
- Help subwoofer
- Limited Key Fob Range?
- Cost Of Nav Map Updates After Free Updates
- Navigation database issue
- Shopping bags + s5 sportback
- 2020 vs 21 vs 22 S5 Sportback?
- 3year service…..
- Audi Connect/myAudi - what an ungodly mess
- Tunnel brace users?
- Mmi display 3D maps
- Traffic Sign Recognition Without Navigation Package on 2021 S5?
- eBay RS5 Conversion kit
- CarlinKit 3.0 ???
- Not many cars have this today.
- OEM 20" Wheels for 2021 S5 Sportback w/ Black Optic Package
- What's the best solution for music source?
- 2021 A5 SB Progressiv (Premium Plus) Red LEDs On Startup
- Some pics of my new 2018 S5 Coupe
- A Uniden remote mute button install
- B9 Phone Cradle For Android Auto / Apple CarPlay – Single Size for Short/Tall Phones
- Key recognition after changing drivers
- Production Time?
- B9.5 Footwell light question?
- Screw in the tread, oh my!
- WTB: Carbon Side Skirts
- Green traffic light appears 80km/h under RPM guage
- Active Cruise Behaviour?
- Audi S5 Suspension Malfunction Light
- MY22 Ordered with Lunar Silver Nappa
- Body Shop Shenanigans?
- Backup camera not triggering in reverse
- Adaptive Suspension - Not Working?
- Decisions, Decisions…. When to Finalize?
- You can "bag" a B9 Coupe
- Accidentally put 1/4 of a quart of the wrong oil in
- Kinda in an interesting situation right now
- Today, I bought a B9 2018 S5 Coupe with 13,500 miles.
- Missing key holder rubber mat
- Model Year Counts?
- Help me out, I am in a Pickle! (How did I get in this giant pickle?)
- The Wait Begins......
- Oil leak from lower oil pan?
- EUROFEST MAGGIE VALLEY
- Black front grille S5 badge?
- Aftermarket Wheels for S5 Sportback (Post Your Pics Here!)
- Ceramic Coating....fantastic
- Small Black Particles on Center Console???
- Crankcase Breather Hose
- rs5sb on track today
- Anyone with Erwin for RS5?
- Audi A5 2021 owner, any issues with this model?
- Audi Films
- Apple Carplay goes Black
- RS7 ROLLING DOWN IN THE DEEP!
- 2019 S5 Sportback 19x8.5 APR Wheel/Tire Fitment?
- 6-Speed Manual Low-Speed Shifting Problem
- Parking Lights Stay On
- LED interior lighting plus package
- Audi s5 2018 b9 light conversion
- 2022 Audi RS5 Sportback - last fully petrol powered RS5
- Rear brake caliper shlowly tirning black - why?
- Considering adding a sub to B&O system (cabriolet)
- Changing primary name on MMI
- Looking for Winter tires for 2021 S5
- COMM NUMBER?
- Lease Deal on 2021 RS5 Sportback?
- Switching gears P R N D directly from shift paddles on B9
- Question about winter wheels and tires for new RS5
- 2018 B9 S5 Brake Job
- have you switched off pre-sense front?
- RS5 19 Coupe Exhaust Valve Rattle
- 2021 S5 Cabriolet Exhaust
- Anyone Want to Sell Me These Wheels?
- Changing breaks and rotors 2018 A5 sportback OEM/aftermarket?
- Correct spark plug socket size??
- When does my Audi new car warranty expire?
- Swap Tires or Get New Wheels/Tires?
- Dash cam preference and wiring?
- RS5 Inserts Question
- Is dealer scamming me? 2018 A5 SB
- 718 vs S5 comfort?
- Felt tape around rear deck lid subwoofer grille?
- Bang & Olufsen sound not great
- Interchange rear headrests for B9?
- Car is leaning on one side
- At the dealer with some MMI issues
- APR 1.4 and - Side Assist problem
