- Catalytic converter replacing...
- Antenna amplifier location.
- Exhaust question...
- 96 A6Qa Temperature / Coolant Warning Light Issue
- Roof Rack for 1993 100 cs quattro?
- "Tail Light Out" sensor
- Detailer's Domain: Official Microfiber Sale, buy big and save big!
- Electrical circuit diagram for A100C4 2.0E
- S-Fest West Write up - Part 2
- Well folks, I have 4 nice paper weights to use around the house...
- "Fixed" a coworkers 89 325i tonight.
- anti-lock button not doing anything and engine missing...
- Front and rear bumpers the same.
- Dave! you the man
- Hello all,
- My plugs from last service
- Sticky Tach... Kinda Sketched!
- Power Lock Issue's
- Brake pedal air leak: What is broken and how do you fix the issue?
- Homemade tool for Bilstein front struts collar
- Need a gray sunroof switch panel...
- S-Fest West thanks, shout-outs and a few pictures...
- Rear trailing arm bushings - question
- OT: proper wagon
- Anyone need an OEM ignition switch?
- New Battery
- transmission type help
- About to buy a '93 100 CS Quattro Wagon
- SQEEKE
- A weekend getaway to the NC Mountains...
- Audi Accessories Sale!
- Best Place to Buy Bilstein Sports?
- Front Tie Rod Part #'s
- Weekend ramblings, new project, old project, other project, and junkyard junk
- Anything I should be pulling from a V8 in the junkyard?
- stumble on cold start.
- ****Reminder - Hartford, CT - GTG - Wednesday, 9/19 ****
- Ok, it finally got the best of me.
- Brake Pad Light
- Stumbling...
- CD changer plug location.
- Check Engine Light came on...
- S6 stolen September 15th, Dortmund, Germany
- What is the minimum octane rating (RON)?
- Valvoline Synpower brake fluid, anyone use it
- So, what is the tricks to doing the motor mounts? Any tips?
- Help with boiling colant.
- Here we go again...(a coming of age tail...ish)
- Tie Rods - Am I going to have a problem.
- Replaced the bulbs in the differential lock switch.
- Broken manifold bolt
- '95 A6 vacum hose diagram - auto tranny
- check engine light
- Since I can now park in my garage, decided to throw this together
- Does the defroster switch symbol light up with the engine running?
- Stereo code question for '97 A6 wagon
- not mine but shareing
- Power steering rack - is it worth replacing?
- OT...A4 stuff
- Here's what's going on in my neighborhood...
- E-Brake adjustment
- Brake Question
- Giggle Giggle (video)
- Been asking a few questions the past week or two. Time for a formal intro...
- Should the gear selector display and the temp display be lit when the lights are on or all the time?
- Is it possible to repair the Gas-filled strut used to support the hood?
- Warning: Meyle Heater Cores
- DAMMED CABIN FILTER AGAIN ???
- Is it possible to swap the 2.8L for the 5Cyl S6 Engine?
- Major headache with Bilstein shocks...
- OOOO my!
- PSA - Front floor mats can't be had with rings on them anymore just "A6"...
- Debadge or not?
- Group buy
- I need a section from a 100/C3 repair manual...though I'd ask here first because
- Some observations post-replacement of my ignition switch...
- Any know of any Euro C4 A6/S6 rear bumpers that are on this side of the pond?
- Evol, This ones for you
- S-Fest West Registration is still open! Register now and have a chance at a $1400 Apikol FMIC or
- Looking for a used rain channel and wind deflector for the sunroof. Anyone got 'em?
- It's that time - Timing Belt Replacement
- Speed control blues
- spark plugs
- Mr. Clean Magic Eraser works great on ecru trim!
- $2500 Avant in black with ecru...ebay NY
- Time To Say Goodbye To This Board
- Wobble socket
- I get to do my heater core again! Insert F-word here--->........
- rear brake calipers .....
- Mityvac vacuum pump
- Anyone know what the extra two wire are for on the OBD cable in the center console?
- 1996 A6 transmission problem - car won't move in drive. No first gear when in drive.
- Some one got 210Hp from a 12V
- I'll probably be hitting the junkyards this weekend. Let me know if you have any requests.
- I just saw these on Phoenix Craigslist (not mine!) but they'd fit our cars:
- Does anyone know if the window-up feature with the key has to be reset? Since....
- Anybody have a dead steering rack (servotronic) for me?
- What does the climate control flap above the glove box do?
- Replacement antenna mast for Avant?
- What's the glue called that holds the driver's window...
- Anyone ever have to send something back to Blaufergnugen?
- Non-Start condition '96 A6-Advice please
- CEL driving me nuts
- Is anyone else having problems getting eBahn to print lately? IT Gurus help, please.
- 96 drivers window malady
- Humming in front of my car
- Anyone interested in buying a belly pan from 1995 A6
- Anyone have a visor clip in grey?
- .....hhhmmm
- Anybody see these?
- Can the amber reflectors in the A6 corner turn signal be removed like on the A4's and newer A6's
- Steering rack interchangeability
- will 96 urs6 steering wheel fit a 97 a6 avant?
- Driver side window
- Immaculate 94 CSQ in Vancouver area
- Weekend projects: A6 half shafts, Focus upper strut mount bearing, A4 trans pan, etc
- Crank seal leak is back (austinado16, 4driver4, others)...
- Audi 100 2.5 TDI fuel injection pump belt
- Serpentine Belt Problem
- Who's got access to parts cars??? I'm looking for some side mirrors.
- bonehead move
- EGR fixed I hope....
- Transmission is out.
- Avant roof rack update
- Dave, I sent you an email earlier, did you get it?
- electrical surge / head lights
- User's guide
- Boots...CV Boots
- A hearty thank you to DaveinSaltLake for talking me off the ledge today...
- strut mount question
- Post pictures.
- last call for wheels and tires
- Anybody want a 1992 Audi 100 S that looks nice but really isn't?
- Engine update
- Can you still get the metal dividers (for dogs) for the A6 Avants?
- X-post re: EGR: paging austinado16
- Rear window sun shade
- I am taking my radiator to be cleaned today in hopes that it will help with the boiling coolant
- Paging Bmthorn. Money on it's way
- With a bit of recent chatter about ignition switches I'm sad to report that...
- Any tips for removing the ECU? I STFA and didn't find any new information.
- Detailer's Domain 15% off sale for Labor Day! Get your stuff for the weekend.
- Quattro on the beach...
- Question on load reduction relay in central electric panel and AC function (long)
- weird problem
- I need the Concert Radio and CD Changer gone... $250 takes it all now.
- I met a fellow AudiWorlder in the junkyard today...
- is it.....
- Fault codes and water in right rear passenger seat....help please!
- rear brake caliper has torn rubber sleave. How long will it work?
- I love my new maf!! Thanks Mance!!
- one last shot, my wheels and tires went on e-bay
- Anyone in the Vancouver area got the timing belt tools?
- Any Colorado folks have the 2069 strut cap tool?
- any ideas for removing stripped allen screw? it is set back a bit, so vice grips = no. TIA.
- Question about a 93 100s
- Got to drive an S6 today (yee hah!!!!!!!!!!!)...
- What are the typical oil temperatures for the 12v motor?
- Parting out 93 100CSq
- Cig Lighter
- follow up to last night 93 100 windows ac wipers and blinkers
- Take a stab gentlemen.
- Does anyone have a picture of the dipstick tube on the earlier transmissions?
- Cabin/pollen filter question again
- Feeling pretty stupid --- Re: fog light lens
- Ideal Control Valve location
- multiple problems w/ c4 98 avant. any thoughts?
- anyone with a c4 98 avant cargo cover or know where to get one?
- Could anyone with an automatic use this?
- probs w/ windows blinkers(and hazards)+a/c-heat fan
- Detailer's Domain August Contest for free stuff! Check it out!
- Need a multifunction switch!!!
- Crap... trans flange seal woes.
- Wagonboys: I need advice on a roof rack for my 98 C4 A6 avant. Want flat bars. Thinking.....
- PSA: the front diff doesn't necessarily have a drain plug.
- Anyone in Oregon know about this car?
- Why you should flush your cooling system using the block drain plug...
- Front crankshaft seal leaking problem fixed (info for austinado16 or others who replied to my...
- i also have a pair of front speakers with the housings and everything, speakers still work
- Tailgate Trim Fixed-Still Noisy
- swaybar rubbers replaced!!!
- i have a pair of oem orange corner lights and a ski bag if any 1 is looking
- Going to look at a 98 A4 this weekend.
- Anyone have an open Carfax?
- Clicking/light thunk while turning left
- Paging islingtonaudi: When you did your S6 rear brake swap...
- Anyone interested in a 5-speed tranny?
- I think the temperature gauge may be getting stuck and not showing overheating!
- Any advice/procedure for replacing the exhaust manifold?
- I did it -better: I TRIED TO- what did I learn? Better not to...
- PSA: Bentley Service Manual (3) voilume set on eBay (not mine, not related to seller)...
- 12v Engine for sale on ebay
- Radio install done! 3 days&nights till 5am, plenty of cuts, and one beautiful soudn system
- Need some spec's off of the rear springs for a few models
- Tailgate trim Removal (Again)
- Hi! I just got a 1997 A6 Avant... Swaybar bushing nut/bolt problems!
- Idle issue - air conditioning?
- Anyone with a pair of 95-98 oem front corner lights collecting dust?
- Introducing !!
- 95 A6 selector lever guide...
- Auto trans problem on Urs6.
- shifter question follow up from yesterday
- Hey guys, ....HELP! [kinda long]
- How to position camschaft gears?
- Two questions: 1. When did the sunroof switch panel start to include a ...
- shifter question
- Is the radio code given when you buy the car? Or do you decide what you want to program it to be?
- YAAF
- 1993 100CS blew a heater core
- Oh no man more gremlins!!!!!
- Has anybody out there had this or any other virus show up in the eBahn reader?
- Selling My 95 A6 Q Avant
- does any1 know how to get the radio out of SAFE, i tried the FM &AM buttons but i dont get the
- 94 100 timing tools
- Finally made a little progress on my new motor today...
- Anyone in Pittsburgh know a good mechanic? (Timing Belt)
- Headlights went out
- does any1 know how to get a radio out of SAFE when it shows the two ll bars help please
- Can't shift back into Park
- Cabin filter ???
- No radiator fans, need some brain storm power!
- Ski Racks?
- PICTURE FRIDAY...post em!
- Bet it would be going to Audi heaven in US or UK?
- manuals on ebay (not mine)
- Mobil 1 vs Mobil 1 / High Milage oil
- pics of the broken thermostat I found during timing belt service
- i have a q about the radio code, if i have the #8 in my code which # do i use to enter that?
- UGLY :(:(:(:(
- Help finding part
- Audi 100 '93 - Oil warning alarm
- It's funny and tragic how the little things set you back sometimes...
- Audi 1994 A100C4 Opearation Manual
- Hi, I have a few questions about my car...
- Front anti sway bar bushings
- holly miles!!!
- Wheel Alignment
- coolant warning light when engine is started
- +1 for Worldimpex!
- Question on the protective cover underneath the front of our A6
- inside wheel rim rubbing on lower control arm...(more)
- Sorry, STFA buttttt, can anyone tell me
- Interesting observation on quality....Ford Focus vs A6 throttle body
- Well, I'm off to the airport....
- check out my install... and if you have a chance.....
- Has anyone been thru the torture of replacing this bushing in the rear suspension?
- auto transmision problem ..no shift from 2nd to 3rd or 4th
- Anyone had any luck using VIN's before '92? I can get data for VIN '92+ but not '91 back
- New motor and expansion tank boils over.
