- Bentley wanted
- :: ECS Tuning :: Genuine Audi 80/90/100/200 5 Cyl. Ignition Wire Sets - 84% Off!!
- Palo Alto, CA: Looking for honest and good Audi Mechanic.
- 1997 A6Q (C4) Coolant Overflow Issues
- 97 Audi Q 2.8 Transmission Issues
- Pre-Facelift '98 Avant
- Replace A6 C4 Door Regulator With Dorman Assembly
- non working fuel gauge
- 96 A6 Quattro Central Locking Box Shot - BATTERY ATE IT!!! :(
- car skips and pops
- Need power seat motors '92 100
- So how bad IS the A6 Purple color?
- Window Control Module
- Need Help 92 100 steering rack question
- TRUNK?? Zoom zom
- auto not shifting
- 93 Audi 100, fuel injectors not getting signal to open
- 1993 100 oxygen sensor help
- Heater Control Valve in 94' 100 CS
- 1996 Audi A6 Quattro Wagon rack boot
- 1995 A6 Misfire and Shudder
- Plz! Need help on a 97 A6. Might buy it.
- 2.6 Quattro head gasket
- Major Engine/Acceleration Hesitation/Studder
- Rain water leaking behind dashboard?
- Rear Brake Rotor Removal
- Power seat motors
- 1198 Avant body electrical going cazy
- Gamma CC Bose needed or suggestions
- Unknown warning light 97 A6
- Anyone have a spare hvac controller?
- A6 1.8q 1996 Vagcom scan
- 89 Audi 100 Crank Sensor?
- Electrical problem
- Check valve part #?
- 1992 thermostat?
- 97 A6 Quattro Sunroof Motor
- 1990 Audi 100 windows, sunroof, radio all quit working
- Spark Plug Wires
- New (to me) Audi
- How to remove dead power seat
- 1992 100S blower motor.
- 1997 CA A6 Avant Wheel and Tyre upgrade advise
- 1991 Audi 100 Rear Speakers Help
- Some NAmerican C4 UrS 100/A6 front bumper removal and replacement hints
- Alarm will not shut off
- 1997 A6 Quattro Cruise Control
- Used car buying advice - '97 A6 Avant
- 93 CS 100 CAR WONT START ANY IDEAS
- Radiator Cooling Fan Problems
- 1997 A6 Avant Quattro (Steering wheel grinding)
- 1997 Audi A6 2.8 Oil Light Intermittent problem
- 91-100 fuel injector regulator
- 91 AUDI 100 POWER WINDOWS HELP!
- 12V V6 Cam Position Hall Sender Replacement DIY
- 91 Audi 100 Brake Issues
- Cat Stolen, Need advice on removal of exhaust manifolds on 12V a6
- Power lock problem
- Coolant Fans No Engaging
- Engine Studder
- Trans or Fuel issue?
- Audi 100/A6 headlights issue
- 92 100cs wont start!
- 1990 100 Quattro Parts
- fuel problems 91 100
- 1990 Audi 100
- Vent on all the time
- Price of no TLC
- Central Locking Issue
- 1992 100CS 2.8 Drive Belt Jumping
- 90 100 Quattro PS Pump
- anyone have a 96'-97 a6 avant for parts
- i need front bearing housings
- Where is the engine code in the Audi A6 1995 2.8 V6??
- Please Help! Jerking and underpowered 100 (C4) 1994
- Instrument cluster and heater control bulbs
- 1992 Audi 100S Air Thermostat HELP!!!!!
- Radiator
- 1996 A6 - Power Steering issues - Servotronic or non-Servotronic ?
- I miss my old C4 wagon
- Rear brake trouble
- Parting out an AFC engine
- 1993 100 recirculation flap vacum line
- Fuel pump conversion ?
- Oil Cooler question - 1994 Audi 100 2.8
- have a tapedeck player is it worthless?
- Quarter Glass Removal
- Cluth Problem Help
- transmission stays in high gear quattro 100cs
- AFC rebuilding heads replacing head gasket
- Black Friday 2012 Special is here! - Detailer's Domain
- 1992 100s 2.8l - cooling fan wiring woes
- A6'98 front axle replacement
- 2.8 12V block drain plugged with black ****???
- Replace A6 2.8L Valve Cover Gasket
- listed a sport steering wheel in the clasifieds, best upgrade for your interior
- Buying 1989 Audi 100
- 1997 cabriolet very little heat. Temp running cold
- Automatic power trunk
- 1997 A6 2.8 Quattro Cooling Fan Issues
- 89 100 shaking on acceleration issue
- 92 Audi 100CS relay question
- Reverse Sunroof Gremlins
- Build tag on 95 a6 quattro sedan
- OIL LEAKS HELP!!! Which motor do I have? :/
- Enterior color codes
- Refinish wood(?) trim
- Bentley Manual
- Help!
- Sunroof Gear and Rails Don't Catch Fixed
- Can i program a keyless remote to my A6?
- Audi A6 C4 1996 avant 2.0 16v
- 1994 Audi 100 2.8l V6 - timing belt job
- Inner Tie-Rod Removal
- Parting out a 1994 CS 100 Quattro Avant
- egr solenoid
- Rear Window Help
- Blinkers not working
- Finding chrome(aluminium) trim paint code
- 1992 Audi 100
- 1993 100 CS Quattro turn signal frustration...
- Timing help
- Jerky Auto gearbox changes
- Anyone tried to pair a C5 remote before?
- Whine coming at speed then fades out
- Front springs
- '95 A6 Quattro Interior lights/fan/wipers still have power with key out
- 92 Audi 100 CS Quatttro (wagon)- Blowing Hot Air
- 1993 UrS4 62K original miles, full RS2 build, 034 maintained...
- A6 2.8 Quattro Wagon - how much torque converter slip is normal?
- Anyone need a radiator fan relay? PN 443 951 253 S
- 96 2.5tdi hard to start when cold
- ECU swap/malfunction?
- Blown C4 A6 head gasket
- 96 A6 Quattro Sunroof Issue
- All lights sitting in Europe - trash or ship?
- TWO WEEKS until S-FEST West! Register now to ensure your spot & door prize!
- Replaced CV joint. Now rough automatic shifting.
- Auto trans Erratic shifts
- Headlight disassembly
- 94 100scq Starter removal thread..help find.
- 1994 100scq not starting
- Advice for 1995 A6 quattro
- HCV / HEATER CORE
- Mystery Part - Help Identify Me - 1994 100cs
- Replacing Drivers Side "Bowden Cable" aka inner door latch cable
- 92 100-CS Passenger window goes up but not down
- low-end hesitation
- brake fuse burns out
- ignition switch issue
- Electric seat headache
- Sayonara
- What's the difference between these injectors
- A/C recharge DIY?
- timing top dead center
- My first Audi 95 A6 - it's not as nice, but it was cheap!
- HVAC drain clogged...
- Auto trans trouble
- a6 2.8 waterpump drive shaft help please!
- C4 Intercooler Strapping
- Back in the fold
- NO START!!!!
- how to remove invidual switch from the window panel
- Starting problem in hot wheater, audi A6 c4 1994 mod avant
- Bentley A6 C4 manual for sale
- How do I take off a driver side door panel on 94' CS100??
- Front driver side suspension
- My post on QW - C4 maintenence cost
- "air bag" light on
- 2.8l engine codes
- 1997 Audi A6 2.8 Quattro - White/Beige - Columbia MD
- Automatic Gearbox problem!!
- When bleeding brakes, the fluid comes out too slow. What's wrong?
- 1996 A6 that has been sitting since 08' revamp suggestions
- Where is 2.5bar oil pressure switch?
- 1995 A6 Avant 2.8 misfire problem
- 1997 A6 Quatro Cooling Problems
- Turn Signal fell out when i was driving. Can't find a socket anywhere!
- 97 A6 2.8 quattro wont start.
- '98 quattro differential
- 1994 100S wagon - Fan won't shut off.
- volts question
- How do I access the turn signal stalk after removing steering wheel and airbag?
- Parting '94 100CSQ Avant w/176k
- Need to Stock up on your Detailing Gear! Free Shipping at DD till 5/1/12
- Overheating
- My 100 is acting odd
- ball joint connector bolt
- About to Lower my 1992 Audi 100 cs Quattro
- 1992 AUDI 100 QUATTRO Clicking in steering colomn when car is off??
- Need Help to Pass Salvage Inspection!!!
- Tow Hitch Installation Procedure - C4 100 1993
- Radiator fans wont come on
- What's it worth? Audi A6 blown head gasket... in NY
- carburator for AAR engine
- New Car. Baseline advise please.
- pressure relief valve
- HOW TO FOR SPINDLE REMOVAL?
- Lower control arm change c4 A6
- Secondary air injection error code
- Engine noise/squeal/grind in park + neutral
- listed a 3 spokes steering wheel in the for sale section
- NO START
- 94 cs 100 stereo code
- Occasionally overheating
- new member
- 97 A6 no heat
- Anyone know of a good write up on how to replace shocks for a 97 A6?
- 1993 100 cs quattro tcm / 3rd gear?
- 1993 100CS Spraying Coolant
- Transmission/t-case/differential
- Power Window Issue
- Last Day to Pre Order the Griots 6 inch Orbital Polisher Kit at Intro Price
- Windows Roll up randomly
- C4 side strip set
- Swapping interior from 97 sedan to 97 wagon
- Piston misfire 2&3
- Is the driveshaft (prop shaft) indexed to the final drive?
- Disabling Autocheck headlamp out feature
- aftermarket radio
- 1990 audi 100 just won't run right
- what to disconnect
- Hot Start Problem
- lots of white smoke when at idle or low revs???
- Trouble with aircon
- euro parts
- Brake Light circuit short - blows fuse immediately
- Tire mixing
- Shudder Under Braking at Low Speeds
- 100 quattro pcv valve
- OUTER SILL TRIM WANTED
- Rail / Holder for Spark Plug wires for 1990 Audi 100
- Double snorkel air intake hose for 1990 Audi 100
- 97 A6 Avant Intermittent starting problem
- General info, how to troubleshoot blown fuses without blowing any more fuses.
- Headlight Upgrades?
- Help! Crazy high oil temp *yikes*
- Can't get it out of Park
- 96 A6 quattro hatch trim
- can anyone help me plzz
- Rear Defrost Relay location
- New clutch installed, now I can not get in all gears (93 S4)
- Wont start.. weiiiird !!! help?
- Last Minute Holiday Promotion - 15% off - Flat Shipping - $20 gift code on next order
- Blowing fuse - dealership can't figure it out and says there's no wiring diagram
- WTB 92-94 100 q or 95 a6 q 5spd
- BUY 2 GET 2 FREE UBER Microfiber Towels - Start now ends 12/8/11
- HELP! Is 96 A6 Quattro worth saving??? Trans/coolant mix
