- Anybody tried this?
- Transmission Capacity?
- Audi 100 will not start
- hey guys got a question
- Strut cap removal tool...
- April SoCal events -- special event / driving school / breakfast mtg + Julian Drive
- Audi 100 won't start
- Climate control... found 'em CHEAP on ebay!
- Replacing a non working Power Window Motor
- Central locking Fuse
- just had my magnaflow instaled today
- Leak---is it Coolant
- Fuel pump relay location?
- attn rick601
- Third Ignition Switch !!!
- Electrical Problem. Ideas?
- How to drop auto trans pan '92 FWD
- Mysterious Cat-gutting Saga
- clunking noise when making tight right turn
- Anyone notice the steering feels 'dead' on-centre when the Servotronic relay is removed?
- 8 pin cd from 96- fit in 98 audi??
- 96 A6 Armrest dangling (loose) fix !!!
- Ignition troubles
- Beep-Beep
- Broken Exhaust manifold studs; 94 100CSQ Wagon
- emergency brake cable
- Can you use a stock Foglight switch and hook it up you a pair of your own foglights? if so...
- Finally replaced my led's for my gear indicator in the IC. After almost 2 years it takes some....
- Sunroof Rattle on 95 A6QA
- Pinout on the foglight switch. Any idea?
- Can anyone confirm the exhaust pipe diameter for the A6 from resonator to silencer? Maybe 2.5in?
- OIL COOLER
- Offset? will ET 37 15x7 fit a 100cs
- anyone know if oem speakers from a 97 a6 will work in 92' 100 (nonbose)
- Accessing central cell-phone speaker?
- Alarm Blocking Engine Start on 100 S
- Burned out bulb for outside temprature indicator. Replaceable?
- 100 2.3 Electrics
- Alrighty. NGKs ordered (along with other goodies). Help on the gap?
- no heat from floor or defroster vents after service
- A light behind my tach just went out. Is that an LED or a light bulb? If a bulb, anyone know the #?
- AFTERMARKET ALARM
- Curious, has anyone here completely overhauled their suspension?
- saw a pearl A6/100 w/ aftmkt wheels & clear corners in Katy, TX . RU in this forum?
- Wagon Trunk trim
- Floyd Bennet Field GTG
- Just wondering what non-dealers are getting to replace outer CV boots in your area? More...
- Gas mileage question
- New oil - start up engine noise - '01 A6 2.7T
- Any market for the 3 vol. Bentley paper Manuals?
- Brakes pull left til Anti Lock light comes on Any ideas?
- Help- cant get it out.........
- Where can I get oem speakers
- Q: are there any meets coming up? A: YES, Tuesday April 5th @ The Stand in Encino (SFV) 7:30pm
- WEIRD moonroof issue - damn electrical!
- anyone ever experience this, tach increases but engine speed does not increase
- How do you disable the headlight washers??
- Where can I find a set of OEM floormats?
- Testing sensors?
- A6 98 Wagon 12V----PS/Steering wheel/Trunk Lock
- Question regarding new remote entry for 1997 A6....
- cracking brake hoses
- what are the parts that contribute spark to the spark plugs before the dual ignition coils?
- Stop wasting money on Pentosin
- so im selling my c4...
- Old-School quattro Gathering, Cumberland MD, Aug 19-21
- Oil Sign keeps coming up
- Looking for the definitive word on outer CV boots....
- Changed Thermo
- Changed my P/S fluid over the weekend. A simple task turned messy fiasco, but now it's done.
- Check Engine Light
- Steering groan
- replacing basic Gamma CC with cd player
- ATF fluid dipstick?
- G2 Power Steeering Fluid equivalent?
- How do you remove the trim from around the climate control? I have a replacement here.
- i am getting a hissing sound form my motor.....
- Remote Fob
- does anyone know where i can find a repair manuel for a 92 audi 100s V6?
- where can i find a repair manuel for an 92 audi 100s V6?
- Is anybody parting out a '92-'96 100/A6?
- ok i have another leak
- How many relays are there for the interior lights?
- fuel pump stays running
- Vibration at high speed
- oil consumption
- Weight reduction ideas?
- How many liters of P/S fluid should i buy to do a flush in my 97 A6? Where is the cheapest place....
- Got a weird noise....
- i am getting sort of werid ideling
- Pics from our recent Buttonwillow track event
- no spark coming out of the spark plugs and wires
- I had a Throttle Position Sensor low vltage CEL come on. Is this something I should replace? (more)
- Cd changer help
- Nav Plus "how toos" with the pictures
- 92 Audi 100 S for sale $2700 NE ohio, Pearl white
- Aftermarket radio installation tips
- Fix It or Replace It? $4,300 Repair Bill.
- what does the camshaft position senor look like?
- what are all the components that are included in the ignition system before the dual ened coils?
- SoCal reminder: FRI March 25th, SCC Audi special event @ Mosier Restoration in Inglewood
- Cruise control is just non-responsive...bah
- STILL GOT A BUNCH OF 92 100 CS STUFF!!
- what are all the components that are included in the ignition system?
- does anyone have a camshaft senor diagram to show location of it?
- anybody experience P/S fluid leaks from reservoir or hose connection?
- anybody replaced their radiator fan motor? ....easy or hard DIY?...(more)
- Need some help.... tranny acting up.....
- Know where I can get OE replacement floor mats for a 100?
- where did you guys get strut retaining cup tool 2069?
- Has anyone had your transmission rebuilt?
- How much is a throttle position sensor and where can I buy it? I cant find it on partspalace.com
- Window problem?
- i searched but no results: looking for a write up to take the shift panel apart
- car cranks, it turns over but no spark
- So THAT'S how the Picture Poster Works...
- Wheels or paint first?
- radio question??
- question for these wheels....
- Strut Inserts
- Radio makes annoying pop sound when i shut off car
- Where is the throttle position sensor on a 97 A6? Hard to change?
- Car not starting
- Audi Gamma non bose radio wanted
- Well, I guess I'm shifting forums- moving to C5 (2003 a6) some loose ends from my shop though...
- what does the code 4444 on an 92 audi 100s mean?
- Got some goodies for some of you guys
- clicking from front drivers window
- Location of auto tranny dipstick on a '93 100?
- Steering wheel/ignition tumbler removal
- Anyone know of a SGI dealer ( or other grnd effects ) in the US?
- Does anyone know the diagnostic code(1111) on an 92 Audi 100s?
- locked-up brake
- Gearing up for A/T fluid change (no pun...), how much fluid will be needed in liters? More...
- Selling my 97 A6 cant post in marketplace so here it is
- My name is tim and i drive an aries
- Bilstein Strut Clunking
- Radiator fans keep running
- 1998 A6 avant what forum should i be in?
- 92 100s temp gauge not working
- Anyone ever chande the lighs on the fog lighr switches from yellow and green to red? I would like to
- What type of bulb does a 97 take for the high beams?
- Rotors and Pads
- Tire size ?
- Special Purchase 22lb 18" Wheels
- Anyone have center caps for these wheels?
- Interesting reading about Audi
- Lights in switches, can they be replaced?
- Any thoughts on A/T fluid, i.e. Pentosin vs. Castrol Synthetic? I'm getting ready to flush...
- Strange problem with my 94 Audi 100S
- Anyone ever check their t-belt and see it looks new and not change it?
- 100CSQ ABS issues
- auto transmission
- can't start after check light comes on
- New to the forum, and to Audi. A couple questions (kinda long)
- A6Q transmission
- TSBs for all!
- No Start.. Ignition Problem?
- electrical problems when starting.
- ok follow up on strut question for my favorite audi masters...
- need head torque specs again and sequence
- Whats with this PS pump noise & how long until it dies?
- What front struts to get for a 97 A6
- how many people are actively posting on this board? i see jim and some others
- Hi guys! I have a 94' 2.8 V6 100 non Quattro.
- how do you instal a new strut... do you need a spring compresor
- 95 A6Q...oil leaks....what are the common issues?
- Dash bulb replacements - where to buy the replacement bulbs? Dealer is a rip off! 9$ a pop!
- engine flush as i post on my 92 100cs.. wanted to say hi to old friends and ask some q's
- "Repair in progress" photo's
- Door Panels
- Radio on "Safe" mode?
- huanted trunk!!!
- anyone have the Ronal R-41 on their car
- If you're looking for black oil filters and OE stuff try Europeanautomotive.com- free UPS over $50!
- 1993 Audi 100CS Quattro for sale
- 1992 Audi 100 S For Sale
- My head is spinning- need a new thread.
- curiouser and curiouser- checking tranny fluid. ANY comments>>(please)
- Power Steering pump
- 98' A6 2.8 Timing Belt
- From our recent Angeles Crest Drive. Not a bad turn out given the unsual road conditions
- Where do I find Euro spec headlamps for a 95 S6?
- Any way to tell which O2 sensor is bad?
- In an effort to throw this to the top... Optima battery...
- I'm getting a loug ratchetting/clicking
- Ignition lock cylinder
- help, my headlights won't turn on !
- Does anyone have a pic....
- CT/NY Audi Group "Not-Quite-Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
- Onboard warning system faulty
- Sold My Baby Today (crying inside)
- In ref. to the prev. instr cluster post , does the in-dash gear selector have a light? Mine, nada
- Climate control modules: A4 and A6 from same gen = the same?
- My Unbalanced Washing Machine -- Resolved
- Where do you check/fill transfer case on '93 100 Quattro
- oil pressure issues on 2.8l V6
- Boston peeps:
- Need some confirmation about the Airbag warning lamp.
- Head light bulb
- What's the dealer part # for the black oem oil filter for a 93 100s...anyone know??
- Air bag power cord
- Any thoughts on the best air filter for the A6 2.8? I read the comparison test but am still not sure
- somebody sells totaled Audi at Queens NY for $500
- Any particular battery of good choice for these cars?
- Clear corners - what bulbs do I need?
- what other body mods are out there
- coolant to get and where?
- royal purple
- Help with insturment cluster light replacement!
- Toe in adjustment: Audi Tool 3076
- Just curious, does anyone notice that their front passenger window motor is slow vs.driver's side?
- what is the problem with using Fram oil filters
- Keyless Fob & Switchblade Compatibility?
- Best Spark plugs i have ever used.......
- Rear right wheel getting hot when I drive
- Moon Roof
- I replaced the front struts in a 95 A6q but now the struts twist a little in the top mount and
- Is there a PCV valve on these engines?
- Brake fluid, mineral or synthetic
- Special tool required???
- Driver mirror glass is stained - where can I find a replacement?
- Another trans (linkage?) question. I noticed last night...
- Clicking......
- 1997 A6 Door Panel?
- Q7 SUV info - new
- my car unlocks in cold weather??
- 1993 audi 100cs quattro a/c woes..
- Can anyone identify this?
- Sunroof problem solved! For anyone who's interested...
- HELP!! I reconnected the battery and the sunroof refuses to close!
- How much does a tune up go for and what's involved? I've been thinging of getting a tune up at 150k
- Latest Crash update
- 94 100s....2 or 4 O2 sensors??
- New Prestone coolant(mix with anything) good or bad?
- check engine light
- 2.8l V6 engine oil recommendation
- Is the 10-disk CD changer from an UrS4 a direct bolt in for 100's?
- Would black shoe polish work on steeringwheel cover?
- A6 Temperature Gauge
- electric fan is a turn though the engine is cold of it.
- Can anyone name this plug?
- Help? Window trouble
- PCV valve elbow and vacuum hose
- Follow-up to my trans fluid top-off adventure (longish)...
- can you use the positive chared post and the ground post.
- Audi/Bose Wiring Harness From the UK - Follow Up
- Need help from fellow NY/NJ AW members
- Best source for the Bose Rear Amp
- What is the best laser echo ???...more
