- FOR IAN B. !!
- How to disable Central Locking System?
- Cutting Cats off
- we need to find some new headlights that fit our cars. And on the cheaper side.
- Since switching to Mobil 1 5w40 "truck & SUV" oil, lifters are completely silent
- could someone post a picture of his stock exhaust system from the front all the way to the end?
- A/C evaporator drain cleaning???
- STALLING AND THEN WONT START !!!!
- STALLING AND THEN WONT START !!!!!
- Ignition Switch Problem
- Has anyone retro-fitted HomeLink garage door opener to their car?
- selling my silver avant
- 95 A6 Quattro Power Steering
- Has anybody replaced thier cat convertor with an
- Inspection / Airbag Reset Tools
- update: DIY ported TB: idling issue: fixed (and here's another colon:)
- Ok, hood popping question.......
- Just got done re doing the front end of my 100s what a difference
- squishing noise over bumps.....
- 1991 Audi 100 Oil Pressure Question (Electrical)
- v6 engine vibration @ 2000 rpm
- How could you convert a CIS (Continuous Injection System) to fuel injection?
- Rear Final Drive Seals?
- **UPDATE** for those not already heading this way, don't forget
- X-Post: NE Ohio GTG 6/19 - Bunker's & Cruise
- Paging Seattle Scott or anybody else for Spark Plug Change procedure
- Info on the car that has to go...
- Air Bag Light - What's the problem?
- A6QW stuck rear door
- Rear wiper problems
- sheesh, how many people have driven on I-90 here?
- DIY bored Throttle Body... just wish it was as good as UrS4's from the 12v forum
- Above 5 BAR Oil Pressure, and Oil light..
- Help Needed..Overheating all of a sudden..
- 1990 Audi 100 Question
- i need some help...
- Spark Plugs
- What do you think? Lowering springs, ebay.de
- How do you remove the rear calipers???
- yeeeeee hawwwwwww
- Really have to get rid of my A6...
- FYI... I got a brand new A/C compressor with drier for $345 on eBay.
- Milage Report
- 97A6Q : Looking for a Wheel for my Full Spare Tire 205/55R16
- Squeaky Seats ....
- Whats the fastest that anyone has driven their Audi's ?
- 2004 Northeast Audi Event -- June 25th & 26th
- Has anybody replaced their body trim
- Help, brought my '93 100 to Aamco for Oil leak, now I got a problem!
- UHHHH I just got ripped off on strut replacement
- High-level (center) brake light bulbs
- does anyone know the fitting size for the brake lines?
- A/C blows hot air on any setting except low
- 10 Disc Audi/Bose Changer producing Static?!?!
- alarm troubles
- Struts....Rick601....struts
- AC problems
- parking brake and rear caliper problem '92 100
- anybody looking for clear corners?...saw one in eBay
- Fix one A/C now the other is busted
- Anyone have a salvage surp. belt tensioner they'd like to sell?
- any input on a product called engine restorer. to put.
- Coolant drain questions
- Autocheck DIsplay
- are any of you 100 owners proud of this owner?
- stuttering while accelerating? dirty egr valve?
- quick question
- anyone wanting to sell a reset tool for indicator lights?
- Transmission dipstick--audi 1993 100s----
- USGP F1 Dinner and Indy Audi GTG June 19th
- is there any way to get the hood open if the cable breaks?
- reset info. for indicator lights....
- My 100CS has gone through another A/C compressor...
- Mark's brother- did you do the outer sway bar mount yet?? result??
- 93 100 csq interior door panel removal
- Northeast Audi Event coming soon!
- strut dust boot question...
- Should I have a fuel injection cleaning
- Audi S3 2002 strange paint spots after 2 years...
- Brake Light indicator
- just hit 150k pulling into my driveway tonight
- Will an audi gamma (non bose) from a 93 90cs fit a 100s?
- Audiclub raffle of A4 Cabriolet or TT 3.2 DSG!
- Strut Bearing
- Key on Battery dead almost
- Which shock absorbers? Audi 100 C4 with H&R springs
- Dealer service history printout ...
- Anybody had the Child Seat Tether retrofit done in an Avant?
- Cam someone tell me the procedure to properly change my timing belt, what parts need to come off
- Ok, so I changed my sig. Tell me what you think
- Why is the coolant expansion tank cracked on my 97 A6 Avant quattro?
- Trans Flush: 1997 A6 Avant quattro
- In search of (4) power window motors (complete with controllers) from 97 A6
- How hard is it to install new front struts on the 100
- Annoying noise from front driver's hub
- Annoying 1990 100 brake light info center
- Anyone here have the Intrax springs on their car???
- i have a big tranny leak...
- Audi 100 2.5tdi fuel filter leak/ warning light problem
- 1992 audi 100 center armrest removal
- A quick glance through our FAQ, and it's obvious what the problems are with the C4
- ** 4th Annual Audi Owners Gathering! **
- 1990 100 idle adjust?
- Winter wheels / spring project
- Cup Holder Dilemma Solved
- JUST BOUGHT: 1997 A6 Avant quattro
- 94 A6 wont start
- a/c not working properly...
- Bose Audio: (92 100 CS): Replacement parts
- Audi 100 1992 Headrest removal problem
- wheel bearing for 93 100CS Q- please help
- Ok I remember there was a common oil leak....
- Unfixable Oil Leak!! Help!!
- TO BUY OR NOT: 1997 A6 Avant Quattro
- saying HI a4 style
- Replacing Brakes.....
- electric roof
- coolant problem??
- Anyone parting out a 100???
- how much weight do you think can be put in the back of a 92 100?
- smokiesman
- Is it OK to use Mobil 1 0W-40 YEAR ROUND??
- Drivers power seat won't move
- SoCal folks... REMINDER: SCC Audi Julian Drive -- Saturday June 5th
- anyone know of a place that takes or needs tranny cores?
- for anyone interested...
- What is the reccomended t/belt replacement interval?
- O2 Sensors for Audi A6, 1996?
- drove to work today for the 1st time in the new a4....
- Survey: Which oil weight do you normally use in your 2.8L V-6? I've have been using 20W-50...
- COMPUTER MELTDOWN !!!
- Service charge question?
- Street Closed: Audis Only
- 96 A6 - WAGON QUATTRO Oil Filter & Timing belt inspection???
- CS 100 Cylinder heads: oil plugs/relief valves
- Brake plate??
- Where does the black wire on remote locking controller go?
- instrument cluster
- jota1965 post some pics of your audi in rome!
- How to remove oil pressure switch for gauge?
- any opinions on the '95 A6?
- EGR valve or O2 sensors?
- Ticking in the engine with the AC on... Any advice?
- Location of A/C Low Side
- 1992 Clear Corners
- 100CSq climate control issues (diagnostics)
- Audi 100S 93 : Trunk Strut
- A6 help needed
- Shocks on a '97 A6 Avant
- '92 100cs catalytic converters
- I have hooked up my iPod to the CD changer.
- i did it guys.
- Windshield Washer Fluid Reservoar
- Any ideas on how to remove broken guide pins from engine block?....
- Sell price advice
- OK. Here's my day today at the Belmont Lake with the kids really wanting to go fish... and we did!
- Strange radiator fan thermoswitch problem.
- wagonmann did u ever post the pictures when u did the radiator flush on yours?
- random location question: where are we all located?
- 1990 100 VS 1993 100 (long)
- removing heads in a few minuts - where's block drain plug?
- Fellas, some audio help
- Whats tha average Life of the fuel pump ?
- check valves in the heads.
- Changing instrument cluster illumination light
- snowman or jschick: its vagcom time
- What's the name of the bushing causing a clunk on turns or bumps>>
- OT, but car related, looking for contacts
- guys. i might be leaving this board soon....
- my first CEL... AND I had to MAKE it come on! kinda...
- Any suggestions for an Indy shop in or near NW Suburbs of Chicago??
- proper trans fluid for 92 audi 100 CS FWD
- Fail-Safe Mode
- Large rims and tire pressures
- how much would you pay for 97 a6q in exelent condition and 102000 ml.......
- Questions about my 1990 100
- Will my 2000 A8 17" wheels fit a 93-94 100 CS Quattro
- paging decolliber
- Gas guage drops to empty
- Sec.Air Inj.Sys.,Bank2 Flow too Flow
- Shocking Discovery
- When I do my t-belt service soon (i have 73,000 mi.) should i replace anything else? 97 A6
- so i bought a used laptop at the pawn shop for the vagcom
- Climate control - temp motor?
- dash light
- Add an oil pressure guage?
- HeyBrdman!!
- Analog Clock on 92 100s
- X-Post: NE Ohio GTG 5/29 - Bunker's & Photo Shoot
- warning "chime" failure
- Exhaust
- Strange A6 Avant V6...
- Finally fixed my Cruise Control...
- What brand front end bra do people use?
- im sitting in the garage vagcom'ing [edited]
- audi reset tool on ebay for about 70.00 us..
- Is it easy to replace Front Driver side Strut Dust Boot?It is torn Any procedure you can share..
- Do people not know how to type in the subject line of responses?! :-O
- Heres a stumper for you....
- Looking for some fatherly advice from my fellow forum-ers.
- My new gas saver..
- 92 100 shuttering please help
- Do someone know about the best place to get used parts for Audi A 6 1996?
- Climate control not always works.
- anyone have info on how to remove.....
- 1997 A6 Q
- IMPORTANT: Please support our Audi Enthusiasts from Audiworld/other Audi sites that are overseas!
- Anyone replace their cv boots? Hard??
- kudoos for Smokiesman
- How to replace Audi 100 Relay Box
- did my obd2 conversion today and tried my cartechsolutions interface with vagcom and it didnt work
- sunroof
- Maaco Paint Prices??
- Rear camber on FWD 100S
- Car Cover
- 1990 audi 100 speedometer problem
- anyone know the size of our cats?? also what is the exhaust tubing diameter??
- Where is the PNP relay?
- ATF question?
- Hey 4Driver4. Headbold driver revisited...
- Just purchased another 94 100 CS
- Anybody have good right front and left rear lower door mouldings for sale?
- O2 sensors for '96 A6Q
- Has anyone had to replace rear driveshaft in quattro?
- Brdman*, where'd you tap into the power mirror for your stereo power?
- '96 A6 both remotes not working
- Anyone know how many miles a 93 100s will go before giving up
- Does anyone know where the Bose amp is located in an Avant?
- MY wife 94 100S is acting up again
- 93 Audi 100CS
- Interested in a Michigan forum?
- conflicting e-brake info- where to adjust cable??>>
- i ordered the cartechsolutions interface on ebay
- ouch
- going to Budapest for work for a month on Sunday. anyone from there?
- I posted a shocking Gaza Strip post earlier today but AW has taken it out. It featured Israelis...
- what did i miss this week
- Mark/Steve...Get the Bentley today?
- A few problems (oil light, etc)
- O2 sensor question - will a 13913 Bosch oxygen sensor be acceptable to use...
- You will not like this but it does show a 100 in a hostile Gaza environment.
- need sheepkin seat cover for 97 a6q.. any reccomendations?
- Engine Stand Mounting Bolts?
- Just Replaced high Pressure Hose 1994 100s
- Window washer stopped working...
- X-post: Custom Audi Racing Jackets...
- NE1 have a cam tool for doing the T-belt timing (or can give me some details)?
- What driver do I need for my new headbolts?
- 97A6Q - Good Audi Service Shops in the Carolinas
- now why would i expect changing coolant on my audi to be simple...
