- now why would i expect changing coolant on my audi to be simple...
- Didn't use premium
- '97 A6Q - AC Recharge - Final Word as far as I'm concerned
- Posted this on the audio forum but no response....
- Car almost caught fire today.. Battery shorted
- MAF Sensor Disconnected
- Could low tranny fluid...
- Humming noise coming from back of the car
- FS Audi 100/ A6 1992 Auto Trans and misc parts
- THERE'S STILL SOME MEAT LEFT ON THEM BONES
- Relay Box Cover Label
- Newbie
- I am looking for rebuilder 92 -97 100 A6
- FS: Audi 8 Pin CD Changer for Delta
- Major transmission problems are breaking me..help!!
- I need Help popping the Hood on an 95' A6. How can I do it with a bad release lever?
- Terrible results against a weak car...
- For your viewing pleasure. Bottom one especially...
- What is the pin # on the circuit board for Concert II button illumination?
- The Cabin Pollen Filter I Used...
- Paper Bentley's are bringing good money.
- so the car didnt shut down on the interstate on me the last days
- I changed my job. Now I am taking subway. I did not drive for last five weeks.
- Electrical drain problems. (window relay, yellow wire, etc)
- fans...on...and....off
- Trunk light question
- How to open a stuck rear door?
- Automatic trasmission problem 096 (long)
- Help. went to replace pollen filter & there was no old one there, I though I was going to...
- Good partz
- The 1994 100S Pearl White unfortunately has to go, any buyers outhere!!!
- '94 100S Check System
- can someone help me find..
- I wonder what he was thinking
- Tires Size Questions???
- air conditioner recharge.....
- my local parts store didnt have the pentosin coolant, they only carry prestone...
- Reliable Parts Dealer that ship to Germany?
- Data sticker explanation - Optional equipment
- Some summer projects and questions....
- Anybody know..
- Midas Cats vs OEM
- help serious battery problems!!!!!!!!!!!
- Good parts car or maybe fixable
- REMINDER: Charging on High Side of A/C is EXTREMELY HAZARDOUS.!!!
- W T F???????
- Oil sensor - 89 AUdi 100
- 1989 Audi 100 fuse diagram
- Took the 100 to the track
- Charging the A/C in '94 100CS-the continuing saga! Long post.
- arite, so i gotta drain my coolant and buy the right kind, is this the right way to do it?
- Has anyone connected an audio source to the Delta CC Radio?
- engine shutting off on the interstate again (gets to be a daily thing this week) DTC2324
- Why would a rebuilt caliper stick when>>>
- Anyone have a pass side front lower bumper corner grill?
- Where can I rent that tool for tensioning the timing belt?
- Anyone with Bentley's willing to print something for me?
- 1994 Audi C, shifting transmission problems, or are they?
- Does anyone have the part number for the pollen filter for a 97? ETKA...
- Don't know if anyone knew but 12v.org is back online, maybe I just found this out :-P
- new caliper "sticking?" I'm smookin'
- SAID GOODBY TO AUDREY! (sniff sniff)
- What's my 95 Avant worth?
- CD changer adaptor
- Need help with door locks-alarm
- 96 A6q wagon - a/c charging question
- 92 100s temp gauge not working, which wires to test? diagram?
- Where to get A6 front bra?
- Reverse Lights Driving me insane
- Pearlm30 did you get your blower motor out? I've got to do mine now
- 94 100 CS A/C Epilogue.
- vrooooooooommmmmmmmm
- CALLING SMOKIESMAN !!!!!
- now that its getting warmer out, I just detailed my car...
- steering squeak......
- Performance Mods for '96 A6? (and other purchasing considerations)
- how many people are using vag com on this board?
- Engine Covers busted and Ratty????
- quick "C" Band Servo question.
- For those who are looking for the 3-volume hardcopy set of the Bentley Manual,....
- I love the way the c4 avant looks....
- Where do I drain the coolant from?
- 97 a6 odometer/ outside temp bulb replacement
- abs
- Will 98-01 A4 wheels fit '93 100CS?
- I just bought a 93 100CS Quattro
- Boss tried to be nice but may have made a mistake...
- Check out this jacket. The wife said, "why don't you get it?"
- 1993 100 V6, I want to buy a VAG-COM but which do I need ? I'm a n00b
- o2 sensors won't come out.
- REar Brake is driving me crazy (97 A6Q)
- 92 100 2.8 interference motor if t belt breaks????
- Question From a Friend: "Is there a chip for a 94 C4 100 V6 that will make more horsepower?"
- BOSE verus GAMMA radio
- lookee! i got some bling bling in the mail today
- Will a ECU from a 91 100 work in a 94 100 avant?
- universal cat converter
- Can't get transmission out of park
- funny driveline noise
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), Sign Up Now...
- Trans Multifunction Switch
- analog clock on IP cluster not working all the time...
- Muffler
- ABS relay???
- 1994 Audi 100 CS questions for Air Conditioning Charging
- '97 A6 Quattro--- Brake Fluid & ATF
- Transmission, center & rear diff services
- Hey Guys Question
- What is the exact name for the front strut rubber sleeve??
- 92 100s 2.8 v6 hesitation problem
- Car stereo head unit with red digits for audi?
- Blower Motor Removal Instruction???
- NorCal Audi Club Marin drive: Saturday May 15th, 2004
- is it me, or recently a lot of people type in caps only? Is it because Muhammed is out? :)
- Sunroof Drains
- still need original mags for a6 97. in mint condition...
- No Brakes!!!
- I think my mech is tryin to rip me off....
- Help!!! Oil Pressure.....
- so i drove around 100 mph today and gotta
- Oil Burn Smell
- 97 A6 12v coolant sending unit
- engine coolant question?
- 92 100 CS Shifting Problem
- CLIMATE CONTROL ON 97 A6
- found on ebay-resett without tool. what ya think????????
- headlight bulb burnt out... what's a good upgrade>
- Pedals
- A6 2.6 Avant 1995 - Timing belt question
- Almost solved the gear indicator, dim problem, thanks everyone - more inside
- 3.0 Engine on eBay
- dont go into this forum very often but i do check it- havent seen many pics but i came across this..
- are you happy with you car, or would you change something
- 1995 Audi A6 with serious Idling Issue...
- soneone explain me the memory seat function please.
- Just have seen some Black A6 towed in NYC. Are you here?
- anyone have any experience with front end bras...
- Any Way to Check Tranny Fluid?
- Finally I will have the printed Bentley Manual
- My car was hauling today...
- RF Remote - (story, questions)
- Thanks for all the help guys.. but I got rid of my 1996 A6
- I's Sure this has come up b4 - Are our Cars Really Slow ?
- Replacing front struts on a 92 100
- how many of you have taken the inside of the airfilter apart
- so i drove some 600 miles during the last 2 days and had some problems
- A Question on replacing a piece of molding.
- Power Window Nightmare!
- is there a 57i kit for the c4? i looked around and didnt find anything today
- Catalytic conveter blow out
- Instrument cluster removal for 94 100S
- Good sale from Dave Pennington
- Anyone have a front plate holder for sale?
- ABS???
- Service Interval Light resetting procedure
- car wont start(audi a6 automatic 95)
- Mud flaps
- 2004 Northeast Audi Summer Event Info/Registration/Forums/Site is up!
- Re-torque Head bolts - is it possible to break the bolts?
- Wobble!!?
- used tire shine stuff today on all them moldings. looks awesome! never tried that
- HELP ME!!!!!!!!!
- This guy claims he can turn off the service warning lights...
- so my mum tooked the audi to go and pick someone up to go to church
- OK guys. A BUGATTI. So what? 1001hp is nice to have. The price is a little off though :-(
- rattling sound
- Hey! What's with the cig lighter sockets???
- Extremely off topic
- anyone need a valve body for the 097 tranny or other electrical?
- '96 A6q tires and wheels
- replaced the tranny in the 92 100s over the weeekend
- Boot Lid Stuts Question ?
- !!! need advise with stuck screw on IP cluster !!!...
- Black 100 w/ roof rack in queens NYparked behind me b4 .. you in here?
- FOG LIGHTS
- Excited!!! I just ordered this Printed Bentley 3 vol set today
- Got my 2.7T!
- The car is officially for sale...
- 97 A6 Q: Air bag light on for a minute...
- anyone on here or know anyone who might have some throttle bodies laying around?
- Keyless remote on a '96 A6Q
- Can anyone tell what this is???
- one radiator fan not functioning... fix it immediately or.. chance it for a few weeks
- Something you may not have thought of this spring?
- 93 100 quat turn/flasher
- Need sunroof switch panel for '96 A6 2.8Q Avant
- loss of power, need suggestions
- Airbag Safety Disconnect (red single pin)...
- Does the PRND321 shift indicator in the display dim with the dimmer?
- Drove a TT Today
- If the speedo is broken... can I just buy a used instrument cluster and swap it?
- 93 100CS side moldings
- Look what I did tonight
- 97-A6-Q What is function of the square button with speaker icon, on driver's seat door post?
- 97-A6-Q What bulbs are used for the PRND321 and other LCDs? CalG?!
- Weird place to find an audi
- When I replace driveshaft...
- This seems like a well written article on basic Audi matinance...
- tranny fluid change or flush? how often on the 2.8L?
- Any online user manuals for the 97 A6 Quattro? Links?
- 97 A6 Quattro - No user manual - DQ - How do you set the analog clock?
- Adding a outside temp display!
- Just bought a 1997 A6 - please help!!
- 97 A6 Quattro - Anyone have a URL to visual instructions to removing the dash panel?
- Hey, CalG... Thanks for the info on the dash lights. I was finally able to fix my PRND321 lights!
- 90 audi 100 quattro help pls
- Door chimes and Buzzers
- can you help with my homework?
- Broken Alarm remote
- Instrument panel bulbs, replace only bulb, or bulb with base?
- Cooling issues may be solved....
- Is anyone from this forum going to Carlisle Import - Kit/Replicar Nationals next month
- Repost: How much should I sell my car for...
- plastic engine cover fasteners
- Climate control auto
- Now the passenger side window won't rollup!
- Anybody know where the chime is that lets you know your headlights are on after key removal?
- engine randomly stutters and doesnt take gas well
- Hints for changing BOTH oil pan gaskets??->>
- 94 S100 ignition and door locks
- brake questions....
- Just got back from ontario.......
- Where is the best place to purchase clear corner lights for 97 A6? What price should I pay? Post...
- ignition switch?
- were/how to machine the heads?
- Bad AT, bad! Tranny problems and woes...
- Spark plug & wire
- Looking for Audi Gamma Head for 93 100s
- mulling '96 A6 wagon conversion to manual 5spd
- Hey guys, how are the C4's running?
- Trans Service Done...Good news I guess
- Clicking Noise????
- How do I remove the door panels on my 96 A6?
- How much am I looking at for a new headunit? CD & FM only.
- Anyone ever re-code the Auto-tranny?
- THE END IS ALMOST NEAR!!!!!!
- Is that 100 still being parted out, or have the bones been picked clean?
- Does anyone have a 92 100s and a Vag-Com?? help please
- A few 1993 100s Questions O2 Sensor
- Why am I beeping ?
- BOSH SPARK PLUGS
- rear lights out
- audi 1 ford 0
- anybody in NJ/NY willing to test an ECU for me?
- Anyone driving a white 100 or A6 near manhattan college today?
- Belly Pan can loose at 70 MPH
- anyone have Eibach pro-system?>
- So all my eletrical gremlins had a simple answer!!!
- whats the fix for the reverse lights beeing on while in drive
