- Where could I find JUST the external temp chip/module>>
- Anybody recognize this part? I found it at the bottom of my door frame.
- Audi 100CS 1994 Transmission & O2 Sesor problem Fault codes 2331 and 2342
- Engine Light........
- I owe it to:
- type of oil to use......
- Almost ripped off my front bumper.....
- Concert II auto power off failure with ignition and after 1 hour problems?
- Think I've figured it out
- Beating a dead horse... how to change struts?
- Audi 100 wagon rear hatch
- ~Sea Foam!!Need the Location of Vacuum Line!!~
- 92 A100CS Engine dies
- anybody changed their instrument cluster bulb? I wanted...
- CEL Ignition Output?
- 92 100s has anyone converted their AZB tranny to the CDT?
- How to open inspection/adjustment port in wagon hatch panel?
- Has anyone use DEXRON III in their transmission?
- Lowering an A6 quattro 2-3 inches?
- 25 pin connector
- Heeeeeyyyyyyyy Wagonman! (or anyone else)...
- wheel offset question
- Central lock
- OBD1 to OBD2 Port Conversion???
- 4 sale parts on dismantled C4. This guy may still have some parts available...
- Question on rear hubs - (and maybe looking for salvage one)
- Anybody need a new engine or quattro trans with 60k on the clock?
- Could someone please tell me what this code means....
- Check engine light on. no 'woosh' from gas tank
- 12v V6 running rough all of a sudden
- Stinkin' AC
- Oil Loss on 2.5 V6
- Putting in a driving computer?
- climate control,only cold air coming out
- 1993 100s freon refill
- '97,A6 automatic trans indicator on dash
- cd changer
- would 2001 A4 rims fit a 92 100s?
- Audi 100 help
- Touch up paint for interior
- Useful link Electrical diagrams
- I've loosened the frozen cam for the E-brake but it still doesn't return>>
- Which side of the 12v engine is "Bank 2", right or left? TIA
- how bad is an exhaust header gasket install? My piece sounds old and farty. ;)
- who is this?
- age/Mileage poll 92cs 128.932miles
- front fogs independently running from headlights?
- driver's side wiper problem
- Question about Bilstein HD
- Does anybody have an extra Clutch pedal for sale? Thanks.
- Question regarding Gamma CC radio
- Where is the engine temp.sensor specifically located on a 97 A6Q?
- Interior Trim
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), sign up info...
- Lowering
- Electrical Problem
- gaskets- which #'s for MY 96...
- MAF Sensor Question.
- ok Guru's what tranny do I have???? 92 100s, 097,01k zf4hp18
- How can I tell between crappy brakepad squeal and bearing squeal?
- Sunroof leak?
- 100CS water pump r&r.
- My A6 had NO cabin filter!
- I washed my engine at the car wash !
- need brake parts
- strut removal tool?
- Question about the Bentley... with VAG 1598 terminals and the like...
- 93 100S won't start after crash- need advice
- Crap ! Got a flat tire today.
- Superb 94 100Q Avant on Ebay
- Does anyone have the minimum wear measurments for front and rear rotors on a 97 A6Q?
- High pitched sound on acceleration at various speeds
- Photoshop help
- 1992 Audi 100 Suspension Question/Problem
- Heat even though A/C is on??
- RATS Went to fix my rain channel today & found more parts in the roof
- I just though I would PRAISE the manual tranny. Anyone with me?
- Does Anyone Have their OEM Front Springs????
- Poll : Did you loose functionality when your ignition switch was changed?
- What concenus did we reach on the proper way to change the tranny fluid on a 97 A6?
- 2.8 V6 Ported Throttle Body
- Looking for cheap 16" wheels for my 95 A6QA
- valve change
- 96'A6- auto tranny kinda jerks when downshift from 4th-3rd.. abruptly, when car's been driven a whil
- Crap ! Just changed ignition switch, now the radio stays on w/key removed. Bad replacement? Tips?
- had tie rod installed...shouldn't it be leveled instead of angled?
- '96 A6Q Rear upper control arm ends only or assembly
- Is the engine temp. sensor and the water temp. sensor the same thing?
- Help- wife is stranded
- just curious...any other Avants out there?
- One-Handed Trunk Operation Not Working
- anyone have the bentely manual for 92 100s and Vag-Com
- Trouble with A/C code 29.2 (29.4) (+)
- Audi 100 insperation needed!!!
- Made it past 100K mi this wk
- WTB: Black Passenger Side Seat Belt from A6/S6
- 90 100 alternator
- God!! Don't you love an Audi... accident pictures URL
- can someone email some info from bentley manual??
- NEW...Ronal R41 wheel style....COOL!!
- need instructions on how to....
- A/C won't blow from center vents... Just floor and top of dash!
- PULLED MY TRANNY CODES 00293 , 00300 , 00518
- CATS ARE GONE
- Weird light situation
- Torn boot?
- i guess im back on the road again (kinda against my will)
- Anyone know Remote Locking Controller Part# for 97-98 A6Q?...
- lectric drain (cont.) power plug (6 position) next to battery in rubber...
- Drowned '94 100S
- anyone have set of floormats for sale for 97 a6??????
- O2 sensor.......
- A/C Compressor Replacement Cost?
- Replacement Radio Question
- Rubber trim at bottom of doors
- Which floor mats will fit my car?
- (poll) whats your favorite mod on your car?
- Heater Issues
- May be selling my audi...
- Blown Speaker
- bumpy and thumpy
- Any of you with a Bentley for 100 or know about lug bolts....
- can my alternator suck the life from my battery- overnight??
- Leak
- Spedo Problem
- car came back from the shop
- Trunk lock doesn't open the trunk...
- Temp guage never goes up (92 Audi 100 CS)
- Ran the VAG-COM today, gave me a fault code for engine temp sensor. Where can i get one cheaper...
- window wont go
- does bentley manual cover 92 100s trans rebuild? valve body
- Look what I did yesterday......turned to the dark side : (
- OMG! A friend of mine who wanted to sell his UrS4 just GAVE me the car!
- Changing coolant hoses on 92 100CS
- Brake Lights
- Keyless Entry system for sale
- CLIMATE CONTROL DISPLAY LIGHTS
- My car exploded today, front bumper was 200 ft from the car! Huge ball of fire!
- Does anyone have a picture of what the remote for my A6 should look like?
- remote auto start
- did you notice in the faq
- Ok, so the car is running good. Here is a question about driving the damn thing !
- Off Topic...How do you get the sig at the bottom of your posts
- Door lock weirdness
- Hi guys,I'm back.P.Window issue solved.
- RE: Oil pressure warning light in instrument cluster came on again...
- How much should I ask for my car?
- Power Steering High Pressure Hose
- Samm or HenryK... please share your solution for the 3 to 4 shift issue.
- 95-96 AUDI A6 Keyless entry remote program
- Best Performance Tire upgrade for C4
- Key switch
- rear suspenssion clicking.
- Relay noise/ extreme clicking noise in park when releasing brake pedal
- Jay Koval, can you delete your post in the FAQ and ask your Q here, please?
- coolant/overheat issues. (long, but please help).
- Slight engine vibration on 92 100CS....
- 92 100CS Parts Needed....
- Is it me or does BLAU contradict the info I got here...
- frost plug size
- looking for cai for an 96 a6 2.8q
- Can/is the trans fluid in a 97 A6Q supposed to be changed or is it lifetime? Thats what the...
- I'm getting VAG-COM software. Is therething I can adjust in the computer for more power? 97 A6Q
- Suspension question.
- Rough Idle, CEL, 02 Codes, Generic O2 Sensors...
- fuel gauge malfunction
- YOU ASKED FOR IT!! "Not for the faint of heart"
- is Audi most complicated car,how many fuses and relays this car have
- so the final words are
- How to duplicate key
- does anyone recall who has the diagrams for converting audi 2x2 conectors to OBDII
- Sunroof acts up (A6Q SW '96)
- Needed: Head lamp for a '96 A6
- 92 100s auto, what is this Tranny # 128kw-gkap-aut
- 3rd Annual EPqC Nazareth Area Fun Run: 03-APR-2004
- Having fun with the A4
- Wow, there are some beautiful C4s on ebay...
- So the radio died a while ago and I was wondering is it easier to go aftermarket...
- Anticipating trouble- What do you carry??>>
- Erratic Idle
- Anyone with a set of these 15" wheels...
- AHH, wish I had the funds... Drove a Volvo S40 T5 at their driving event today.
- still Ican't find power window fuse,does somebody know where is that fuse,I don't have ow. manual an
- broken high beam switch?
- Need instructions to take the fuel pump out of
- damnit, I broke the fricken door panel...
- Ft. CV Boot/Ft. Control Arm Replacement
- Audi 100 avant oil presure problem
- Well guys, the wagon is gone
- 98 Avant Question...
- Climate Control lights repair
- i had some time today and layed under the car
- Please HELP ,where is fuse for power window,is hard rain in Seattle
- who wanted a pic of the glovebox light?
- 21,000 mi. 96q on Ebay...nice
- WHAT YOU THINKS FOLKS??? LETS MAKE A DEAL??
- Still havent been able to find the fuel pump relay !!!
- remote entry alarm etc.
- Door Panel Help
- what do I need for VAG-COM and where to get it? LAPTOP
- fo the trunk monkey
- squeeling noise getting to be to much??
- A6/S6 C5 Platform Fires...
- Whine/Growl-What is it?
- 1993 Audi 100, Help Driver Front Window Broke :(
- Trunk opening
- where is fuel pump relay loceted by 92 audi 100cs
- Dashboard Removal
- 92 100s Fwd, can you confirm it has trans computer--shift problems
- Brake light (O)
- Hello from Russia
- For those who have wind noise from front door seals..........
- Can somebody post a picture of how the glovebox light is mounted? Mine is just hanging down...
- battery?
- Idle Tensioner
- Where is the fuel pump in 94 100S, in the tank or...
- My engine temp guage is intermitent, mainly it doesn't move. Oil temp guage NEVER moves....
- Oi Vey :- (
- How much should I ask for my A6?
- Good Source for Audi Gamma/CC Radio?
- what size battery fits in my '92 100s?
- Whats the snowflack button on the Climate Control?
- HELP, was running fine and smooth while driving and just died ...
- Gamma Radio
- Sun Roof won't close.
- 2.8 badge for the 100s??
- URS4 Throttle Body
- PUTTING MY BABY UP FOR SALE!!
- Serpentine belt broke due to broken idle tensioner
- can the voltage regulator be tested seperate from the alternator?
- starter removal and reinstallation
- alternator removal and reinstallation
- i wish
- shimming at 80mph
- Does any one have instructions for removing the side mirror switch
- what are all the different bulb models for replacement on a '96 a6...tia
- I have an early build Throtlle Body..
- radiator fan is always running on slow speed ...
- 93 100 csq needs new fuel pump
- My mechanic doesnt know if he replaced the water pump and t stat...
- Overheating Issue
- New? Sunroof Problem (didn't see this problem in Forum before)
- Went to change my cabin filter...
- 94 100S side mirror switch ....
- Climate Control question: How does the CC unit power on/off? (private dealer messed with wiring)
- S type Headlights
- Will These 2002 A4 Wheels Fit My 97 A6Q
- odd spark plugs?
- snub nose mount
