- Think I might be saying goodbye soon guys...
- ok so what else could fail? neutral safety switch?
- so its not the starter
- '94 100s - Clicking Relay/Headlight flicker
- some dude bought a waterpump and didnt net it for his a6
- Timing belt
- finally got em out
- 97 A6 climate control
- Chronic engine problem...ECM related(?)
- what the heck is up with this squeaky wheel?
- need help finding miniature bulbs for...
- If one were low on oil to the point of harm being done, would an icon appear on the dash?snowking8-)
- this board is really slow as of late. What's the deal? No problems?
- X-Post: NE Ohio GTG 3/20 (Back to Bunker's)
- MPH Warning lamp
- 96A6Q alternater doesn't charge (above 8-10 v) till 2300RPM???
- 95 a6 Quattro
- 95 a6 Quattro
- No leaks from the valve covers but I see a puddle of oil
- Need some advice on gaskets in general...
- Has anyone re-torqued their headbolts?
- Creak Creak Audi A6
- Engine Problems
- Brake/Battery light problem
- so the starter is finally loose but not out of the car yet
- three in a row, I win!
- Coolant
- I'd like to thanks everyone who helped me on my clutch job...
- power (cigarette) outlet
- dang nothing done today (edited) got something done
- Reminder: March 20th, Dirty Jersey Drive final details
- Hey Sebastian, what happened w/the white face gauges????
- MAF cleaning added to FAQ
- Satellite Radio
- transmission computer
- for those with bentley
- the bolts holding the starter are tight
- Anybody replaced their leds on the mirror switch?
- GAS SPLURG OVER YET?
- Rear shock replacement on 95 a6 (FWD)...
- Installed a Streetpilot 2610 in my car...
- so as i am working on the starter
- So close yet so far...
- ok. im finishing with replacing the ignition switch but sadly the car wont crank
- should i go for that one?
- Odd clicking sound
- Replaced valley pan gasket - car still leaking oil - ideas?
- NE1 with parts car - have a good surp. belt tensioner?
- Any idea why 92-97 Avants aren't allowed into Canada...
- 94 100S rear rotor replacement ......
- damaged my roof fabric upholstery due to cleaning! how to fix?
- 92 100 Tranny Trouble
- Oil Pressure Gauge?
- What would be the best way to....
- Engine Mounts
- Anyone know of a link or audi/vw specific site to list my car for sale or......
- URGENT:
- flashing red thermometer on the dash 93 audi 100
- sell car w/ or w/out wheels?
- VAG COM question
- Anyone know if these rims from the below post would fit on my car?
- pics of the brand new ignition switch
- '96 A6 Tranny oil change
- any in here ever pulled out the starter? it looks like its only
- Audi 92-93 Cruise Control
- 93 Audi 100 AirBag going off in drive way
- Anyone selling an A6 Avant?
- paging miktip
- Replaced brand new strut
- I dont think that the fuel pump on my car has been changed...
- would someone be interested in my audi? or should i part it out
- Dash Light bulb replacement 93 Audi 100
- No CATS at all?
- Propaganda: Guys, if you need rims/tires, check Audiworld classified.
- Beep-beep check ur mail pls.
- starter not turning over.... maybe a sign of a broken ignition switch?
- 93 100CS dash lights
- 93 100CS tranny problem
- Opinion requested on this rim...
- so the audi left me stranded again today
- What would cause high oil pressure?
- Need torque spec for harmonic balancer pulley and water pump
- Go To :
- Could bad valve cover gasket cause...
- Where's the wire? factory alarm!
- is third row seat a standard or optional. And do you think, I can sell mine?
- Wheel Spacer implementation
- today I have seen three C4 Audis on the way to work.
- Can someone tell me how to replace front cam seals?
- CD changer info for my '93 100CSQ
- Poll: What are you guys paying for a gallon of premium fuel? $2.19 in westchester, NY
- 1997 A6 Quattro Radio & Tranny HELP!!!
- European Bumpers - What are they worth???
- OEM Mirror Glass Source? (A6 Quattro)
- CV Boot revisited - $69 and 45min at CV Pro's while I wait
- Coolant bleeder mechanism
- Slightly OT: What's a good engine degreaser?
- What's this Radio Questions
- Front Drive Shaft removal
- Where to buy cargo cover
- Anyone know why the cigarette lighters are so big in the A6's....
- Color of 3rd seat, 1995, 1996
- anyone on the forum can halp me,found tranny for my quattro
- 92 Audi 100 Wheel Cover
- Antenna amp wire color?
- '95 A6- shocks and springs
- does someone want this audis
- Intake manifold removal.
- Aux Panel II
- FS: 1996 A6 Quattro Wagon
- How hard to replace CV boot?...
- B-SK where'd you get your tranny kit from?
- valve tapping noise 93 100cs
- 96 A6 Q - VAG-COM questions
- Installed OEM O2 sensors on friends 94 100CS instead of soldered ones,
- Reverse light switch on an auto 94 100S ....
- Audi 100 dash parts and other parts for sale
- new car 20 questions
- Worked on the clutch again today...
- PLENTY OF 92 100CS PARTS LEFT !!!
- ac refill
- Just noticed that my shift position lights on the dash are not lit (95 a6)...
- 94 Audi 100 Front Axle problem...HELP...
- Has anyone attemted an A6 to 100 headlight upgrade?
- Help with fitting a mesh grill , Anyone ?
- anyone want to sell an old wheel?
- Anyone interested in doing a boston area pot luck bbq g2g in boston this coming weekend?
- Uh oh, what am I up to again?
- argh
- Like my trunk monkey?????
- need advice
- Hey guys I just reallized that my Engine temp gauge ...
- I'm sure this is common...
- 92 100CS smokes, loses power, stalls
- Airbag Light confusion...
- hey i just bought a 96 a6 2.8Q for my winter car and was wondering what
- I'll be going to the Carlisle Audi GTG
- Rear Brake Caliper - Thanks.
- Anyone know where I can source a rear bumper support?
- Damn cruise control
- How hard to replace cam seals?
- Oil Pressure Sensor - is it for the gauge or light??
- odd torsen I question?
- Speedo is frozen at 22MPH
- I huess Audi's r now available in grocerie stores
- head and fog lights for 100 cs
- I experienced Transmission "Fail Safe" mode today
- Sebastian didn't u want 1 of those?
- Any of u have the 100csq withOUT the winter package..
- skolnick, did u mean FK sells the grill or the high quality material?
- Can someone send me the procedure for bleeing the cooling system?
- What's the sensor behind the oil cooler?...(more)
- Transmission Questions...yeah
- Body work gurus?? proper sequence for>>
- lamp control module
- 93 100cs can't get codes from engine
- Where i could get that "special" Transmission Dipstick for my none dipstick transmission?
- 94 CSQW rear hatch rust
- windshield wiper help...
- Radio is stuck in safe mode, put in wrong code , how .....
- 3rd brake light adventure
- Lower Grille
- Disabling safe mode on 1993 Audi 100S
- Need Sunroof Motor for 96 A6 Quattro
- transmission code
- Check Engine Light
- Now that my steering fluid is clean should I drop a magnet in the tank, like...
- Please Help trouble a non-starting problem
- Oil Plug, have to use audi?
- Looking to buy a '97 A6, wondering about reliability
- Need assistance with wheels decision
- MikTip, what kind of foglights are you using, are those the 959's? Thanks!
- Does any one know where the reverse light switch is........
- Glove Compartment stuck shut
- Water, water, everywhere! 1996 A6 Quattro Wagon
- 94, 100S brake pad sensors light
- New tires
- any known probs with '95 A6?
- those who pulled the bose out and put an aftermarket unit in
- fuel pump problem
- Anybody have problems with trans after changing fluid/filter on a high milage car...
- Hey B-SK 1982. Did you ever pull those Bose Speakers??
- Time for front struts... usual questions
- repairing body rot- resources?>>>
- Help! unidentify car problem
- Clear Corners
- Help, I have green coolant, but I bought g11 pentosin
- ATF question
- Does everyone here use Bosch 13913 generic o2's?
- shakey steering when brake is press
- Audi's logo: Vorsprung durch Technik
- $#%&! Dash Lights
- Rear Wiper Woes 94csq wagon
- Can a Concert II radio be wired in to an 95.5 A6 with Delta unit?
- 97 A6Q sedan front strut blown, leaking oil...
- 2004 A6 Wiper Arms on 95.5 A6/S6
- Changed front struts, rotors and pads
- auto gear shifter stuck..
- Valve seals...
- looking for a european headlight plug
- Wheel suggestions for a pearl A6
- Lubricant
- Anyone repaired a Larin floor jack
- Anyone on the forum have VAG-COM?
- Anyone here from Fort Wayne, IN? I have a couple of questions for you...
- update to my 92 100s shifting problem
- word of causion on lowering the car
- 92 100s cruise control not working... diagram anyone??
- Did they change the suspension at all for the C4 A6?
- Mille Miglia A1
- Guys-Can you tell me if this CD Changer will work in my car?
- testimonial of first 6 hr drive in the 94 100csq
- attention JAY KOVAL...
- what can feel like a bent rim besides>>>
- el Senor Beep Beep...
- CPU shutdown?
- Strut/spring removal on 92 100s?? Please reply.
- Audi Parts at below list
- 97 A8 Quattro 116k for 12K??
- Fri. May 21st - Drag Day - Lebanon Valley Track Rental - Sign-up is open...
- Heater temperature
- Heated mirrors and washer nozzles
- Stalling on cold start & engine oil temp
- Ohh yeah...
- Can u believe it...
- Recommended 75k mile maintainence?
- Need some advice regarding the A6...
- Any trany mounts out there?
- is this normal - temp?
- Remote Fobs
- Is there a way to...
- Bose or Not Bose
- Question about computer chips in the remote controls (key)..
- Wiring Diagram Request
- Anyone have Camshaft 3242 & 3243 Tools V6 Tool they can lend?
- DTC Number 00652
- audi 100 models
- cat convertor.
- cv joints
- would eighteens work?
- Wind noise
- 96 A6 - WAGON QUATTRO Gas mileage
- darn radio replacement.
- Oil ring/sender
- Anybody parting out a 100/A6? I need the e-brake lever.
- audi 100 BODY KITS anywhere ?? : /
- some questions for you peeps
- how to remove the fuel injector?
- get brake caliper new or rebuilt?
