- How do i check the timing belt on my 97?
- Air Bag Light
- whats he difference between 100 and a6
- 60,000 miles on my 97 A6. How/where do I check my timing belt for wear?
- Extended warranty good news/bad news
- non quattro trans fluid change
- Important Question About an 1993 100s Spark Plug Wires
- poll: what are the broken things, you have in your car, but you are not going to fix it right away.
- What does a dealer do In a In 1 inspection other than resetting the light itself???
- How can I find if a S6 is 95 or 95.5? Thanks
- Replacing dashboard lights- anyone know how? '95A6Q
- Check Engine Light (has a mind of it's own)
- Got my manual today. some questions.
- Need some advice on the purchase of A6 wagon...(More)
- ok here's the scoop...
- Audi A6 alarm...
- Where is the wiper relay located?
- Worth of buying?
- Bad Brake Booster?
- Any of you guys know the p/n for a license plate holder for the front bumper (it screws onto bumper)
- Hmm, so once I replace the radiator, what should I do?
- Replacing Steering Rack for theThird Time!
- 12v thottle body mods
- Can anyone recommend a good Audi salvage yard for used parts?
- For those who are planning to buy an Audi A6 98 or newer
- Has anybody replace H3-55 with H3-100 ? Do I need to make any electrical mod to accomodate this?
- Hey, got a question for all you A6 people......
- Chime for headlights not working
- Good link on which ATF to use in your Audi
- Replacing Audi badge on front side molding.
- Selling my '96 A6.. anyone want parts?
- I will be taking my 100 to the race at LeMans...
- Now need O2 sensors...Help!
- odometer and cooling fan
- Another question about the radiator... any help?
- 92 100cs fuel gauge
- ouch
- how to take out radiator and condensor?
- Rear door wont open ?
- Another rear brake light question...
- On a slightly different note.... got a few questions about the radiator fans...
- radio guys, what is this please?
- Anyone have any centre caps for these - 2.5" diameter ?
- how long do the 1991 100s last
- Planning on ordering a new radiator from www.performanceradiator.com, some questions...
- rear door speakers 92 100cs quattro wagon
- moon roof
- Worn Fuel Pump Relay? (long)
- Leaving the forum....
- Rear Brake Light Went Out
- 96 A6 Q new problem
- Guys tell me what you think
- EGR System and Emissions
- Look what I got in the mail....
- rear panel removal
- It's not been a good day. Update on my recent woes...
- Rain problems in the A6
- Its just about that time guys... im going to sell the 1995 Audi A6
- more questions on water damage
- how to tell auto tranny identification number?
- What brake pads are you using and how do they perform?
- LLTEK RS Front (Pricing info Posted)
- Any way to tell if a 96 has keyless entry?
- strange liquid inside coolant resoviour (sp?) ...
- If you like A8s
- 95 Audi A6 Manual needs 2 new catalytic converters
- Airbag light goes on, is there a way to check without VAG-COM?
- bulb out light constantly comes on
- torque convertor?!?!?!?!?
- Please (I beg of you!) HELP !
- Is Delta the correct radio for a 97 A6 Avant?
- there's a swimming pool in my audi
- tire for 97 a6 q
- Got a question about bleeding coolant. Seattle Scott?
- Audi 100s 1993 Power Passenger Seat Not Working :(
- List of 92 100 parts car stuff and history
- Correct Clearcoat Paint Applications.....
- So I just replaced the radiator and all seems well.... then the hood gets stuck! Help!
- how much longer is an A8 versus the 100/A6?
- Stupid Question Re: Transmission Fluid
- Headlight warning chime? Is there one?
- Water Pump/Timng Belt
- It was blaspheme I tell you!
- Wheel bolt pattern. Will V8Q wheels fit my 96 A6? I am measuring
- just got system metered...
- Can you recommend a good HID Kit for 97 A6 Avant?
- squeaking in rear control arm.
- cigarette lighter
- Problem #2: buzz/hum sound while driving...
- Problem #1: coolant tank leak... help please?
- 1994 100s transmission fuse????
- Brake "popping" back on reverse
- No forward gear - what are the options?
- a/s/l? (excuse my ignorance)
- brand new aah engine on ebay
- dang radio possessed
- Hesitation under 20mph
- help
- leaky water pump
- Power steering
- need vaccum HELP!
- Bolt pattern /Offset for 92 100CS?
- 97 A6Q steering gets stiff when hot at idle. Bring revs up all O.K.
- 93 2.8 v6 aah engine with trans on sale on ebay
- what is up with 92 100?
- well.. dropping the car off to get painted tommorrow..
- How $$ to rebuild 2.8?, plus advice
- running oddly need HELP.
- rounded oil drain plug crisis
- GIRLS!!! (from DE, NJ, PA, etc.).....
- Tranny Problems - Slippy When Hot
- Anyone know how to set the dashboard clock on a '94 100S Wagon?
- While we're on the topic of loans...anyone got $85k for this?
- i just changed my 02 sensors! and YEAH!
- Anyone got $3500 I can borrow? ;)
- NorCal Audi Club Marin drive rescheduled: June 21, 2003
- Cruis control problem and trip computer?
- Sick Bose
- Engine speed seems too fast for road speed
- Vag-Com
- How do you "clean/lubricate (Fluid SLS)" sun roof rails?
- 12V BiTurbo
- New owner has some questions
- If anyone ever had done or been quoted for
- Wheel Recommendations
- 93 100csq fail safe mode
- Deadline: June 1st for the June 14 Rally...
- water leaks?
- WOW this one is going real cheap...
- Head lamp is all fixed...
- Which two of these are antenna leads?
- Audi tools 3242 3243 on ebay
- Service/travel advice - Colorado
- RE: What happend to...
- Anybody installed a cabin air filter (97 A6)
- Still some 2003 Audi Calendars left - any interest?
- Polyurethane bushes
- Mo and Crew.... serious help needed...
- Hi, new here, slow connection - some ?s
- Anyone know where to get the silver coated amber bulbs for the front turn signals?
- FM modulator/CD changer install (attack)...
- what the hell!
- What's happenin' everybody?
- Any body knows Eibach Springs part number for a 92 100 non quattro?
- Ported Throttle Body opinions
- Changing rear trans seal, carrier seems mushy. Change carrier? Rebuild shaft (ujoint, etc)? 55K 1997
- 100 avant in need
- Questions on windshield replacement
- 92 100cs cables in the trunk question
- anyone know where i can get a body kit
- ABS Knocking
- bent suspention - part unknown
- Looking for a pearl white rear driver's side door.
- Info on 1995-1998 A6 wagon needed for newbie
- replacing the temp motor flap.
- Help with changing front struts of 96 A6.
- About to undertake a BIG job and looking for advice
- Ignition Switch help...
- yearly maintenence cost for 98 A6
- New LED taillight pics..
- Final Post for the 2nd Annual Trivia Road Rally and GTG is up..........
- 1990 Audi 100 A/C Problem
- Audi 100CS Cracked Passenger Fog
- Damn Warranty Companies!!!!
- Reminder: Calgary area GTG this Saturday (May 24), see link inside!!!
- Steering Wheel Mod Help-
- Boge / Eibach a good choice?
- Suspension
- So I'm gonna change an autobox on Saturday. Any tips?
- E.PA/S.NJ Trivia Road Rally/GTG -- see Mid-Atlantic Forum
- Okay, big maintainence (sp?) check list... anything I am missing?
- 8-PIN CD CHANGERS FOR DELTA CC HEAD UNIT RADIO
- 97 A6Q 4spd auto, tail shaft seal (rear trans seal) r&r proceedure?
- K please
- Berlin, VT
- brake pad wear indicator light
- 93 CS100 Cellular Phone Port
- I got my car from dealer. Impressions after two week with Stratus.
- HIDs made me realize that I need clear corners
- What's the risk of buying wheels off a scrapper? Could they be bent?
- This is OT but really funny: You Might Be A Ricer If.....
- just installed 7000k HID (PICS) EXCELLENT!
- Can I get some ride height measurements from A6Q owner's
- Turbocharged V8 and a Beetle with a 12v V6!
- ES-12 replacement for R-12?
- Anybody use H&R S6 springs on a A6Q
- Towing With Auto Trans
- Muhammad, you said you had sources for re-manuf. A/C compressors?
- Changing the lights in the dash- anyway to change from red to something else?
- Engine does not start!
- just replaced the front left axle (PICS)
- Need some wheels
- body kits
- brightest headlights for 94 100...
- What's the sweetest mod anyone's done on a '95 A6?
- what to do if someone scrathces ur car
- FYI on cooling problems
- Need urgent help on strut install please!
- sweet
- '95 Avant hatch lock/catch. Should I replace it myself? tia
- Anyone know the part number for the radiator on a '92 100?
- Full taillight LED conversion.. tested and sucessful!
- Turned a 100k on the way to see the Blue Angels!
- where i can find performance parts
- Bad Check from Nilton Santos of New Jersey
- Found this gasket set on eBay
- trans fluid replacement..
- Anybody have a 100/S4 lower grill (bumper mounted) for sale? or tips on where to find one?
- Need help with gauge faces...
- Okay, I need some ideas for a price for my car....
- info for A6 (95-98) purchase
- Where are the Bleeder Screws?
- instrument panel
- 97 A6Q Wheel Bearing Problems -- Are They Common?
- oil drain plug totally round
- Where is the fill and drain plugs on (non quattro, '92) 5spd trans and diff?
- here's something that will be in my garage tomorrow :)
- I NEED SOME MAJOR HELP
- Tons of Problems!!!!
- 92 100cs o2 sensor replacement
- Anyone "Worn Out" a 2.8?
- Replacing the electric sunroof motor "seal" in a '93 100
- Swiss Cheese Air-Box
- What the FECK!?
- A good laugh..
- 92 100 on ebay for parts!
- X-Post: 12v owners: Any interest in full exhaust systems?
- Exhaust coming from '95 A6
- lights
- wallpapers...
- Jack, give me the details on this fuel injector upgrade w/ nitrous. Im very interested. Parts....
- body-kits
- Quesitons about Bentley Manuals.
- Radio no longer turns off after Ignition Switch change...
- BMW 7 series Computer uses Windows CE!!! Trouble!!@#
- The Black Ball
- Uneasy Idle on '95 A6
- pictures of the axle I got
- Timing Belt Broke or Have > 90K miles
- what shocks to buy? everyday driver, not racer
- Hey Nathan, did you get that axle assembly today?
- how much should i sell my car for?
- PRND321 all lights are light! WHAT WRONG
- 97 A6 Ball Joint Removal, help...
- do new s4 front seats fit our cars?
- Help with warning light!
- 60,000 miles! What types of parts and components should I check to see if they need replacment?
- Help with CD changer/stereo/antenna hookup...
- 92 100 driver's seat
- Air Conditioning Season Again!
