- Sunroof doesn't close and more...
- Most interesting Audi experience to date. (Good Story)
- brake pad warning? how long left?
- Engine Cover DEMENS
- Transmission Electronic Control Module
- I need to transport a 19" server rack cabinet.
- Help... Engine will not start!
- 92 100csq warning buzzer malfunction
- Door lock connecting rod help
- Old style Serpentine belt tensioner
- Ignition problem same but different from Chick2
- Hey Guys.. anyone have any Nice pics of their 100's?
- I NEED MORE POWER! Seriously, what types of upgrades can i do to get more hp? I have a 97 12v 2.8Q
- Anyone have a gamma radio they want to part with?
- Tight door
- audi 100s 1992
- Oil Filter 94 Audi 100S
- Floor mat fasteners
- Where is the Central Locking Pump in a 94 100?
- 89 Audi 100 - thinking about buying, $500, need advice
- 92 100s need help!!
- How hard to replace fan motor on a -96 A6Q?
- remote keyless 93 100cs
- What is this hose called...
- I DECIDED TO PART MY 92 100 CSQ
- Timing belt
- leak problem
- Is there a special procedure to bleed the brakes on my quattro?
- Black Goop
- Water Temp Gauge Sporatic
- General interior trim question for 92-94 100's
- Weirdo FOREIGN symbols on dash + dinging warning bell..
- Delayed trunk light
- Door trim 93 100q
- Wiring harness
- chip available for 97A6/A6q 2.8 12v
- how do I reset the remote cental locking?
- 2.8 12v timing belt service
- Quick help/advice needed: $350 for prop shaft seal replacement??
- Need Info
- Windshield washer light
- new starter, new ignition switch, and my car will still not start!!!
- i got hosed.........
- transmission 92 100cs frontdrive
- Who was it that said if a topic is posted the others will have the problem too?
- Some one stole my car!
- Squeaky steering column
- 1 for me 1 for wife 1 for parts
- got my car back from audi technicians...
- Temp Gauge Questions??
- Vibrations from the V6
- Anyone have 93 100 left side rear door red
- Anyone have a cheap transmission?? If not want to buy a 93 100 CSQ Cheap!
- In.1 Indicator Appeared too soon?
- Impression: Bridgestone Potenza RE950.
- Change gear oil in differential?
- need transmission fluid dipstick
- euros??
- 93 100cs quattro....
- This looks like a good deal, no ?
- SOS-SOS-SOS
- Rocking drivers seat - 95 Audi A6
- exterior mod's??
- Electrical Gremlins
- Happy Happy 93 100 q 5spd
- Just picked up my car from TDL
- Canadian 100 owners!!!!
- Few Question's
- Replacing a front pump on a 93 100CSQ
- Brake warning klght
- Brake fliud change options.. DOT 5? Super DOT 4?
- GALA??? Newer options to adjust??
- Check eng light
- car troubles...
- Project 90% completed. Thanks to all of you for your help!
- Having a hard time getting out of park.
- 12vChip development info......
- v-belt snapped..continued..
- Loud noise from exhaust...
- Help!
- MY 92 100 cs shakes at 1800 rpm
- More info on fuel injector cleaning...
- Cigarette lighter fuse
- how to take out ski sack
- B&G trans products
- Anyone have a RS2 Headlight Part#...
- What is the hose called coming out of the Coolant Tank...
- 17's or 18's?
- Speakers for sale
- 1995 Audi A6
- Boardcomputer
- Please Help!!!!
- Need some advice
- New audi! 1994 Audi 100 CS Quattro (maroon)
- Looking to buy a 98 A6 Avant for my wife.......have a few questions....
- Still Selling '97 A6 Quattro
- 94 100s bolt pattern
- 12v 2.8 upgrade
- looking for an AC compressor good/bad
- Half Shaft Replacment
- speaker sizes
- '91 Audi 100, intrument panel removal.
- I am volunteering to test the UNICHIP....more details inside..
- Yay! just bought my first Audi 100!
- went to TDL today to checkup on the work being done.......
- Anyone have the Bilstien shocks/h&R springs?
- Was sport suspension an option in 95?
- 95 A6 Quattro - 2.8L rattle noise
- Suspension Poll! I got Eibach Pro Kit/ Bilstein Sport
- Bowed door suggestions?
- What's the take on engine mounts? Ever a need to change them
- mirror
- WANTED: 15x6 bbs mesh rims, 4x108mm
- rim pics
- Brake Pad Wear Indicator (O) came on last night....how much
- Pictures from the Oct. 6 Calgary Audi GTG!
- Buffalo GTG 10/12 3pm Duff's
- Last Call - RSVP for the Reading PA Fun Run this Sat. 10/12!!
- Would you recommend a 100 CS Q to someone not concerned about Power?
- Schmitt's never called me back, plan B (Buffalo GTG)
- SEMA Show Badges/pass (cross post)
- Cars Value
- '97 A6 wagon with 60,000 miles: Shocks likely to need replacement?
- P-Shop of my 100
- Info on the Buffalo GTG
- Tranny question. Are trannys from 92 and 94 5 Speed S4 2,2 compatible?
- parts from 1990 80
- transmission from audi 80 to audi 100
- so last night..
- Anyone have any 4 x 108mm 15" 100 rims for sale?
- Just got my obdtools VAG-COM configured. How do you turn off the oil change light?
- Gotta love Audi
- HELP! Emergency! Car won't start...broken serpentine belt...what happened?
- Amsoil products q....engine flush
- air conditioner clutch
- timing or spur belt.
- Reminder: Oct. 6 Calgary Area Audi GTG! (Westhill)
- Climate Control Unit needs to be replaced
- I have found a lot of tech. info for VW (it might be useful for Audi).
- Audi Page
- '96 A6 CHECK ENGINE light not coming on when key is turned...
- Engine cover on the bottom
- The mirrors on my A6 need replacing....
- Help...again
- Audi Newbee Help
- How often have you had your rear differential seal leak?
- (X-Post) My Audi got smashed!!
- Need V6 heads or engine... Bent valves are OK..........!!!!!!!!!!!!!
- ColorPlus Leather Restoration System
- Just got my Audi back from the shop
- Head Bolts
- Board comp. went crazy
- Oct. 6 Calgary Area Audi GTG!
- I got a Golf 97 as a second car
- TECH TIPS: Just bought a '96 A6...
- Brake-ABS Bleeding quiestions
- Getting Codes from my Climate Control... Help!
- Anyone want carbon fiber interior trim to replace wood trim?
- Philly Area peeps: Fun Run scheduled on 10/12. Mark your calendars!
- Audi Radio Website Link? Want to upgrade my Audi audio system.
- What's the stock rotor thickness for FRT + Rear for 97A6q2.8sedan
- Have you done..?
- rubber floor mats
- DTC 2411 & EGR has just been cleaned
- Check out on saving money on your car... Nice !! but nothing new to the AW members..
- Finally, my 96' A6 Avant Quattro is finished
- Diff/ATF fluid...redline or amsoil? Opinions?
- tech specs / mechanical resources...... fluids, timing, etc... (quick tech sheet)?? and any links??
- Anyone use brake fluid from a Motorcycle shop?
- Did anybody replace head gaskets on 12v,how PIB is it?
- Michigan and Lake region audi event
- Alternator upgrade options available
- Lubro-Moly radiator flush
- Montreal Folks : *MAC meet next Tuesday (Oct. 1st)*
- Anyone selling a stock audi telephone?
- Rear Differential Leak :( ....... more
- Wanted: Good condition Climate Control wood trim peice for 100 cs
- Front brakes dragging, MC replaced
- Need ideas on a good all season tire...
- Light replacement and engine noise?
- about to buy a Jetta
- Which CD Changer, and where is the connector...
- Door chime stays on all the time on 100 S
- Carbon fiber shift knob...Auto
- Side mirrors - 92 100cs
- 2nd Calgary Area Audi Get Together! (Oct. 5 weekend)
- Trying to build a Cone filter adaptor.
- Rotors.....I know its been covered a million time and I did the search
- Audi A6 - 1995
- Need new set of 205/55 R16 Tires - Opinions Anyone?
- Consequences of axle replacement
- Cleaned injectors today... woohooo!! Runs great!
- What?? Bentley says the thermostat "opens" at 189f and "closes" at 212f so...
- clock
- C4s built in 1990?
- Body styling by Beutlich.de It seems as you can purchase from USA through their webshop.
- my gas pedal fell off!!!
- A/c Help (again)
- Go EBay !!!! Lookie here. Those S4s are way too low priced :-) - 1st
- 1986 4000s Newby here
- NGK
- Ingition switch HELP... Screws for palstic collar on steering column?
- The 100 glass sunroof in on EBay again. Anyone??
- Where?
- HELP-Poping interior door handle
- where + $ for oil pressure relief valves / oil check valves?
- 94 Audi 100, Quattro, manual?
- 12V Chip at last?
- ISV and 12V site?
- No heat...
- Anyone want my wheels and tires for $1000.00
- Free Retrofit Program for Child seat tether Update.
- Okay, this is worrying me....
- Alberta owners check out the Canadian forum for info..
- Need a nice set of ignition wires. Any suggestions
- ELECTRICAL/BATTERY related "car won't start" problem...help please!!
- A6, 1996 - need advice about sunroof
- Stumbling and Stalling when it Rains
- Does anybody have a copy of the timing belt procedure from 12v.org?
- Help!That's scary!
- here is a tire size+wheel calculator if interested
- should I do this?
- trying to learn about the wheels...
- Decided to sell the '95 S6... Want to purchase a 86-88 Porsche 944 Turbo, due to going to college...
- Newbie with a 1992 100cs and some easy questions
- 4 Tickets to USGP Formula 1 Race
- totalled car
- 1993 100CS reciever installation... ?
- 100 to an A6?
- Wheels URGENT
- towing with your 100?
- quattro Transmission Rebuilder in the Northeast
- I know they're replica, but should I buy these for my 97 A6?
- Coolant hose replacement
- engine clicking again audi 100s 2.8 v6 1992
- The saga continues with leak
- Gas Pedal fell off
- headliner removal.
- would it be wise/reasonable to....
- codes, o2 sensor question
- Over Boost/No Boost steering...
- Removing CC unit on 95 A6 Wagon???
- HELP WITH AN AUDI 100..1990 MODEL
- Please help with a little timing belt question!
- Found OEM and After Market Parts For pretty cheap (All Euro Cars)
- wheel wobble
- Transmission Trouble
- What's everyones experience with non-studded snow tires on A6Q's
- Weird oil pressure...
