View Full Version : Audi Original "S" Cars
- Opinions? First one seems nice but overpriced, 2nd one seems well priced...
- Converting to switchblade key for 1997 S6 (need part number) ....
- I gave the Audi virus to my wife......just came home from a 4 hour round trip
- |skolnick: where's the Negative ( - ) jumper point under the hood on the 92 S4s?
- What's everyone got on the odometer? 200k+ please chime in... My old man's urS4 is...
- Winter wheel question....
- So My speedo is bouncing at low speed (5 mph), and then engages and reads too slow...
- Who's URS6 Plus in Pleasant Hill, CA today? - sweet ride...
- Who sells Stromung exhaust systems anyways?
- anyone intersted in a new, factory, never taken out of the box Concert 1?
- S6 with 75K miles on Fleabay!
- Anyone who made a Brake Pressure Bleeder, where did you get a Cap to fit our reservoir?
- Big Reds for sale at vividracing for $850. I dont have any money or i would get them.
- is there going to be a harness for the yukon or ls1 coil option?
- Installed 034 CAI yesterday and after the initial test drive...
- Stromung gen IV $875 not mine
- 97 S6 Remote Key Fob
- What's 443907388 for?
- just got an S5 at school ... oh yeah!
- What is the 1.8t Coil Failure Mode?
- CARFAX ANYONE? I MAY BUY THIS TODAY THANK YOU!
- Anybody know where my green S6 Avant is?
- Anyone ever have a rattle on bumps from a front caliper carrier?
- ET40 17"x7.5" RS4 Replica's ok ?
- I bought a 93 for $1800 yesterday...
- Repair Update: The car was repaired VERY WELL I think!
- She's Done
- Hello and goodbye for now...
- So, what's been the prefered method when installing dash trim cut for Airbag into a dash that has no
- Anyone taken the Speedo apart? how does the needle go back on? my MPH is off...
- A/C issues continued: Compressor still cycles=1sec on 5sec off -frustrated.
- Smoked my headlights found a nice surprise...
- Can anyone in Calgary help me leak test and diagnose my boost issue?
- Search but couldn't find if pads for the G60s are the same between the B4/C4...
- found a company that does a dye kit for our specific leather interiors.ship WW...
- Refurbishing my beloved LM's
- Working on my 034 CA intake install...and was just wondering if....
- Herr Schroder, YGM! :o)
- Anybody here go to Germany on any sort of regular basis?
- Aftermarket oil cooler for 92 S4?
- Ok, just got the A/C redone = New Condenser, New Compressor, New R/D, New orifice tube.
- Anybody know anybody?
- My 94 is now officially a Canadian citizen
- $4,000 Fuel Pump Replacement
- No more clunking - dealer strut mounts were the cure!
- *sigh* final dollar number on my motor 5,400.00 :(
- it was/is a WEAK COIL... finally solved well...
- got it together again today, crappy pix but the system works...
- finished the higher wattage bulb exchange for the IC. Tried door chime mod, doesn't work, don't do
- how much horsepower can the stock fuel pump handle???
- CarFax please? SO much thanks! WAUEA88D4TA281482
- Did euro bumpers have replacable black trim?
- Does anyone have a better source/price for the door trim than this?
- How much have you guys "invested" into your UrS???
- Updates to the FAQ on the POS with spec sheet and X-ray photo, etc.
- 993TT brake question......
- testing spark of coils, can I adjust the maximum gap of my 1 new coil
- Slotted Rotor Recommendations, DBA?
- i find myself wishing (on a daily basis) that audi would make these cars again
- Opinion on RS2...
- Where can I get the special tools for this cap?
- A2 Golf with 20v Turbo (AAN or ABY) and quattro drive train.
- when does one consider the ECU or component of ECU to be bad?
- Another reason I do ALL the work on my cars.
- 2b software? Trying to find out info from them is like pulling teeth
- Looking for a babysitter...
- Trailer Hitch for S4?
- A brief update on my car - big blacks and highway mileage, and can someone help me with Samcos?
- Poser Urs6.
- Chips are making so much more horsepower than they used to...
- GotR2 22 more days!
- soooo, how much life does my clutch have left in it. 152k on the odo.
- Round two........
- shop called, replaced weak coil, car still cuts under boost
- Winter Cold Climate Oil, 0W30 or 0W40?
- Is that common problem to have some wet oil on theC.Diff& tailshaft?
- If you have a problem - if no one else can help - and if you can find them, maybe you can hire:
- 1995 S6 Arrived from Seattle
- Bored ? Want to see what a pain in the a$$ the 2.7 T is ?
- you'll crack yourself up but it's alive....D585 coils conversion in action .....works!
- Replaced WGFV at 224k miles - noticeable improvement
- Completely OT... unless you corelate our AANs have a turbo this one has turbos...
- Can anyone confirm this will replace the 15 tooth (small yellow) gear for the odometer?
- Anybody done this mod?
- Fuel pump life extension...
- Who likes BBS CH wheels? Do I need spacers for 5mm?
- Here's a coil testing thought that could be interesting
- For you guys with 034 HO coils......do you run with or w/o the valve cover?
- What do you use for wheel spacers? What brand and where to buy?
- Folks with a CD (electronic) Bentley. In the Diagnostic code section, does it list an AAN?
- anyone have a use for a blown stock 5-spd? located in MA
- I really wish I could find a decent Black interior locally.
- S4's For Sale
- Radio questions, is there any radio from the sale that i can make work? a concert conversion?
- 101 oct fuel. thinking of trying some for kicks and grins.
- took car to shop, coil number two was bad... coil 2 was replaced by
- NOOB here, hello all
- ****Hartford CT GTG - New Date - Wednesday, September 17th
- My front Koni is leaking now.
- 22 ft-lbs, check
- Guys carnt seem to find the urs6 gearbox oil capacity in FAQ?
- I have a 1992 Sway Bar (only) - where can I has the other bits I need to install ?
- Amazing ! Soylent Green passed CA SMOG with Mihnea's Fueling Software & GT3071
- Help with oil pressure problem... (long)
- JulianB & Zwoobah YGM boyz ! NWS
- Flat spot in the power band....
- Back in the dayz
- ipod integration complete - dash switch reads "FUNK" not something else.
- Cheap OEM Radios
- Saw a silver S6 in Westport CT yesterday, anyone?
- //S6 Plus Avant - anyone 'interested'?
- ***Postponed, 9/9 Hartford CT GTG, due to weather.....new date to follow
- Brake rotors for Big Reds?
- Hello from a fellow URS4 owner
- Need sound advice
- Anybody dreaming of a 1994 S4 (or two)? I've made a tough decision but-
- Anyone have experience with 2B sport springs?
- Anyone looking for an Avant??
- Checked codes for AC and Climate Control, i got 15.1 and 29.4
- Pearl Avant S6 in central WA, anyone here?
- I hear bubling in the cooling system after shut-off
- Removing front shock rubber boot
- What's up with my headlights?
- Ever seen this before?
- how does a leak in the vacuum line to the ECU allow extra boost?
- Update on the UrS4, now with Stromung power
- Need vagcom obd1 in CT area today. Please help, have inspection tomorrow
- Nipple broke off on coolant after-run pump
- My steering rack is now officially out. What a POS.
- Normal to get about 13 psi in 2nd, 15 in 3rd, and 17 in 4th?
- What hose clamps to use with new pcv plumbing
- Anybody have a blown front bilstein for sale?
- Update on front end groan
- looking for advice, things to check
- Exploding turbocharger (bad thing to happen when trying to merge)
- I just found out my brake servo is leaking. How much of a biatch is that R&R?
- Does anyone know the difference (if any) between 100/S4 sport springs?
- Time to make waves.......
- help!!! need a crank lock tool in ct
- D581 Prototype
- does anybody knows if mirrors from a 94 100CS would fit my 95.5 S6?
- Now this is a FMIC set up !
- Gathering of the rings 2008
- Clear corners....where to buy in the US??
- Thoughts and prayers needed for a fellow Audi enthusiast that just lost both his parents
- Anyone have a source ??
- Response from Brewspeed re: their high output coils (I have responded back)
- Dave F, YGM re Leavenworth
- serious brake noise from big red monoblocks with brand new pagid pads
- Serious battery corrosion...
- Under-manifold coolant hose....
- My car runs again, FINALLY! :-D Thanks to this forum and the people on it!!!
- I recognize that phrase.
- Maybe I'm missing something, but where can I find the coolant hose that runs under the intake mani?
- Hug your kids and wives, explanation inside. :(
- Havent seen these posted, Another Coil Option already made DIS...$225!
- my s-car moves under its own power, for the first time in 5mos
- Passenger Window Switch intermittently not working - any BTDT ?
- Urs4boy....if you have some time, could you email me?
- you guys r hilarious!!!!!!!! i meant performance chips
- oil switch
- $6000 95.5 Avant with Stromung on ebay.....not a bad deal
- Brain's burnt out... what's the name of the dark tan interior? Just can't think of it.
- Questions on removal of IC, also does anyone else have problems with the Key in ignition warning bee
- I am thinking of moving my instrument cluster like those new minis
- 93 urs4 tach not working
- Impromptu S Gathering In Denver This Saturday (6th) Evening!!
- control arms, upper strut bushing and da' bomb... how long to change all three bits?
- Toluene. Is anyone in CT looking for 10 gallons or so?
- I just chewed up one of my rims on the curb. It's the outer lip. Can it be buffed?
- When replying to threads, alway try to edit the subject line, otherwise
- HVAC annoyances
- Worst design ever..stupid coolant hose under the intake manifold!
- chips
- Hey fellas, My stock keyless entry wont work, any troubleshooting...
- Anyone have a coil to sell?
- How do I keep the middle "O" exhaust hangar from wearing out?
- Darn it just pulled a 2113 code
- So some of the problems my S4 has... thoughts?
- went to reset the MAP sensor code and it was not there...
- UrS4 Ignition Coils and Beru POS on eBay
- Camshaft lift and duration specifications from Marco on the S2 forum (YMMV)
- 2008 Engine Compartment Revision
- Phreeaks
- 1995 TDS-1 users
- I need lifters. Anybody have some just lying around for cheaps?
- Cam chain replacement
- Backup lights, trunk light and plate light not working????
- I have moved my S4 in to position.
- Info on break point for AAN's with external Hall sender in a tuna can. UPDATED
- kinderutz: YGM... Thanks!
- time for a brake job (yay)
- //SFest '08
- Legal action advise...help REVISED
- How do you test the starter motor if its staying on ?
- question about the car stalling
- 13.81V on Alternator,13.3V on Battery is this normal?
- Started installing the Stromung
- For all you Bolero lovers.....
- Brake fluid?
- Another what is it worth thread
- Brakes don't work
- What could cause the turn signal to stay solidly on when you hit it to turn
- TDS-1
- Just another reminder - Old School quattros V.I. this weekend (Sept. 6-7)...
- Car Crapped Out - Possible Head Gasket?
- Compressor wont turn on... light comes on when i hit the button but goes off right after.
- 1000 hp s4
- Got acceleration?
- Audi S2 coupe 535 hp vid
- Is this fair? Whats Audiworld say?
- Found a source for moulding kits:
- What's the going price for a reconditioned AAN head ?
- Are our AAN cranks knifed? Question arose when I saw this picture of a 3B bottom end...
- Need help choosing a turbo
- Under hood corrosion: Does this happen in the NE both with and without belly pan?
- Schroeder wants this seat color badly in teh UrS... Must make it happen..
- Are the fuel filters for these cars supposed to rattle?
- 95 S6 won't run
- Proud S4 owner
- Anyone make any progress on a Carbon Fiber POS cover ?
- Believe to have found coolant leak, Fast4est was right about the check valve into heater core...
- Swapped POS modules, left old #1 un-used and car feels really good...
- How you guys making out w/ the coil project? I may be due to do the same here soon.
- ***Reminder, Hartford, CT GTG - 9/9/08***
- My car died today.
- new owner!!!!
- Is it just me or does this Mercury Marine 150 CXL EFI coil look familiar?
- I need to borrow some money...
- Shipping big parts question....
- Some notes on a 6spd install / throwout bearings / slave cyl install
- FOCK! Replaced ignition switch and still no-start...
- Just posted my Fuchs for sale on AF
- An answer whether 7A or 3B wire ends should be used on an AAN head with D585 coils
- Anybody have a source for "stock" rear subfame bushings - not aluminum/delrin
- O HAI EVERYONE!
- Anyone have an AAN Head for sale?
- how the heck do you get the bottom downpipe nut off? Cant get anything in there.
- Anybody hear from Hap lately? He hasn't responded to my emails...
- Just purchased a 1993 urs4 i was wondering...
- Help Please...
- i need to replace my tie rod end. i've heard to stay away from meyle.
- Why is this still for sale??
- Newly consolidated By-Pass Valve information with PNs.
- Put in your requests. Iam going to a yard with a WHOLE 1992 S4.....
- Check your rotor hats!
- New Audi R8 GT3 (RWD)...
- what is wrong with my inspection??
- i love my job :)
- poll: what's your favorite <$100 summer tire for the UrS
