View Full Version : Audi Original "S" Cars
- Anyone used Witch Hunter injector service?
- Just home from the Weekend ALMS Races at Road America - Lots of Pics:
- Any UrS4 owners in NC? Spotted one...
- FMIC installed
- For you wagon-lovers.....(NAC)
- //SFest 2008 Teaser...
- What you want <> what you get.
- Ruled out fuel management I think, still at base boost.
- ive done it now
- 93 for sale on Denver CL, who's is it?
- can a faulty potentiometer slow down overboost reaction times or cause slow boosting charateristics?
- 1995 s6
- ebay found for all bored with urs
- Problem resolved.
- Calling on all UrS6 Avant owners: Do you have a bracket for the child seat restraint mount and if so
- IR Key troubles.
- ***Hartford, CT GTG, Tuesday, September 9th***
- What is the P/N ? 034 253 033C
- what is the correct part number for the ISV? 034133455B or 034133455
- Update on coolant leak. / And can someone explain the lumbar support mechanism?
- had a weird sound
- Where is the photo of Brian B's Silver (edit) Avant with red 7A cam cover and HO coils?
- Mysterious clunk. Worn ball joints?
- Paper manuals $150.00
- Brake pad warning light suddenly goes out
- Anyone know if Javad is on vacation? Nate.......you around? Need response to my e-mail.
- Any place besides the dealer to get known, good strut mounts? Mine are failing less than a year/8k..
- Where can I buy brake hard lines?
- How many years of you guy!!! before the bomb has gone?
- Any thoughts on (experience with) 034s.....
- 1993 Audi S4 - Ned's Project Car - $27000 (Olympia)
- Mmmm...Cyclamen
- Useless C4 tidbit: Did u know that 100's are prewired for the A-pillar microphone.
- rot-ro
- Suspension help please - part # for one use bolts
- what is needed to upgrade speakers and amp but keep stock head unit, 95 S6
- Woot!! Found a great source for LS2 coil conversion wires
- are walboro pumps universal?
- Importing an S car from Canada....any links?
- Those with a V8 rear diff, do I want one from an auto or manual, 3.6 or 4.2?...
- LMK, who's going to SFest08 on Aug 23rd ?
- Edited:Speed bumps has pissed me off.
- Welp. got the OE rear seat heating wiring harness routed & in place w00t. Have done a 90%
- Have a D585 (Delphi 19005218) coil in my hand. Smaller than I imagined. But heavy enough..
- Quick update on hydraulic pump issue - back on the road again and pleasant side effect...
- new (well new to me) wheels
- Your opinion please? The car had been running better than ever. Suddenly developed bucking, hesita
- A-pillar guage pod
- could someone please provide wiring diagrams for the Audi-phone microphone
- How bad would it be if I put hydraulic fluid other than 11s into my system?
- RS2 EM
- Anyone selling a good S6 out there?
- Need some used parts...I could go to the recylers, but wanted to ask here first...
- Two questions: Anyone have a '92 inst. cluster and / or can I drive the car without one?
- Four 1.8t coils die at once, underlying issue?
- Dave, whats the latest on the plug wires? You had a chance to test them?
- I am planning a FMIC this saturday.
- Wandering. My rubber bushings are squeezed out at the top of the rear shocks. Is this the cause?
- H&R or Eibach Pro kit...
- Do the rotary and rocker switch sunroof switches interchange?
- custom pipes
- cheap avus on ebay
- Is anyone running a manual boost controller with their RS2 set up?
- Changes to Transport Canada's Importation Rules
- my woman drives a 200.............10v....big pics inside
- coolant is leaking but im not sure from where. it seems from the plenum area bc under neath it
- Trailer hitch?
- are all the gaskets the same for stock and RS2 exhaust manifold?
- Need to remove the strut for new upper strut bearing?
- Hard rain last night
- How-to integrate an aftermarket head unit with stock Bose components
- Alpina last offer ill be buying a car wednesday if i dont here from you
- Took a little trip this weekend to Road America in WI...on the way there and back my secondary fan..
- Green urS4 in downtown Oshkosh WI, north side of Main st.
- Who was the Pearl/Ecru UrS4 in Mira Mesa on Friday Aug 1?
- Detail cross post...
- A few new pics...
- Gona fit my new AC condensor any piping issues i should be concerned about??
- black S6 sedan on RT 80 West on Friday at 8 pm (Wayne, NJ area), anyone?
- Denver area UrS BBQ. Aug 9, 5pm. I'm just gettin' the word out..
- someone please confirm this is the antenna adapter piece we need for Audi-to-Aftermarket deck
- i bought wheels that are 17x7.5 with a 43 offset. how much are these wheels going
- Last minutes!
- wet foot
- warning buzzer
- Update on coolant leak right about transmission plug. Checked under plenum cover found no signs of
- Passenger door outside handle feels weird like it is ready to break when I open the door.
- Blacked out Headlamps
- So changed my oil today,,,whats that? what? oh yeah my front H&R springs are BOTH BROKEN!
- VADER WAGON IN ALL ITS GLORY
- Got beat up by my S4 today =( .. bleeding from being stabbed underneath fingernails, bloody nose
- Do our Scars A/C systems use an orifice tube or expansion valve setup?
- Taking the Avant out in 75 degree weather for a drive on twisty back country roads listening to ....
- PRoblems removing circlip on rear wheel bearing, any suggestions to how to do it?
- coolant leak above transmission
- Looking for Audi S6/A6 exterior trim pieces
- bose leftovers
- Troubles with the front passenger locks. Any suggestions?
- how much a PITA is it to pull the EM?
- Saga carpet removal report
- Does anyone (other than Azeem) have Fred Munro's blower motor R&R... the faq link is dead =(
- For better or for Worse the dash is out.. I can finally pull the last 2 Elm Wood trim pieces!
- The suspension problems seem to be because of the springs missing the sleeves! Input?
- Need some sage advice
- $135 (+tax) for a set of 7A wires for my LS2/Yukon coil conversion. Now I have to check whether...
- i'm finally replacing my fukked up white powdercoated fuch's with some avus yo!
- While this IS a nice example, isn't the price a bit $entimental?
- I think I stumbled on another problem doing A/C troubleshooting
- for those interested... I'm back in Poland after my ride to Croatia
- RF remote problem - Yes I've read the FAQ and STFA
- Anyone here in the SF Bay area?
- Finally have a pic of the Family...aren't they beautiful??
- I am buying Travis P's UrS4
- Anyone seen the new twin tails on the O34 3inch exhaust system,now thats better.
- :: ECS Tuning :: C4 A6 / S6 FK Badgeless Grilles - Now Available !!!
- Weldo Call Me
- I think I'm gonna start dismantling my car's interior today.
- Looking at suspension parts, are any of these brands bad? Moog, Beck Arnley, Spicer,
- Rob, can you email me some of the pics you took homie? :-]
- where can I find the best urs4 / urs6 already built up and for sale right now?
- Going to Germany
- Dave are you still coming up for a club drive and BBQ?
- Snapped some pictures
- paging thetatau87
- AHHH. help me out. washed engine yesterday, now i'm on 4 cylinders
- Hey kinderutz, Luk has decided that the 02-026 is the wrong kit and 02-025 is the right kit.
- question.. Is there a black silicone -sealant- applied from factory around the door card
- Pulled the trigger on the D585 Yukon coils and connectors. Total less than
- Left signal blinks fast
- Noob inside: P/N and/or desc. request: 93 URS4 #8 Relay f. Backup lights
- Will this work to charge A/C through low pressure port (switch removed & shorted of course)
- //Sfest is quickly approaching and the raffle list is growing! Have a look at....
- I won't be driving the UrS for a month....then for a few months. Oh the drama!
- Im missing a grommet where the accelerator cable leads through to the engine bay....
- Can a hot side housing on a turbo be swapped? Say T3 to K26?
- Looking for confirmation on axle triple square size. 10mm? (inner front)
- Where to find a good 52mm boost gauge?
- s4 gamma radio
- Old School quattros V.I
- CC DTC 08.6...G92 motor position sensor...
- any news on the yukon/corvette coil conversion?
- Contact info for the bracket to run an AAN CPS on a 7A head
- What do you for living?
- Dave - when developing the 1.8t coil conversion, did you look into using S4 coils?
- Best looking URS4
- is there ever any luck with selling oem springs?
- Whats it worth?
- Anyone ever heard KW's or FK Automotives suspension kit?
- Does anyone know if sunroof parts from an earlier UrS can be used in my 95?
- My board computer got crazy! Almost all numbers are wrong.
- Another Fleabay S4
- Well, I am now an owner of a C4 and B5 S4. I know a bit about tuning the B5 but questions on the C4
- Attn: Brian Weldon
- what is the best way to remove the tie rods end?
- FYI, I just noticed that Force5 is selling a big red brake kit off an S6 for $800.
- vag com says 11519, intake manifold pressure sensor (G71) pressure sensor defective
- Anyone who has installed the 034 CAI themselves....
- looking for Fuba betaflex D antenna, NLA found METRA - 44UA30 is it any good?
- Need information on a Euro Rollerblind Switch...
- need advice on big brakes....
- Fun, hawk ships me pads, one outer pad has threads for the clip screws the other does not.
- A/C Woes part deux
- Any pics of moisture trap on urs6,i know its down in the kick panel?
- ok weird electrical problem pax window switch works up but not down?
- any performance ECUs floating around?
- heard a new one last night
- Any of you guys have a current CarFax account?
- Does anyone have .BIN files for RS2 or equivalent ?
- hey alpina PINGGGGGGGGGGG me need some info
- RS2 Turbo Inlet....
- Inner tie rod bolt VERY loose...
- HRSB question
- thetatau87, ygm.
- The McBoost.com Waterfest 14 Gallery is DONE!
- I did the lobotmy , but the dash icon still comes on,,,any suggestions?
- Any update on the Corvette coil-based HO ignition system?
- Anyone ever fix a 1997 S6 door buzzer?
- Anyone know how to test my car is chipped?
- Need source for L/R caliper, parking cable & rear pads for 98 Avant 12v. Other than Worldpac
- A while back (looked but couldn't find it) there was a guy fabbing an AAN into a white Golf...
- Has anyone retrofitted urs6plus brakes on their urs6?you might have different brakes over the pond??
- Cam Position Sensor DIY Replacement Walkthrough
- CEL 2342... How do I determine what's causing this?
- Looking for Audi S4 or S6 New England area
- So,,, do you think 21.7 ohms is too much for my plug wires?
- would a bad coil pull my boost back to 12 psi? boost started hitting 30 psi at 1/2 throttle
- Why does my rebound adjustable Koni feel like it is adjusting the compression?
- PSA: 95.5 S6, Craigslist Boston, $5800, 110K miles...
- I'm not even sure how I'm going to describe what my car did today...
- AutoCheck Oil Warning, No other symptoms.
- well, mystery solved and it was quite the funny turn of circumstances (albeit frustrating)
- i'm about to get car cover. Any dibs?
- If I can get barely used Bridgeston RE050A's for a good price are they any good?
- car today started missing at 20 psi in 4th gear, felt like I was running
- Found that my ECT was dead, but still have the problem...
- well i need to get rid of my 95.5 green/ecru s6 avant. What are these cars worth with 230k miles on
- Jeff Gerner's Pikes Peak run...
- To Dave the Librarian...
- s-fest.us is down
- Failed NJ State inspection on both CO and HC
- Tried my first eE85 and gas mix yesterday...
- I am interested in finding gadgets that improve mileage. Yes, I know you will tell me to drive like
- Early CPS information.
- windshield washer problem
- Deephouse --- YGM
- Hydraulic pump went this morning and I am a far from home (long)...
- Will someone PLEASE make a Carbon Fiber replacement for the POS Cover
- FMIC install question
- Brake pad wear sensors
- Need help finding a weird part
- H&R springs.....Powdercoating?
- Something is still wrong with my suspension. Very wrong. Ideas?
- Speaking of Fiber. I got my rations a few weeks back...
- heya JonnyK Make some money off this dude.
- has any one used the konigsport coil overs
- Need turbo/engine match info
- Matching shocks to my ABT coils
- c4 with rs4 rims pics??
- Paging Eric P. (SilberUrS6). Got the Gamma bits yesterday, much thanks.
- make sure to get your recommended daily value of fiber on this wednesday afternoon...
- JUST FYI There is no S-Fest West this year due to unforeseen circumstances.
- //SFest info/update from captain Paul over on the D2 forum (same info as on the S-List)
- need wiring diagrams of the autocheck and climate control systems
- Need help locating a fuse.
- Paging S6 4RiNGS
- so whos got parts
- Old Car and Driver article: S4 vs M5 vs 500E
- question about 2B exhaust system
- Has anyone installed this crankcase ventilation kit? Any thoughts, pictures, on how to?
- Working on converting to LPG ... anyone got any leads on an Intake Manifold ?
- Brake light comes on and off. Fluid is full, Sensors voided due to BBK. Is it the brake Bomb?
- OEM Exhaust removal, Stromung installation.
- S-car on ebay. (someone here?)
- After a big rain today, my glovebox is wet and have a nice pool in the pass. side footwell
- Lost another 115R...
- i press the A/C button and the snowflake comes on but once i let off the button it goes off...
- If vac lines, turbo, ECM lines, that barrel on the fire wall, the boost solinoid, good plugs....
- Big O tires on Havanna in Aurora, CO says!: "Well when you take off an aftermartket wheel its bound
- ISTFA. Found mostly old post but a few new posts. Is anyone on here using MegaSquirt 2?
- Anyone have details on JEff Gerners Pike's Peak run?
- Waterfest 14 Gallery is live!
- Where do folks get the Purple G12+ Anti-Freeze from ?
- Anybody have a spare Bilstein collar? top cap, retainer cap, whatever you call it?
- so can i really get the cluster out w/out removing the steering wheel?
- How many have replaced their fuel pressure regulators and found that the new one is different than
- Virus Alert: Notice from UPS with a tracking number
- Diff switch, diff light, bulb replacement.
- OT: 7yr Anniversary this weekend, took the wife and mistress camping.
- What is the going rate for a complete set of S4 Fuchs in good shape?
- If my 93 S4 has a 09/92 build date, does that make me a late model 92?
