View Full Version : Audi Original "S" Cars
- Sidemarkers
- What screen resolution does KATE need? I'm buying a laptop for her.
- Anyone going to the dyno day in sterling ma this weekend? I forget the name of the place
- Long Story about chips and overboost - Ploz Help
- Cheap Control arms if they are indeed OEM
- Car is still broken... :-(
- 034 Street Density Motor mounts Installed & Downpipe Question
- Help from our Euro friends...
- 2B coilovers installed. I love the ride now! - BWW
- brake light
- Testing the TPS and have questions.
- Any BTDT Radiator Replacement?
- The numbers are in (price breakdown): Boxter kit
- Fuel Injectors ultra-sonically Cleaned
- Looking at getting rid of my 1997 A8 for a S6 I need boost!!!!!
- Ok so do we have self leveling rear suspension?and how does it work??
- DIY Catch can (free parts from most autobody shops)
- Retracting rear brake caliper pistons
- PSA: Price point on Will Griffin's 94 S4...
- Time to sell the 'ol S. See audifans market place...
- Anyone ever use a 5x112 to 5x120 adapter on a URS car?
- my take on the VME HIDs...
- This'd be a nice stock replacement for the rusty exhaust system...
- still have mushy brakes, after recharged bomb, and proper fluid flush. Master cyl time? (WW)
- Bottoming out w/ Eibach Pro Kit and Bilstein Sports... Common?
- Simple questions (hopefully)
- i'm back! :)
- Germantoy carpet cleaning service
- Anybody have a spare cam gear for sale?
- Eclipse CD7000 - Worths $279??
- Should my car run with the MAF disconnected?
- Any appreciable gains with a P & P head on a chipped car?
- Woohoo, called H&R they are sending a replacement spring!
- 31337 Coils can handle 45 psi of boost!!!!!!!!!!!!
- More coil talk. Why do the 1.8t coils work on a 20+ psi 1.8t and not a 20+ psi I5?
- Odd. The car with the the waterlogged PCM...
- Something that goes with the S6...
- Is there any way to test the MAF sensor? I don't see any measuring blocks in VAGCOM
- Where can i buy a vmap and not a chip? I have my mystery chip and i think a vmap maybe be needed
- Thinking of switching to the 034 High Output coils......
- what grease to use for the sliding bits in the bell housing?
- What's the best place to buy some wheel hub adapters? Not spacers, but the lil rings that go on
- Do the differential 17mm box hex drain plugs require some type of sealant?
- What sealing paste to use for differential housing? Audi says :
- Can overfilled the coolant causes it to be blown out?
- I asked if the MP3 interface on Ebay works with the Delta....
- So I have a dead skip on the clogged drain car.
- Who's the guy building the Pikes Peak urS-car in KC???
- My poor Avus........
- Please help... problem replacing ignition switch
- Part # 4A1422893Q,power steering hose
- |skolnick, YGM
- Crank Bolt Tighting Torque Help !
- ECU is ignoring the O2 sensor
- RS2 wheels...
- I got the Scar back yesterday.
- Is this for real? Brand new RS2 turbo for $650?
- MP3 Player Interface?
- Broken rear coilover spring. Should I change my rates?
- Well, spring has sprung and snows have finally been put to bed, did a little color change...
- These, I think, are the perfect upgrade wheels on a UrS4
- Engine running at 110 degrees Celcius
- Two full days on the 034 HP coils,,,,,wow,what a,,,
- Dave (urs4boy) you are RS2 and 1.8t correct?
- so I broke my timing belt today and I need to decide what to do
- 2B camber plate experiencing some noisy...
- Anyone interested in trading a S6 or S4 for a 1997 A8?
- Boxter kit purchase... And, the numbers are in....
- Thermostat/temp question
- so, does anyone use the extra turbo wuss boost on the steering?
- Clutch needle bearing.... wtf?? please 'splain this to me!!
- Will this work as a replacement for the high pressure fuel line going from the tank to the engine?
- Silicone AAN boost hose kit group buy, details inside:
- Dying coil(s) - what is the consenus on the 1.8 conversion.....
- rear caliper to carrier tq? 26 ft lbs. carrier to hub assbly tq? 48 ft lbs. is this right?
- cruise control fix - clean contacts
- If you wondered where Emre was....
- I a dedicating Friday night to one of my Audis. But which one and what to do?
- Non UrS content question re: G60 caliper / Corrado VR6 application.
- 2 bennet camber caster kits ? lifetime waranty! i dont tink so !
- Instructions on how to build your own pressure bleeder
- I am getting tired of waiting for my coilovers...
- Upcoming NAAC Driver Education Events for April and May
- Guys ,Can I only drop in the brand new tire on the front?
- Sprung an oil leak, any thoughts before I put on hoist
- I hate Audis, I hate my Audi, damn sick of this car not being right.............................grrr
- ETKA Help needed...
- It's funny. I have 1 "project car" and a daily driver and I still need a backup car. I love Audis.
- Low Audi Content: Wife broke bumper on Toyota Echo (Yaris), driving over a parking barrier.
- parts number for the porche rs2 brakes bracket ??
- poured PS fluid in the Brake Res -- now it seems that the master cylinder is ruined... why did...
- Also...this is pretty sweet!
- Some K27/S6 stuff
- Ok,,,where is the best place to get this hose,,,4a1422893q.
- any clues as to what this SW is? obviously MTM but clearly says 269 ps...
- Anyone have a extra rear tag holder in black?
- some one quick, do I get em,? 245-35-18 Goodyear F1 gs-d3 new for $860
- 93 cruise control fuse location please
- Getting ready to do my driveshaft carrier bearing. Does it just slide off or do I need a puller?
- Free chips!
- so is anyone against using a universal type O2 sensor
- anyone know where i can get just the front H&R springs or..
- don't know about the quality. but looks interesting for those wanting hid's
- passenger side = right side ???
- need to replace transmission output shaft seal, shop says "Sorry, can't do it"
- Keyless IR working finally FTW!
- Newb question: How do I set the in-cluster clock? I need to move it up an hour!
- Where to buy Power Steering X-plug online?
- looking for a spare aux relay panel #2
- Found a good used of 6+4 Cayenne calipers Anyone?
- I have been looking up turbo blankets....anybody have on opinion on where I should buy from....
- Has anyone run a stock S6 at the dragstrip?
- Anyone know how to remove AC clutch?
- Destroyed rear outer CV when pressing it of, am I doing it wrong?
- Does anybody know the correct part number for driver seat foam?
- Just noticed today that the trunk deck that I had resprayed just this past fall...
- Any Canadians want to repatriate a car?
- Green
- I saw this car yesterday.....
- Krap ! Found mystery wire unconnected. Can someone identify ?
- How much of a PITA it is to remove the plastic door sills?
- you guys were right, changing the oil really does help to reduce emissions
- Does anyone know of an Audi Blaupunkt radio decode service in the US? I tried the on-line decode..
- So H&R springs have a life span of about four years?
- Alright, so, does 034 sell a Bosch 005 FP kit or not???
- Cheapest place to buy OEM A8 rotors??? ....
- Replaced #1 coil today, a few tips...
- Julian_B, YGM!
- Pinging, update.
- Someone want a Traffic Pro?
- S4 damaged corse opening at Rally New York
- Wagner RS2 EVO Exhaust Manifold rings like a bell when tapped. Even gently.
- Kinda OT but it is Audi related...
- A show of hands please!!!!!!
- Black 94 in Cali? Used to be owned by a stasis employee anyone?
- noticed something yesterday...
- LED Instrument Lamps
- Guy I've just put on the 2B camber plate on the car.
- I've got some seriously squeaky serpentine belt action going on.
- Generally speaking, if a chipped PCM gets wet and fries...
- Anyone photoshop one of these onto an UrS of any kind?
- bleed the clutch last after all of the calipers?
- Has Anybody used STI coilpacks yet. I ordered from Autohausaz,
- ok guys dont laugh! im thinking about air ride suspension!!get this
- E-10 Ethanol?
- Am going to attempt to make my own FMIC , suggestions and things to keep in mind?
- Mileage Reference Point: 10L/100 km = 28.2 mi/Imp gal = 23.47 mi/US gal
- Feels like hitting brick wall
- possibly buying S6 and have some questions...sorry kinda long
- Happy Times!!!
- What bumper is on this silver S?
- Hmmm, transient pinging getting worse.
- Anyone find a Stromung exhaust gasket solution?
- Sucks to be those guys.
- guys with VME HID kit, your help needed.
- how would you build your perfect engine?
- dang, all i want to do is work on the S and the TT, but i have to freaking work
- new member/stuff for sale/howdy
- I know this is OT but I have to post it :)
- woot woot! South Bend stage 3 on the way!
- So my car burbed yesterday.....
- Attention all Noobs
- He got 30 mpg from a Urs
- dead #2
- Recent urs6, new to the forums
- 190k
- Well, my driveshaft has graduated from "occasional clang" to "occasion thump/shudder" =(
- Need help - detonation under partial throttle
- I think I'm gonna do some cleaning in the engine bay. what d I need to cover or stay away from.
- guys where do i locate the throttle potentiometer?
- what is a set of front Koni adj. rebuilt by Koni worth?
- Noob (at least to this forum). Recommendations on where to find used S4's?
- How long would you expect a set of G60 front brk pads to last??
- my rear koni sport shocks are driving me crazy creaking,had them 7 years
- Porsche 928GTS calipers... PN check....
- Is the community loaner J-Hose available??
- Just broke in at 150K
- Steering rack lash adjustment just took 10 years off the feel of my car. If your car is feeling....
- oh noes ... look what I got!
- Just wondering...is the leather on these cars vat dyed or sprayed on?
- Attn 90Carat (Tom): I found my "after-run override switch" schematic...
- All the exhaust manifold flow numbers inside:
- Cars been running great since I put in the 1.8T coil harness and new coils, now it wont start
- Gona design a twin intercooler set up on my euro urs6.
- this is a nice looking avant
- spotted cashmere S6 Avant in Boulder at Target today, who I see?
- Head/Clutch job done and progress updated. Thanks for all your help!
- A few issues,,Hope some one can shed some light,,,
- Couple of questions...
- Anyone ever try this brake tool? Is it worth the price?
- I now know the secret behind the fanny-pack.
- 93 s4 owners i need help reguarding the trim that runs above the doors down the a and c pillars
- Ooo.Ooo. I've got Parcel!!
- You guys are smart. I am replacing the carpet in my CQ. I need sound deadening suggestions...
- so there's this yellow lambo gallardo in the area..
- Anyone whos bidding on the white on black s6 sedan in mass im going to look at it tonight
- LOL @ ad copy.
- H&R spring broken,,,,any suggestions on what replace with?
- Pic request: 18X8.5 ET35 wheels on a lowered Ur.
- A lot of movement in the shifter on accel/decel = new snub mount.
- Brake Booster
- PSA- April 12/13 is opening event @ Lebanon Valley Speedway ..
- ok guys do you think a little loss of overboost could be down to diverter valve?
- Chromed OEM 16 Fuchs on Black UrS6
- Needed: coolant flange below back of head. Any options?
- MiniMan finally gets the box flare thing figured but goes too far with a hood scoop.
- Considering how rare it is... it's not a bad deal... I think...
- Who is this?
- Can you get the vacuum hose to the intake from a local auto store?
- It snowed a lot last night. I'm now on summer tires. What a great opportunity to practice...
- Appraiser thread - 93 S4 w/ 196k Pearl/Ecru
- This is interesting,,,
- Spotted Nice white (pearl?) S6 avant in Portsmouth, NH last night.
- Anyone need S4 clear corners?? $19
- anyone want to trade? i need an avant...
- Cheapest place these days for a BIG RED caliper?
- I was just thinking of how much easier it'd be to make the wider front fenders out of fiberglass.
- Clutch Question. I STFA and came up with alot of clutch issues with..
- Well, if you want an Avant, this might be your car.
- Buy it now!
- Another wheel thread
- Anyone have a spare cam gear for sale?
- who's in the Boulder, Lafayette, Denver, Butte areas of CO?
- Almost lost a wheel on the highway.
- Guys have you checked out the ARC cool fin??it actually works!!!!
- OH HAI 2 U SUMR WEEULZ!
- pics of emerald S6 w LM/reps? anyone?
- Reeves Audi replaced my A/C compressor, and dryer...
- Green + Not Running = Dirt Cheap
- P/S Pump
- Oh, and PSA: Don't forget to check the torque of your
- No fear people, winter is now over
- Hard not to love the sound of a big turbo wrung out on race gas :)
- FYI a 2.7t motor downpipe R&R is quoted at 5 hours labor
- no frikin way! what a deal!
- Per Nick's request...K26/27 Dyno Numbers
- Who's replaced the clutch pedal on an UrS6?
- trim piece
- X-Post: New solution to bolt-on center support bearing
- Paging cialowicz and chefbob
- Weldo / Mark post your dam numbers already!
- outer cv boot - replacement
- Post a photo of your favorite polished or powder-coated coil pack cover.
- took some pix today.......u be the judge
- Where to buy BBK brake bracket 8A0 615 125A?
- Sadness.
- RS2 High output manifold flow numbers
- The Audi sickness has spread to others...
- relay question
- Andrew WK. If you are not still following my problem please check link
