PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. When testing for boost leaks with a tester....
  2. Climate Controls Flaps
  3. Where or what is the sensor that the oil temp gauge gets its info?
  4. Any urs4/s6 owners hitting up the Atrium Boston GTG this thursday?
  5. Anybody in GTA area have an extra couple of rear calipers i can borrow?
  6. 2113 - Cam Position Sensor Fault
  7. Auto-check BEEP driving me insane
  8. WIll the H&R race springs for the sedan fit the avant? a freind of mine put a6 sedan springs on
  9. I give up....
  10. I replaced my oil pressure switch on Saturday in -7 weather. O so fun.
  11. Software question regarding adding FMIC to a full RS2 setup?
  12. S6 "Sport" Airbag - Part Number Request
  13. Well its about time......
  14. I am to assume that you have yet to send the viscous fan Emre?
  15. NEW MASHUP!!
  16. Newbie with big brake question
  17. Anyone selling a set of '92 springs?
  18. Remote Locks....keyless entry ... part deux.... help please....
  19. had a couple of avants at the shop today...
  20. Damn! Left my ignition on with heated seats on - killed battery. Question - Can
  21. What part is this?
  22. The pink tornado runs again!
  23. How can I resync my alarm system and locks?
  24. Right rear squeal? Checked dust shield...
  25. still no start
  26. Rumble felt through the pedals. Wheel bearing?
  27. another day, another AAA tow
  28. Does a 95.5 avant need the sway bar bushing mounting plates from the HAPrear bar kit??
  29. Keyless entry question - How does this #*&$* remote work:?
  30. Well my fan clutch went on me and it took my serp belt with it, can i fix it myself?
  31. played Touchee-Feelee with the heater core hoses today.. Each was practically the same temp, however
  32. Anybody recognize this car?
  33. terrible question i know but, what is the minimum i can get away with?
  34. someone is trying to scam me (inside)
  35. Would an exhaust leak all the way behind the resonator throw a CEL/Code?
  36. 1993 Audi S4 update on my progress or lack of..am I on the so called slippery slope?
  37. Could someone ask the dealer for 4A9861327 01C? TIA
  38. Nav+ install
  39. How can a CPS fault be intermittent without touching anything??
  40. I love youth......just got challenged by a TT at DQ......
  41. Ok, need suspension help. What do I need to buy, what should I buy?
  42. Anyone have a pic of a green S4 with black wheels w/ a polished lip?
  43. anyone have a oem warning triangle?
  44. So what should I expect to pay(range, obviously), for a set of 7A cams?
  45. stock front license plate bracket part number? where can I get one?
  46. Look Adam, your door made it on to an A6 Avant. It was repainted black.
  47. Let's set up a conference call brain trust. An S-car A-team, if you will.
  48. alignment issue
  49. Hmmm, and "Awww, crap."
  50. Ok.. opinions on a new car needed...
  51. What brand parts to get for front suspension rebuild?
  52. The A/C compressor shuts down when it gets too cold out, yes / no? At what temp?
  53. euroalowicz.
  54. Detroit Auto Show Highlights
  55. Audi gods are messing with me, too. My car runs... but I have no idea why.
  56. Audi Gods are really messing with me.........Long rant
  57. subframe work.....done.
  58. ok, so I'm too lazy to search.. some1 spoon feed me pls =P. No hEEAAT! grrr, sucks @ -30C
  59. STFA? You're darn tootin'!
  60. hey kid quattro are you looking for urq's to restore? e-mail me I might know someone with two
  61. anyone with tinted windows can post pic that would be sweet
  62. Hey anybody know where I could find a used PT#034 133 357s...
  63. reasons to do a timing belt
  64. can someone confirm this is what I remove for the speed limiter?
  65. 16 x 8 forged Fuchs are awesome.
  66. PSA: More strip caulk is NOT BETTER!
  67. snow in seattle....I wonder which wagon will perform better?
  68. chefbob, ygm...
  69. Looks like my car needs major work. :-( Suspension for sure, new turbo maybe?
  70. Fuel filter adapter?
  71. Help! Cant find location of outside temp sensor to replace it, pics inside
  72. Wow, really nice S6 for sale
  73. Annoying effing rattling coming from the moonroof!!!
  74. Can someone confirm this?
  75. Change pressure plate bolts or re-use?
  76. Transmission out. Holy hell this sucker is going to be fun to put back in...
  77. sunroof trouble
  78. Wheel fitment 18 x 8.5 et 32 ....
  79. Some pictures I don't think I ever posted...
  80. looking to do the emmett03 mod to my instrument cluster for the bulb out signal...
  81. Which model front ends will fit on my ..
  82. Does anybody have audi tool 3256 in the alabama-ish area?
  83. "IMNSHHEO"I think Dave's FAQ thread should be linked at the top of the page. How can this be done?
  84. For those interested...FYI...
  85. If anybody runs across a good deal on 16" winter tires please let me know. I am in no rush
  86. looking to buy some 18's for my 94 S4. Please post pics of what you have.
  87. Looking for a good used AAN head. (more inside)
  88. Noise after turning off the car
  89. Found some glare ice to test the EDL.....
  90. Anyone got extra/spare lug bolts for the Fuch wheels laying around?
  91. How is the AUDI badge held into the molding in the RF fender?
  92. B5 S4 avant BT: would you switch?
  93. Ahh just finished my remote start install with locks
  94. cialowicz, how did you make out with your no-start?
  95. my inner CV joint bearing was loosing out this morning.
  96. Does anyone...
  97. Started on the clutch today....
  98. PCV Valve?
  99. Windshield washer reservoir R&R
  100. Intensive windshield washer setup pics
  101. my creepy motor mount
  102. A question about driving technique
  103. graph finally uncorrected to the wheels :)
  104. i cleaned the rear gutter rain track from the rear wheel access point with a weed wacker wire, but
  105. what wire to tap into parking lights to flash when arming/disarming(aftermarket alarm)
  106. What does mph in a cirlce mean?
  107. Anybody have a good MAF for the crispy chikAAN?
  108. Anyone here have english version of SSP143? TIA
  109. Ross-Tech cabling question.
  110. anyone know where to get the G62 Temp sensor other than the dealer?
  111. Airbag portion of the wheel
  112. Auto check brake light problem, maybe Kday can help?
  113. VAG-COM "lambda control" block stuck at 1.00. Any ideas?
  114. Does anyone have a rear left corner lamp, full sized right mirror or shift linkage kicking around?
  115. Cialowicz, I have a solution to your reliability problem
  116. anyone the part # for this white molding clip?
  117. Should I change the clutch master cyl when I do the clutch?
  118. What anti-theft devices are in my 97 S6?
  119. If you had to put your UrS for sale, what would be your asking price (CAD/USD)?
  120. Scammer?
  121. Should i buy or not...
  122. Do the interior lights of the car come on if the trunk is open?
  123. Should I buy...?
  124. Zing ! The mods are cracking down
  125. Has anyone seen hide or hair of Alex from IA.....
  126. Those with JE pistons...what type of piston heads to order?
  127. gabe finish your car
  128. more odd engine noise...
  129. new winter beast
  130. WTB..need one Bolero!
  131. A weekend of small jobs.............OAT fixed, seat heat fixed, Concert I installed.
  132. Nice S6 on Audifans. That interior looks minty! Beaute of a car, sad to see you selling Tom.
  133. goodies
  134. Congrats to Dave F!
  135. N75 Valve
  136. a couple urs cars a mnaudi gtg.
  137. Considering changing seats - Newer S6/Allroad recaros....
  138. Lock system still freaking out
  139. So, I suppose I should start diagnosing my car.
  140. More info on S6 avant for sale
  141. After driving many cars, and modding my S over a period of years, I conclude that:
  142. What is your COMPLETE mod-list?
  143. My new high score -or- How to break impact sockets
  144. for cialowicz
  145. Does your car need to be painted??? TRIFECTA ha Cialowicz
  146. Does your car start correctly?
  147. Have you checked your stock clutch lately?
  148. anyone have the outter diameter of the hard fuel line under car?
  149. block!
  150. Strike a pose...
  151. Some HID pics...
  152. i noticed two wet spots under my brake and clutch pedals. i go down to touch it and im pretty sure
  153. Save me before it's too late -- thinking of buying an UrS4
  154. Alternator Output
  155. Won't start again.
  156. Gamma/Bose Harness for Blaupunkt aftermarket
  157. Lock System Gremlins(I need Help!!)
  158. More info on stall problem (interesting).
  159. Problem believed to be with Aluminum Flywheel and Crank sensor(sort of long).....
  160. Car runs now!!! ...... Kind of
  161. oil pressure/fuel pressure gauges w/TDS1
  162. Does anyone know of a tool similar to "VAG-COM" that is for BMWs?
  163. Popdemonic,pls email me.
  164. Need help from VAG techies re: 1.8t coil pack markings.
  165. just got back from tuning my S6 w/3071 and standalone at EPL
  166. Anyone we know?
  167. Front Seats Experience...
  168. Im frustrated. My car is broken.
  169. Anyone have an update on that Canadian UrS that was stuck down in Florida?
  170. Dave, your A6 Avant has arrived...
  171. Wish V8s came with manual transmissions in the US.
  172. question about oem vs replica s4 rims
  173. Global warming? Snow storms delay delivery of A6 Avant.
  174. Too much boost and crap gas....... oops
  175. GOT TDS.1?
  176. I hear a bunch of hooligans are at epl getting some dyno time, curious to hear the numbers
  177. Front inner CV Joint 'stuck'...
  178. Fuel tank leaking -- need advice
  179. Even and odd part numbers, which is left and which is right?
  180. Spotted a black URS6 Avant on route 46 West in Fairfield the other day
  181. some late-night Avant sexyness for all you "wagon whoores" (including myself)
  182. Lift points, jack stand points
  183. Are these capped O2 bungs?
  184. when highway driving going about 70 i floor the pedal and the oil temp warning light illuminates
  185. I'll throw this clutch question out again to see what the response is...
  186. H&R sports.... 10mm spacer in rear or no?
  187. Some new'er pics of the S4....
  188. TDS-1 boost gauges (& etc.) are available again...
  189. Hmmmm... what do we have here?
  190. Stiff clutch pedal, but newer clutch. ????
  191. When I cold start my car, the brake light stays on for a moment.
  192. More ABS and EDL questions, did the STFA with no luck....
  193. Front door hinges
  194. Paging Julian_B, YGM
  195. fuel pump replacement question
  196. Anyone have the LATCH points installed on thier sedan? Audi pay for anything?
  197. Best way to color the chrome?
  198. camber plates questions
  199. Euro front bumper and FMIC
  200. R.I.P. One less green S6 around..
  201. The good and bad during a day in MiniMan's shoes.
  202. Incident with a rocking chair left me with a little issue... need front bumper..
  203. Antilock sucks in the snow so on/off switch went in
  204. Well Avant just arrived in one piece.....
  205. 330 ft lbs. of torque on the crank pulley bolt correct? Dont want to break anything.
  206. motodyne has a myspace its pretty comical to
  207. I need new tail lights (inner)
  208. Ambient Digital Temp Display Wonky
  209. Closed loop / Open loop - boost issues
  210. looking for silver audi
  211. A little advise
  212. Anyone tried the chubby Mann oil filter?
  213. Stromung Gen4 (thanks Posto) and 2 of 3 Samco hoses installed tonight...
  214. I was a little puzzled on my way home from work today....or are they really that fast?
  215. Does EPL have a webpage? I wanna have a chat with em about Stg 3 for the A6.
  216. i am pretty satisfied with the revalved bilsteins, hence...
  217. Yes everyone, I am still alive. I did not die in a tragic ghost riding incident. I took my CQ on a
  218. Car Phone Instructions?
  219. First custom mod to my S car. It feels faster already.......
  220. still cant deside on what boost gauge to go with
  221. Question regardring engine stall (95S6)
  222. Question on behalf of my brother regarding MTM Stage 1 vs. Stage 2 (1.8T)
  223. Anyone have a pair of side bumper snaps...the parts that attach the bumper to the fender laterally?
  224. Badly Need/Want Rear Roll Bar. Not Many Options?
  225. Question about TAP's chip horsepower gains
  226. thought it was fan clutch... it wasn't. thoughts?
  227. HA! I love my car! (really)
  228. Anyone know the best way to Ipod a 95.5? I searched but didn't find much.
  229. went to hoppens web site cant see our motor?
  230. What official chip suppliers did I miss at the new C4 S-car FAQ thread?
  231. Could someone post a picture of an Avant with a Euro taillight setup? And Happy New Year UR Bros.
  232. UrS = Moneypit?
  233. Where can you resurface the headlight reflector....
  234. Looks like I'll be the owner of a 04 A6 2.7t S-Line TIP soon. VR-Life , advice?
  235. anyone have a pic of solder work needed to fix warning display?
  236. Anyone have a spare coil???(functioning) (94s4)
  237. Clunking from left rear shock
  238. Happy New Year my UR brothers..........Question: Do I need new longer lugs for a 5mm spacer? TIA
  239. Anyone looking for a RS2ed 95.5 black on black Avant?
  240. Anyone have a spare ECU I can borrow / rent for a few days??
  241. I would like to see pics of the bumpers
  242. Random thought... anyone ever made chairs from a set of S4 seats?
  243. Happy New year. Sudden lose of power around 5000 RPM if I stomp it. Could it be the fuel pump
  244. 95-95.5 diff on diffs?
  245. Should I convert my narrow radio to the wide one?
  246. DIY:the vacuum pump for the trunk lid
  247. Tonnes of awesome links in the B5 A4 FAQ thread. Maintenaince, wheel gallery, universal DIY, etc
  248. My S4 is going to pretend to be an S6, because...
  249. my brake pedal thrumbling solved!!
  250. Two somewhat time-sensitive separate Q's... re: Euro bumper and 034 FMIC
