View Full Version : Audi Original "S" Cars
- I'll be playing with an S3 A*** this weekend
- can the tail light lenses be removed? perhaps I can seal the cracks with modeling glue?
- Spare parts cache recommendation
- Poll: How many people have the trip computer in the cluster ? e.g. can see av mph
- Anyone have a stock MAF to turbo hose they want to sell?
- Failed Again....
- Fire Extinguisher...
- Any of you w/ Fuchs use a 10mm spacer? Curious how it would look. TIA
- installed F6 DTC plugs yesterday. so far the impressions are good, much better than with the NGK
- Cost of Used RS2 Em?
- i'm reading the ign. replacement instructions and it seems more involved than everyone makes it out
- Need the part numbers for 1.8t coil, for daves conversion i cant find it anywhere
- Arrived!
- warning lights
- Anyone selling a set of new/ used big reds?
- Follow up. I now have fault code 2341. I pulled the plug and it is black.
- How many people are running Big Brake Kits with stock Avus 16's
- Spotted...green UrS4 on Rt.23 N near Ann Arbor last Sunday evening...
- Anyone have a Kamei grill they'd like to part with?
- color code question
- Looking for a small fire extinguisher for the old girl, recommendations and where?
- putting on factory BBS wheels, the one's from a 6-speed A6 (C5), what wheel spacers are needed?10mm?
- Radiator fan won't turn on
- Silver UrS behind me on I-89 near burlington VT this morning, any of you guys?
- A bit OT, but x-post from C5 on the A6 AC woes - to cheer up those...
- First pic of my car
- check out this movie...recognize the engine? 900HP
- Radio Antenna
- Leaving Subway for lunch today and smokin....
- Anyone else fail emissions with the Bosch 044 Fuel Pump?
- S6 is mysteriously losing 12oz of coolant if it sits for 24hr. Ideas?
- recharged my A/C system with freeze 12 and some leak stop. icy cold a/c is back...thank god.
- Update to my so called "Pastore" chips
- coil diagnositc help...
- Question for you problem solvers out there...when VAG won't "recognize" the car
- need help with turbo vacuum line
- Mounting CPS to 7A head.
- can someone link me to the outer cv boot replacement. thank you.
- funny thing today with my Bilstein/Eibach Pro kit setup
- Where to locate a new fuel injector cover (yes the plastic injector cover that always breaks)?
- Hey Crapple.....
- Just a plug for www.eshocks.com
- No airbag??
- Is this Bailey connected correctly?
- All this talk about WG diaphrams!
- PSA: F'n A, I miss my car.
- Its a wastegate wednesday. Everyone go out and mess with a part that just doesn't break.
- Well, since today is the day for wastegates
- Waste gate diaphram question?
- finally got chipped...
- s4 and s6 tail lights are the same yes? (center lights)
- chefbob, did you ever find that pass. side headlight sprayer. i'd like to paypal you as it seems
- F*CK! does anyone have a spare wastegate?
- Progress......
- OBD Codes my S4 is displaying, lots to fix, any advise where I should start is welcomed
- roof drains not draining....
- On the road again
- Is there a way to check fault codes and reset them without having the Ross Tech ?
- I think my start problem has been isolated
- trying to change my wastegate diaphragm, but the nut won't come off
- Oil inlet restrictor on the 3071
- Question for anyone using pastore rs2 chips? Is a RS2 MAF a must?
- Replaced the O2 sensor and the hesitation & misfire is still there!
- w00t! sounds like my mechanic figured out my boost cutoff issue
- Got the news from the machine shop...
- Will this fit with some slight modification?
- Pressure testing IC and hoses question
- Coolant sensor question
- Paging Adam C. (EB_1920). You got Europa S6 Avant mail on..
- Final Notice! Old School quattro gathering this weekend in Cumberland, MD!
- I WAS TOLD TO POST THIS STORY HERE
- OOOOH HERE SHE IS IN ALL HER M6 BEATING GLORY :)
- If any of you guys are looking for rims or tires I have the following;
- Does Oettinger do any bodyparts for our S-car?
- is this what the serp. tensioner assembly looks like?
- part no. for ign switch: 4A0905849 that correct?
- Anyone?
- problem with starter?
- 034 Stage IIC conversion harness progress
- To Wax or Not to Wax.....
- who can beat 111?
- If you're looking for a carbon fiber hood for a URS6 or URS4 then check this out
- FMIC + Samcos installed.
- OK, need some help w/ an oil line question......
- New owner
- anyone have a spare 7a cam cover leftover from a project?
- AC woes cont'd: pressure too low @low side, proper charge in system - points to bad expansion valve?
- 495 SOUTH IN ACTON NOGARO RS2!!!
- Low Boost + Falling RPMs = Vaccuum Leak?
- Fuel Lines Replacement
- Help needed for exact location of these chips on the board.
- My take on the 1.9 bar spring....
- New 034Motorsport Fuel Pressure Gauge Adaptor
- Where i can i find production numbers?
- Bosch F6 DTC plugs: the perfect match for MTM software...?
- anyone help me locate a S2/RS2 wiring harness? thanks
- Considering parting out a '93 S4 with RS2 mods etc
- Looking for info on hitches
- is this the real deal RS2 EM ??
- Cleaned up the car today, and took a lot of pics...
- What's a fair price for a AAN intake and exhaust manifold?
- Is it possible to get the rubber boot for the trunk lock mechanism new from Audi?
- anyone interested in buying a greddy profec b spec 2
- Replaced the master cylinder for clutch but...
- Well, since I'm keeping car, and it just hit 120k. It's maintenance time.
- Any of you have this turbo?.........
- OK..... 2 drain plugs for rear differential. The question is are there 2 fill plugs?
- Pagining ChefBob
- Paging Crapple
- Paging Spiralsmurf
- FMIC install time.
- Think I can expand the one end of my IC pipe from 2.5" to 2.75" or close by using this?......
- headlight washer ...anyone has a spare?
- Got pipes??.......
- Turned out to be the starter...
- smoke question
- EPL stg.1 beta testing began today... ;P
- Anyone got a carfax account?
- Need new/used exhaust system in Denver
- Where to buy termostat cover?
- Chip Gurus - Preferences/Opinions - MRC vs MTM
- My car only works for short amounts of time. (Also - thank you to Darin from S-cars.org)
- What gear oil you guys use in tranny and diff.? I can't find a GL-4.
- pix from last week, before i got it tinted....freshly waxed....
- Well here is a better question... Can a relay make odd noises, if its on its way out?
- i'm going to recharge my AC with Freeze 12 instead of R12, lets see what happens.
- I am hearing an odd noise, sometimes coming from under the steering column...
- t-belt....DONE!!! Dimitri from Euro Spec Motors rocks!!!
- Some pictures of my 12" sub box.
- Doea anyone know where this tube goes and what is the purpose of it?
- starting problem and cutting out, Long
- ok, big question here....
- Repost from 100/A6
- Serp. Belt tensioner: There a way to replace the bearing in the pulley w/o buying the whole ass.?
- CPS GB #2 Last chance to pay
- CPS install, help please
- So besides the engine getting an overhaul...
- Need to lift my car up some. Anyone wanna trade springs?
- Pretty crazy stuff...
- Dumb question!! Cig. lighter
- H&R springs for sale
- hellllzzzz yeah!
- Bump stops
- 18x8 Avus Speedlines
- compression test values...good , meeh or bad?
- who's //S is this in the vid?
- AC issues: system properly charged, compressor rapidly cycling on/off
- should i buy? [urs6]
- Bargain hunters....(x post)
- Early A4 sport wheel upgrade need help ....
- How to tell if a strut is bad?
- does anyone has pix of their slotted strut mounts?
- blue smoke today at idle after moderatly fun drive home
- Totally forgot to post pictures of this, but before everything goes on...
- My AC compressor cuts in and out sometimes when it's really hot...
- those of us in states where they check the computer in smog tests, can we get away with standalone?
- Denver S-car owners......can one of you look at car for me?
- Better pic of the CHunkies.
- Are S6 and 1995 Audi 90 Climate Controls Interchangable?
- Fair price for a stock ECU?
- Bilsteins Sports.....ECS or Blauparts? (big question inside)
- A Midsummer Night's Audi GTG Boston Area August 8th
- 3 battery PSAs
- Is the radiator stopcock the blue plastic one that's on the left bottom corner (looking at the engin
- NE //SFest UrS Information -- IMPORTANT
- Why does ETKA show same part # 4A5 411 105T for 92 & 93 S4 Front Springs?
- urRS4 vs RS4...
- A/C quit functioning... pulled CC Head codes, got a 29.2 and 29.4... Help!!!
- fair price for headlight washer(doesnt have to work) and headlight housing (or new headlight)?
- oh yeah almost forgot, L.A. GTG @ The Stand (Encino/SFV) tomorrow night -- Tuesday, July 18th @ 7pm
- Wiring the H2O injection set tonight, need a 12V wire to tap that's got current all the time.......
- Pretty please?
- How do i check the level of my AC do i dare say "fluid" haha
- haven't been on in quite sometime, is germantoy still around?...
- Do I remember correctly... When license plate bulbs are both out, that means something else is wrong
- Didn't someone here have a tow hitch for sale (one that's not being used)?
- have any of you ever run over those large metal sheets they use to cover up man holes?
- smog braintrust: what would cause high hydrocarbons at idle?
- OK, dumb question not covered in the archives...
- What's an ECU with MTM and 3Bar worth complete?
- IT'S HERE!!!!!
- my car is becoming increasingly difficult to start. sometimes it cranks and then doesn't sync up
- my 19" rims arrived.any problem with this tires setup?
- Ok I give in - where is the Lash Adjustment on the Steering Rack ?
- Alright...a question that doesn't get asked very often on this forum...
- Any thoughts on this?
- STaSIS Motorsports back from Miller - No race results inside just pictures and link to results.
- Kind of glad I didn't make waterfest this year.........
- ooh, was driving behind my car today and saw once grey smoke from exhaust
- so there is a 93 S4 with 240,000 miles and big reds for sale locally
- Anyone know anyone who knows anyone who has 1 Cup 3 17" in chrome?
- What do you guys recommend for timing belt change interval?
- i didn't drive my car for a week and it developed this ticking sound when i started it today
- Shokan: X-Post
- Interesting way to fail...
- You guys see this?
- Anyone selling? S6 Avant or RS2'ed S4?
- Just got home from ALMS & speed challenge.
- The S is pulling new duty! Road trip!
- Cam position sensor location photo and diagram
- Anyone got a Flywheel?
- Hose from power steering pump to rack & pinion
- OK, got my Stromung DP, going to wrap it tonight w/ fiberglass heat wrap......
- A few questions....
- Switched 12v Power, 15 or 15a dist. post under dash?
- oh man, 13 minutes left, someone pickup these bbs RG-R
- did the RS2 have adjustable cam gears or is there anyway to adjust cam timing
- Help! - Engine missing/running rough when warmed up - what's up?
- my brother's got an performance exhaust header/manifold that he cant use b/c his cars too small...
- TSW Trophys 17x8 are mine aparently
- Help! Brake pedal stiff.
- An apology for those going to WF....
- since we're on the topic of shipping, just did a quick comparison from the 3 major carriers
- TSW trophy 17x8 on eBay for cheap
- Need Diagnostic Help
- Abt chipped RS6 Avants are FAST.
- Photo of a FMIC behind a 93 R12-equipped S4 with a Lltek lower spoiler
- clutch disengages during normal driving
- Two tickets since the S6 arrived..
- Checked some things, is my MFTS bad?
- OK, I'm not SERIOUSLY considering this, but I have played it out in my head and on paper...
- New MAF Cleaning Products
- Polishing window glass...
- how do i take out the rear headrests??? pls help!!
- Kinderutz did I see you in Chestnut Hill (Philadelphia) yesterday or...
- Since my mileage is crap.... Aesthetics first?
- bump stops.....are these front or rears?(circled in red)
- New transmission (RS2 or 95.5 S6)
- More questions about gas mileage (sry for being lengthy)
- Anyone ever dyno a K26/K27 with RS2 S/W?
- Chip Herr sets fastes lap in combined practice at a 3:09.218.
- NE //SFest Swag now available for purchase......
- I hate people.
- 18x8.5 50offset 225-40-18 tires will they fit our cars?
- Chip Herr running 6th in first offical practice of the 4.5 Mile Miller Motorsports Park
- can some one provide a pic of where the vehicle speed sensor is
- is there a lawyer in the house?
- So phat, so CHunky.
- which sensor does the "06.1 Engine Coolant Temperature (ECT), A/C static open" refer to?
- Any suggestions on how to tighten up Steering feel ? Read as : Help my steering is too light !
- Can someone shoot me a number for subframe bolts....
- hey guys!!! Today is my birthday..
- TurboJew:
- Samcos just showed up today.
- Imagine my fun.....
- A quick 10 minute, $3.65 bumper fix...
- //SFest Swag coming soon
- I've driven my car .25 miles in the last 2 months. That is all. 8^(
- Does anyone know which brake upgrade kit this is? What source for rotors and pads?
- S4Boy, I am thinking of doing a POS Coilpack conversion....
