PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. just got some new hardware/parts
  2. Replacing cooling system hoses/T-fitting tonight. What else should I do?
  3. Center caps for Avus knock-offs
  4. AVUS Rims (decisions, decisions)
  5. central unlocking issue
  6. Big brake kit for sale?
  7. Any UrS owners in Toronto/GTA?
  8. Dave, what does it take to turn an A6 into an S6?
  9. If you do any welding, you might want to read this
  10. window relay clicking wtfs
  11. hesitation when cold?
  12. Accelerator Pedal Replacement PN 4A1721507J
  13. Info about the 2004 "RS2" Turbo Group Buy Turbos
  14. What rotor can I use with the ECS stage 3 kit?
  15. First Look: Marshall 5411 Boost Gauge vs AutoMeter and
  16. rear suspension knockings
  17. rear calipers w/ better e-brake?
  18. NEED PADS. WHERE TO BUY.
  19. radio display on 96' S6
  20. I switch ingition to start position and then the trunk unlocks? WTF
  21. VW Gamma CD HU - could this work??
  22. La porsche calipers
  23. Spongy brakes
  24. FINALLY, time to work on the S6... have many questions...
  25. canadian import
  26. Scammer Alert: Jase Williams , perhaps AKA Jason Charron was back on AF marketplace!
  27. Looking into some HID's. Help!
  28. Boost gauge feeler: Who is interested in a custom gauge?
  29. door panel?s
  30. Engine rotation - ?
  31. Fuel Rail Part No. info
  32. Noob.
  33. Has anyone seen problems with MT90 tranny fluid?
  34. Looking for ...
  35. wheel question??
  36. Dave all things dual mass read on.....................
  37. It's time to sell my car, I can't bear the cost any longer. :-(
  38. longballrally - registration is up
  39. '95 S6 ,"SAFE" Displayed on Radio, Help Please!
  40. UrS4 wire harnes includes headlight washer wire?
  41. key fob help!
  42. Steve Eiche chipset with aftermarket coils
  43. Cam and Crank Seal removal questions
  44. power steering pump possibly shot ?
  45. does anyone have the wiring diagram for the ingitions coils(1.8t coils)
  46. Camber plate studs part number
  47. Who has a great looking AAN engine compartment?
  48. Ignition problem .... again?
  49. 1992 AUDI S4
  50. Eibach coil spring spacer - remember them?
  51. S8 for sale
  52. Found S4 for sale, need advice
  53. Best power mod for under $100?
  54. How to tell if an RS2 EM is the real McCoy??
  55. My Heater Core Is Broken
  56. Big Turbo Q
  57. losing boost at 5000rpm...detail inside
  58. want to replace the stock air box, which is better?
  59. Just bought a 95 S6 avant.....
  60. stage 3Porsche BBK rotors...??
  61. anyone with carfax acct?
  62. 034 H.O coils or DIY LS2? Discuss.....
  63. drive line slop???
  64. Name my coolant leak
  65. Hello Everyone............I've missed you all.....
  66. looking for anyone in Houston that has similar vehs to disuss upgrades with
  67. s-Cars in Houston
  68. Newbie "what's it worth" question 282k!?!? help!
  69. Turbo help?
  70. Pin Out Diagram 4 silverbox
  71. quattroworld down????
  72. Obnoxious Beep!
  73. P/S fluid?
  74. Audi Parts
  75. Can anyone tell me what this is?
  76. My front strut mounts are broken again. That's like 4 times now. Is this normal?
  77. Can anyone tell me where the purple/black wire of the FP connector goes?
  78. Our cars still hold up well
  79. B5 A4 steering wheel fit on UrS4?
  80. Car died. Bentlet CD won't work. Keeps blowing fuse 17. Fuel pump. Short?
  81. Looking to Buy 95 S6 in Great shape!
  82. Guys who bought from Jason Charron, any luck?
  83. Parts available @ S-fest - Bilstein HDs, 92 coil springs, etc.
  84. CC Channel 51 - Engine coolant temp. Under what conditions does it read accurately?
  85. Ok, well I have to work on my car now! Anyone have an A/C compressor? Mine is seized
  86. Let's start a new rule: Don't reply to any posts older than a month.
  87. Longball Rally 4
  88. I need some inspiration/ motivation....
  89. Basic Idle Switch and Throttle Position switch testing (from the Bentley)
  90. how do we remove the c-pillar lower trim under the small window?
  91. Anyone wish to confess to this?
  92. Looking for big injectors
  93. Anybody got an extra "MM"?
  94. Airbag Replacement and lock repair
  95. excessive heat coming into the car ! from the engine compartment any idea
  96. S-Fest West 2009 - Writeup
  97. needed - 1 set of rear lower coil spring seats
  98. 15 months and 40,000Km - first 115R coil failure. Roadtrip - spare in trunk
  99. Avus replica rims
  100. my commuting fail.....
  101. I gots my own A/C problem.......
  102. What's wrong with my exhaust
  103. Car broken into....
  104. A/C delete?
  105. Got a question about shaky idle with the A/C on
  106. Which key blanks work?
  107. Where can I get a new belt driven radiator fan?
  108. How do I remove the DAMN C-pillar?
  109. how to bleed power steering
  110. S-Fest West 2009 - August 15th 2009 - Registration and Sponsor Announcement
  111. 1994 Audi 90 clock and shift indicator light
  112. Looking for a new chipset, need recommendations.
  113. B5 S4 Brakes
  114. How much should I be satisfied with from my insurance co. for a total loss?
  115. Timing Belt Job, can a friend handle the job?
  116. Colorado Peeps... who is going to DATR? I know Hap's car will be there.
  117. meet tomorrow in Montreal at Julep?
  118. Upgrading HU in 95 S6
  119. S-Fest West 2009 is this Saturday!!! OMG!
  120. Head gasket R&R is underway....
  121. where are all the UrS4 galleries? Whose got pix of 92-94 silver cars?
  122. 034 Clutch and flywheel group buy!
  123. It's official, people are stupid.
  124. Kday, i need to remove my AC drier. i saw an old post of yours
  125. SMIC upgrade, anyone interested?
  126. Anyone have some Power steering lines for a UrS4/s6?
  127. Dave Forgie, can we americans buy Canadian S4's or are they hard to import?
  128. New Build -took 3 years of picking at it . Engine Noise
  129. Drive flange removel?
  130. Washers on PS Pump install
  131. Breaking news! A real deal Nogaro blue RS2 will be present at S-Fest West 2009!!!!
  132. This is TurboJew Signing off from the UrS Forum
  133. Finding the code tag on an UrS Avant
  134. Replacement Tranny Options?
  135. urs6ville PM sent
  136. Another whats it worth: 2B coil overs w/springs,shocks,camber plates,strut housings?
  137. 93s4 for sale?
  138. Spotted a wrecked Pearl UrS6 in Stowe VT last week on a flatbed : (
  139. AAN short block needed.
  140. Pop quiz- Magnolia=?
  141. Catalytic Converter replacements??
  142. Whats a well kept, stock 95 S6 with 170k going for these days?
  143. S-Fest West 2009 - August 15th 2009 - Registration and Sponsor Announcement
  144. Loss of boost at 5000rpm
  145. Anyone here with really good body work knowledge willing to help me with some ???'s
  146. PSA: Use more loctite on the CPS bracket bolts...
  147. Anyone have a spare (amber) pass. side turn signal to part with?
  148. boost gauge install
  149. Is there such a thing as low dust brake pads for Big Reds?
  150. May have blown my head gasket??
  151. Anyone find an upgrade to the rear shock mount rubber donut that goes around the big
  152. HELP! LATCH install problem
  153. Couple S-Fest West PSAs. First 25 PAID attendees to receive S-Fest West Souvenir.
  154. Addict Motorsport Design to Sponsor S-Fest West - One lucky person wins a custom tune
  155. who's green UrSa did I see driving down Front St in Salem on Saturday?
  156. looking for new shoes
  157. Taking I 95 from FL headed to S fest anyone else going that way wanna meet up?
  158. Chip quiz for the old timers
  159. 93 Urs4 transmission issues.Lost 1st and 2nd gear
  160. 034 Stage 1 chipset impressions (now that it's sorted)
  161. Anyone know anything about the S6 Avant at Force5?
  162. I got the resonator removed from the exhaust today
  163. Max PSI for stock fuelling/ecu
  164. I just replaced my CC unit, how do you erase the error code memory?
  165. hesitation issues, compression test?'s
  166. Bad ECU anyone?
  167. Frustrating miss / cutout under no specific condition
  168. Looking for opinions on 034 coolant hose kit for S6...
  169. VEMS with stock S4
  170. Anyone have a set of lowering springs and shocks they want to sell?
  171. Rebuilding Head
  172. Cd Changers Etc
  173. Anybody have a 'magic silver box' for the cd changer they want to sell?
  174. who can help w/ a carfax??? thx in advance
  175. Ur-S Import Statistics
  176. Reminder: Colorado UrS Gathering this Weekend, July 25th. Let me know if you did NOT
  177. Anybody looking for a CAI?
  178. Vacuum Supply Pump and Power Lock Question
  179. I STFA for the diy pressure test instructions but cant find the thread...
  180. Differential Lock UrS4
  181. Stock boost UrS4?
  182. Odd Headlight Issue - 93 UrS4 (Canadian model)
  183. Cruise control vacuum pump....
  184. S-Fest West Shop is Open! Get all your gear early!
  185. //SFest 2009 Aug 29th.... game on!
  186. OT: Rally!
  187. Anyone have a Detailed How-to for Bleeding the Big Reds?
  188. Anyone from the Uk, could you help me out?
  189. Anyone actually got paid back their money?
  190. Is there a difference in the voltage reg. between 95.5's and older models?
  191. anyone have a good steering rack forsale
  192. wheres weldo?
  193. Anyone have a spare V8 torsen diff they're looking to get rid of?
  194. Looking to buy Mint S6. Anyone wanna sell?
  195. KDay, shoot me an email. I need to grab my hoist. Thx.
  196. UrS4 rear diff service?? any how-tos?
  197. Under hood temps.
  198. Decisions
  199. Rear suspension parts re: sway bar
  200. Rear OE exhaust part numbers (for EDIGREG)
  201. GT3071R to Stromung downpipe issues
  202. I have access to an S6 avant parts car.
  203. UrS4Boy...
  204. Any advice: going to have insurance co. look at my car.
  205. S-Fest West 2009 - August 15th 2009 - Registration and Sponsor Announcement
  206. 2 MORE UrS cars spotted in Stowe VT.
  207. Spotted green UrS6 in Stowe VT today....Across from Macks.
  208. Is it the "michelin man"? ..(boost leak)
  209. Need ECU for 95.5 S6
  210. G 28 Engine Speed Sensor Fault Code
  211. i think its the fuel pump
  212. xs-power.com reviews tell me what you think
  213. Car out of storage - won't run/stumbles bad
  214. I need a good definition s6 logo image..
  215. OBDI code reader?
  216. 2Bennett Brake Kit - dissected
  217. Adjusting gearlinkage Audi URs4 5spd.
  218. Which turbo to get!!!
  219. S6 Rear Bump Stops are GONE
  220. Any CPS's left over from GB?
  221. Instrument cluster wont light up
  222. Trunk won't open. Glad to be back!
  223. 105K Service
  224. AC compressor wont stay on.
  225. Running 4 cylinders I believe, need some advice to continue forward.
  226. Sunday quiz: Which wheel bolt style is correct for OE Audi wheels? Photo inside
  227. Aftermarket Remote Control Trouble
  228. Help a noob! Just bought URS6 in great shape xcept for 3-4 gears. Mechanics in CT/MA
  229. Factory 6 speed shift knob...
  230. newbie with HID trouble!
  231. on going crank/no start issue
  232. Green S6 Avant in Swampscott during the fireworks tonight?
  233. I just finished the in dash vent servo r/r
  234. brake failure - intermittent?
  235. Anyone got a link for otc kits.
  236. Vent Mount for Boost Gauge
  237. Gauge Pod options
  238. I have a bad habbit of leaving tools under the hood of my car...for weeks.
  239. Brake upgrade??
  240. Please Help....car turns during acceleration!!
  241. Oil filter change, not enough room for standard wrench.....
  242. Anyone in a state with 4 seasons running an all season tire year round?
  243. S-Fest West 2009 - August 15th 2009 - Registration and Sponsor Announcement
  244. r12 capacity for a/c
  245. What chips were available in 1995?
  246. What would you do with $10,000?
  247. 1995 S6 gas cap source?
  248. When I steer I get an awful squeal/squeek at low speed.
  249. wheel bearing replacement hints
  250. Digital Boost Gauge from Auber
