View Full Version : Audi Original "S" Cars
- Where is the fuse for the radiator fan?
- Repeater?
- Carbon cover spark plug 's head
- Gas Pedal Broke
- Guys, I need some help on the fuses correct amperage
- 20" S8 wheels on an S4
- remember the two tone interior pics from ebay. i got the same thing but reversed
- New car woes, help please
- nice wheels for a nice price.
- Who nuked the S6+ front bumper GB thread? There was some good discussion in there.
- Need a Head Set! .....
- Brake J-Hose Source? Heard $400 bucks today?! OUCH
- Tomorrow's car show should be fun....
- anyone here have the bira system 3? Did you mill the stainless caliper pins 1mm each?
- ARGH! I'm going through withdrawl!
- Lower ball joint is bad after less than a year, wtf
- I need opinions; will i be satisfied with 400-430 crank hp?
- Wouldn't you be scared parking next to an S4 on its side?
- Loss of power + weird smell
- anyone have any advice for doing wheel bearings, inner and outer control arm bushings?
- How the symthom when "POS"has gone?
- Sport Quattro Manifold- Source?
- fixed my car. i was able to extend the wires and solder everything back together
- unintended acceleration strikes again (?!?)
- Rear Parking Brake stuck
- Transmission Q
- Any UrS parts cars out there?
- Stupid Rad fan- replaced blue connector- now nothing-
- Harness Connector (Firewall bracket) List for Future Reference
- Queens, NY Black urS4/6 ~10pm last night Union Turnpike underpass you here?
- Asking again: HC to high at idle. Ideas?
- hard rain and Idle swing?
- tested for boost leak and found one which seems to be coming from ICV?
- in the process of changing my steering damper i think i ripped a wire
- Unfortunately...just my KEY is gigantic
- RS2 guys, what Bypass valve do you use???
- S6+ front bumper
- Why is it that no matter what I do the climate control comes on when I start the car?
- didn't Volvo end up buying lots of the tooling for the 5-cylinder engines?
- Anyone looking for a new audi?
- GT2871RS !!!
- Anyone thinking about selling their avant?
- where do you get a long enough hex key to remove the intake manifold?
- Nothing has broken since August 9th.
- Anyone selling Samco hoses? I'm looking for a complete set...
- Is it supposed to sound this way?
- Looking for headlights or lenses for my '93 S4, Any suggestions?
- can't pass inspection
- can someone help explain these codes please
- Coming soon, S4/6 Short Shift Package...
- Just did the VAG COM test
- UrS6 Front brake pad?
- what does blink code 2144 mean?
- Link to suspension replacement guide, if any.
- Crispy car update........
- Power Steering Signal is shown on Board, What??????
- Usefull / useless info........
- Anyone have: a stock 95 S6 gas cap and 2 stock avus wheel center caps?
- My clutch pedal has left the building
- Enjoy every moment gents, I'll be taking a little break from AW for a while.........
- where to get Rear sway links?
- What do u guys do when you need to get a key made?
- 93 S4 Carbon Trim
- i have a fault with my knock sensor. why did you guys tell me to check my hoses?
- Is there a hose missing?
- torque setting for plugs ???
- Cig lighter no worky..
- what the he!! is this?
- New Sig... No Mod listings!! YAY or NAY?
- need pics of UrS6 with 19" rims
- Transmission Axle seals and Clutch Replacement thoughts.
- 'til the season I guess...
- it's a plus..
- S4 Issues Update (Someone set us up the bomb!)
- I experienced a mysterious loss of boost yesterday
- Is AudiWorld broken or is it just me? No new posts. Diffiicult to load, etc.
- Ok this is my last question about the Radio!, I promise
- Woot Tire dilemma New Tires on order
- The real source of the "chrome" A8. Bling boys need to look.
- Any tricks to pull the radio
- ANYONE in massachusetts going to boston fishing peir gtg this wednesday?
- Can anyone make sense out of this VAG-COM info?
- KDAY whens the boost gauge come out? im desperate here
- Cool seats
- Didn't realize just how bad my tires were until I got a new suspension..
- How to wiring the Boost Gauge on UrS6?
- We lost one :(
- a little comment about fmic air flow
- New spark plug's has become black(may be it's the causal!!)
- will a 6-speed transmission be compatable with a URS?
- you guys see this? just came up on eBay
- Tom, will your FMIC fit under a S6+ bumber cover?
- if i remove the airbag safety connector do I need to disconnect the battery?
- GT500R YGM
- So I'm thinking my oil pump <may be> on the way out..
- Boost gauge mount. Too ricey?
- 1st Pic Poster attempt
- How much is it to paint a perl white s4?
- Is it possible to remove the front springs without disconnecting "ball joint,tie rod,hub etc." ?
- Nice gem found at an antique place.....
- Just replaced my steering damper...also information related to previous post
- New Canadian UrS4 owner in need of parts...
- Winter O No!.
- Attn: |skolnick : muddy pics!
- oil change
- Gettin' ready for winter 9/10/2005 Tuneup BWW
- possible to repair hotwire in MAF? Anyone got a used MAF?
- Leavenworth Run: Seattle - Vancouver Meet-up. SUNDAY Sept. 25th
- I didn't work on my S4 this weekend, but I can never escape working on cars...
- What is "UrS4/S6" stand for?
- With regards to the dyno post I had below - I've been informed that there was a slip issue..
- Just watched Transporter 2 (minimal spoilers)
- K & N
- Brake pad sensor location
- Delta -> Concert I conversion gone bad, Help!
- has anyone tried driving without the steering damper?
- My car have to go to garage every week.I need one more help!!!
- Acura TL's are tough customers and black wheels draw too much attention.
- should i unplug the battery if i'm removing my airbag to center the steering wheel?
- Can anyone help me out with a radio code????
- Well... I guess for being 12 years old and just chipped. I'll take it!
- Oil Temp Guage not working
- Overboosting - still
- OT: Has anyone driven a late '90's 5 series BMW in the snow?
- A/C fan is a chirpin ....long
- ATTN: UR-maninblack! I found a clip from the off-roading
- Quick Q about thermostat location...
- Anyone running 245-40-18 tires. Purchased some wheels off E-bay and I'd hate to 86 the shoes.
- Group Buy ??
- How hard is it to get to the heater core?
- Any one know where I can get some slotted rear rotors? I tried ecs and they are currently out.
- Dropped my baby off today : (
- Low RPM engine miss
- The ECU just arrived...
- New AudiWorld T-Shirts
- new 18"rim.Is there any problem with final drive?
- its look like our cars are truly designed for the $12 bosch plugs
- selling my S6
- GT35r and AEM EMS review!!!
- Finally have some pics!
- Let me try again.... Anyone know what wheels will fit?
- Anyone got a AAN oil pan for sale /
- Ok, I finally fixed the damn dome light plastic sunroof switch plastic thingy.
- What other Audi wheels will fit?
- Got my alignment done today. Ya, I know it's been 3 months since I lowered my car...
- Anyone looking for a project?
- PS Pump. looking for help
- What if I gotta switch S6 to 523i(E39)
- Boost leak or Boost Guage problem..
- interior door handle question
- Q for the Brake Pros
- 4Driver4....Good article in "The Gripster".....
- guy from ct at sfest witht he urs6 avant and urs4 messed up foot?
- On ebay right now: Bentley Audi Manual (Paper):100, A6, UrS4, UrS6, S4, S6: 92-97
- AC Condensor
- Join us a for drive this Saturday, Sept 10th- from Malibu to Ojai w/ stop at Old Creek Ranch Winery
- 13 years later: UrS4 vs. BMW M5 vs. 500E
- my rear suspension feels dead...
- S$%t , I just won $260,237 and didn't even play.Who wants to claim the $$ for me ,you can keep the $
- I found oil in my Bypass valve... :-( is turbo going???
- Librarian, whats the scoop with the brats and beer run on the 24th, still on?
- Due to Adriano's Email to me... It prompted me to use a pack of...
- Wastegate Screw Replacement (in case you need one)
- Anyone have a link to the Billzcat Short Shifter install instructions?
- Ok... well due to somehow winning the SRE/LWFW auction, I will be doing a clutch install.
- 17X8 35mm offset, 255/40/17 any of you guys running this???
- Where are some good spots to look for parts. More specifically...
- Are the Eibach's on EBay the correct springs?
- OK big turbo guys i finally got some cash to purchase a bigger turbo :)
- See i'm thinking about a new plate, and keeping my 4 rings on my dad's 04 A6...
- Dave F: did the Leavenworth cruise last weekend :)
- S6's Turbo glowing red....
- Samco hose clamps
- how high can u rev???
- Need help with my 1.8t coil pack conversion project.
- OT: Post a Pic of yourself...always wonder what everyone looks like
- OT: Transmission Q
- Recoding an S6 Tach that reads too low
- Snapped a pic of the "new" ride
- How are these cars in the snow?
- My latest mod:
- S4 on ebay
- if I get a hands free kit for my phone can I wire it into the factory hands free system?
- CRISPY CAR Update ....
- S6's top speed?
- Any good tips for cleaning REALLY thick brake dust?
- Cracked crossover pipe.....need replacement.
- 993tt calipers.... changing pads really as easy as it sounds? Hidden disasters waiting? Tricks?
- Will 15" fit my S4?
- Creaking from rear
- Fastest/Hottest Audi 200 EVER 200+ mph (video inside)
- Are these wheels 97 S6+ specific?
- Is it okay to leave the cooling system full of pure water for a few weeks?
- Poll: Pic of your urS4/S6 and what suspension mod you have!
- this is a good oppurtunity for someone looking for a cheap 6speed
- Is it common for the interior wood driver door trm to crack?
- Nice pic I found!
- Can anyone confirm if these values are correct?
- OK, black wheels attract a lot more attention than my old Avus wheels.
- am I just not fit to work on cars? Still leaking at the X-Plug
- anyone got an extra right outer tail light? I just backed into my dad's truck:(
- I feel much better about my car now.
- Crispy car LIVES-----sort of
- Skolnick, this one's for you...
- I'm back to "S" work!
- MAF connector question
- Anywhere to get 2 new little audi emblems that are on the side trim?
- Anyone know where I can find 1 stock wheel??
- alright since i got an influx of emails about how i detail my car here we go WAX!
- anyone ever consider using dry ice in the intake or air box?
- Need to know what porsche to buy.
- Subframe bushings, for those of you that have replaced, where to buy and......
- Just installed my RF central locking system. Works Great
- i dont know how similar the AAH with ADU engines are but...
- CHEAPER GAS WITH OCTANE Boost in a bottle !!!
- My S6 lowered with H&R 29800's and Koni Adj. <<GOOD PICS>>
- GT500R - Who's your Daddy!!
- HELP: Trans no longer going into gear
- hey emre, can you send a paypal request to me
- I saw myself on the way home - another Pearl S6
- Turning Motor Over Help...
- Parts Cars??
- Noticed something about a S6 im looking at...
- Anyone have the ignition recall number for the UrS4/S6 ??
- What OCTANE do you use with which CHIP??
- Anyone have a stock 95 S6 Avus wheel that they want to get rid of in the Chicago area?
- Anyone interested in a set of hats and brackets for a BIRA sys 6 brake setup.
- Bye Bye S4
- Stolen e//S2
- REMINDER: BROOKLYN MEET TOMORROW
- Xenon TT retro night shots!!
- upgrades question ( will sound noobish ..cause i am)
- Two n00b questions during my quest for perfect cam timing..
- That HVAC box is a bitch.
- 1994 URS4 needs some mods - what to do??
- Some more crappy cell phone pics... I want my camera back!
- Poll: RS2 Turbo/Injectors vs. Big Blacks vs. Paint
- Do you remember when you first fell in love with the S-car?
- Got HIDS?
- Hesitation is still here.
- A little update on my current look :)
- where to find clutch kit for 200 20VT?
- hesitation is gone (knocking on wood)
- BPV Question...quick
- $moking deal in Boulder.
- Bob Rivard - you out there?
- a/c woes, i hope you guys can help
- Boost gauge for...
- Pics of my new exhaust
- What if I want to remove the engine fan?
