- 1991 Audi V8 Starter issue
- 91-200-20v-Fuel pump
- chipped 1988 5000CSQT fluctuating idle
- Vacuum intake
- 1986 5000CS Chip
- Audi 200 MC2 starts then dies
- audi v8 4.2 swap into a 1986 audi 5000 cs quattro.
- 91 200 intermittent power loss
- 90 V8 for sale
- Audi 200 gauge cluster problem
- audi 200 tq 91
- Audi 200 Options (ME4, ME7, ME8, R37, 719)
- First Audi
- audi 200
- audi radio
- Audi 5000 reverse polarity
- Black Friday/ Cyber Monday deals from Car Parts Discount
- New Audi owner/member
- audi 200 mc2 10v engine info stock block power, etc, help
- 20V avant suspension options?
- 91 Audi 100 Burnt Air Filter
- 1991 Audi V-8 Quattro runs rough
- Special promotion for Audi World Forum members
- Air spring's on a type 44
- Forum group buy with Car Parts Discount
- Wut is this thing? '85 QTCS
- 1989 Audi 200 Turbo Quattro Wont Start
- rebuild 89 200tq ecu?
- Locking differential vacuum lines
- Electrical-ignition issue maybe ?
- 1991 200 avant quattro brake master cylinder
- 91 200 20vtq avant brake upgrade
- 88 quattro cs spring chicken looking for help
- 86 5k tqcs no start after heavy rains
- 1990 200 tq engine swap
- 1991 200 no heat or vent control
- 1990 200 TURBO 10V TIMING HELP
- 1990 200 QT NO DIAGNOSIS
- Special promotion for Audiworld members
- FS: 5000 TQ wheels
- 200 20v won't start
- Hi! I'm new, I just bought this 91 Audi 200 TQ! It's my first Audi!
- whats the best "older" Audi i can buy.
- WTB: steering rack
- Barn Find: 1986 CQT
- Audi 200 Turbo Quattro 1985 Rebuild
- 1990 100 Exhaust Manifold
- Miscellaneous on 200 MC and 200 3B
- Can either cranck pos. sensor or speed sensor be just faulty?
- 1990 V8 Power Windows
- Audi 200 windows
- Audi 200qt
- Starting issues--Audi 5000 Turbo
- Type44 CSQ drive train parts for sale
- Replaced J-hose, did I kill my brake accumulator?
- Audi DELTA BOSE pinout diagram?
- I finally got my A/C running. Here are the conclusions
- 1990 V8 DRIVE LINE CENTER SUPPORT BEARING
- Can a Brake bomb from C4 work on 200 20V?
- Dipstick
- audi 5000cd turbo
- Is the 1st fan speed and after-run pump work with the same relay?
- Relay questions series (V): This one´s basic. What relay goes in #1 Position for 20V?
- Relay questions series (IV): Relay for BOSE Speakers 200 20V
- Relay questions series (III): Sound system relays on 200 20v?
- Relay questions series (II): Relay for position 6 in 200 20V
- Relay questions series (I): After-run relay on 200 20V. Position? PN?
- 1989 Audi 200 turbo lag issues.
- Silver side reflector replace
- HELP! 1993 Audi V8 Quattro Automatic 4.2L AWD
- Misfire! Please help! Wet distributor?
- audi 5000 turbo break light warning
- 1988 5ktq Avant 2.3L head swap
- Window Regulator - 1986 5000 CS Turbo
- A/C Clutch Relay. Has 4 pins and socket has 5 cables into panel (!?). Diode thing?
- 1991 Audi V8 Quattro temperature light flashing
- 1991 200 Quattro Lock Housing/Lock Cylinder removal procedure?
- 1991 200 Quattro Ignition switch replacement problem
- Audi 5000 timing marks?
- 200 20v major missfire right before full boost
- New Audi 5000 owner
- Climate Control Head Unit INPUT signals diagram??
- 1990 3.6 v8 oil leak question
- looking for 200 parts
- V8 alternator
- Want more power
- New Owner: 200 20v avant
- Resetting airbag light in a V8
- 1990 V8 - Fuel return line part number
- 1990 V8Q throttle stuck open (redux)
- Looking for 200 avant driver door
- 200 vs 100 power steering and brake bomb
- '87 5000 parts
- 5000TQ center driveshaft bearing replacement photos
- '91 200 20v turbo quattro owner new to forums
- Alarm Going Off - 1990 Audi V8
- Clutch Judder
- 1990 Audi V8 Fuel Pump Replacement
- Losing steam on my winter car, should I part ways?
- '91 Avant, bad hall sensor, options?
- Replacing Starter 1990 Audi V8 Quattro 3.6
- flooding issues
- Changing rear main crank seal
- 1990 200tq 10v coolant issue
- Thinking of buying a V8 Quattro....any suggestions?
- Audi 200 10vtq treser idle and acceleration problem
- new owner of an 89 100 with issues
- T44 rear bumpers
- QLCC stage 1 chipped 200 turbo Aut. Odd behavior (!??)
- V8 Quattro 4.2 swap problem
- missing
- 90 V8 Quattro - Passenger side distributor cap breakage!
- 1986 Audi 5000cd Turbo
- Please learn me about relays...
- 90 v8
- Old v8 diagnostics-need some advise.
- 89 200 quattro front sway bar bushings?
- air conditioning condensor
- PRND321 LIT
- restoring 1986 Audi 5000
- Audi V8 93 - Lost manual and window/indicator problems...
- 1986 Audi 5000 Obsolete
- How to turn off Traction control/ESP
- new a/c condensor
- HELP BATTERY DRAW 1991 Audi V8 Quattro 5 speed Seattle,WA
- DESPARATELY LOOKING FOR GOOD RF 1990 V8 HALFSHAFT
- Car taking multiple crank cycles to start.
- looking for parts
- 1990 Audi 200 wagon randomly will not start
- 3.6 pt 32v rebuild & boost
- Installing Cd Head unit in 1990 200 wagon
- Valve Covers 91 V8
- 1992 V8 adjustable steering column-What do i need to get it done ?
- New Audi owner 1990 200 wagon
- 5 speed swap my 82 5000?
- V8 Timing Belt Cover Broken Parts Car or Builder?
- V8 parts
- Restored audi 5000cd turbo 1986
- Brake light
- Won't run all of a sudden.
- New guy Intro...............
- Transmission leak
- New owner - 89 Audi 100 quattro
- front facia swap Audi 100
- Selling 200q20v avant
- My new find...91 20V avant...with questions
- Just Picked Up A 88 Audi 5000 Any Ideas??
- 3B spark plug wiring diagram
- 1990 3.6 V8Q light throttle hesitation -- O2 sensor?
- 86' Audi 5000 CS Quattro Turbo High idle
- What kind of brakes? G60?
- 200QT Belt Squeal
- Bad clutch master, slave, or both?
- 3.6L V8 OCI
- looking for 91 200 parts and good sites
- For Sale 1990 Audi Quattro V8
- :: ECS Tuning :: Audi 80/90/100/200 5 Cylinder Ignition Wire Sets!
- Early 90's V8 Sway Bar size
- audi 5000 won't crank
- V8 4.2 auto to manual swap- Done, but something wrong with speedo.
- V8 3.6L Timing Belt procedure
- Issues with Climate control on 2 audi 200
- Audi 100/200 Fuse Diagrams
- '86 5k CS Turbo - Formed Fuel Injector Line
- looking for power steering hose for a 200
- 200 Quattro Emmissions Help!
- '90 V8Q Bomb replacement
- What is stronger?
- Help with 78-84 5000 radiator plumbing
- Audi on ski field
- Off the boat ready to do some work! Upgrades?
- trouble sourcing throttle cable for 1990 200 turbo quattro
- Wheels
- Alternaotr pulley problems
- Audi 200 Quattro Leaking Power Steering Hose
- Please Help. Another new struggle.New brake Bomb instal and brakes hard as a rock!!!!
- 91 v8 failed emissions
- AUDI V8 Book on the Market !!
- Desperate seeking answers on my Gamma CC Radio
- K24 Turbo housing expansion/freeze plugs
- 1990 V8Q Recommended battery
- brake hose for 5000CStq front brake upgrade
- Help on power steering pump 200 '89. which reman?
- Myriad 100Q running issues - so much oil in the intake
- Audi 5000 turbo vs. 200 Automatic Trans Question
- front struts
- using optional transmission dip stick
- '93 V8, 128K miles, 2342 code.
- Looking For Advice on a 3.6 V8 transplant
- bouncy throttle when transmission is in limp mode
- V8 Quattro Fault Codes?
- popping out of 3rd gear - '89 100Q
- audi 5000s won't start
- 1990 V8 Quattro - taming a loud custom exhaust
- 1990 Audi V8 Quattro Serpentine Belt
- V8Q 3.6L interior fuse box location
- Autocheck dead
- Frayed hose on manifold, what's this?
- Wet Cylinders
- high idle (sometimes)
- 3.6 V8 PT fuel
- 1990 v8q new owner!
- 200 Quattro clutch disengaged, pedal stuck on floor
- bolts on underside of the master cylinder?
- Buy audiparts from US but where is Keith Tackett Suffolk?
- Replacing master cylinder--any hints?
- Build your own Hybrid Turbo?? is it possible
- BOV on 10v
- Normal boost pressure ?
- shift linkage parts 86 5000S
- clutch bleeding 86 5000S
- In gear, but car still moves downhill
- Do 10v turbo chips still exist?
- Engine Vibrating
- 90 v8 Quattro Accumulator Hose Leak
- 20V is totaled...now what?
- Where to find 200Q 20v dizzy cap?
- any one interested in Audi V8 literature ?
- 200 10vt turbo replacement
- Bentley manual for a 200
- Longtime lurker popping back in to say hello!
- Wheel Fitment question
- Starting Issues...please help
- Can you guys help me put a value on a 1 owner 91 V8?
- anyone been ripped off from v8 parts car on audifans?
- Hot/Cold transition climate control 200 20V
- Just got a '90 200 Quattro Avant
- Need Local 1992-1994 Audi 100s for 3D Scan
- Done with everything, car will suffer from 4000 rpm
- 1985 5000 KH turbo
- MORE HELP FROM THOSE THAT KNOW
- 1980 Audi Diesel
- Rear passenger door won't unlock (86 5000CStq)
- Need HELP
- Need HELP
- alternator belt PN or size(s)?
- '90 V8 Spare Tail Light Left Outside
- Brake pressure fault?
- knock when foot off of brake when running or not
- 86 5000s 5spd tough shifting 1st & 2nd
- Flywheel Timing Marks?
- '86 5000 S Automatic, No 2nd Gear?
- I5 Swap or overhaul?
- eating alternaotr belts? replacement pulley?
- Releasing ignition/timing sensor wires
- audi 100 2.2l in china
- Quattro Ecode lights anyone?
- '90V8 Oil Cooler Hose Removal
