- Help with sale price on a 1991 200 20v, 120k miles, two owners
- Will speedo limit boost??
- what's a 1990 200 20valve with 157k worth? there's one I may be interested in...
- To be or not to be......
- Looking for a few parts for 91 200 20v...
- Do not use water to clean carbon from motor! Big pic warning.
- Hey all... Just a quick new year reminder for troubleshooting...
- Turns over 1/2 dozen times to start
- one last differential question..
- Current Draw problem in my 87 5000sq
- Today's encouragement...
- Angst: V8 Quattro vs. A8
- Happy New Year AudiWorld
- who ever came up with this should get shat on
- where do you fill the rear diff , I think i found the drain plug but where to refill?
- beep sound after starting and start to move
- Good Fun at Gruppe 1
- has ne1 ever have to adjust the linkage on an auto transmission?
- puzzle me this: no start between 3.5 and 5 hours off
- v8 clutch quattrotrac may know a answer
- Remote Starter
- calling boxerfan!!
- Fuel tank repair and more...
- Tried to buy a '91 200 FWD 5spd
- Rear Wiper on a 91 200 Avant? Was that standard as mine does not have one.
- Need more info Cruise rod?
- checking cold start valve spray...
- help ! stranded far from home with with no brakes
- Rear Differential Oil Leak - 200 10V TQ
- Throttle snaps open when i switch gears. tps?
- Audi Drama. Blown Engine. Suggestions?
- 89 200TQ MAC14 ECU, CEL illuminating under acceleration, how to extract code?
- WTF, my info cluster says " Brems licht " what the hell does that mean?? 90 200 TQ
- Is there any aux air valve on MC1 engine? Got 2000-3000 rpms on idle :-/
- need a new fuel filter....where...any recommendations
- Need a motor diagram or something like that! please help!
- ABS pump running?
- Good used 016 tranny coming out next week-$50 plus pick it up, and it's yours. In Maine.
- Make your travel plans to Germany NOW! Autobahn speed limits might be in works...
- V8Q tranny whine
- Anyone know dimensions of the front grille V8 badge?
- just curious, how do you know if your heated door locks work also
- Drat! Throw Out Bearing is Howling. Time for a New Clutch.
- Brake Buzzer
- What's this transformer in my V8Q's relay box? And this plug?
- Lookin' for wiring diagram of MC engine management..
- idle stabalizer valve buzz....
- hood latch ......
- 91 200q20v for sale $3000 obo
- Simple question...
- Thanks, lads..
- A new Type44 movie sighting
- Interior Lights turning on and off while driving ?? -- 5K CS Turbo
- new boxerfan chip update...IC is strapped!
- WTB: Audi 5000s Quattro Passenger Front Axle
- propeller shaft and carrier bearing - mechanic issues
- 1st and 2nd Gear hard to Engauge
- LF: Idle Stabilizer Valve for '88 5KTQ
- 91 200 20v Samco Hoses-Where to get 'em cheapest? TIA.
- Need more power... need Boxer Fan
- Help Removing my Steering Wheel
- 5000 exhaust...
- WTB used 200TQ coil
- 5000 Question.....
- 86 Turbo CS Wagon...Fuel Pump...
- Losing some pep, fuel economy in my 90 V8 Quattro
- Gotta love newbs...
- Engine question
- so, where does the boost guage on a 91 200t get it's reading from?
- 200 20V on long hills and under full power will miss, jerk, briefly especially in 5th gear under
- Merry Christmas my lovable forum :P
- No start Issues...
- new boxerfan chip installed
- Cooling system malfunctions
- how/what does the INT control switch on V8 Wiper/TC stallk work?
- Picture of strange part
- I figured this would be a change of pace..
- has ne1 replaced the fuel accumulator, pressure regulator, and ne other fuel related part with good
- Relays anyone?
- since others are posting new to them Audis
- Slight Hesitation - 1990 V8
- Are we still able to say Merry Christmas?
- Vintage Audi Brochure
- Merry Christmas to the best group of guys and one girl :-) please read my disclaimer
- New member of the family...
- What's the difference between 5000 and 100/200 door latches?
- Name that strange part...
- Looking for 5 spd tranny in CO
- 200 20v pressure plate: how much tq are u running on stock?
- Help, anyone? kinda long -5000
- Anyone fitted a reciever hitch to a 5000 Wagon?
- Why does the Wii remote lawsuits remind of the the whole "unintended acceleration" thing??
- Monroe Sensa Tracs: good OEM alternative?
- MYSTERY WIRE
- audi 200 avant driver sid taillight lens
- 200T Trip computer / boost gauge / door lock operation?
- Dont know what to get your wife/Gf for x-mas? Here's an idea....
- Do i buy radiator fan motor or the whole fan, or should i go to junk yard
- 1987 Audi 5000CD TQ
- He's MINE!!!!!!!!
- so heres my problem ....
- Anybody know this car/owner?
- Any of you guys submitting offers on this? LMK
- Cold start- high idle issues
- Exhaust Manifold--Missing Bolt!
- does ne1 know where the boost guage gets it's reading from? mine has been at 0 for a long time
- Engine battery terminal connections?
- Gauge advice
- So anyone here from CT/ MASS / RI / NY around next week?? (forum meeting)
- Anyone want a Pearl Fuch Wheel?
- Auto Trans Cooler source?
- Vibration when cornering at low speed
- Audi V8 Quattro PART OUT
- Leaking steering rack, Replacement cost? How hard to do?
- Trip computer stuck reading 0.7 bar
- This New R8 is certainly stunning
- Need advise from the pros
- Climate Control Question?
- How much is the car worth?
- top starter bolt!! why do you evade me?!
- '91 20v g60, need new rotors and advice
- occasionally rough running right after hot start , usually smooths out
- What now?
- 90 200tq wont idle after high revs
- suggestions for drive axle replacement | half shafts |
- What could cause a sudden increase in fuel consumption?
- what size is the small bypass hose just under the bottom radiator hose on a 91 100
- can someone post the procedure to remove driver's side headlight?
- 200 10V TQA update - V8 brakes, fuel leak, oil pressure, and clutch
- so if the i turn the key and the lights all turn on but the car doesn't attempt to crank ...
- Getting fast blinker but all bulbs work.
- Any brake fluid leak BTDT?
- Going from B6 A4 to 200 experiences....
- Where is the WUR located and anyone have the part number
- alarm question
- 200q20v flywheel timing window location?
- climate control not working fuse keeps blowing
- Spotted a black 20vT Sedan in Chicago....hot!!
- Blinker relay replacement walkthrough? BTDT anyone?
- 1991 200 20v dist. cap replacement tips
- warm start issue ?car always starts but idle drops and runs rough
- I have brakes again, changed the bomb today (pretty straight forward)
- Today's humor...
- 1991 100-Q
- How much time do I have left?
- fiberglass taillights
- ha ha, just destroyed an 02 civic si ha hahah
- now this is a hint that u need to replace your shok absorbers (also a smal alternator question)
- Has anyone used a non Audi heated seat element for replacement?
- radiator fan relay question
- Using a DMM - Need to Test Battery/Alternator
- E-code Headlights are LEGAL in Canada!
- I feel the pull of The Dark Side
- 5k shifter boot ?, does semi circle plastic piece go on front or back of shifter
- Low Boost Pressure? Any advice welcome.
- Still looking for...
- Anyone have an extra set of CIS injectors for a 5ktq?
- as much as i love audis i hate my car..
- Need some advise
- Avant vs. Sedan springs
- UFO brake Q's
- Will Never Change Oil Viscosity Again!
- I think my Steering Rack had a stroke...
- Need Brake help with my 5000q
- I want more power
- Will I burn out my heater core running the heat with a broken blower?
- '87 5000TQ on Craigslist in Denver
- 200TQ 20v vs. V8Q (questions galore)
- trouble with 86'audi.
- V8 Bilstein sport shocks (12mm thread) should fit on a 5kqt right?
- Audi V8 Quattro
- UPDATE-Intermittent no-crank problem....
- Clutch job on a 200 20v turbo?
- 200T: Dead auto trans questions
- wanted , working I.C. for 200 tq 10v
- Strange check engine light
- Ignition switch in Bentley is where?
- Jamex lowering springs just added to Classifieds section
- Just a rant...
- 89 100 on way to crusher anyone need parts whiles its still in garage
- quick question: will the rear shock absorbers from a non quattro fit on a quattro??
- Freeze plug? 87 5000 cs.
- Fuel Pump Relay
- I am in tears!!!! sniff sniff...I just had the most amazing ride in this V8!!!!
- Opinions on broken flywheel teeth??? (3b engine)
- 86 5ks Weird Shifting Behaviour
- any temporary fix to leaking power steering rack....or just keep toppin off
- new member here! need feedback please 91' 100Q 2.3L NF
- V8 Window Sticker
- Winter quattro Haiku
- And you think you have had a bad day!!!
- Do any of you know of any Audi Buffs coming to Missoula for the 1A football game today?
- Radiator replacement.
- High idle problems, right around the time it started getting cold out my 86 5k TQ started to develop
- How much is an 87 worth?
- *SPROOIINGGG!!*
- Anyone interested in a trans and rear diff with 4:11 gears?
- Help: non starting 5000
- The ski Car is now ready for the winter .
- Anyone here in need of a tranny?
- Crazy video of a UrS at the strip
- Somebody buy me a Touareg please......
- Is the lower 'dash tray' on the DS of 5k's compatible to other models? I like it!
- Advice needed on 86 5000CS quattro wagon
- Auto-Union Race Car to fetch upwards of $12 million...
- Idler Pulley?????
- 89' 200 TQ..Oil can... fault needs cleared to go away? (long)
- A possible steal?
- Anyone from Akron at EJ Thomas Hall tonight?
- steering rack leakage....making me angry
- turbo coolant line busted anybody know how much cash
- reading and inside lights of my A100
- a recharge for "bomb".....what are ur opinions
- radiator for 200 20v
- coil spring question
- Anyone looking for a 20V Avant?
- low mile nice 89 200 for sale richmond,va
- Where can I find an exploded view of the under side of my dash?
- need front spring ASAP!!!
- Cold start trouble - 87 5000S
- 89 200tq, Trying to track down occasional no crank issue....
- Trying to figure out exhaust options for my new 200q
- Wheel/Tire Compatibility Question
- Giving Away old cars
- Alright...alittle frustrated; 90 Turbo Quattro starting problems
- Please help-200 heats up, then cools down and gets COLD!
- Paging Dan Adam.....
- Got my 5000 home..
- I sold my '91 100
- first cold night, having some trouble with the start
- Fogging int windows - how do I open the upper door?
- 89' 200 TQ...trouble idling, staying running.
- Any tech write ups for a radiator replacement for a 87 5k
- Anyone have any good ideas to eliminate vibration from dash speaker grates/covers?
- 200Q20V rear brake differences
- Slow speed problems
- Coolant sensor
- Ok, it's time for my episodical update on the Heater (for those that have followed)
- Non-Turbo 5000 quattro????
- Applying sound deadening to doors
- Oil seepage .....
- 87 5k Question???
- help...5000cs repair manual....fax/scan...?
- wheres the best/cheapest place to get a repair manual for...
- Rear Suspension Creaking - 200 10v TQ
- '93 V8 Struts
- New Clutch in 200 vibrates some on innitial let off of clutch pedal. Is this normal?
- Electrical Grimlins, all warning lights blinked on and shortly after the engine died
- 5000 TQ for sale w/ parts car $1000, Calgary ab
