- Never seen these Headlights before
- Pics from Petit LeMans (Road Atlanta)
- bpv on stock cis?? is it possible?
- Here's one to think about.....
- Engine Type Designations
- Tie rods: same L&R side on Type 44?
- '91 V8 if anyone is interested (Craigslist)
- are 100 insterument circuit boards all the same ?
- Turbo conversion A success !
- Does an Audi running on low boost risk damaging the turbo in any way?
- just joined the family
- Non-functioning Delta Bose radio
- Audi's Ferrari killer
- LAST CALL: ACNA 2-day track event @ Willow Springs (Oct 9-10)
- 92 100 Quattro Automatic, transmission reliability? Mother needs new car.
- How much coin have you laid down on MODS? How much time doing/planning this modding?
- 5000cs turbo quat, will stock b5 s4 17x7.5 et 45mm avus wheels fit???
- More on the hydraulic system
- 2 AUDI 5000 Wagons for parts
- Oil accumulation in intercooler hoses...
- anyone know what to resolder in the I.C. to fix my tach, info center and trip comp.
- 89 200 TQ finally running great!!!
- Ummmm....I normally like the wagons but...
- Hydraulic Pumps (Rebuilt)
- Fuel Pump for an 89 100
- Higher end 4" seperates for my 89 200TQ, any ideas?
- anyone in upstate ny area want my 89 200q avant?
- Best place to get a "bomb"?
- LA-SoCal Peeps: Best place to get rims refinished? thanx
- Why you shouldn't paint your car.....
- Yayy- new heater core installed- now- dash light question!
- Transmission Compatibility?
- Cruise control rod & bushings, dealer only part?
- Almost time to put the toys away....
- strut housing/assembly question
- QLCC code or chip?
- 1991 200q20v: 15.7 mpg around town.
- Front springs question.........200tq
- well im back for good!!!!
- You'll all have to excuse me...
- Three cheers for new(ish) starter.
- A nice piece for the 20vt guys
- Question about lights .........
- Powdercoated my wheels
- 200 Vaccuum hoses HELP PLEASE!
- No spark on a 91 200tq, looking for idea's on what to check...
- Calling Boxerfan if you've got a minute ....(or anyone else who has an idea)
- German spec headlamps : Where can I find them?
- 1990 100 Avant Auto poor fuel consumption
- Headlight protectors
- Ordered a new heater core today- ugh- any tips (I've found some stuff )
- Two New MFTSs and Still No Gauge.
- k24 vs. k26
- **Hartford, CT GTG - Tomorrow - 9/27- Forecast is 73 degrees and sunny!
- TONIGHT: L.A. GTG @ The Stand in Encino (SFV) - 7:00pm
- New 5000 (to me) start problems please help
- What are a mint condition set of forged Bolero's worth with almost new Pirelli Pzero Nero's?
- I always hear talk about intercooler straps, but where do you buy them?
- Does anyone have a . . .
- 89 audi 200tq parting
- 1.95 BAR MAC 14 ECU F/S
- Best "straps" to use for intercooler?
- Rear Brake question. / 5000 qt 87
- nf head swap yet again
- MFTS - Bad Out of the Box?
- anybody got pictures of a 5k/200 with avus 17" S4 rims on it?
- just one more question about my oil, i promise no more after this one
- So heres a stumper ..........
- Fixed low oil light - thanks.
- today is a big day for my audi (see picture)
- This needs a new thread, still having bucking issues
- Source for K26 rebuild kit?
- This board is a God-send . . .
- Tall pins on flywheel????
- Ok, setting duty cycle. Im confused, please help.
- fuel filter 200 20v
- quick oil filter question
- So now the A/C compressor won't run...
- Upgrade order? new turbo or new exhaust
- just wondering , why my oil gets dirty so quick???
- New AW STFA Avatar =)
- Injector seals
- NAC. Transplanted organ. As in Hugh Jorgen...
- MFTS Pigtail
- cv joint
- REMINDER: upcoming Audi GTG @ The Stand in Encino -- TUE Sept 26th
- Subframe bolt pn verification
- Clutch problem continued
- '87 Audi 5KTQ for parts
- HID bulbs - do they make any difference to crappy stock lights?
- Shift knobs: Can we still get the faux leather ones? p/n, where, etc, thanks
- Can someone confirm what year the 200's start using the K24
- 4.2 V8 trans and engine
- V8Q - no acceleration poor top speed
- Anyone here who wants to sell me a BPV set up for my 89tq (10v)?
- oil filter gasket "kit"
- Switch light issues
- For Pushbutton Auto: My video
- BIG..price drop...(2) 87 TQCS's
- Trim Strips above/below Grille - 1989 200 Turbo Quattro
- Thought the 200 was running OK...
- 89 200TQ, 200T FWD Automatic, ECU differences?
- Clutch Problem
- Windows and sunroof not working at all
- low oil light
- 200 Quattro - Low Miles FS
- Nice to see type 44's being represented in this video:)
- Update on poor running 4ktq (please read)
- Rear Crank Seal - '91 200 T Non-Quattro
- the new baby
- Hot start issue...any thoughts?
- Cleaning out the garage a little bit, if anyone needs 5k/2c stuff
- Cooling system Episode ???? About ready to give up on this car
- anyone know much about the early 80's 5cyl diesel?
- v8 instrument cluster
- 89 200tq won't accelerate past 5000rpm, hesitation
- nuff said!
- Seat memory again
- anyone rallycross?
- Will OE wheels from a '92 100 fit my '88 TQ?
- Any interest in FrankenAudi 2.0 chips and springs?
- Finding Used Parts
- high idle on a 5k tq
- what you guys think of this...
- If you're thinking about upgrading the rear brakes to the V8/UrS vented setup...
- Anyone have an 89-90 200q for parts?
- 87 5000CSTQ back on the market - may part out the ECU/spring
- Having my wheels powder coated. Color?
- V8 wont start up
- O2 sensor fault code question
- rear muffler for '89 200Q
- Waste gate question on a 89 tq .
- 5000 Turbo conversion ...running way to rich MC1..need help please!!!
- Crack head?
- Clutch pedal, to the floor... F@$k
- the iggy switch was the culprit!
- Super Trooper Alert!
- Another type 44 disected for parts...
- 200tq, front strut R&R, add oil(tranny fluid) to strut housings or not?
- Found the leak .... 89 100
- cracked leather on steering wheel fix?
- Been busy one question
- So after .........
- Source for rebuilt fuel distributor
- Hoe does the idle stabilisation system works....Trying to understand my idle issue from the bottom
- how to set the seat memory ?
- Alternator Bracket - 1989 200 Turbo Quattro
- Ever chuck a 2113 and have your Hall Sender & Timing spec out?
- V8 dash light issues... and more...
- Valve cover gasket
- Clutch failure
- ut oh ..........
- A little off topic (BMW)
- Update on crappy running 4ktq
- Tranny Fluid ...........
- Arrrgggggg!!!!!!!!!!!!!!! Just missed a 5spd V8 for $4500 cdn
- IA CHip
- For those with a 200, I have a question
- V8Q Self Check Question
- Whats the 'official size' of the vacuum lines..
- Need brake input from experienced or someone who knows this
- What's your opinion regarding replacement shock absorbers?
- 2nd speed radiator fan a no-go, and I can't find the after-run relay
- Scored some neat stuff today!
- Source for Power Steering Pump?
- 89 200TQ, 89 200T Automatic, grafting front end frame rail/inner fender?
- V8Q - Oil Pressure Gauge Question
- Let's hope the Feds don't mandate the deletion of a manual ESP on/off switch...
- 1st Ottawa Old School Audi event / Sept 17
- radiator replacement-ugh! Fan question
- Alright... who are you pearl 20020v near Lyon Colorado today.
- Is the windshield the same for the Wagons and the sedan's?? Thanks
- pondering over driveshaft noises
- climate control gets BRIGHTER when i turn headlights ON
- OCT 9-10 : 2-day ACNA track event @ Willow Springs (not Streets). Who's going?
- Part number needed for 1991 V8 fan bearing
- Need help with my 200 Instrument Cluster... I'm gonna lose it!! (long)
- Who ended up w/ Steve Kibble's (AW - Audi200tq ) old '89 200tq?
- Calling itsav8-Ron-shoot me an email when you have a sec. Thx.
- POLL: NF / NG / AAR engines.. how many have had problems with this motor?
- 91 avant 20t brake and suspension questions
- Denver Folks - anyone want to get together for some beers and conversation?
- Da'Lan Hitch install advise?
- 91 200 for sale near me
- Audi 200 sport seat
- Audi Delta radio
- Talladega baby
- looking for Roosters ? tip on roof lining
- 3rd and 5th gear noise 88 5000TQ
- 200 Instument Cluster removal? Need to take off the steering wheel?
- FYI: Parting 200 20v in Aspen ad on Audifans has wrong email addy
- Headlight issue
- WTB fuel pressure accumulator 88 5KCSTQ
- ghosts setting off my car alarm last night?
- The Denver Trip from Boston in the 20v
- Jim Bush...is your wagon still for sale?
- Instrument cluster question
- soooo now my tach , trip comp. and warning sys. stopped working
- Ignition switch replacement - 200tq
- 200 to 5k compatibility, brake bomb
- power steering hose leak
- 1990 200 turbo distributor cap rattle/buzz
- 1990 200 Turbo quattro stick wagon - For Sale?
- 1991 200q20v: p/n's right and left e-brake cables please? thanks!
- Does anyone on here have a 5spd fwd trans. f/s in Ontario?
- Solution: Lowbeam (only) inop; euro
- Head Gasket prices from local shops
- kinda stupid question
- digital display out on V8 Quattro
- 1990 audi 200 turbo (not quattro) overheating
- So where is the wastegate exactly
- 89 nf engine, almost impossibe to restart.
- 20vqt to 5kqt Transmission Swap
- Needed ASAP!
- Very nice. No affiliation.
- Calling punkbomb-James I need a euro p/n from your car.
- HELP - V8 starter Re & Re...
- Can someone with European ETKA pls look up a p/n for me?
- Slightly OT, but of general motorsport interest: rally driver killed
- no spark issue..
- any groovy ways to turn off the "burnt-out bulb" display?
- Sorry to hog the board... but its project time. Oil question - synth to dino back to synth... okay?
- empty button slot with connector?
- Well... I think I am ready for the cross country journey after replacing everything...
- Whats the pattern for unbolting the head and putting it back on and what should it torque to? Thanks
- I know the V8 seats fit the 200q20v, but isn't there a seperate connector for the rear seat heaters?
- '91 200 TQ Avant For Sale
- New Audi Owner
- 20vt radiator...?
- When installing hoses to heater core - which hose goes to the top and bottom?
- Anyone have the part# for a VDO ISV for a 200T?
- New sony head for the V8...but no sound!!!!!
- 3/4 up the temp gauge @ 2500 rpm highway on a 70 degree day? (long)
- Los Angeles/San Fernando Valley locals, new mechanic shop:
- Tool: Tee Wrench P377. Anyone know what size that is, in "mm" or inches.
- Does the CSV flow at WOT?
- Still having 3000 rpm idle speed!!! I'm a bit desperate...Help anyone...Longish
- 1991 100Q for sale, $2495
- ETKA
- Anyone know the hex dimension on the 2069 tool?
- 1991 200Q20V. Detonation under load/low rpm/hill climbing. LOTS of ECU retard felt.
- 1991 200Q20V. a/c compressor wont engage. Low speed fan engages. Disconnected the MFTS, no change
- Hood release cable broke?
- Just bought a V8: questions on interchangable parts
- does this resistor/chip work? on ebay
- Transmission/Differential Maint.
- New Parts!!! WOoO
- Can someone confirm the amperage of this alternator
- Tons of stuff - cheap/free
- blower control module
