- Brake pressure accumulator (aka bomb) replacement last night...
- HELP!! Weird cold start problem 1990 100Q
- Need to pull diagnostic codes on my '87.......
- The right spring? also a quick question
- Power hesitation under WOT
- 5000 sedan to 200 wagon bumper trim piece compatibilty?
- long cranking cold-start issues on MC2
- Anyone ever put a Ford 5-liter into a Type 44?
- anyone got a used foglight laying around
- So how would i go about tricking the ecu not to cut off fuel?
- anybody know where to buy stiffer wastegate spring
- Follow Up To: Wheel is pulling badly to one side when I accelerate/deaccelerate
- "ABS Off" Light - On All The Time
- 1988 5000S Starting problems
- 100 Radio Question.....
- Where can I find 200 sport seats? Will A6 seats also fit the rails?
- How to pull codes
- steering rack input shaft
- still starting w/ an occ. blue cloud
- small successes! inspiration for those with electrical problems
- Anyone need a 1989 200 TQ sedan? I need a driver.
- CC head
- Universal O2?
- Need a Type 44 Rear Wiper Moter for my Avant........a '91 200 TQA
- Clutch versus Slave Cylinder? My 200 20V clutch often needs to pressed to the floor to disengage
- Can someone check their 5k Bentley for me
- On a side note....
- Power steering prime?
- convert the A/C system or not?? also a cruise controll question
- wtf? car starts mint runs mint but dig. boost guage reading .5 at wot!
- Anyone successfully used a Dent Wizard or other paintless dent repair...
- trans
- Pressure Transducer location
- Hesitation
- boost gauge question
- Anybody need a Fuel Pressure gauge kit for the 200 20v/UrS4?
- clunk felt under car when i hit the brakes fairly hard any ideas
- $5k (CAD) for an '88 Olympic Edition?
- 1990 3.6 V8 Hot Start
- 87 tq, need help with performace ideas
- Anyone have a fuel accumalator?
- So I think I want to buy a 200 TQ avant,, what can I do to it??
- 91 q v8 engine swap
- [SAT Aug 12th] Special event for SoCal, Tour of the NEW Audi Design Center in Santa Monica
- Does anyone know the exact pinouts on MAC-05B?
- Older Audi Club ( Ottawa ) 80's - mid 90's
- Need help interpreting A/C readings
- Running rich/slight stumble
- Hood cable snapped, I did a search but I need
- You won't believe this!
- Anyone else see this on AudiFans?
- Poll: Who's using a LWFW on their 10vt, and which one are you using?
- WTB: 5000 Quattro Turbo flywheel + Pressure plate ....
- Parting out EFI'd 87 5kTQ
- maintenance sched. for '81 5000s diesel
- PROCON-10 - How the heck do you pull the tranny???
- Save yourself a major breakdown...Heater valve catastrophe...
- '87 5000..........A/C sometimes blows cold............
- 5000's for sale...
- Video: Adam drifting at the local Autocross
- I hate Turkish hackers....that is all!!
- total newb mechanic about to try timing belt on '91 200 20v, tips?
- Effects of installing non-matching tires on the Quattro system
- What's a '91 200 TQ Avant worth these days........
- Audi question of the day - cold oil cooler
- Boxerfan, whats your e-mail?
- itsav8 and audiv8
- Just a question re: NF head on Mc block, take exhaust valves from MC head
- 1.9 BAR spring.
- Eprom information
- Leaky Rack?
- V8 Radiator R&R
- doorlock question
- Headlight Woes
- Rebuild of lower hydraulic hose (power stearing pressure hose)?
- Nice Pearl Fuchs FS in case anyone's looking.
- Replacing ignition tumbler... does this activate the switch?
- 5000 help: weak idle
- Front brake upgrades
- I need a couple of items: 1) a non-leaking Turbo metal coolant line part # 034121497a &
- Factory CD Changer in 5k's?
- Got her running,Guys.
- So I cant seem to find ..........
- Clutch without lift
- Anybody chip & wastegate upgrade their 1990 QT 200?
- My 1990 V8 Quattro
- O2 sensor time?
- will a 5000 windshield fit a 91 / V8 ? both are 44 body style ? kind of .
- Okay, now I've seen it all, a 5k in the demo derby (turn sound down at work)
- sell or upgrade?
- Looking for new wheels, 87 5k
- somthing is wrong
- Knocking noise from front left tire on turns..
- anyone have a spare air-temp sensor
- Changing steering wheels... what do i need?
- Did anyone get the A3 brochure on Thumb Drive?
- Final Notice! Old School quattro gathering this weekend in Cumberland, MD!
- Wheel is pulling badly to one side when I accelerate/deaccelerate
- Misc. Temp issues in Audi 200 Aut and 20V
- Getting only 15 MPG in the city and 19 Highway on my 20V 200. Could Fuel Injectors cause this? Tune
- 5000S Sedan Woes
- K so this voltage draw thing ..........
- hey, Finally ready for a Qlcc and 1.8bar spring, where to find?
- Here are some pics of my "new" 20010VTQA
- Be wary of Hall Sender Kits from that Wisconson company...
- Heavy acceleration above 3000 causes check engine light
- parts source
- 1990 200 qt 10v- radio, front cig lighter, tach, speedo, trip comp intermittent
- Someone buy these nice 5k s euro lights/clear corners for $50 already! No afiliation, blah, blah...
- Hey jurq, this may be the solution to your oscillating idle problem...
- Will a MC auto tranny 'bolt-on' to a KH motor with auto tranny? TIA.
- Havent i seen you somewhere?
- Mmmmm...Crow!....(Katman gets an assist on another one!)....
- Looking to replace my black seats in my 91 200 20V. Which model Audi will swap out the easiest? A6?
- Driveshaft CV joint replacements?
- Found a Type 44 on ebay, WI anyone?
- Update, 200 10V TQ clutch/running issue
- So I replaced the Hall sender with a oe brand new unit. The only hiccup during...
- Some people tell me this is way better than STP Jet Fuel Injector Cleaner... thoughts?
- 20v woes
- air conditioner woes
- Any of you brothers mess with Alfas and Bosch L-Jet?
- any of you know where to get this part?
- Need some help/ideas pls guys-
- What is a snub mount?
- '92 100 electric oddities
- Lookin for a Fuel dist... I think
- Does everyone use Rain-X (or a similar product)?!?!?!?
- Epoxy... Which kind do you use? The different types I've used all fail.
- Adam's turning 23 on the 23rd tommorow:)
- Could Audi have found a better place for this filter?
- Update - Remember the Strut mounting problem I was having?
- anyone want to buy a slightly used greddy profec b boost controller
- I need takers by Monday... then it's all gone...
- Can someone please edumacate me on what exactly the MFTS does wrt...
- Well... I went and did the brakeline to the front driver's side with a double flare tool
- Bypass Oil Filter Addition
- This is one handy gadget!
- Dear Audi god's thank you for saving my baby!!!
- Oh maaaaaannnnn.... And I just culled the herd down to 2...
- Looking for leather pigment...
- What do you guys think the value is?
- Nice t43 5kt fs on ebay. No affiliation whatsoever...
- 91 200 20V Turbo running temp is just past midway point on guage? Wagon is at 1/4 point same engine
- Is there an adjustment screw on the fuel gauge in a 200?
- I hate brake lines. Who's done their hardlines? I need to do one ASAP. Also, where to find parts?
- 80s thru 91, 100
- Different throttle bodies for MC engines?
- 200 10V Gods, quick question
- Update: Fear, loathing, shouting, swearing, crying, and then... Joy. <long + BWW>
- mobil 1 synthetic vs. pentosin 7.1
- radiator source
- Does this sound like 'horse hockey' to anyone else?
- various audi problem
- Oh... and I almost forgot... had some fun with a new GTI last night
- I'm know nothing about A/C replacement, never ever had a car w/ AC...
- 1st and 2nd gear are getting hard to put the car into gear (87 5k quattro turbo)
- Cross-post: Recharged '92 100 A/C with new EPA approved R-12 direct replacement ... R-420A >>
- Anyone looking for BBS RC wheels and tires?
- various audi electrical problems
- Looking for V8 H&R springs for sale
- Can we use some parts from this Ferrari on our cars? Seems like CIS to me.
- Anyone familiar with the 2 Megasquirts ?
- Thought I'd share my past weekend project.....
- Fuel system leaking AGAIN....
- 1989 Audi 100 - Automatic
- V8Q hardcopy shop manual set -For Sale
- Cylinder head question.
- V8 running temps
- 200 20vtq question: Where is the...
- Anybody pressure test IM for leaks?
- A Midsummer Night's Audi GTG Boston Area August 8th
- Dumb AC Charging question...
- Re: RADIO CODE - How to finally.
- fixed wierd boost on trip computer
- Avant owners please help.......stuck rear wiper....
- Rough idle questions....
- Fix for some board computers.
- Hey boxerfan when you get your new distributor rotors for the V8 can
- 90 200 wagon headliner
- rubber cover on injector lines?
- Trick for inserting injectors?
- Death for the cause.. (~Visiting Listers)
- Audi 200 Door Lock .Problems
- What, exactly, is Duosound?
- Shokan: X-Post
- Are the Bentley Manuals still in demand?
- Radio wiring......
- Adding Mobil 1 today first time since......
- Are All Strut Mounts Created Equal?
- Starting questions for a 91 200 Quattro
- fuel line???
- side mirror removal
- anyone have a how-to on re-setting airbag light, 200tq??
- 200TQ/V8 seats
- fuel pump????
- Parts interchangability: 4.2 ABH V8Q and 200 10VT?
- Gator Grip = Best invention Ever!
- Ronal 17",--$129
- Really remedial question........
- 200 TQ brakes
- OK, question to the turbo gurus:
- rpm sensor...
- Unfortunately, it's time to let my 87 5kcstq go.... any interest?
- HOLY COW!!!! Try tuning up a V8!!!
- Anyone need trunk badges for your 5k?
- Alright guys...heading out for NJ tomorrow morn...
- What is comes down to: 1987 Audi 5000 Woes - (loss of power)
- A/C wont blow hot,.
- New Audi Parts !!!
- Where to get silly little light for the key?
- have a question for you guys
- time to change my sig pic dont ya think?
- rivet/guide in driver's window, how do I replace?
- Looking for info on 5000 transmission gearing
- Anyone ever lose a CIS fuel injector nozzle in the insert before???
- double the headaches, but double the fun...
- For Sale - 1989 Audi 100 - Toronto
- Same problem as "I'm no pro" top strut mount just not right
- 3b engine in "limp mode"....can anyone help????
- Help - need wiring diagram for the radio on 89tq sw
- Wastegate diaphram RR complete
- Anybody have an active Carfax account?
- 1984 5000 subframe bushings replacement?
- Has anyone converted their 5k/200 rear solid discs to the later V8 vented setup?
- RADIO CODE
- Mobil 1 / Pentosin Leak Update
- Hard Starting warm, sometimes cold??? Runs good
- How does one go about buying an ETKA CD?
- I find this funny. How do you do this much damage backing into a fire hydrant?
- Watefest
- Timing belt change!
- Da'lan hitch for sale.
- Is the 5ks non-q fuel tank/sending unit the same as 5ktq??
- HELP... RPM sensor location on a V8?
- MC1 Head on a MC2 block
- Strut Mounts - Have a look is this normal
- After a tough event at Infineon, STaSIS heads to Miller Motorsports for round 5 of the SPEED WCTC.
- Alternator questions.....No battery light with key in on position
- V8 Emissions woes
- Damn you! Damn you Audi Gods!
- Let's talk power steering hoses:
- A/C Question
- Help needed
- 1990 200TQ Speedo Drive Gear
- 86 5kcstq back on the road again!
- audi 100 repair cd
- Put a remanufactured PS pump on my 5000, it works great but the brake alarm goes off every time...
- Why my room mate hates me....
- My fastest repair yet - AM radio fixed in 15 sec.
