- passenger window problem on '89 200tqa
- 1984 Audi WU motor parts available...
- How rough is it to change out the EVAP core in a 200?
- MC engine: Knock sensor Q's
- Can't pull ECU codes. Anyone have this problem?
- Parts for sale
- Lowering, Camber Plates, etc...
- '90 V8 Quatto: Sell or Store?
- Calling Berserker
- I'm running out of idea here.
- Headliner
- Starting problems.
- White Lithium Grease Door Locks
- odd cluster lighting issue
- Mmmm, Double Vision's dual '91 200 tqa 20vt's were the avant hotness @ Burien
- 15" 4x108 factory BBS mesh wheels?
- Could someone here tell me, where the best place to
- Strange A/C occurence....
- washer resevoir upgrade
- Speedometer & Trip Computer
- K24 Thrust Bearing
- Paging Will or anyone with Climate Control knowledge.....
- CGTBrad - '86 Tresser on eBay, "but it now" = $14,500
- NITROUS!!!
- Bummed: Did all this work on my 5k to find out... (long)
- Possibly parting out a '90 V8...any requests?
- ? for someone thats A/C Knowledgable
- type 43 Bentley on eBay
- temp gage
- proper method of crankcase recirculation delete?
- Denso compressor conversion to R-134A..........
- Any V8 Bentley (paper) FS?
- Burien rocked. Met Ned Ritchie, met the team of "Double Vision", got my 2nd set of 5k Bentley's,
- 200 turbo cheap
- V8Q Runnin Hot...Problem Solved w / 2 Discoveries... :-D
- did you guys ever get such a fuel efficiency? :))
- How to identify a WE haed?
- Free Techron at Autozone
- The weather in Michigan has been nice
- Is this normal???
- Euros for 5k
- 5000 fuel pump relay
- Still having some overheating problems
- Quick ECU question?
- Is there a reason my thread was deleted?
- Fluids, Fluids and more Fluids
- Who's man enough for this?
- alrighty then...blower motor it is...
- I thought nobody steals...(rant)
- Installing new starter on 100
- And who will be representing Type 44s at Waterfest? ;-) (Myself included)
- audi 5000 won't start
- Ever replace the selector rod for the manual trans shifter?
- What kind of misc. items do you guys snag from turbo cars at the junkyards?
- Hayden Oil Cooler Kit as replacement for Audi
- anyone got an ecu for sale 1991 200 20V TQ
- Anyone use Plastigauge before ??
- OK "car nuts", who else has switched to Folger's Coffee
- check engine light mystery
- 2 weeks... until Streets of Willow. Registration deadline is July 1st, space still available
- 87 Audi5000cs avant FS
- 5000TQ Wagon - Alternator No Good?
- if I borrow the battery out of my 200/bose will it need a security code to get the stereo working?
- In pic # 136-10 of ETKA there's a rear facing seat in the type 44's, has anyone
- Oil Pressure Light Epic Part 2!
- Gauges not functioning
- 18s on 10v
- My Type 44's past and present.
- ISV control unit question/problem
- anyone looking for a rebuilt 20v turbo in a good parts car?
- seat swap
- Anyone have a good avant cargo cover for sale?
- Does anyone have a good driver side front axle for a 91 200 20v?
- is the audi inline 5 cyl a interference motor?
- Parting out an 1989 200 turbo
- throttle body differences
- "Kai Desler" - did you find your vacuum leaks & loopy idle?
- Best place to buy 034 133 357 P? (intake boot)
- '90 10v 200TQ cooling fan issues (cont'd)....
- gamma radio
- Changing Wheel Size
- For Sale!
- fuel pressure
- considering being completely done with my audi... Might part it out but seeing what kind of interest
- Check eng light inop but bulb is OK. Ideas?
- Ronal 17-18", R38--SALE
- Who here has retrofitted a 7a cooling fan onto a t44?
- Adam's been lurking
- anyone have an a/c condenser they want to sell or give me :)
- Oil Pressure Light went off!
- 20V Avant For sale in the Marketplace.
- A little help please, from any one in the Northwest,Vanc, or Seattle
- Audi Stars and Cars Night
- Is is okay to put Castrol 10w30 in a Audi 100?
- replace timing belt
- 6/26/05 - Krispy Kreme GTG in Newington, CT
- Do all V8 Q have auto or was stick avail? I see Quattrotrac has a 5spd. V8.....
- 5th Annual Audi Expo - Schedule:
- Is the starter from '89 100 interchangeable with 5000?
- What was the K26 035145703M used for ? What's the difference between this K26 and RS2 K26 ?
- What a way to start a monday :( (sorry, pictures load slow, but load!)
- i want to write a mac 14 upgrade
- Water squirters iminent...
- V8 Over Heating
- Viscous Fan Bearing on V8...where does it go and what does it do?
- Location of power door lock pump on an avant?
- Anybody know the procedure for the R&R of a starter on a 5ktq?
- Nippon Denso A/C compressor used on Audis...........used else where.......
- Question about Airflow
- 'Up' n 'Runnin' again...
- about to install my chip...
- NEED A V8 ENGINE
- Any idea on # of avants vs sedans?
- Bomb questions - cost of replacement? instruction on how to swap 1? other models that will work?
- Is there a HVAC manual to show the "secret" functions?
- changing rear struts on (solid axle) 5k...
- Difference between CS & CD 5000's?
- coolant
- Update on HID for V8.
- hrm.. audi is acting pretty strangely
- new ride - '86 Titan Red 5ktqa
- is there ever such thing as having too many cars?
- front wheel bearing...
- '90 10v 200TQ cooling fan / fuel pump?
- MC flywheel install question
- Not all oil coolers are created equal.
- Warning - You'll be seeing a lot more of me very soon ; - )
- Leather seats
- Do you need stiffer WG spring if using boost controller?
- really nice driver on ebay - garanteed???
- Gettin rid of some things
- So someone ran into my new to me '88 5000TQ...
- Pictures and questions....
- Don't forget to register: 2-day ACNA driving school @ Streets of Willow - July 8 & 9th
- What is the correct knock sensor bolt torque?
- Warm/hot outside temp start problem...
- X Post: Can anyone help with a Diff Lock issue on my UrQ?
- V8 power steering question....
- started my bpv install tonight...
- 9 days 'til Audi Expo! - Have we heard from you ?
- I can't seem to shut up today...
- How much drivetrain/suspension is similar between 5k and V8 models?
- Compressor maps and calcs...
- Parts Audi 5000S I do not know the year.
- if anyone is interested in chip and spring upgrade.. 5kcstq
- FYI, the c-class mercedes xenon ballasts with lights will plug right into the audi v8
- Working Car Phone
- Observation question about AC
- Any other exhaust manifolds fit an NF motor?
- Picked this up from GT Style's thread
- Any thoughts on Meyle rear tie rods? Are these aftermarket?
- cooling system
- Sad to see an avant in such sad condition, but it does seem to have a factory cel phone
- Hey Soffolk... is that your web site?
- wierd ebay auction vehicle..
- Looking for a free/donor MC block in new england for my never-ending audi saga. someone help me out!
- Any other type 44 FAQ's?
- Toxcheap - why'd these posts get deleted?
- HP #'s in an '86 5ktq - 158 or 162?
- anyone got a MM hose?
- Radiator fan replacement
- installed new rear tie rods and brake lines
- Fixed my ignition lock/switch (long)
- Crank turning question for MC1 motor
- wheel plus sizing poll - plus 1 or plus 2 on a stock MC1
- what would you guys pay for a two-piece exhaust manifold?
- gt-style. no photoshop rs4's on 200 20v avant
- Transmission is in! (but need help- clutch bleeding questions)
- Ohhh Boxerfan....
- Just threw code 2113 - Hall sensor. <insert explicative here> Any BTDT's?
- I was wondering who would buy this for me??
- Off the wall Question
- Where can I find an AC compressor.....
- Anybody use CERIUM OXIDE to restore their windows ??
- Good times under the shady tree!
- Is there an online manul for the 5k similar to the 100/200 Service Training manual?
- OK, some new news..update...
- Frustration setting in...long perhaps...it all relative
- Need to plug a nice road trip......
- next to the intake manifold, there's a pipe coming up that's
- Front end help
- Can someone p-chop the "S4 - 114" & "RS4 - 131" onto an avant please
- Had some fun with an older S8 on the 404 yesterday...
- Now I think I am concerned...
- May have a bent up front strut housing.....
- Amended post from below...HEEEEEEEEEElpppppp
- 20V Avant still stumbling, and horrible gas mileage......
- Hey Deisel 5K owners - brew your own Bio-Deisel...
- overheated audi 100
- water pump
- My V8 for sale. Scam??????
- No start issue found...
- Electrical Connection Help Urgently needed...10:30 AM Sunday
- Power steering hose again....
- 5KTQ dies, cranks but doesn't start, blows fuse #13.
- 5 speed swap
- ok, more questions! Are there inherent
- Can you Help???? 90 100 "44"
- Ignition Switch went bad :)
- ATTN: V8 guys. Exhaust options
- FrankenAudi Still won't start. Help?
- Still looking for a 1978-'83 5K
- Hey, Seattle/Tacoma owners would you to be in a AW Texas Hold'em tourny?
- anyone around denver have a VAG-COM?
- Thinking about making an offer on a like new '85 Treser 5000 - but how much!?
- FrankenAudi ran beautifully yesterday...
- Anybody in the Boston area
- just saw this / Audi 200 Turbo 4 sale
- Thinking of Buying another AUDI
- My wipers on my 87' 5k turbo stay on low if put the wipers on intermentent. Turn them off and they..
- Set of 200 Euro headlamps for sale !!
- Well now I've done it :)
- Sedan v. Avant
- What exactly this thing is (picture)?
- I need help!! Light accel falls on face..
- Would a '92+ 100/A6 strut housing bolt on to a V8 (UrS4 strut)?
- looking for....
- Head Gasket?
- 91 200 tq got to go...
- Vag-Com
- Franken-Heater-Core!!!!!! ARRRRRRRghhhhhhh <venting>
- Can anyone here confirm....
- Whats the PN of the Mac14 ecu?
- who wanted 20v fenders?
- RS2 Turbos Back in the US... (Limited Supply)
- Undercoating. POR 15 or generic spray bomb?
- OK this may sound so obvious but I'm sorta stumped at the moment..
- This Audi got owned...
- Steering/Suspension Problem, Still unresolved......
- ps leak out top of the cap.. any ideas?
- who was looking for black interior? steve?
- Brake Bomb R&R?
- Howdy, anyone have pics of the following
- FrankenAusi is "Back in Black"!!
- Measuring fuel volumes
- It's official summer is here! How do I know?
- '87 5kcdtqa....update & possibly FS
- Is it possible to just replace #1 exhaust gasket with the rest tight?
- HELP! Anyone near Allentown/Trexlertown/Bethlehem PA?
- 200 rad. replacement help..did search conflicting views...
- towing with my 200tq
- Fourtitude article on Koln type44 meet...
- 91 200tq 20vt killer project...
- DIY Portwork...
- Calling turbo experts - what's wrong with this?
- As the Divorce Noose Tightens........
- somebody buy these seats!!!! not mine, just good price
- Needed: Air temperature sensor....
